Staro 11.04.2006., 18:31   #4531
Virus7
Datum registracije: Jul 2003
Postovi: 800
Autor RAK
Ovog trenutka mi se skinuo patch. Barem se nadam da je to on. To ide u postupak testiranja.
das link
Virus7 je offline   Reply With Quote
Staro 11.04.2006., 18:53   #4532
RAK
Feldwebel
RAK's Avatar
Datum registracije: Feb 2002
Lokacija: bolnica
Postovi: 3,739
Tih kao mačka
Brz kao gepard
Jak kao lav
Elegantan kao leopard
Nisam to ja, to je moj komp.
Staro 11.04.2006., 19:08   #4533
maX
maX's Avatar
Postovi: 7,326
Patch skinut. RAK, cekam tvoje zeleno svijetlo! : goood :
Staro 11.04.2006., 19:09   #4534
Virus7
Postovi: 800
Staro 11.04.2006., 19:31   #4535
G0RKI
G0RKI's Avatar
Lokacija: Solin
Postovi: 1,753
Ima neko mozda change log ili readme da ga posalje..od novog patcha mislim v1.2? Nisam ga jos skinija (kad odem do faksa skinit cu njega i ove dvi mape) u međuvremenu ako neko ima neka posalje..zanima me sta je poboljsano u MP i SP?
Danke!
G0RKI je offline   Reply With Quote
Staro 11.04.2006., 19:35   #4536
Hrconja
Hrconja's Avatar
Postovi: 1,624
ljudi brišite apsolutno sve modove. inače nema mapa
točnije morate ih palit prek konzole. samo original fileove ostavit i onda ić igrat
Hrconja je online   Reply With Quote
Staro 11.04.2006., 19:37   #4537
RAK
Feldwebel
RAK's Avatar
Lokacija: bolnica
Postovi: 3,739
CALL OF DUTY(R) 2
1.2 PATCH README
Last Updated: 3/23/2006
INTRODUCTION & IMPORTANT NOTES
This document details numerous additions, fixes, and changes to Call of Duty 2 in the 1.2 patch.
The Call of Duty 2 1.2 patch is an all-inclusive installation, containing all of the previous updates from the 1.01 patch. Information about updates included from the earlier 1.01 patch can be seen at the bottom of this document.
IMPORTANT NOTE: Use of the in-game console is not supported by Activision(r). Please do not contact Activision Customer Support with issues that arise from using console commands in-game.
NOTES FOR MOD USERS:
- It is recommended that any user modifications that have been installed to the Call of Duty 2 directory be removed before installing this patch. These modifications are not supported by Activision and may not be compatible with some of the new features that are included.
- Call of Duty 2 does not support mods that have spaces in the mod's folder name. Be sure that the folder that contains your mod does not have spaces; otherwise users will not be able to download the files. For example, a mod in a folder called "My Mod" would be invalid, whereas "MyMod" or "My_Mod" would work.
PUNKBUSTER(tm)
Call of Duty 2 now includes PunkBuster Anti-Cheat software technology. PunkBuster Anti-Cheat software technology and services combat online cheating in Call of Duty 2 Internet play.
The use of PunkBuster Anti-Cheat software is optional and is provided without direct cost to our users. For more information about PunkBuster or for PunkBuster support, please visit http://www.evenbalance.com/.
Note for server administrators: When enabling PunkBuster for the first time, you must add "set sv_punkbuster 1" to the "config_mp.cfg" file to initialize PunkBuster. This file can be found by going to the "Call of Duty 2\main\players" folder and looking inside the folder named after your profile. If the "sv_punkbuster" command already exists in your config file, you can simply change the value to "1".
NEW FEATURES
- Added two new multiplayer maps. These maps support all current game types:
mp_harbor (Rostov, Russia)
An important shipping port in southern Russia, Rostov fell to the Germans in November 1941. The Soviet 37th army quickly counterattacked and punched through the overextended and winter-weary German lines to the north, forcing the 1st Panzer Army out. The Battle of Rostov resulted in the first major German withdrawal of the war.
Call of Duty veterans will recognize this location as an updated version of the original Harbor map. In addition to the graphical and performance updates, several new structures and flanking paths have also been added.
mp_rhine (Wallendar, Germany)
The 2nd Rangers crossed the Rhine on March 24, 1945 at Wallendar, Germany in pursuit of retreating German forces. German forces harassed the advancing Allied units while withdrawing.
Decimated by 5 years of war, the streets of Wallendar are covered with rubble and impact craters creating intense battle over difficult terrain with blown-out buildings providing cover. The Americans are attempting to take the German city on this map of urban combat.
- New PunkBuster functionality included (as described above).
- Added a "PunkBuster" filter under the "Filters" section of the "Join Server" screen.
- Added a "PunkBuster" display column on the "Join Server" screen.
- Added HTTP redirection for Servers running Mods or custom maps.
To enable redirection on the server, set sv_wwwDownload to 1. Set sv_wwwBaseURL to the base directory where the files are stored. For example, if the server had a file named 'myfile' meant to be stored locally at \Call of Duty\Main, sv_wwwBaseURL should be set to "http://samplewebpage1.com/". The file should be stored at http://samplewebpage1.com/Main/myfile. To prevent clients from taking up a slot on the server while downloading, set sv_wwwDlDisconnected to 1. This will free up a slot for the duration of the download and the client will attempt to autoconnect when the download is complete. Set cl_wwwDownload to 1 to enable redirection downloading on the client.
- Added a new Multiplayer welcome screen when joining a server that details the Map objectives and victory conditions.
- Added a "Message of the Day" for Multiplayer servers that will appear on the player's welcome screen upon joining. Server admins can control this text by setting the "\scr_motd" dvar to whatever text is desired.
- Added Multiplayer spawning logic that will reduce instances of players spawning in front of enemy players.
GENERAL FIXES
- Corrected an issue that occurred on certain systems using AMD(R) Dual-Core processors where player health would not replenish at the intended speed.
MULTIPLAYER FIXES
- Fixed a potential exploit where players could get outside the map boundaries.
- Corrected an exploit that caused some servers to shut down unexpectedly.
- Please note that all "Message of the Day" text needs to be less than 1000 characters total.
- Hovering over an enemy player no longer causes the crosshairs to highlight in red. This change does not affect teammates and crosshairs pointed at a friendly player will still highlight green.
Headquarters Changes
- Adjusted the objective timers to ensure that the objective respawns more quickly once destroyed.
- Removed compass icons for potential objective locations before the objective has spawned.
Capture the Flag Changes
- Added HUD icons to show the flag post location when the flag is missing.
- Players in possession of the flag are now identified as flag carriers on the scoreboard.
- When an Allied player picks up the flag, fellow teammates will now see the flag carrier's position displayed on the compass.
NOTES FROM 1.01 PATCH
Call of Duty(R) 2 Intel(R) Dual-Core Optimization Update README
This update for Call of Duty 2 adds optimization,
specifically to take advantage of Hyper-Threading technology in
Intel processors. These optimizations will increase performance
in both Single and Multiplayer modes. While significant
performance gains will be seen on Single-Core processors which
support Hyper-Threading, the greatest increase will be realized
on Dual-Core processors.
HOW TO TELL IF YOU HAVE A SUPPORTED PROCESSOR:
1. Hit Ctrl + Alt + Delete.
2. Select 'Task Manager'.
3. Select the 'Performance' tab.
4. Select View CPU History One Graph Per CPU
5. More than one graph side by side below the 'CPU Usage History'
label indicates you have a Dual Core processor or a processor
with Hyper-Threading technology.
AUTODETECT: Call of Duty 2 will automatically enable these
optimizations if it detects that you have a supported processor.
Tih kao mačka
Brz kao gepard
Jak kao lav
Staro 11.04.2006., 19:39   #4538
Hrconja
Hrconja's Avatar
Postovi: 1,624
no, i kad bu server 1.2?
i primjetio sam da nemogu uć ni na jedan 1.2 server .
neam original key. šta sam vam rekao
Staro 11.04.2006., 19:41   #4539
E.T.
E.T.'s Avatar
Postovi: 2,458
Upravo skinut...Imamo li zeleno svijetlo za instalaciju?
www.rabbits-clan.com
E.T. je offline   Reply With Quote
Staro 11.04.2006., 19:43   #4540
Hrconja
Hrconja's Avatar
Postovi: 1,624
lol, pa sniimi. nitko ti ne brani. ak nebu valjalo, briši igru
Staro 11.04.2006., 19:45   #4541
RAK
Feldwebel
RAK's Avatar
Lokacija: bolnica
Postovi: 3,739
Autor Hrconja
Nemojte još ništa instalirati jer i nema puno servera koji su u verziji 1.2. Patch još nije SLUŽBENO gore. Tako ga nema niti na našem serveru. Ako instalirate na komp, više nema našeg servera. Igra će vas izbaciti zbog različite verzije igre.
Testirao sam patch i njegov utjecaj na naš mod. RADI sve po planu. Nema baš nikakvih problema za sada. Što ne znači kako ih neće biti. Imam još malo vremena za razna testiranja kako bi bilo sve savršeno kada se pojavi na našem serveru. Instalirao sam igru sa crnog DVD-a i sa Verbatim DVD-a. Oba rade. Dakle, Verbatim DVD je kvalitetan medij (ma što drugi pričali o tome).
No to je tek početak i imam još dosta posla oko testiranja, no prvo gablec i njegov utjecaj na moje zdravlje. Onda probam one dodatne mape, pa punkbuster, pa...
Tih kao mačka
Brz kao gepard
Jak kao lav
Staro 11.04.2006., 19:50   #4542
RAK
Feldwebel
RAK's Avatar
Lokacija: bolnica
Postovi: 3,739
http://www.callofduty.com/patch%5Fcod2/
NE INSTALIRAJTE patch. Nije na serveru i nećete moći igrati na našem serveru. To je jedini razlog.
Hrconju ostavite u zapingavanju servera na svoj način. MOD RADI, a o tome kada bude patch i na serveru.
Tih kao mačka
Brz kao gepard
Jak kao lav
Staro 11.04.2006., 19:54   #4543
Amdejac
Amdejac's Avatar
Datum registracije: Jun 2003
Lokacija: Kuća
Postovi: 5,400
Skinuto i čekam start za instalaciju.
Asus N750JK (Upgrade)
MBO: Asus N750JK
RAM: 2x8 Gb PC3-12800 DDR3
PSU: Asus Li-ion 69486 mWh
OS: Windows 8.1
Monitor: 17,3 LCD (FHD)
Net: Intel AX210 NGW
Net: TP-Link Archer TX55E
PSU: Xilence, Bronze 550W
Monitor: Samsung
VGA: ATI RX570, 4 Gb
HDD: NVMe 1 Tb, Patriot
PSU: Inter-Tech SP750
Monitor: Samsung
Amdejac je online   Reply With Quote
Staro 11.04.2006., 19:55   #4544
atha
atha's Avatar
Postovi: 9,067
@RAK
LOL
veseli me onaj dio gdje se spominju mp_rhine i mp_harbor.
weee... can't wait.
___________
Just atha
x
Zadnje izmijenjeno od: atha. 11.04.2006. u 20:09.
Staro 11.04.2006., 20:01   #4545
G0RKI
G0RKI's Avatar
Lokacija: Solin
Postovi: 1,753
Danke komadanthe RAK!
Zgodne ispravke u Capture the flag.. I S& D nije lose i dodatne mape da... fino bome... Imamo se cemu nadati...
P.S Dize i accuracy kod Amerikanosa....kad je njemac na nišanu....sada brze pada
Staro 11.04.2006., 20:08   #4546
Hrconja
Hrconja's Avatar
Postovi: 1,624
onda sve ok. nemojte se ništ ljutit na mene. ja bum osto na 1.2
Staro 11.04.2006., 20:09   #4547
atha
atha's Avatar
Postovi: 9,067
molim vas, nemojte takve stvari spominjati na forumu.
koristite pm.
___________
Just atha
x
Staro 11.04.2006., 20:11   #4548
E.T.
E.T.'s Avatar
Postovi: 2,458
Molim IP kojeg servera koji je 1.2 da isprobam novine. Hvala!
Staro 11.04.2006., 20:18   #4549
Renesis
Ex-Gastarbajter
Renesis's Avatar
Lokacija: Zagreb / Rijeka
Postovi: 5,463
evo ja isto skinuo i čekam znak za paljbu
a ovako je bilo pred malo...
e da, šta je sa onom statistikom, to se treba manualno updateat, ili može to nekako automatski... jer sad sam bio gledao... pa to su još oni rezultati od pred davno...
Abit IS7-E + TR NB-1
Homemade vodeno part1
Homemade vodeno part2
Staro 11.04.2006., 20:31   #4550
maX
maX's Avatar
Postovi: 7,326
Autor Renesis
To i mene pomalo zanima...
Staro 11.04.2006., 20:46   #4551
MRKONJA
M.U.P.
MRKONJA's Avatar
Datum registracije: Sep 2004
Postovi: 2,277
Jeste primjetili da se u glavnom meniu pojavio auto update.
Koja je konačna veličina patcha?
MRKONJA je offline   Reply With Quote
Staro 11.04.2006., 20:47   #4552
thuNdeR
thuNdeR's Avatar
Lokacija: na sombra
Postovi: 1,048
32 mb
a za servere sam reko kak da ih nađeš (gabre)
thuNdeR je offline   Reply With Quote
Staro 11.04.2006., 21:08   #4553
tomasini_
tomasini_'s Avatar
Lokacija: Usa
Postovi: 1,164
A ja budala poletio i patchirao....naravno sad ne mogu na server. Kad se stavlja onda patch gore? Da znam dal da reinstaliram ili da cekam. Cekam samo ako ce do sutra bit rijeseno....
divovski kompjuteri
tomasini_ je offline   Reply With Quote
Staro 11.04.2006., 21:57   #4554
dautanecII
el_nino
dautanecII's Avatar
Lokacija: Zagreb-Tresnja
Postovi: 353
Autor RAK
CALL OF DUTY(R) 2
1.2 PATCH README
PUNKBUSTER(tm)
samo me ovo tu zanima i da konacno krenemo ravnopravno igrat.
dautanecII je offline   Reply With Quote
Staro 11.04.2006., 22:07   #4555
dautanecII
el_nino
dautanecII's Avatar
Postovi: 353
evo kak je maloprijasnji 'UT mod' izgledao,steta kaj su se Mitzek i m4d kasnije prikljucili,mozda bi prosli bolje,ali.....
tunisia
Staro 11.04.2006., 22:15   #4556
tomasini_
tomasini_'s Avatar
Lokacija: Usa
Postovi: 1,164
onda kad će patch na server?
divovski kompjuteri
Staro 11.04.2006., 22:43   #4557
atha
atha's Avatar
Postovi: 9,067
neche josh dok rak ne testira. krajem tjedna.
___________
Just atha
x
Staro 11.04.2006., 22:56   #4558
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,463
evo malo recentnih rezultata...
Staro 11.04.2006., 23:43   #4559
ZED
a.k.a. LOPOV
ZED's Avatar
Postovi: 2,022
Na ovako dobrom scoreu mozemo sam zahvalit tebi i tvom kempanju koje psihicki dotuce neprijatelja, trebas to malo vise prakticirati sve 5
Zabranjene reklama u sigu.
Staro 11.04.2006., 23:51   #4560
Renesis
Ex-Gastarbajter
Renesis's Avatar
Postovi: 5,463
malo sam bio doduše usporen večeras, malo me umor prca... al bude bolje...
šta kad masu puta ostanem sam kad svi ulete ko muhe bez glave...
I šta je isto najbolje, ja sam uglavnom na istim mjestima, a opet ih masu poskidam
