Staro 12.08.2021., 09:35   #4861
gogoklepci
Datum registracije: Sep 2019
Lokacija: Mostar
Postovi: 340
Susjed mi ima i7 4770 i 580 8gb i nema nikakve potrebe za upgradom
gogoklepci je offline   Reply With Quote
Staro 12.08.2021., 12:38   #4862
Postovi: 8,310
Intel Alder Lake CPU: In a notebook with 15W to 215W power limit on the go
Intel's new CPU family Alder Lake will largely adopt the TDP conditions of the current generation in the notebook. At its peak, there are now 115 watts, but this applies to 6+8 cores and GT2 graphics unit. Tiger Lake-H45 requires 107 watts in the tip for eight cores and UHD graphics. The first two stages follow Tiger Lake-U on the foot, for example, even today a Core i-11000 in the 28-watt TDP configuration can accommodate up to 64 watts in the turbo. This will also apply to Alder Lake's 4+8+2 configuration in the future, i.e. four large cores, eight small atom cores and gt2 graphics. However, the highest level continues, for 45 watts TDP, the scope of the 6+8+2 variant is extended to up to 115 watts.
Accordingly, a PL1 of 20 instead of 15 watts is now planned for the combination 2+8+2, i.e. with two large cores, eight small cores and GT2 graphics. Nevertheless, the 15-watt option is likely to remain for even smaller variants that were listed on the roadmap shown. Intel has made further adjustments to the parameters. Accordingly, with Alder Lake for the first time PL4 could come more strongly than before. This value has been maintained for many generations, but is hardly used, as it is only a matter of fractions of a second. This value is correspondingly large compared to the regularly known power limits (PL), 215 watts would be for the flagship variants with 14 or 16 cores including GT2 graphics, while the normal PL2 value remains at 115 watts and thus ranks 6 watts above the current Tiger Lake-H45 and also Tiger Lake-H81 such as the Intel Core i9-11900KB.
Izvor: ComputerBase
Staro 12.08.2021., 21:52   #4863
picajzla0707
Datum registracije: Sep 2018
Postovi: 309
Autor Dr. Strange Pregled postova
Ti Intelovi proizvodi bazirani na TSMC-ovom 3nm procesu će imati vrlo vrlo paprenu cijenu, do te mjere da će i najveći zadrti Intel fanboysi na koljenima moliti AMD da nešto poduzme, osim ako Intel odluči smanjiti cijene na prihvatljivu razinu i poslovati s gubitkom gdje će gledati samo market share, a profit je manje bitan. Toliko novaca iskeširati da bi bio prioritetni kupac ionako vrlo skupog proizvodnog procesa će se definitivno prelijevati na kupce, nemaju puno prostora za snižavanje cijena i mi ćemo to morati platiti.
ne vidiš ono najbitnije
a to je da amd ostaje bez proizvodnih kapaciteta za iole ozbiljnije povećanje tržišta
apple je pozobao 80% 5nm, ostatak uglavnom ide nevidiji za lovelace, a sad je i intel uzeo većinu 3nm za svoje potrebe = amd ostaje na mrvicama
nažalost, jer su zapravo jedini izvor konkurentnosti i intelu i nevidiji, a da bi iole ugrozili tržišnu dominaciju intela i nevidije, trebaju im proizvodni kapaciteti, bez kojih su očito ostali za idućih par godina
picajzla0707 je offline   Reply With Quote
Staro 12.08.2021., 22:20   #4864
sti
Lokacija: Lawl
Postovi: 1,378
Tih Appleovih 80% je stara vijest (još od prošle godine) i odnosi se na modele za 2021, dakle Iphone 13 koji izlazi za mjesec dana.
Ti mrtav ozbiljan tvrdiš da je AMD ostao na mrvicama za 5nm, iako Zen 4 neće izaći još najmanje godinu dana?
Staro 12.08.2021., 22:31   #4865
picajzla0707
Postovi: 309
Autor sti Pregled postova
ne tvrdim ja, tvrde vijesti koje govore o dealovima koje tsmc sklapa s intelom, nevidijom i jabučarima
da bi se amd maknuo dalje od 20% cpu i gpu tržišta koje je trenutno dosegnuo, trebaju mu kapaciteti, koje očito otimaju veći igrači
5xxx serija se svela na (pre)skupe procesore (a preskupi su jer nemaju kapaciteta za jeftinije non x i slabije manje jezgrene modele, pa im ne preostaje drugo nego dići cijenu i zaraditi koliko se može na ovim skupljima) sve dok apple nije oslobodio nešto 7nm kapaciteta, i tek tada - s debelim kašnjenjem - kreće proizvodnja 5600g/5700g i ostalih jeftinijih modela
i to samo kad je konkurent u tsmc kapacitetima bio apple, sad zamisli što će biti kad se ubace, a ubacili su se - intel i nevidija
Staro 12.08.2021., 22:36   #4866
sti
Lokacija: Lawl
Postovi: 1,378
Koje vijesti, da nije Wccftehch? Taj indijski sweatshop živi od clickbait naslova.
Intel je NAVODNO ugrabio 4000 wafera mjesečno, s postupnim povećanjem na 10000.
Samo za usporedbu sa postojećim procesima:
2021: "TSMC will be stepping up its 5nm chip output starting June, and is poised to scale up its 5nm process output to 120,000 wafers monthly in the second half of 2021, according to industry sources."
2020: "TSMC to Ramp up Production of 7nm Wafers to 140,000 Units per Month"
Ništa se neće dogoditi sa AMD-ovim kapacitetima, ništa. Apple jede prvi, AMD sljedeći, Intel će raditi svoje servere na 3 nm i svi sretni. Pročitao si clickbait naslov i popuštio priču, jednostavno.
Staro 12.08.2021., 22:37   #4867
Postovi: 8,310
Apple već više od godinu i pol dana okreće TSMC 5nm za svoje potrebe, tak da su oni svoj dio već fino namirili, pa kapaciteti ostaju na raspolaganju drugima, a AMD više nije dno-dna po pitanju klijenta.
TSMC’s 5nm process node has been in mass production since 2020, and notably powers hundreds of millions of new SoCs powering Apple’s A14 chips in the iPhone 12 series as well as the new M1 Mac chip. Although HiSilicon was a lead customer of TSMC at 5nm, TSMC had halted all production for the company last September due to trade restrictions. TSMC today updates that it has shipped 500k N5 wafers, which would roughly represent a few hundred million chips. While this lead to Apple essentially having sort of exclusivity for the N5 node in 2020, as more companies are starting to ramp up their 5nm products TSMC will need to ramp up a lot more production capacity, which the company is heavily investing in
Kaj se AMD-ove toliko priželjkivane propasti tiče, ko zna možda se i nakon svega (1 - 2) i to napokon desi, pa možemo mirno dalje - u sljedeće desetljeće stagnacije. Intelove TSMC 3nm potrebe će za početak uključivati 4.000 wafera mjesečno, a kasnije se to penje na 10.000 wafera mjesečno za proizvdonju određenih tile-based (chiplet) rješenja, koja će onda Intel dalje interno pakirati i kombinirati u gotove proizvode. Osim toga, TSMC za razliku od Intela aktivno radi na novim proizvodnim kapacitetima, pa možda ipak AMD potraje još koju godinu i onda mogu lagano u vječna lovišta. nVidia će za sljedeću GPU generaciju koristiti TSMC 5nm + Samsung 5nm procesa, pa i tu ne bude baš tak crna priča.
Staro 12.08.2021., 22:43   #4868
picajzla0707
Postovi: 309
Kaj se AMD-ove toliko priželjkivane propasti tiče...
nitko normalan ne priželjkuje propast amd-a, to su valjda paranoje u rangu onih izmišljotina o dominaciji na tržištu, gdje se 10% udjela na tržištu servera ili 20% na desktop tržištu proglašava 'dominacijom'
ali ok, bumo vidjeli - zasad imamo samo vijesti o dealovima koje tsmc sklapa s nevidijom, intelom i jabučarima, amd je zasad nekako ostao van toga
malo čudno, obzirom na status 'najvažnijeg kupca'
Staro 12.08.2021., 22:46   #4869
Postovi: 8,310
Meni se nekak čini da si ti cijelo ovo vrijeme zapravo gnjevan i ljut, jer ti AMD nije isporučil one "obećane" obične R5 5600 modele, a još su i cijenu digli za 50$, pa ti je sad svaka prilika idealna.
Ništ, čekamo da se sve ove tvoje prognoze fino ostvare i obestine, dosta je bilo AMD-ovih pizdarija. Niti su više jeftini, niti su budžet firma kakva su nekad bili. Previše je stvarno previše.
Staro 12.08.2021., 22:46   #4870
Mladenxy
Mladenxy's Avatar
Postovi: 4,366
AMD potroši hrpu wafera na apu za konzole koji je površinom ogroman.
Staro 12.08.2021., 22:50   #4871
sti
Lokacija: Lawl
Postovi: 1,378
Ne "bumo vidjeli", ništa se nije promijenilo osim što si povjerovao u clickbait naslov indijskog sweashopa. 4000 wafera mjesečno nije nikakakv majority.
Meni se nekak čini da si ti cijelo ovo vrijeme zapravo gnjevan i ljut, jer ti AMD nije isporučil one obećane obične R5 5600 modele, a još su i cijenu digli za 50$, pa ti je svaka prilika idealna.
Ogorčenost mu iskače iz svakog posta, a sad je počeo i sa znanstveno-fantstičnim scenarijima.
Staro 12.08.2021., 22:50   #4872
Postovi: 8,310
Da, a i konzole su ih fino držale na životu svih onih godina, dok su propadali, pa tak da jasno da budu ispoštovali takve ugovore. EPYC ima prednost nad svime, a isti je chiplet dizajn, pa lako onda za gamere i njihove Ryzene.
Staro 12.08.2021., 22:53   #4873
picajzla0707
Postovi: 309
ma to si u pravu za moj bijes za 5600, a upravo u tome i jest poanta - da je amd imao proizvodnih kapaciteta, vidjeli bi mi i 5600 non x i sve ostale nižerangirane procesore, a vidjeli bi i puno veći tržišni udio, jer većinu tržišta ne čine procesori od 300+ usd
zato i govorim - pitanje je koliki su daljnji potencijali za rast, obzirom na sve ove vijesti o zakupu tsmc kapaciteta
eventualno ovo što kaže mladen, ako ne bude nekakve ps+ verzije, pa budu sve 5nm kapacitete imali slobodne za cpu i gpu, ali i to je bojim se malo za veći udio na tržištu
Staro 12.08.2021., 22:59   #4874
Postovi: 8,310
E, ali AMD je proizvel i te modele, samo za OEM ekipu. Nije da nemaju kapaciteta, nego ne žele to dati nama, kad OEM-i poput Della i HP-a plaćaju fine pare, pa je i računica čista za AMD.
Osim toga, TSMC je po pitanju Intela u nekoliko navrata napomenul da im neće raditi nikakve ustupke, a ako žele nešto, moraju se kao i svi ostali prilagoditi situaciji.
Mislim, Intel je pojel vlastito govno kak god se okrene i sama činjenica da sad ovise o istom TSMC-u kao i svi ostali, im je ionak dovoljan udarac.
Može AMD propasti, nije problem, napravili su jebeni posel u ove četiri godine. Tak da sad sve nove procesore koje imamo (Intel i AMD), imamo radi te šrot firme.
Staro 12.08.2021., 23:03   #4875
Mladenxy
Mladenxy's Avatar
Postovi: 4,366
To nitko ni ne osporava.
Staro 12.08.2021., 23:06   #4876
Postovi: 8,310
Znam, samo velim, jer ako se AMD opet sroza, a Intel deset godina svira kurcu, di smo onda - opet ista priča ko prije prve Zen generacije. Intel si je sam kriv za sve što ih je snašlo i konstantno se cigane i ne žele priznati da su zajebali.
Eto ti Alder Lake, po svemu sudeći opet budu imali isto ko s Rocket Lakeom, kaj se potrošnje i zagrijavanja tiče. Glavno da pričaju bajke o naprednim proizvodnim procesima, malim i velikim jezgrama, a sve i dalje monolitno do bola.
Staro 12.08.2021., 23:25   #4877
picajzla0707
Postovi: 309
nije da nemaju kapaciteta, nego to ne žele dati nama - jel ti sebe slušaš uopće?
Staro 12.08.2021., 23:25   #4878
Mladenxy
Mladenxy's Avatar
Postovi: 4,366
A gle, na kraju je i uspjeh da izbacuju nešto na 10nm++, jer do prije godinu dvije smo komentirali da nebu ni toga vjerojatno. Bumo vidli 2025. bude li išta ili ništa. Do tada tko želi najbolje uz najmanju potrošnju AMD. Za Intel srećom tržište je dovoljno veliko.
Staro 12.08.2021., 23:31   #4879
Postovi: 8,310
Autor picajzla0707 Pregled postova
Nemoj uvijek pametovati, jer imaš OEM običan R9 5900, R7 5800 i R5 5600, pa, ako je problem u kapacitetima, zašto ih ima dovoljno za OEM ekipu, a nema ih za krajnje korisnike?
Jebe se AMD-u za nekog tamo gamera, kad OEM društvo naručuje vagone i ne pitaju zašto je cijena 50$ viša, nego prošla generacija.
Staro 12.08.2021., 23:36   #4880
picajzla0707
Postovi: 309
da se prodaju 'na vagone' ne bi udio u prodaji ostao na 20%, a da imaju dovoljno kapaciteta bilo bi tih procesora i za non oem tržište i to odmah po izdavanju 5xxx serije, ne godinu dana kasnije
Staro 12.08.2021., 23:38   #4881
Postovi: 8,310
Dobro, vrti i dalje svoj film, tak svejedno. Jebiga, nisi dobil "obećani" R5 5600 za 1.500 kn i to je to.
Staro 12.08.2021., 23:42   #4882
picajzla0707
Postovi: 309
a jbga, ja vrtim svoj film, a ti potpuno ignoriraš činjenice
zašto je amd 'davao nama' 3600 dok su imali i 3600x u ponudi, a nije davao 5600 - zato jer sa 5xxx serijom nisu imali kapaciteta za sve - grafe, procesore i konzole, zato su išli na skupe modele da iskoriste što više mogu to što mogu
misliš da ne bi izbacili 5600 non x i ostale nižerangirane procesore u zen zen3 tehnologiji i pojeli intelu većinu tržišta da su mogli?
jbga, jednoistavno nije bilo kapaciteta za sve
Staro 12.08.2021., 23:58   #4883
Postovi: 8,310
Zanimljivo kak u ovim "raspravama", jedino ti barataš činjenicama, dok su (po tebi) ostali totalno neupućeni. Zaboravljaš da smo prije više od godinu dana, komentirali da u slučaju da Rocket Lake ispadne smetje, kakvo je na kraju ispal, AMD nema apsolutno nikakvog razloga da za Zen 3 odigra isto kao i sa Zen 2 (oba na istom TSMC 7nm procesu). Tim više, jer nisu ni Zen 2 cijene spustili. Da, i kapaciteti su u svemu imali ulogu, ali Zen 3 generacija je na tržište stigla u studenome 2020., dok su OEM Zen 3 CPU i APU modeli bili dostupni već u siječnju i travnju 2021., sve to usporedno s novim konzolama i RDNA 2 grafičkim karticama. Tak da nisu kapaciteti tolika stavka kakvom ju non-stop prikazuješ, (sad je zapravo problem u ABF nestašici), ali bome nije ni AMD Crveni Križ, pa su ovaj put i prioriteti malo drukčiji (EPYC kao predvonik, a onda tek ostalo). I onda danas, skoro godinu dana nakon Zen 3 lansiranja, imamo (za desktop prepakirane mobilne) Ryzen 5000 APU modele, jer tak jasno da ništa od očekivanih i "obećanih" jeftinih Zen 3 modela, kad se ionako sve prodaje, neovisno o tome koliko se ljudi žalili da su cijene pretjerane.
Zadnje izmijenjeno od: The Exiled. 13.08.2021. u 00:03.
Staro 13.08.2021., 00:21   #4884
picajzla0707
Postovi: 309
dobro, kako onda objašnjavaš činjenicu da nema slabijih modela zen3 generacije s kojima bi amd uzeo daleko veći postotak tržišta, kako objašnjavaš činjenicu da je 5xxx serije bila itekako nedostupna pun kurac vremena, a i činjenicu da apu modeli dolaze s godinu dana zakašnjenja (a nekidan si prdio kako intel alder lake zapravo ne dolazi ove godine jer - za početak idu samo s najskupljima modelima, a ostalo ide tek sljedeće godine - što je onda s amd-om koji kasni godinu dana)
zašto bi amd uskratio 5600 non x ili 5700, zašto ne bi dao i 4core low end modele koji bi konkurirali intelovim i3 procesorima, da nemaju problema s kapacitetima?
zašto bi se stalno trubilo i pisalo o problemima s dostupnosti, ne samo 5xxx serije, nego i konzola i grafa, da kapaciteti nisu problem?
stvarno nekad ne kužim čemu ovakve glupe rasprave u kojima ti ignoriraš ono što doista jest činjenica i o čemu se piše i govori non stop, sad odjednom kapaciteti nisu problem, a o tome se pisalo mjesecima
nekad stvarno ne kužim zašto uporno ideš u ovakve rasprave
Staro 13.08.2021., 00:29   #4885
Postovi: 8,310
Gle, ponavljaš jedno te isto non-stop, eto počelo je s tim da ti na temelju detaljne analize zaključuješ da će AMD ostati bez kapaciteta, a sad opet vodiš monologe, jer eto nije i ne bude "obećanog" običnog R5 5600 modela za 1.500 kn. Jedini koji tu prdi si ti i to od prvog posta, jer moraš biti u pravu na Internetima, a sve dosad rečeno lijepo zapakiraš tako da seciraš postove kak ti u danom trenutku paše. Kaj se Alder Lakea tiče, ne tvrdim ja da neće stići ove godine, već da za manje od dva mjeseca stižu samo high-end modeli za DDR5 platformu i opet nije to moje mišljenje, već činjenica koja je itekak potvrđena od strane Iana Cutressa i sl., a sva sreća, pa je tema unatrag nekoliko stranica puna tih materijala. Tak da, srdi se ti i dalje na AMD i kapacitete i čekaj kaj god bilo da čekaš.
Staro 13.08.2021., 00:34   #4886
Starsylph
Datum registracije: Oct 2010
Lokacija: Sfera
Postovi: 408
Problem je u njihovom Little big pristupu. Little je bio premali, a Big-a nije bilo ni vidjeti. Monolit bi se trebao prekinuti sa Meteor lakeom. To će biti prvi korak.
Starsylph je offline   Reply With Quote
Staro 13.08.2021., 07:40   #4887
picajzla0707
Postovi: 309
... Kaj se Alder Lakea tiče, ne tvrdim ja da neće stići ove godine, već da za manje od dva mjeseca stižu samo high-end modeli za DDR5 platformu i opet nije to moje mišljenje, već činjenica koja je itekak potvrđena od strane Iana Cutressa i sl., a sva sreća, pa je tema unatrag nekoliko stranica puna tih materijala. Tak da, srdi se ti i dalje na AMD i kapacitete i čekaj kaj god bilo da čekaš.
pa naravno da prvo stižu samo high end modeli, na njima je najveća zarada, a i za ove jeftinije koji se masovno prodaju prvo treba naštancati količine za prodaju
isto je tako napravio i amd, samo s puno većim vremenskim razmakom u kojem je prodavao samo high end modele zen3 generacije toliko dugo dok se apple nije izdovoljio 7nm i oslobodio im kapacitete
zato tek sad ide masovna proizvodnja i slabijih zen3 i slabijih rdna2 grafa, jer tek sad imaju mjesta u tsmc 7nm
ista će stvar biti sa 5nm, kasnije sa 3nm, dobit će prostora kad se aple izdovolji, a sad još moraju dijeliti kapacitete i sa intelom i nevidijom, ne kažem da neće imati dovoljno za izbacit van zen4 i rdna3, ali će opet biti na kapaljku prvih godinu dana i samo oni najskuplji modeli
nedovoljno za iole veće povećanje tržišnog udjela, pogotovo kad intel izbombardira tržište jeftinijim i5 i i3 modelima za koje neće imat konkurencije
Staro 13.08.2021., 08:21   #4888
Mladenxy
Mladenxy's Avatar
Postovi: 4,366
Staro 13.08.2021., 08:22   #4889
sti
Lokacija: Lawl
Postovi: 1,378
Sad vidiš zašto ne treba čitati clickbait članke i ushićeno trčati na forum? Pišu se svakakve gluposti.
Staro 13.08.2021., 09:51   #4890
picajzla0707
Postovi: 309
nije to ništa novo, spominjalo se i prije
https://asia.nikkei.com/Business/Tec...test-chip-tech
uostalom, o tome pišu i ostali tech sajtovi, neki su skeptični oko toga, ali ne odbacuju mogućnost
uostalom, intel je itekako stjeran u kut tehnološkom nadmoći amd-a i ne bi bilo čudno da idu u ovakav deal, ne samo zbog vlastitih problema s proizvodnjom
https://www.extremetech.com/computin...m-process-node
ushićeno trčati na forum... daj molim te, pa čemu služi tech forum nego da komentiramo ovako nešto
