#91 | |
Lokacija: RI-KR
Postovi: 789
#92 |
Postovi: 8,361
Imam jedno pitanje... Meni automatic update nudi da instaliram SP1, ali me zanima hoće li to radit s obzirom da imam ASUS OEM ( ![]() Odnosno, hoće li Vista nakon toga radit... Hvala EDIT Instalirao SP1, i maklo mi je Asus OEM aktivaciju. Drugim riječima, sada imam 15 dana za aktivirati Vistu, inače... Krasno... EDIT2 Riješeno... ![]() Zadnje izmijenjeno od: Neo-ST. 28.03.2008. u 00:20. |
#94 |
Gamer 2 the Bone
Lokacija: Zagreb, oko centra...
Postovi: 1,640
Ja instalirao SP1 i jedina razlika koju za sada primjećujem je da mi se sporije diže. Sustav. ![]()
- Nothing in this world is certain. That's the only certain thing I know. - |
#96 |
Lokacija: RI-KR
Postovi: 789
#97 |
Gamer 2 the Bone
Postovi: 1,640
MNa my computer--->properties i meni sada piše 4.00 GB rama, međutim u onom vista sidebar priljepku koji mi monitorira ikorištenje rama i svake jezgre posebno još uvijek piše 3300 mb-a....
#99 |
Beskorisna bitanga...
Lokacija: Sesvete (Zg)
Postovi: 6,956
Nije točno može se koristiti i preko 4GB rama na 32bit samo sa PAE što se ljudima ne sviđa jer se tako ima slabe rezultate na super piu i ostalome jel... ![]() ![]()
-- Have a nice day... |
#101 |
Pod naletima kopita zla
Lokacija: SMB / ZGB
Postovi: 7,735
@CPU inace mozes dati malo vise infoa kaj to radi ![]() Windows Vista SP1 File Removal tool (Vsp1cln.exe). Vsp1cln.exe is an optional tool that you can run after you install SP1. This tool removes older versions of components that have been updated in SP1, which are stored during the installation in case you need to uninstall SP1 later. Saving these older components increases the amount of disk space that is used. Typically, you should run Vsp1cln.exe if you want to reclaim this disk space after applying SP1 and if you will not need to uninstall SP1. Note, however, that you cannot uninstall SP1 after you run this tool. You can use this tool both online and offline, but you must have SP1 installed and you must use the correct version of the tool. If you are running this file on an offline image, you should use the Vsp1cln.exe included in the Windows OPK or AIK. However, if you are running this file online (on a computer that you are booted into), you should use the Vsp1cln.exe file located at %windir%\system32\vsp1cln.exe. p.s ja dignuo sp1 na biznis verziju viste x86..za sada radi sve..podrobnija testiranja slijede nakon dobro zasluženog godišnjeg odmora ![]() |
#102 | |
Lokacija: RI-KR
Postovi: 789
![]() ali ako netko zeli isprobati: start->run->bcdedit /set pae forceenable za iskljuciti bcdedit /set pae forcedisable |
#103 |
Lokacija: Sv.Nedelja
Postovi: 5,823
Ljudi kak je kod vas,evo sad sam baš spojil mobitel SE S500 prek usb-a i kopiram zipani file velik 433mb,al vidim da to traje oko 20min.kopiranje.Kakva su vaša iskustva s kopiranjem večih fileova na mob prek usb-a? |
#104 |
Postovi: 6,956
#105 |
Why so serious
Postovi: 3,415
Da kad kopiraš sa moba ide malo sporije al to je jer je kartica spora u mobitelu ili sam aparat ovisi kak kopiraš, meni isto ide sporije al ne tolko,ovisi i kak staviš da ti komp prepozna mobitel ko mem uređaj ili ko telefon! |
#106 |
Postovi: 553
meni je relativno brzo instalirao, možda za nekih 20min. a i windowse mi je brzo instalirao. sjećam se da mi se xp na istoj konfi instalirao sigurno duplo dulje. |
#111 |
Lokacija: osijek
Postovi: 99
mene zanima ako wista koristi 0,99gb rama dok su widnowsi upaljeni...kako se onda poansa onih 1gb u igricama i programima...dali se u igrama kolje ili sasvim solidno radi...ja imam E4500 (2x2,2ghz)...2gb kingmax 800mhz...kroz koji dan idem kupiti hd3870...dali mi se isplati stavljati vistu ili da stavim xp |
#116 | |
Why so serious
Postovi: 3,415
#118 | |
Postovi: 5,823
#120 |
music freak
Lokacija: Sibenik
Postovi: 3,315
