Staro 29.03.2008., 23:55   #1
schrafsch
Postovi: 49
Konfiguracija za ~4000kn
Evo ljudi zamolio bih vas za komentare slijedeće konfiguracije koju mislim složiti. Svaka kritika je dobrodošla.
Komp bi koristio za igrice, one zahtjevnije te za aplikacije tipa Catia, ProEngineer, Solid works i sl. ako me kužite.
Monitor ne bi uzimao a hard disk bi ostavio stari tako da mi te dvije stvari ne trebaju.
Konfa:
Procesor Intel Core 2 Duo E4600 , 2.4GHz, socket 775, 2Mb cache, FSB 800, box, 3 god. Jamstva 845 Kn
Gigabyte P35C-DS3R, s775, intel P35+ICH9R, FSB 1333/1066/800MHz, 8xSerial ATA II, 1xUDMA133, 3xPCI, 3PCI-E x 1, 1PCI-E x 16, 2xDDR3+4DDR II (Dual channel 1066/800/677/533 MHz), 8-channel audio, Gb LAN,USB 2.0, HT, ATX 676 Kn
VGA XFX Nvidia GeForce PCI-E 8800GT/512DDR3/DualDVI/PciEx 600M Alpha Dog Edition 1544 Kn
DDR2 2048Mb ( 2Gb ) PC6400 Kingmax MARS , 800MHz, CL5 225 Kn
Kućište ColorsIT L8025-C43 ATX, Midi tower, NO PSU 127 Kn
Napajanje CHIEFTEC 450W, ATX2 ver 2.0, 120 mm ventilator, Active PFC 334 Kn
CIJENA UKUPNO:
3751 Kn
Nadam se da nisam stavio neke nekompatibilnosti. Unaprijed se zahvaljujem
edit: također ne trebam ni pržilicu, imam staru
schrafsch je offline   Reply With Quote
Staro 30.03.2008., 00:05   #2
elvis again
In the ghetto
elvis again's Avatar
Postovi: 1,943
mbo - Gigabyte P35-DS3, s775, intel P35+ICH9, FSB 1333/1066/800MHz
cpu - Procesor Intel Core 2 Duo E8200 , 2.66GHz, socket 775, 6Mb cache
ram - DDR2 1024Mb ( 1Gb ) PC5300 Kingmax MARS , 667MHz, CL5 x2
hdd - HDD Seagate 250GB, SATA II , Barracuda 7200.10, 16Mb,ST3250410AS
vga - Gigabyte Radeon HD 3870 512MB DDR3,256bit, DVI-I / D-sub / HDTV
psu - Napajanje FORTRON 400W, PNF serija, PFC, Super Silent, 12cm vent
cas - Aplus CS-185A PC Case, w/o PSU, RoHS
cca 3.950,00Kn sve iz ADM-a
AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor
elvis again je offline   Reply With Quote
Staro 30.03.2008., 00:07   #3
razor i2c
razor i2c's Avatar
Lokacija: Hercegovina
Postovi: 363
poslušaj elvisa,naclockaj to malo i imat ćeš pilu.samo nemoj uzimat hard disk koji ti je elvis preporučio jer ti ne treba i u tu razliku možeš ubaciti 8800gt.ako ti intel c2d 8200 ne treba uzmi 4500 i malo bolje napajanje tipa corsair 450w kojeg imaš u adm-u za 500kn.
Sig 50 kb max :-)
Zadnje izmijenjeno od: razor i2c. 30.03.2008. u 00:18.
razor i2c je offline   Reply With Quote
Staro 30.03.2008., 00:12   #4
Postovi: 7,568
elvise sad ti fino izbroji sve svoje postove di preporučuješ E8200 i 250GB disk i onda reci zakaj predlažeš ljudima ono kaj im ne treba.
Ne peče te malo savjest kad znaš da bude neko na temelju tvoje preporuke dal novce za ono kaj trenutačno ne treba, niti traži?
Staro 30.03.2008., 00:15   #5
schrafsch
Postovi: 49
Mislim da ostajem pri nvidiji. Mrzim ati i njihove drivere tako da nema šanse da ovo uzmem. Samo provjeri Atijev forum i odmah ti je jasno.
+ hard mi ne treba
Staro 30.03.2008., 00:23   #6
elvis again
In the ghetto
Postovi: 1,943
Kad pogledas taj disk je jedan od najjeftinijih 250GB diskova u ADM-u (375kn) pa sto ako je brz. Dok E8200 kosta također relativno malo 1100kn. Posto ima mjesta u buđetu i rece covek da treba konfu i za igrice. Ne pece me savjest jer ipak mislim da se isplati ulozit u proc nesto vise novaca kao i u maticnu plocu. Kad pogledas razlika u cijeni između E8200 i njegovog E4500 je 250kn sto i nisu neki novci a ipak dobija proc nove generacije koji se maje grije ima vise cahca a i nesto je jaci od E4500.
E sad znam da bus opet sa svojim argumentima bil ti u pravu i kad bum cital tvoj odgovor mislil si bum koji sam bedak, ali nemrem si pomoci.
@schrafsch: onda samo izbaci HDD i stavi neku od jeftiniju 8800GT koja ti se sviđa i to je to. BTW na kojem monitoru radis?
Staro 30.03.2008., 00:35   #7
schrafsch
Postovi: 49
Pitanje vezano uz matičnu:
Kaj mi se na isplati više uzeti GA-P35C-DS3R nego GA-P35-DS3?
prva podržava DDR3. Ok znam da mi to trenutno ništa ne znači ali dugoročnije bi trebalo biti isplativije.
evo link za usporedbu:
http://www.gigabyte.com.tw/Products/...ctID=2748,2749
Staro 30.03.2008., 00:39   #8
razor i2c
razor i2c's Avatar
Postovi: 363
nikakav ddr3 nemoj uzimat,cijene su nenormalne,a performanse prema ddr2 memama nisu prevelike.
Sig 50 kb max :-)
Staro 30.03.2008., 00:41   #9
Postovi: 7,568
Autor elvis again Pregled postova
Je, sve je to fino, ali čoveku ne treba disk i naglasil je to, a taj 250GB ne vrijedi te novce. Dok mu je E4600 ili E4500 dosta za ono kaj je navel. Eventualna preporuka, (od strane forumaša), njegovoj konfiguraciji je da razmisli o 400W Fortronu, 430W CoolerMasteru i E4500 procesoru. Mada je i sam složil i više nego vredu kombinaciju i nema potrebe za preinakama, osim ako sam to ne želi.
Relativno malo novaca je kad za quad daš ~1.200 kn. Danas su dvojezgreni procesori s cijenom iznad tisuću kuna bacanje para, jer razliku između 65nm i 45nm ne vidi 99% forumaša. Svi samo znaju da se 45nm bolje clockaju i to im je dosta.
Za matičnu ploču se isplati dati koju kunu više da se dobije čim kvalitetnija i dugotrajnija podloga za cijeli sistem. Opet ne treba ni pretjerivati sa gamerskim i clockerskim modelima. Ali E8200 u ovom slučaju ne predstavlja nikakav dobitak - samo nepotreban trošak.
Samo velim da nema potrebe za forsiranjem, ako je čoveku dosta i ono kaj je sam složil.
Staro 30.03.2008., 00:54   #10
schrafsch
Postovi: 49
hvala na informacijama. Mislio sam uzeti 450W čiftek jer je to ipak neka firma a mislio sam da mi 400w ne bu dosta.
Al ak kažete da je ok onda ok. Znam da sam pročitao da je bolje uzet neko kvalitetnije napajanje pa manje nego smeće od 1000w.
p.s. evo nisam ni skužio ali :
Procesor Intel Core 2 Duo E4700 , 2.6GHz, socket 775, 2Mb cache za iste pare ko i Procesor Intel Core 2 Duo E4600 , 2.4GHz, socket 775, 2Mb cache u ADM-u
Staro 30.03.2008., 01:01   #11
elvis again
In the ghetto
Postovi: 1,943
Po mom misljenju (sad kad mi je McG zabranil da preporucijem E8xxx seriju) najbolji izbor je E4500 jer tu razliku u par sto mhz-a nebus osjetil a ako bus klokal svi idu dosta preko 3Ghz, uz sve to je i najjeftiniji od E4xxx serije.
Staro 30.03.2008., 01:05   #12
razor i2c
razor i2c's Avatar
Postovi: 363
oftoppic-je li ovaj novi intel c2d 4700 ima množitelj 13 ili se varam?
Sig 50 kb max :-)
Staro 30.03.2008., 01:09   #13
Postovi: 7,568
Autor razor i2c Pregled postova
Da i rađen je u 45nm procesu.
Staro 30.03.2008., 01:10   #14
elvis again
In the ghetto
Postovi: 1,943
Staro 30.03.2008., 01:14   #15
razor i2c
razor i2c's Avatar
Postovi: 363
pa onda bi ovaj novi intel c2d mogao biti prava poslastica za clockere,13*množitelj (potrebno samo 310 fsb-a kako bi postigli 4 ghz sa 13 množiteljem).ako cijena padne na jedno 750-800 kn ovo će bit isplatljiva igračka i ako je pravljen u 45nm proces.
Sig 50 kb max :-)
Staro 30.03.2008., 01:15   #16
elvis again
In the ghetto
Postovi: 1,943
Niti se E4500 pokazal ko jako dobar kloker (dojde do 3.2Ghz mozda max 3.4Ghz sto za njegov mnozitelj uopce nebi trebalo predstavljat problem) pa tak vjerujem nebu niti ovaj jer je to skoro isti proc samo s malo vecim mnozitelejm.
Staro 30.03.2008., 01:26   #17
razor i2c
razor i2c's Avatar
Postovi: 363
Niti se E4500 pokazal ko dobar kloker pa tak vjerujem nebu niti ovaj jer je to skoro isti proc samo s malo vecim mnozitelejm.
po meni najbolji su clockeri E4300 i E4400,jer ti su procevi davali max od sebe.mogli su ih i normalni ljudi ali koji su upućeniji u clockanje clockati 80% bez velikih problema,100%-uz malo više truda i volti ,te više od 100% uz nešto sreće,dobre opreme i znanja.ovim novim procevima intel samo sam sebi pravi konkurenciju umjesto da smanji cijene 8200/8400/8500 proceva i samelje konkurenciju (na prvom mjestu AMD koli je i sad u velikim,velikim problemima).sreća njihova je što su kupili ATI.
Sig 50 kb max :-)
Staro 30.03.2008., 01:28   #18
Postovi: 7,568
Ne znam, ali kolko me fotografsko pamćenje služi to je prvi 45nm procesor iz E4000 serije. Bilo je govora o njemu na Intelovom podofrumu, točnije na temi o novi procesorima. Bilo je još vijesti o tom 45nm E4700 na DigiTimesu, pa ako je ko registriran nek provjeri.
The entry-level Wolfdale 45nm part will be the E4700. That processor will be equipped with a 2MB L2 cache (presumably unified), and run at 2.6GHz on an 800MHz FSB with a 1K price of $133. Intel is reportedly releasing a second 45nm part with a 1066MHz FSB and 3MB of L2 cache, but neither clockspeed nor model number has been disclosed.
Sad dal bude i 65nm i 45nm verzija E4700 modela, nemam pojma. Dal su vijesti bile krive - itetak moguće.
Sve u svemu, da ne bi bilo da sam ja izmislil 45nm E4700.
Staro 30.03.2008., 01:36   #19
elvis again
In the ghetto
Postovi: 1,943
Nema frke McG. Kolko sam skuzil E4700 65nm i E4700 45nm imaju iste specifikacije pa ubiti nije ni toliko bitno u kojoj verziji bude izasel.
Rekel bi McG: to je bitno samo tebi (elvisu) jer patis na novu arhitekturu :-).
Staro 30.03.2008., 01:38   #20
Postovi: 7,568
Ne bi, jer da je to istina sad bi i ti imal doma E8000 model.
Nema ništ loše u novoj arhitekturi, ako ona vrijedi te novce.
Staro 30.03.2008., 01:42   #21
razor i2c
razor i2c's Avatar
Postovi: 363
Autor McG Pregled postova
slažem se
Sig 50 kb max :-)
Staro 30.03.2008., 23:34   #22
MIK
no fear
MIK's Avatar
Lokacija: ZAGREB
Postovi: 894
Da ne otvaram novu temu malo da se ubacim
Konfa za frenda:cijena do max 4KKN; namjena za igre; bez monitora i periferije (ima monitor 19" CRT), bez klokanja. Uvjet da je sve iz jednog dućana te da ga tamo sastave. Svi prijedlozi i kritike su dobrodošli!!!
CPU INTEL Core2Duo E4600 BOX , s. 775, 2.4GHz, 2MB c., FSB 800MHz, 64 bit, DualCore -899,00 KN
MBO Abit IP35-E, P35, DDR2, zvuk, G-LAN, S-ATA, PCI-E, s. 775 -702,44 KN
VGA PCI-E GIGABYTE GeForce 8800 GT, 256MB DDR3 -999,00 KN
RAM PC-6400,1 GB, KINGMAX , DDR2 800 MHz x 2komada - 266,01 KN
Napajanje 400W,CHIEFTEC , ATX2 v2.0, 120mm vent. - 323,00 KN
HDD 250.0 GB SEAGATE, SATA, 16MB c., 7200 okr/min, za - 409,00 KN
Kućište FRONTIER FRONTIER Shinobi SH09A-BK/SV, crno-srebrno, 400W ATX2, LCD -350,00 KN
Ukupno: 3.948,45 KN
Zadnje izmijenjeno od: MIK. 31.03.2008. u 10:43.
MIK je offline   Reply With Quote
Staro 01.04.2008., 13:29   #23
schrafsch
Postovi: 49
znači kaj bi najbolje bilo izabrat? E4500 ili 4700? razlika je 100 kuna
Staro 01.04.2008., 13:39   #24
Postovi: 34,084
Ne vjerujem da je razlika u performansama tolika da bi opravdala tih 100kn.
Imao bi jedan prijedlog za tebe - uzmi grafu 2600XT DDR3 i modaj je u FireGL. Time ćeš dobiti solidnije performanse u CAD programima kojima se služiš. Upute možeš naći na ATI podforumu. btw, dotična košta oko 600kn.
Staro 02.04.2008., 19:29   #25
schrafsch
Postovi: 49
imam trenutno hd 2600 pro i kartica nema službene ati drivere s kojima bi radila nego koristim omega drivere. Jednostavno mrzim Ati
Staro 02.04.2008., 20:54   #26
Postovi: 34,084
I ta se može modati u FireGL.
