Staro 13.07.2022., 22:58   #5521
JuiceBox
Xulos :)
JuiceBox's Avatar
Postovi: 7,579
Staro 13.07.2022., 23:13   #5522
Postovi: 8,504
Da, opet što viši takt uz što veću potrošnju, a konkretnog pomaka u arhitekturi zapravo i nema. Nešto veći L2 + L3 cache uz duplo više manjih šparnih jezgri i to je to.
Staro 14.07.2022., 23:08   #5523
Taproot7
mag.math.
Taproot7's Avatar
Datum registracije: Dec 2021
Lokacija: Daruvar/Zagreb, Republika Hrvatska
Postovi: 366
idealan procesor za vrijeme koje je pred nama sa nikad manjim cijenama energije. i9 13900K i rtx 4090 u paru će pretvarati sva zlatna i platinasta top end napajanja do 1000w u otpad.
Taproot7 je offline   Reply With Quote
Staro 17.07.2022., 20:29   #5524
Postovi: 8,504
Sve u svemu super.
"Intel Core i9-13900K Raptor Lake CPU gaming & synthetic performance benchmarks leaked, 5% faster than Core i9-12900K on average. The 13900K offers just the kind of performance gains you’d expect from a refresh. On average, it’s 3% to 7% faster than the Core i9-12900K gaming depending on the resolution. 1440p or QHD sees the most improvement in averages, gaining 7% over the Alder Lake flagship. At 1080p, it’s faster by 4.46% with 4K seeing a paltry 3% increase. The Intel Core i9-13900K consumes up to 52% higher in games than the Core i9-12900K and an average of 20% higher power consumption. This means that the next-gen Raptor Lake CPU lineup is going to be more power-hungry than Alder Lake, even in games."
Izvor: Lolek i Bolek
Staro 17.07.2022., 23:05   #5525
spawn
spawn's Avatar
Postovi: 8,474
Pa dobro nije to nista novo. Intel to radi vec 20 godina. Jedna generacija veliki upgrade, sljedeća mali, pa opet veliki itd.
Staro 17.07.2022., 23:34   #5526
Postovi: 8,504
Da, ali u proteklih 20 godina su samo Conroe, Sandy Bridge i sada Alder Lake bili uistinu nove arhitekture, mada smo od 2006. do 2017. zapravo imali tick-tock stagnaciju i varijaciju na temu.
Nadolazeći Meteor Lake će biti prvi pravi Intel chiplet/tiles dizajn, ali i s tim će opet imati 8P-core + xxE-core kombinaciju, ali budemo vidjeli kak bude sve skupa na kraju ispalo.
Kaj se Raptor Lakea tiče, tu je nažalost sve jasno, mada lako za desktop, problem je kaj hibridni big.LITTLE pristup nije idealan ni za mobilna rješenja.
The Intel Core i7 1280P is a 14 core / 20 thread part consisting of six performance (P) cores and eight efficient (E) cores. The Core i7 1280P had an average reported power draw via PowerCap/RAPL sysfs of 35 Watts with a peak of 107 Watts. That was much higher than the similarly performing Ryzen 7 PRO 5850U with a 22 Watt average during the same benchmarks and a peak of just 47 Watts. Ryzen 9 5900HX was the fastest 51% of the time while the Core i7 1280P was the fastest 41% of the time. For heavily threaded workloads like code compilation, CPU-based renderers, image/video encoding and the like, the Core i7 1280P had a tough time competing with even the AMD Cezanne parts tested but when it came to single-threaded performance for Python scripting, web browser workloads, and other lightly-threaded creator workloads the Alder Lake P processor did perform very well under Linux. The raw performance was great in those areas but did come with significant power costs and generally fell behind in power efficiency.
Staro 18.07.2022., 02:15   #5527
stitrek
Datum registracije: Feb 2021
Lokacija: TRPI
Postovi: 456
i3 13100 vjerovatno nece ni izlaziti isto kao sto je bio slucaj sa i3 kod 11th gen.
14th gen Meteor Lake ce biti nekakav pomak s kojim ce konkurirati naspram AM5.
Staro 22.07.2022., 22:25   #5528
Mladenxy
Mladenxy's Avatar
Postovi: 4,452
https://videocardz.com/newz/intel-core-i5-13600k-14-core-cpu-is-almost-as-fast-as-ryzen-9-5950x-in-leaked-geekbench-mulit-core-test
Staro 23.07.2022., 00:36   #5529
spawn
spawn's Avatar
Postovi: 8,474
Mene kao korisnika zanima samo bang for the buck. Profesionalce koji zarađuju s jakim procesorima/platrormama/kompletima zanima samo top sa što manje potrosnje i grijanja.Ako nije neki upgrade, preskače se, ako se isplati ,uzima se novo. Arhitektura kao takva je samo za raspravu uz kavu ,sve ostalo je manje bitno. Imho naravno
Staro 23.07.2022., 00:51   #5530
Postovi: 8,504
Obični (non-K) Raptor Lake Core i5 i Core i3 modeli koji stižu u proljeće 2023. budu vrlo vjerojatno opet ponudili najbolji omjer uloženog i dobivenog u kombinaciji s B660 DDR4 pločama. Kaj se arhitekture tiče, nažalost, vidjeli smo kak to prolazi s Bulldozerom, pa kad ne valja, ne valja uzduž i poprijeko kak god da se okrene. I onda imamo poplavu kojekakvih procurenih informacija gdje se Raptor Lake vrti na sumanutim taktovima uz još žešću potrošnju, da lakše ima "~10%" bolje performanse u usporedbi sa sada dvije godine starim Zen 3 modelima, dok je Zen 4 prava konkurencija i još k tome izlazi dobrih mjesec dana prije. Intel opet i po ko zna koji put ima istu taktiku, nasvirati sve do ibera i pustiti marketing da odradi svoje.
Staro 23.07.2022., 01:50   #5531
Taproot7
mag.math.
Taproot7's Avatar
Postovi: 366
kome je raptor lake namjenjen? oni koji imaju 12400F sto njima treba bolje od toga. oni koji imaju ryzen 5600x pa navise sto njima treba bolje od toga. ovo je proizvod za ispoljavanje mrznje glupana na internetu. prijatelj ima i3 12100 i odlican je za 90 plus posto svih danasnjih potreba a sve ovo ostalo je bacanje novaca. tko voli nek izvoli moje novce intel nece vidjeti osim ako ne bude opet kombinacija procesor+ploca za manje od 2000 kakvu koristim.
Staro 23.07.2022., 07:02   #5532
BinaryJesus
Lokacija: Sveti Petar
Postovi: 306
i3-12100f je trenutno najbolji bang for the buck tko kupuje novi komp sada. AMD je izgleda odlučio napustiti entry level jer samo prodaju poluproizvode kao R5 5500 koji su još uvijek preskupi s obzirom na to koliko su okljaštreni.
BinaryJesus je offline   Reply With Quote
Staro 23.07.2022., 11:09   #5533
robee
robee's Avatar
Lokacija: VinkovcI
Postovi: 950
i3 12100 je odlican cpu za ok lovu ali problem je sto nema jeftinih itx ploca
robee je offline   Reply With Quote
Staro 23.07.2022., 12:40   #5534
tuxbox
Postovi: 31
Da, to je isplativije nego 10100f, čak i za nas štedljivce
tuxbox je offline   Reply With Quote
Staro 23.07.2022., 14:06   #5535
Taproot7
mag.math.
Taproot7's Avatar
Postovi: 366
Autor BinaryJesus Pregled postova
amd je konkurentan samo zato jer sve procesori idu na sve ploce i one od prije 5 godina kao i sto 5900x radi na novoj ploci od 500kn jednako kao na ploci od 3000kn. intel vise nema tu praksu i ploce za 500 kuna su smece pa kad se sve zbroji amd je isplativiji ali ryzen 5500 je prevara od procesora.
Staro 23.07.2022., 14:57   #5536
Postovi: 8,504
Autor robee Pregled postova
Core i3-12100 je odličan procesor i s cijenom od kakvih 800 kn stvarno predstavlja super omjer uloženog i dobivenog, ali nažalost općenita cijena budžet B660 ploča (neovisno o formatu) poput npr. ASRock B660M-HDV je tragikomična, pa na kraju ispada da za ploču koja realno vrijedi kakvih 400 kn, zapravo treba dati duplo više i onda kombinacija Intel Core i3-12100 + ASRock B660M-HDV ispada minimalno 1.600 kn. Ryzen 5 5500 je s cijenom od kojih 1.000 kn istinabog nepotrebno skuplji od Core i3-12100 modela, ali istovremeno paše na ploču tipa MSI B450 Tomahawk Max II koja se nađe nova za ~650 kn, pa na kraju Intel i AMD opcije koštaju iste nofce, s tim da AM4 platforma podržava sve živo i neživo unatrag posljednjih 5 godina. Nažalost, Intel i s nadolazećim Mateor Lake modelima opet ide na skroz novi LGA-1851 socket uz tak jasno pripadajuće čipsete i isključivo DDR5 podršku i koliko god je super da Alder Lake i Raptor Lake podržavaju DDR4, Intel se pobrinul da njihova platforma ne poživi pretjerano dugo.
Staro 23.07.2022., 15:31   #5537
Mladenxy
Mladenxy's Avatar
Postovi: 4,452
Da, samo kaj je AMD to omogućio jučer, dok su mnogi u međuvremenu na žalost, zamijenili svoje B350 ploče sa B450 i B550 jer nisu dobili informaciju od AMD-a na vrijeme.
GIGABYTE B660M DS3H je 900 kn, realno 300 kn pre skupa ali opet za kombo sa i3 12100F ili i5 12400F vrlo dobar izbor i isplativ kombo.
Problem je kaj je Intel najavio povećanje cijena za 20%...nije im dosta osam milijardi dolara zarade u zadnjem kvartalu, pohlepna gamad.
Staro 23.07.2022., 15:49   #5538
Postovi: 8,504
Da i ja sam jedan od tih je koji je nakon skoro četiri godine zamijenil B350 ploču s tada novom B450 i sad na obje paše sve od prvih Zen do aktualnih Zen 3 modela. AMD je zajedno s MBO OEM društvom koji ionako imaju najviše koristi od toga, lako mogel, baš kao i Intel svake godine staviti novi čipset i novi socket ili pak umjetno napraviti segmentaciju postojećih i ništa ne bi bilo kompatibilno, tak da je na kraju još i dobro ispalo, koliko god se pederski činilo, opet je to daleko od ovoga kaj Intel radi zadnjih 15 godina i po svemu sudeći, nemaju namjeru prestati s konstantnim izmjenama i uvijek novim platformama, socketima i čipsetima. Kaj se pak rekordnih zarada i podizanja cijena tiče, obzirom na ciganjenje ekipe (Pat Gelsinger, Raja Koduri i Ryan Shrout) koja je zadužena za nove proizvode, ništa me više ne čudi, jer to je sve čisti marketing koji se svim silama trudi prezentirati kao da su tehnički potkovani stručnjaci.
AMD, nVidia shut out as Intel eyes $52 Billion CHIPS Act windfall
Intel is expanding its lobbying spend as it tries to convince the US government to pass the CHIPS Act, which would open $52 billion in funding to boost chip production in the US. The chipmaking giant spent $1.75 million on federal lobbying during Q2 of 2022, which represents a notable percentage increase compared with the same period last year when it spent approximately $1 million. The previous highest sum spent by Intel was apparently $1.43 million, and that was during opening three months of this year.
Izvor: The Register i Tom's Hardware
Staro 24.07.2022., 00:55   #5539
Taproot7
mag.math.
Taproot7's Avatar
Postovi: 366
na vrijeme kazes a 18 mjeseci su cekali da ljudima to kazu od jasnog ne do jasnog i sretnog da. onaj glupi robert iz amda je to predstavio kao dar s nebesa. pretpostavljam da se nas dvoje necemo skoro upgradeati sa comet lake procesora jer ne mislimo sponzorirati pohlebnu dubrad. socket 1700 ploce su precjenjene bas za tih 20 posto za koliko ce poskupiti i procesori.
Staro 24.07.2022., 09:06   #5540
robee
robee's Avatar
Lokacija: VinkovcI
Postovi: 950
Znaci nema srece ni u jednom taboru
Kupis taj i3 12100 za 850kn i treba ti jos 2000kn za itx Gigabyte mbo koja je jedina donekle ok a vec se prica o 2-3 gen. koje dolaze i novi socketi s njima. Prije nekoliko godina si mogao bez problema kupiti itx za 700-900kn.
Staro 24.07.2022., 09:49   #5541
Mladenxy
Mladenxy's Avatar
Postovi: 4,452
Gigabyte H610M S2H DDR4 ti je prevelika?
https://www.protis.hr/products/detai...m_medium=click
730 kn, realno 300 kn pre skupa ali za i3 12100F/i5 12400F sasvim OK
Staro 24.07.2022., 11:49   #5542
robee
robee's Avatar
Lokacija: VinkovcI
Postovi: 950
Da, imam itx kuciste.
Staro 24.07.2022., 12:38   #5543
Taproot7
mag.math.
Taproot7's Avatar
Postovi: 366
neces naci postenu itx plocu za normalne novce jer su svi poludjeli sa cijenama tog formata
Staro 24.07.2022., 15:45   #5544
robee
robee's Avatar
Lokacija: VinkovcI
Postovi: 950
Znam, odustajem od kupnje
Stari comp ce jos neko vrijeme posluziti.
Staro 24.07.2022., 21:14   #5545
Postovi: 8,504
Intel Raptor Lake CPUs possibly launching October 17 with the same architecture as Alder Lake
Intel will unveil its next-generation CPUs at its Innovation event in September, before an October 17 launch. Earlier rumors pegged the date inside October. That initial launch includes the i9-13900K, i7-13700K, and i5-13600K, along with Z790 chipset motherboards. Intel will reveal the non-K Raptor Lakes at CES 2023 on January 5 before releasing them along with the H760 and B760 chipsets in the second half of January. Although we knew that Intel's 13th Gen Raptor Lake CPUs will utilize the 10nm ESF 'Intel 7' based Raptor Cove and Gracemont cores which had few changes compared to the versions used in the 12th Gen Alder Lake CPUs, the Intel documentation itself confirms that on a microarchitectural level, both core designs, Raptor Cove and Golden Cove, are the same. What has changed though are the clock speeds, cache sizes & core configurations, all three of which are resulting in the performance uplift versus the 12th Generation Alder Lake CPUs.
Intel could be bringing its 56-core and 350W TDP CPUs to workstations
Intel first announced the Sapphire Rapids line of Xeon processors in late 2019 and has released information about them at a trickle ever since. With up to 56 cores and in-package memory, they'll be Intel's most powerful and enormous processors to date. Intel has been steadily updating the relevant enterprise software in preparation for Sapphire Rapids for over a year. Some of that software is open source and the source of small leaks. Last week, a trawler found a reference to an unknown processor in the boot log of a Linux kernel, the Intel W9-3495. First, the name: Intel uses "W" for its workstation CPUs, for example, the W-3375. It hasn't put numbers after the "W" yet, so that could mean a few things, but it looks a lot like the nomenclature used by the Core series -- i5, i7, i9. It might imply the existence of similar W7 or W5 CPUs with lower core counts.
Second, the specs. The boot log says that the W9-3495 has 56 cores / 112 threads and a base clock of 1.8 GHz (that likely isn't final). It lists AMX and AVX-512 instructions as features of the CPU. However, it doesn't say whether or not the W9-3495 has the 64 GB of in-package HBM2e memory that Sapphire Rapids has garnered infamy for, and I'd wager that it won't. It's prohibitively expensive, and also something that Intel would reserve for its flagship data center processors as a selling point. Intel's workstation CPUs do usually have most of the features of their server-side counterparts, though. If the W9-3495 is no exception, then it will have eight lanes of DDR5 and a mix of PCIe 5.0 and PCIe 4.0 lanes summing to 80. It will definitely use the Willow Cove architecture and Intel 7 node (a rebrand of the 10nm Enhanced SuperFin Mouthful node) and the new LGA4677-X socket. It will also be a mile above Intel's current offerings.
Today's workstation flagship is the W-3375, which has only 38 cores / 76 threads and uses the Ice Lake architecture from late 2019 and the first-gen 10nm node. It's also stuck with DDR4 and PCIe 4.0. It costs a whopping $4,499 - ouch - and is only really available through OEMs, a fate that hopefully the W9-3495 can avoid.
Izvor: TechSpot
Staro 24.07.2022., 23:12   #5546
Taproot7
mag.math.
Taproot7's Avatar
Postovi: 366
znaci refresh ali se drukcije zove. super
Staro 24.07.2022., 23:41   #5547
Postovi: 8,504
Točno to, a i "nove" ploče iz 700 serije budu zapravo prepakirane iz postojeće 600 serije, pa se opet i po ko zna koji put ide na što više taktove, potrošnju i zagrijavanje.
Morali budemo pričekati službene recenzije da sve sjedne na svoje mjesto, ali po svemu sudeći, Raptor Lake je samo varijacija na poznatu temu.
Staro 25.07.2022., 20:24   #5548
Taproot7
mag.math.
Taproot7's Avatar
Postovi: 366
znaci da ce skupe 600 ploce postati jos skuplje 700 ploce jer ove nisu dovoljno skupe a precjenjene su u startu 300 kn. zasto onda nisu raptor nazvali alder lake-s kako su isli sa coffee lake ako je sve isto a samo nabrijani taktovi grijanje i potrosnja.
Staro 28.07.2022., 19:14   #5549
Postovi: 8,504
Intel Core i7-13700K and Core i5-13600K tested, higher performance with higher power consumption
The primary upgrade over Alder Lake parts is increased core count of Efficient cores from 4 to 8 for each part. Furthermore, Raptor Lake models have higher boost clocks, by up to 400 MHz for the i7 SKU (max boost 5.4 GHz) and 300 MHz for i5 (max boost (5.2 GHz). Additionally, both parts have increased (doubled) L2 cache over Alder Lake SKUs, and they support faster DDR5 memory out of the box. In test such as CPU-Z the i7 sees a 10% boost in single-core test and 32-34% better score in multi-threaded. The i5-13600K, in other hand has 5% 39-41% uplift respectively. As for the power draw, the Intel Core i7-13700K consumed around 30% higher power than the Core i7-12700KF while the Core i5-13600K consumed around 20% more power than its predecessor. This additional power resulted in a lot of heat and both chips were operating over 100C with the Core i7 even hitting the 115C wall limit. The maximum package power was reported at 433W.
Staro 28.07.2022., 22:24   #5550
SlavoS
Datum registracije: May 2003
Postovi: 1,116
Ugradit vodeno i u slučaju nedtašice plina imaš protočni bojler
SS
SlavoS je offline   Reply With Quote
