Staro 24.05.2006., 00:40   #31
MOrdecai83
Keeper of the Nine Keys
MOrdecai83's Avatar
Postovi: 193
Autor Last7emplier
topla prepotruka da si s nekim izmjenite iskustva meni ovo djeluju ko najbolji herosi do sad, ima nekih negovfršenih sitnica ali to je zanemarivo
btw pokrenula sam ih na celeron800@900 , 256sdr , R9550 (128MB)
i ide , istina da trza i da je sve na min. postavkama i da se ucitava 10 min ALI IDE!!
OFFTOPIC!!! :: sweating
jos jedna cura na forumu! ovo je za pohvalu! :clap:
L-L-L-Look at you, Hacker. A pa-pa-pathetic creature of meat and bone, panting and sweating as you r-r-r-run through my corridors-s-s. H-h-how can you challenge a perfect, immortal machine? - SHODAN
CPU : AMD 64 X2 4600+ / 2400Mhz (Sckt AM2)
CPU COOLER : Stock
MOBO : Gigabyte GA-M59 SLI-S5 (BIOS - F8)
RAM : 2x1GB SuperTalent CL4 (4-4-3-8) PC6400 DDR2-800MHz
GPU : XFX 8800GT 512MB "Alpha Dog Edition" @ 710/1720/1030
POWER SUPPLY : Thermaltake Toughpower 600W PSU
CASE : Thermaltake Armor Jr
HDD : 2 x Seagate 320GB HDD SATA2
DVD-RW : Pioneer DVD-RW R-110
MONITOR : BenQ G2400W 24" 5ms LCD 1920x1200
MOrdecai83 je offline   Reply With Quote
Staro 24.05.2006., 13:00   #32
Last7emplier
Last7emplier's Avatar
Lokacija: Usa
Postovi: 38
: hitthewa
zanemarite ono (a) viška
neznam jeli ko od vas zavrtio Etherlordse , meni jako vuče na njih samo je puno bolje
Beautiful Girls in your town
Last7emplier je offline   Reply With Quote
Staro 24.05.2006., 15:58   #33
pepe
Lokacija: split
Postovi: 47
evo instalira san igru jucer i super mi je
samo mi pocne trzat ka luda kad smanjim kut gledanja (cca 30 stupnjeva od heroja, tako da vidin gotovo drugi kraj mape) a dok kod vecih kuteva ide normalno i ovo ne ovisi o grafickim postavkama, ista stvar i na very high i low...
bice jer iman malo memorije...
MOB: Gigabyte GA-8S655FX(-L)
CPU: P4 Northwood 2,8@3,2
VGA: LeadTek 6800LE 16/6
MEM: Dual 3200 DDR(Kingmax 256mb + Vdata 256mb)
HDD: 80gb SG Barracuda + 20gb Maxtor
OP: DVD RW LG GSA-4163B + DVD Samsung TS-H352A
PSU: Fortron 350W, 12cm vent
pepe je offline   Reply With Quote
Staro 24.05.2006., 16:53   #34
MOrdecai83
MOrdecai83's Avatar
Postovi: 193
Autor Last7emplier
: hitthewa
: axeman :: giljotin
CPU COOLER : Stock
Staro 24.05.2006., 19:21   #35
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,472
jel neko skužio kako razdvojiti jedinice (1x100 na recimo 2x50). ja nikako ne uspijevam....
inače dojmovi, sada sam na 4 misiji, igrica je ok, malo dok još sučelje pohvatam...
e da, ne znam kako vama, ali meni ždere ~460Mb RAM-a
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Staro 24.05.2006., 21:16   #36
Facelessone
Facelessone's Avatar
Postovi: 4,205
Autor Renesis
drži shift dok razdvajas
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 25.05.2006., 00:18   #37
mrtvi
mrtvi's Avatar
Postovi: 183
neznam jeli ko od vas zavrtio Etherlordse , meni jako vuče na njih samo je puno bolje[/quote]
Zato jer ih je radio Nival
mrtvi je offline   Reply With Quote
Staro 25.05.2006., 01:19   #38
Panzer
Panzer's Avatar
Lokacija: Sv. Nedjelja
Postovi: 1,814
Autor Last7emplier
Moram si je i ja nabavit...
Jel jako trza? Ja imam slican komp, celeron900@1200, 320MB, FX5700...
UPGRADED...
MBO: Gigabyte M59SLI-S4 cooled by HR-05 SLI & Zalman ZM-NBF47
CPU: AMD Athlon64 X2 3600+ cooled by Scythe Infinity @ 2.7GHz / 1.25V
RAM:2x 1GB Kingmax DDR2 800
VGA: Sapphire HD3850, 256MB Accelero S1 & 120mm AC @750/1900MHz
HDD:Western Digital 160GB (S-ATA, 8MB)
HDD 2: Western Digital 640GB AAKS
CD/DVD : DVD RW Pioneer DVR-112D Silver (Color match with case)
Powered by OCZ GameXtream 600W
Everything in Chieftec LCX-04SL-SL-A (HDD cooling – 3x92mm Sharkoon, ispuh 1x120mm CoolerMaster)
Coolers controled by Zalman ZM-MFC1
Visual expirience by Samsung 940BW
Notebook: Fujitsu Siemens Amilo Pro V3205 (12", CoreDuo 1.6, 1536MB RAM, 80GB) & Ubuntu 8.04
Audio sistem: Monitor Audio Silver RS1, Monitor Audio PureFlow Speaker Cable, Marantz PM310 pojacalo, Pioneer PD-S501 player, van den Hul M.C. THE BAY C5 Hybrid interkonekt.
Panzer je offline   Reply With Quote
Staro 25.05.2006., 14:26   #39
pepe
Lokacija: split
Postovi: 47
Panzer potpis ti je legendaran, definitivno imas najjaci potpis na forumu, preprejak ti je...
Staro 25.05.2006., 23:43   #40
Paske
Ekspert iz sjene ...
Paske's Avatar
Lokacija: New Eden
Postovi: 3,801
Autor Facelessone
Ne radi care - barem ne meni : hitthewa
Staro 26.05.2006., 00:11   #41
Marzd
Marzd's Avatar
Datum registracije: May 2005
Postovi: 28
Klikni na jedinice koje razdvajaš, drži shift, mišom prebaci na praznu kućicu i pazi da ti ljevi vrh kvadrata od jedinca bude u sredini druge prazne kućice u koju prebacuješ i onda ponovo kliknaš mišom (Ljevi klik)
Marzd je offline   Reply With Quote
Staro 26.05.2006., 00:22   #42
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,472
meni radi. drži shift, i onda klikni na jedinicu
Staro 26.05.2006., 10:08   #43
CatKiller
al se nekad dobro jelo...
CatKiller's Avatar
Postovi: 3,312
Probao sam heroje V i nisu mi se dopali
Izgleda mi kao prebrikani Warcraft3 , nema do trice...
Staro 26.05.2006., 12:37   #44
Exa
Datum registracije: Apr 2003
Postovi: 59
Autor Paske
Ima malih problema oko toga, ako imas 600 jedinica na jednoj strani a 400 na drugoj kad prebacujes sa shiftom ove vece na manju moras klikati do besvjesti da ispadne 500-500, ali ako prebacis sve na jednu hrpu pa ih onda ides odvajati s Shiftom onda ih splita ispravno tocno na pola.
Exa je offline   Reply With Quote
Staro 26.05.2006., 12:50   #45
Exa
Postovi: 59
Grafika super, malo zahtjevna, ponekad trza na vecim mapama pogotovo pod kutem gdje vidis najvise ispred sebe, Puzzle Map u plavoj boji, vrlo nepregledno i tesko za naci, Heroic tezina (monsteri pljuga za proci, heroji damn too hard, prevelika razlika pogotovo kad imaju 10 puta jacu vojsku od vas u bilo koje vrijeme), neki gradovi su prilicno nepregledni, pogotovo Inferno, koristim iskljucivo skracenice s desne i lijeve strane , muzika odlicnaaaaaa, pogotovo grad od Flower-Sniffer-a i kad se ucitava mapa.
Promijenjeno napredovanje kod level up-a, malo mi se to vise svidjalo u HOMM IV (jedino sto je valjalo kod nje).
Malo kaoticno upravljanje mapom (pazite na trapez), sve je u 3d-u i izgleda fantasticno, borba u 3D-u i male su jedinice pa ne znam koja je koja :P, hmmm nasao bi sad sigurno jos nesto, ali ne pada mi na pamet, sve skupa kad se zbroji i oduzme ipak mi je bolja III-jka, igrivost na prvom mjestu, a fancy efekti i nisu toliko bitni.
Eh da heroj sad moze nositi puno manje artefakata nego u trojci i cetvorci, i jos nisam nasao da se artefakti mogu spajati (kao u III-jci Shadow of the Death).
Pozdrav!
Staro 26.05.2006., 12:58   #46
grizli
Postovi: 141
Cekaj malo ja sam igrao 2,3,4 kakva je razlika jer me bas zanima kaj su noco mogli dodati. Sada kad zaigram 2 treba mi malo vremena da se naviknem jer u 2 i 3 katapulti razbijaju dok ih u 4 nema uopce a onaj elven hero moze sam preci cijelu mapu bez i jedne jedinice u timu kad ga nabrijes. Lik si pozove zmajeve i elemente i oni samo deru tak da je to bilo malo glupo
A64 3000+@2,5Ghz // Epox 9NPA+ // 512 MB Geil // XFX 6600 // Bara 120gb + WD 40gb // Chieftek 360W
grizli je offline   Reply With Quote
Staro 08.06.2006., 01:46   #47
gunnar
gunnar's Avatar
Lokacija: Dungeon
Postovi: 6
Smile
pozdrav svima, prvi put sam ovdje na forumu: hello2 :
htjela bih reci da sam probala heroje 5 i moram priznati da su jako dobri. grafika je izvrsna, ali heroes 3 su mi ipak bolji, barem za sad, jer sam tek pocela igrati... mozda je to samo nostalgija, ali subjektivno mislim tako...
tek sam na drugoj misiji kampanje (inferno), nisam jos vidla kako je u dungeonu, mom omiljenom gradu iz trojke
i da, nedostaje mi moj gunnar s kojim sam podijelila mnoge neprospavane noci dok smo razmisljali kako pobijediti kad igras na impossible? uostalom, zar ima ikakvog uzitka u igri, osim ako ne igras na impossible i postignes svoj najbolji rank (u prijevodu archangel; score 498): goood :
gunnar je offline   Reply With Quote
Staro 08.06.2006., 14:42   #48
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,472
oho, još jedna cura... welcome...
ja sam isto sada na inferno, 3 misija. malo to stagnira zbog cod2... mi uskoro u susjedstvu radimo ligu, svi mi se nešto prijete, vidjet ćemo kako će to ispast...
inače moj apsolutni best iz trojke je hero koji ima speciality sharp shotters, i onda 4*80 sharpshootera... rastura....
Staro 11.06.2006., 00:52   #49
mrtvi
mrtvi's Avatar
Postovi: 183
meni su preslabe obrambene zidine, te je sučelje neupravljivo,sporo i nepregledno
inače je sve bolje od 3 i 4
Staro 11.06.2006., 03:40   #50
gandza
I am Zeko!
gandza's Avatar
Postovi: 12
ma dajte molim vas... nisam ni znal da je petica uopce bila u planu, ne kad su onak zeznuli cetvorku...
nego samo me zanima dal se moze mjerit s tricom (pitanje vrijedi za one koji su tricu igrali dok je to bilo hit, jer oni koji su to nedavno probali im se ziher nije svidjelo)...?
gandza je offline   Reply With Quote
Staro 11.06.2006., 04:10   #51
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,472
mjerit? u nekim stvarima je bolja, uzela je uglavnom dobro iz 3 i 4...
e sada, kao šta mrtvi kaže, sučelje je malo sporo...
Staro 11.06.2006., 05:08   #52
Marzd
Marzd's Avatar
Postovi: 28
nakon 7 dana igranja petice mogu reći da mi je sve bolja i bolja, samo treba pohvatati sve stvari, igram zasada kampanje i prića je jako dobra. U svakom slućaju bolja od trojke jer je meni ipak dvojka najbolja.
Nisam skužio da li se heroj brže kreće (tj ima više koraka) ako ima brže jedinice kao u 2 i 3 i svi ti novi skilovi me malo zbunjuju kao i neke glupe magije koje neznam ni koristiti.
Staro 11.06.2006., 10:37   #53
vex
vex's Avatar
Datum registracije: Aug 2003
Lokacija: sl. brod
Postovi: 1,325
Autor gunnar
hehe gunnar...uvijek igram s njim kad mogu dungeon dobit...najbolji je :clap: , sve dobre skilove dobije
Staro 11.06.2006., 12:44   #54
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,472
magije su dosta kompleksnije sada, da. meni se sviđa. recimo Mass effect je luda stvar... skillove sada treba malo promisliti, ali može se dobit opak hero... ja sada igram inferno kampanju, i sviđaju mi se neke stvarčice...
ono što je definitivno minus u inferno gradu, su visoki prohtjevi za zgrade, za sve treba sulfur, a i masu gemova, kristala itd...
Staro 11.06.2006., 12:56   #55
gunnar
gunnar's Avatar
Lokacija: Dungeon
Postovi: 6
Autor vex
dungeon lives forever!!!! kod gunnara logostika i taktika su 2 najbolje stvari koje mozes dobiti na pocetku dok nemas vojsku... taktika je fenomenalna na pocetku, poslije kad se razvijes i nije toliko bitna, ali na pocetku je:-) cim izgradis u dvorcu beholdere, s njih 10-tak i nesto harpija, podijelis trogloide na 2 mjesta i stavis beholdere u kut a ovima okruzis beholdere i svi padaju!
Staro 11.06.2006., 20:41   #56
grizli
Postovi: 141
Vi ste luđaci, nisam igrao 5 ali sam igro2,3,4 i sve sam proso na istu foru. Nabavis masu ekipe na daljinu(strijelce, bili su dobri iz trojke geeniji, i tak ekipa) dok lik dođe do mene svi mu popadaju (nisu losi ni titani iz 2 kad ih upgrade sa gromovima)
Staro 11.06.2006., 22:22   #57
mrtvi
mrtvi's Avatar
Postovi: 183
Autor grizli
točno tako nisi igrao 5
Staro 11.06.2006., 23:56   #58
Mar
Suit up!
Mar's Avatar
Postovi: 5,975
U petici su sve jedinice dosta brze, tako da ima otprilike 20% jedinica koje mogu prijeci cijelu mapu iz 1 turna, 75% iz 2 i 5% iz 3.
Takodjer - strijelci su ranjivi na napade drugih strijelaca, vise ne funkcionira da stavis melee jedinicu isprijed strijelaca i da ih drugi nemogu gadjati.
- Barney Stinson
Staro 12.06.2006., 20:30   #59
Sand
Lokacija: ZG Travno
Postovi: 333
Još nisam igrao peticu, ali jedva čekam jer sam ju vidio koliko je ušminkana. Igrao sam sve HoMM, i samo ću reći da kako god igra izgledala, ako ima naslov Heroes of Migt and Magic, ja ju moram odigrati. Trojka je istina i meni bila najbolja, ali to ne znači da i peticu neću s velikim divljenjem odigrati do kraja.
Potpuno se slažem sa Gunnar u vezi težine. Impossible je ipak najveći gušt odigrat.
Sand je offline   Reply With Quote
Staro 13.06.2006., 11:35   #60
gunnar
gunnar's Avatar
Lokacija: Dungeon
Postovi: 6
bravo sand: roller :
što se trice tiče, meni nema smisla uopće igrati ako ne igram na impossible!!!
