Staro 30.04.2020., 17:40   #3151
Wolverine
Wolverine's Avatar
Postovi: 12,431
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 30.04.2020., 20:40   #3152
lobo64
lobo64's Avatar
Postovi: 1,346
Anand citat:
At ~$430, the Core i9-10900F goes up against the R9 3900X.
At ~$180, the Core i3-10500 and i3-10400F go up against the popular Ryzen 5 3600.
Pitanje kako će se Jenki cijene transformirati kod nas.
Plus MB koji će u slučaju OCa (Z490) vjerojatno biti još skuplji nego X570, a niti po fičurima ga ne dostiže (pcie 4.0).
Nadam se da će čipovi biti brži (ili barem jednako brzi) nego Ryzen, da se slučajno ne desi obrnuta situacija od prije nekog vremena (mužnja korisnika).
ASUS ROG Maximus XII Extreme Glacial ? -
ASUS ROG Maximus XII Extreme EATX $750
ASUS ROG Maximus XII Formula ATX $500
ASUS ROG Maximus XII Apex ATX -
ASUS ROG Maximus VII Hero WiFi ATX $399
ASUS ROG Strix Z490-E Gaming ATX $300
ASUS ROG Strix Z490-F Gaming ATX $269
ASUS ROG Strix Z490-G Gaming mATX -
ASUS ROG Strix Z490-G Wi-Fi Gaming mATX -
ASUS ROG Strix Z490-A Gaming ATX -
ASUS ROG Strix Z490-I Gaming mITX $300
ASUS TUF Z490-Plus ATX -
ASUS TUF Z490-Plus WiFi ATX $200
ASUS Prime Z490-A ATX $230
ASUS Prime Z490-P ATX $160
ASUS Prime Z490M-Plus mATX $150
ASUS ProArt Z490-Creator 10G ATX
GIGABYTE Z490 Aorus Xtreme WaterForce EATX $1299
GIGABYTE Z490 Aorus Xtreme EATX $799
GIGABYTE Z490 Aorus Master ATX $389
GIGABYTE Z490 Aorus Ultra ATX $299
GIGABYTE Z490 I Aorus Ultra mITX $269
GIGABYTE Z490 Aorus Pro AX ATX $269
GIGABYTE Z490 Aorus Elite AC ATX $219
GIGABYTE Z490 Gaming X ATX $200
GIGABYTE Z490M Gaming X mATX -
GIGABYTE Z490 Vision D ATX $299
GIGABYTE Z490 Vision G ATX $199
Pitanje je koja od ovih ploča će uopće dozvoliti OC obzirom na konfiguraciju VRMa.
Zadnje izmijenjeno od: lobo64. 30.04.2020. u 20:49. Razlog: dodavanje
Staro 30.04.2020., 21:12   #3153
Mladenxy
Mladenxy's Avatar
Postovi: 4,437
kome to treba oc kad boosta tak visoko. ocanje je zastarjelo.
Staro 30.04.2020., 21:20   #3154
Wolverine
Wolverine's Avatar
Postovi: 12,431
Na zalost gledajuci sve to i dalje ne znam sto bi korisnika natjeralo da uzme ista od ponudenog u odnosu na Ryzen.
Z490 ploce ce bit preskupe a glavni feature (PCIe 4.0), koji ujedno i dodatno dize cijenu, je u potpunosti nekoristiv. Daljni OC i9 proceva koji vec u defaultu imaju 250W TDP na plocama koje imaju VRM dizajniran za 350W je blago receno upitan.
Kad bi vec morao uzet, vjerojatno bi to bio i5 10400F i neka mainstream ploca.
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 30.04.2020., 21:28   #3155
Odinarius
All-rounder
Datum registracije: Sep 2013
Postovi: 1,338
Price cut je najbolja stvar u ovoj generaciji, ne zato što ih čini poželjnima. U najboljem slučaju se izjednačavaju cijenom i performansama s Ryzenom, na lošijoj platformi. Super je što bi taj price cut mogao gurnuti Ryzene malo niže, kojem je hex super pozicioniran, ali octa nije. Najjeftinija Intel octa je jeftinija od 3700x po trenutnim cijenama na amazonu, i to zove na pojeftinjenje, nadam se i za hexove
Staro 30.04.2020., 21:33   #3156
lobo64
lobo64's Avatar
Postovi: 1,346
Očito da nekom treba, inače se postavlja pitanje egzistencije Z490 čipseta.
Kad smo već kod OCa, Asrock izgleda ima svoju furku:
https://www.tomshardware.com/news/in...requency-boost
Zadnje izmijenjeno od: lobo64. 30.04.2020. u 22:15. Razlog: dodavanje
Staro 30.04.2020., 22:08   #3157
Postovi: 8,485
Nova NIC peripetija bude ispala ko P67 - Z68 situacija otprije nekoliko godina.
The two key features that Intel is promoting to users is support for Intel’s new 2.5 GbE controller, the I225-V ($2.40 controller price), in order to drive 2.5 gigabit Ethernet adoption. It still requires the motherboard manufacturer to purchase the chip and put it on the board, and recent events might make that less likely – recent news confirmed by Intel has stated that the first generation of the I225 silicon is not up to specification, and certain connections might not offer full speed (down 10 Mbps from 2500 Mbps) depending on the end-point. As a result Intel is introducing new B2 stepping silicon later this year, and we suspect all motherboard vendors to adopt this.
Staro 30.04.2020., 22:14   #3158
MadBoY
MadModerator
MadBoY's Avatar
Datum registracije: Sep 2002
Lokacija: N/A
Postovi: 5,195
Vjerojatno ce proizvodjaci maticnih forsirati max boost clock da traje duze i da takt bude visi nego sto je to po Intelovim specifikacijama. Zato i Anandtech napominje da su im proizvodjaci rekli da ocekuju 350 W potrosnju kod ovih 5 GHz+ modela. 250 W je "default" TDP za 5.3 GHz, a maticna ce sama forsirati max-boost, tako da vjerojatno ni nece biti neke velike razlike izmedju "default" i OC.
Staro 30.04.2020., 22:21   #3159
Wolverine
Wolverine's Avatar
Postovi: 12,431
Autor lobo64 Pregled postova
Ista stvar kao i ranije dok ne dobe po prstima od Intela i povuku stare BIOS verzije sa sluzbenih sranica i ostave samo najnovije koje ne nude podrsku
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 30.04.2020., 22:29   #3160
Manuel Calavera
Manuel Calavera's Avatar
Postovi: 14,585
180$ za i3? To su dosta veće cijene od onih "leakanih" što smo spominjali na prošloj stranici...
Što se tiče clockanja - pa to je sve clockano out of the box. Od skylakea intel samo diže clockove. Dobra mbo je must (pogotovo 8 i 10 core).
Staro 30.04.2020., 22:36   #3161
Postovi: 8,485
Imaš i 4C/8T Core i3-10100 za $122, ali kod nas bude to ispalo 1.200 kn i možeš se slikati, ako B460 i H470 modeli ne budu isti dan dostupni, jer ovak kupac treba bar $200 za početni Z490.
Staro 30.04.2020., 22:39   #3162
Manuel Calavera
Postovi: 14,585
Ma jebeš i3, nego sam mislio u smislu ako je najdkupli i3 180$ i ide na ryzena 3600, i5 je skuplji i nekompetentan
Staro 30.04.2020., 22:43   #3163
Postovi: 8,485
To i još kad AMD izda Zen 3 + odu cijene ovim trenutnim i počinje šou. Još uvijek mi nije jasno kak su uspjeli ploče sfušati s ovim NIC-om za par dolara.
Jedino ASRock koristi Realtek za sve, dok ostali imaju kombinaciju svega pomalo. Najgore su prošle ploče sa samo jednim NIC-om, jer taj je tak jasno I225-V.
Staro 30.04.2020., 22:45   #3164
lobo64
lobo64's Avatar
Postovi: 1,346
Kod Jenkija je 150$ najjeftiniji Asus samo je pitanje koliko dugo njegov vrm može držati boost i na kojoj frekvi, pa čak i za tako štedljivi i3.
Staro 30.04.2020., 22:50   #3165
Postovi: 8,485
E, ta stvarno nije loša i cijenom i opremom. Uredno podržava do 128GB memorije ko i skuplji modeli, a koristi provjereni I219-V NIC. U kombinaciji s Core i3-10100 dušu dalo za FreeNAS.
EDIT:
Ne samo da su svjesno u prodaju pustili ploče koje samo čekaju zamjenu s novom revizijom, nego se paralelno sprema i Rocket Lake nasljednik, tak da je pitanje da li bude ovo uopće doživjelo jednu godinu koju smo prije spomenuli u kontekstu DOA platforme. Mogli su Comet Lake procesore komotno pustiti na Z390/Z370, jer dosad su svi potvrdili prijašnja nagađanja da nije bilo potrebe za novim socketom. Krajem godine (rujan/listopad) onda imamo Rocket Lake i Zen 3.
Zadnje izmijenjeno od: The Exiled. 01.05.2020. u 15:25.
Staro 01.05.2020., 20:52   #3166
demetrius
demetrius's Avatar
Lokacija: rijeka
Postovi: 3,873
https://www.youtube.com/watch?v=DA6pq4vj4lI
ćemo vidjet ako će novi socket z490 bit i za sljedeću g4eneraciju cpu-a,pci 4.0 je već integrian u ovim proc 10 serija ili će bit tek u novim cpu??ako i bude ista ploča z490 podržavala nove procesore hoće li i ddr 5 memoriju??ako je zarez na istom mjestu ili nije samo zarez bitan.
Staro 01.05.2020., 21:00   #3167
Manuel Calavera
Postovi: 14,585
Imaš u onom anandtech linku
One big thing that users will want to know about is PCIe 4.0. Some of the motherboards being announced today state that they will support PCIe 4.0 with future generations of Intel products. At present Comet Lake is PCIe 3.0 only, however the motherboard vendors have essentially confirmed that Intel’s next generation desktop product, Rocket Lake, will have some form of PCIe 4.0 support.
DDR5 neće ići na taj socket, možda bude na idućem LGA 1700
https://www.guru3d.com/news-story/su...ktop-cpus.html
Staro 01.05.2020., 21:07   #3168
Postovi: 8,485
Z490 bude u tih pola godina koliko se namjerava zadržati, prvenstveno za one koji žele Core i9-10900K ili općenito kupuju novu Intel platformu, pa je došlo ko naručeno.
Sljedeća platforma za Rocket Lake bude tak jasno (opet) imala novi čipset, mada bude LGA-1200 socket ostal isti i tek s tim (novim) procesorima cijela PCI-E 4.0 priča ima smisla.
Staro 01.05.2020., 22:08   #3169
Manuel Calavera
Postovi: 14,585
Taj Rocket Lake će vjerovali ili ne opet biti na 14nm, no valjda bi napokon trebali donijeti novu arhitekturu.
To je ono što sam ja stalno govorio da su trebali napraviti - ako je već zapelo sa nodeom zašto je zapelo sa arhitekturom da furaju skylake još od 2016 god...
Samo mi nekako ne drži vodu da će i to ove godine doći... Vjerojatno je frka zbog zen3
Staro 01.05.2020., 22:38   #3170
Postovi: 8,485
Možda ga proguraju na početak 2021. tak da baš ne bude totalna šamarčina svima koji sad kupe Comet Lake, tim više, jer Rocket Lake (navodno) ne ide dalje od 8C/16T za high-end modele, jer budu nagurali i 10nm Xe iGPU u to čudo tehnike. Tak da tehnički mogu reći da imaju 10nm na desktopu. Evo, Ian Cutress skoro dva sata priča o tome kak se nekome ko ima 9900K ne isplati prelazak na 10900K taman i da ide u isti socket, a Rocket Lake je ionak već iza ugla. Joj, koji čušpajz bude na kraju ispal, a mogli su biti fer, pogotovo s obzirom na situaciju u kojoj su se našli - i dati ljudima opciju da na Z390 ploče stave nove procesore i voljno.
Staro 01.05.2020., 22:51   #3171
Manuel Calavera
Postovi: 14,585
I ja mislim...
Nema smisla da sad ovo izbace na ljeto, a kao od jeseni evo nove generacije... Nema šanse
Što se tiče rocketa - sve ovisi od te arhitekture tj. kakav će IPC pomak biti. Taj će do zen 3 morati imati pozamašan IPC napredak. Što se tiče jezgri ne vjerujem da više od 10 corea mogu ponuditi... A još ddr5 platforme pred vratima...
Staro 01.05.2020., 22:59   #3172
Postovi: 8,485
Iskreno, ne bi me čudilo da naprave upravo to, jer za jesen imaju onaj tzv. back-to-school period, a opet za kraj godine imaju šoping groznicu subotnje večeri. Tak da vrlo lako za jesen/zimu mogu plasirati Rocket Lake, jer zarada je bitnija od svega ostalog + nove Z590 LGA-1200 ploče za dobru mjeru. U slučaju da se Zen 3 pokaže superioran naspram Willow Cove arhitekturi koju misle iskoristiti za jezgre u Rocket Lake modelima - e onda kaj god da naprave, ne bude dosta. I kaj se tiče jezgri, ne ide više od 8C/16T za Rocket Lake, jer jednostavno nemaju manevraskog prostora, ako žele iole dobar IPC + TDP u kombinaciji s tim famoznim 10nm Xe iGPU-om, kojeg su već morali srezati u odnosu na Ice Lake, jer i tu muku muče, pa ne ide više od 4C/8T kombinacije, ali za laptope. Zato velim, ovo bude potencijalni čušpajz neviđenih razmjera, ako se odluče u istoj polovici godine napraviti rošadu.
Staro 04.05.2020., 16:00   #3173
BusMaster
BusMaster's Avatar
Datum registracije: Apr 2017
Postovi: 343
LGA Socket 1700 for Alder Lake-S in 2021? (8 BIG + 8 little cores)
@The Exiled
@Manuel Calavera
Izgleda da će Intel (opet), napraviti baš to... nova platforma i socket LGA1700 u godinu dana ili manje? Očito nema smisla nikakva kupovina sada ili u dogledno vrijeme.. ovo je baš teško lutanje i zezanje s kupcima.
https://www.guru3d.com/news-story/lg...s-in-2021.html
Staro 04.05.2020., 16:10   #3174
Manuel Calavera
Postovi: 14,585
Zvuči kao mobitel... (8 high perf. cores i 8 low power), tako da nisam siguran za taj dio, no igpu sa hbm može biti dosta snažna
Staro 04.05.2020., 17:03   #3175
Matebaron
Matebaron's Avatar
Lokacija: Supetar
Postovi: 328
Koliko sam shvatio nisu rekli da će igpu imati HBM nego samo da će cpu die imati takvu "sendvič" arhitekturu kao HBM.
I have spoken.
Matebaron je offline   Reply With Quote
Staro 04.05.2020., 19:42   #3176
Postovi: 8,485
Da, oni takvo pakiranje nazivaju EMIB, tj. služi im za povezivanje više čipova. Kaj se jezgi tiče i taj ARM-ovski big.LITTLE prisutp su već najavili, pa ništa od ovog nije čudno - ni najmanje. Šou samo takav u Intelu.
Također, vjerujem bez ikakve dvojbe da je ovo nešto na čemu Jim Keller radi unutar Intela. Em je to njegov fah, em je to radil prije u AMD-u, Appleu i Tesli. Tak da to stvarno i ugleda police trgovina, ne bi se čudil.
Zadnje izmijenjeno od: The Exiled. 04.05.2020. u 19:59.
Staro 06.05.2020., 10:41   #3177
pci_e3x
Premium spammer
pci_e3x's Avatar
Datum registracije: Aug 2010
Lokacija: D.Zagora
Postovi: 776
LGA1700 First Mainstream Socket from Intel since LGA1156 to Last Over Two Generations of Processors
https://www.techpowerup.com/266701/l...-of-processors
edit: vidim da se i u gore postanom guru3d linku spoinje two-gen na lga 1700..
Staro 06.05.2020., 11:14   #3178
Lewis
Freelancer
Lewis's Avatar
Lokacija: Bilje (Osijek)
Postovi: 5,326
Stavrno su genijalci, kud ih AMD gazi po cijena/performanse oni jos i dalje kemijaju i tjeraju ljude sa novim socketima iz godine u godinu....
Staro 06.05.2020., 11:42   #3179
Postovi: 8,485
Na kraju ispada da stvarno ni sami ne znaju kud bi krenuli, jer ovaj Zen ih prije sad već skoro četiri godine uhvatil totalno nespremne za bilo kakve manevre. Glavno da se hvale kako imaju više od tri milijarde spremno za "marketing" protiv AMD-a.
Super, mogu imati i 300 takvih paketa i žali Bože nofci, kad neovisno o ciframa koje imaju na raspolaganju, ništa od tog "marketinga" im neće implementirati novu arhitekturu.
Pa sad malo implementiraju MCM rješenje kakvo im je AMD smjestil, pa malo ARM i 10nm, malo 7nm, malo bi - malo ne bi, ni vrit ni mimo. Kak god se okrene sve zbrda - zdola.
Staro 06.05.2020., 12:05   #3180
Ali rekordna zarada je i dalje tu. Intelovim dioničarima i suvlasnicima tu na forumu je ionako samo to bitno
Ne stvarno, kad se uzme cijela slika zadnjih 5-7 godina reciklaže, lutanja i kanibaliziranja 6-12 mjeseci starih platformi, ovo da će LGA1700 izdržati 2 generacije procesora je stvarno hvale vrijedan potez. Kako god to bilo "malo", eto pomaka "na bolje" za one koji misle ispaliti pare za tu platformu sada.
