Staro 31.03.2008., 10:54   #1
Campeonato
Premuim
Campeonato's Avatar
Postovi: 1,748
AMD Ne OC do 3000 KN
Slazem za neko komp do 3000 kn.
Oca nece biti, jedina namjena tom kompu su igre i internet.
Komponente su moguce iz vemila i adm-a
Hoce li ovo biti ok
Gigabyte MA69G-S3H, AMD 690G, S. AM2, 4 x Serial ATA II, SATA RAID, UDMA133, VGA ATI Radeon X1250 shared, 2PCI, 1PCI-E x1, 1PCI-E x4, 1PCI-E x16, 4DDR II (Dual Channel, 800/667/533MHz),
8 channel High Definition Audio, HDMI, Gigabit LAN, IEEE 1394
443.57 kn ADM
Procesor AMD Athlon 64 X2 4800+ , socket AM2, BOX ! , 65nm, 1024Kb cache, Brisbane, 2.5GHz
524.60 kn ADM
Gigabyte Radeon HD 3850 512MB DDR3,256bit, DVI-I / D-sub / HDTV, DirectX 10, PCI-X 2.0 , GV-RX385512H
1,005.50 kn ADM
DDR2 2048Mb ( 2Gb ) PC6400 Kingmax MARS , 800MHz, CL5
224.77 kn ADM
HDD Seagate 250GB, Serial ATA II, 7200 rpm, Barracuda 7200.10, ST3250310AS, 8MB cache, jamstvo : 60 mjeseci
338.35 kn ADM
DVD upisivač Liteon DH-20A4P-06C, 20x , DVD-Dual, black, ATAPI, bulk 161.41 kn ADM
Kuciste MS Apolo 400W 231.00 kn Dom Racunala
Konfa ce mozda biti kod mene 1tj ili 2god tak da ononije bitno
2,929.20 kn
Zadnje izmijenjeno od: McG. 31.03.2008. u 14:28. Razlog: Slomljen layout foruma.
Campeonato je offline   Reply With Quote
Staro 31.03.2008., 10:58   #2
Facelessone
Facelessone's Avatar
Postovi: 4,205
samo makni to kučište i napajanje i uzmi bar codegena, ili chiefteca/fortrona 350W + neko kučište.
AMD Ryzen 7 5700X
BQ Pure Rock
MSI B450 Tomahawk Max
500GB Crucial MX500
Fractal Define R4
Corsair HX850 Platinum
Logitech MX Master 3
Logitech MX Keys
Logitech Z2300
Dell U2715H
Iskon 300/100 Mbps
CPU Intel i7-4810MQ
VGA nVidia GT730M 1 GB
RAM DDR3 16 GB 1600 MHz
SSD 500 GB Sandisk Ultra
LTE Modem
DVD-RW
9 cell battery
Napajanje 135 W
Windows 10 Pro
Logitech MX Anywhere 3s
AMD Ryzen 5 7640HS
AMD RadeonT 760M
14" 2,8K, 120Hz
16GB RAM
1TB HDD
Windows 11 Pro
H110M-DGS
Intel i3-7100
8GB RAM DDR4
WD Red 8TB
WD Purple 4TB
Seagate IronWolf 3TB
Seagate SkyHawk 6TB
Nanoxia Deep Silence 4
Seasonic X650 SS-650KM Gold
Staro 31.03.2008., 11:07   #3
razor i2c
razor i2c's Avatar
Lokacija: Hercegovina
Postovi: 363
HDD Seagate 250GB, SATA II , Barracuda 7200.10, 16Mb,ST3250410AS-skuplji samo 30 kn a ima 16mb cachea,fortrona 350w-obavezno,ako ne želiš da ostaneš bez komponenti,kućište možeš ovo- Mode Com midi tower Harry, bez PSU, USB 2.0, audio, 92mm fan, 2×cd cover, crno, imaš ga u vemilu za 150 kn.
Sig 50 kb max :-)
razor i2c je offline   Reply With Quote
Staro 31.03.2008., 11:31   #4
Campeonato
Premuim
Campeonato's Avatar
Postovi: 1,748
sada u kompu imam to ms kuciste i napajanje i sve radi, 1950GT i Dual core
Mozda i ovo
Codegen midi tower M604n-CA, 400W PSU w/12cm fan, crno, USB, audio, mirror
HDD uyimam ovaj sa 16MB cachea
Staro 31.03.2008., 11:49   #5
razor i2c
razor i2c's Avatar
Postovi: 363
uzmi fortrona 350w nemoj da ti tamo neka codgen ili ms napajanja drže 3850.
Sig 50 kb max :-)
Staro 31.03.2008., 20:34   #6
Campeonato
Premuim
Campeonato's Avatar
Postovi: 1,748
Mozd i uzmem Fortrona 350 PNF. Kuciste Harry s njim. Pnf 200 kn + kuciste 150 = 350 knak uhvatim dodatnih 50 kn. Da li se s ovom 3850 dobije dvi na vga adapter posto imam vga monitor?
Staro 31.03.2008., 20:42   #7
Postovi: 34,077
Dobiješ. Još nešto - ne znam je li ta Gb grafa ona sa Zalmanom, a ako je, znaj da Gb na nju stavlja sporije memorijske čipove tako da će biti nešto sporije od ostale braće. Preporuke bi bile Sapphire ili Powercolor. Nikako Peak jer nema automatsku regulaciju venta na cooleru.
Staro 02.04.2008., 12:00   #8
Campeonato
Premuim
Campeonato's Avatar
Postovi: 1,748
Bili se razlika razlika u preformansama da uzmem GB 9600 gt, jer se puo prica o sporim memorijama na 3850 i 3870.
EDIT- Uzimam Fortrona PNF 350.
Staro 02.04.2008., 12:12   #9
razor i2c
razor i2c's Avatar
Postovi: 363
samo gigabyte stavlja sporije meme na 3850 i 3870 grafe kako bi cijena bila što jeftinija.dok drugi proizvođači to ne čine,ginward čak stavlja i brže memorije.9600 gt performansama je skoro indetična 3870 dok je brža u odnosu na 3850.moja preporuka- uzmi najeftiniju 9600gt ili 3870(sa što više garancije i sa što boljim hlađenjem).
Sig 50 kb max :-)
