Lokacija: Zagreb, Hrvatska
Postovi: 108
pomoć oko konfe
e sad frend mi kupuje novi komp pa ga zanima da li je ovo ok il bi bilo dobro nesto zamjeniiti. naravno do 4000kn MB Gigabyte MA69G-S3H, sAM2, AMD 690G, VGA, SATA II, GLAN, FW, ATX Gotovina/Kartice: 498,37 CPU AMD Athlon64 X2 5200+ BOX, dual core, SckAM2 Gotovina/Kartice: 738,90 HDD Seagate ST3160815AS, 160 GB 8MB, S-ATA300, 7200 Gotovina/Kartice: 338,11 2x DDR2 1GB PC6400 (800MHz), Kingmax 2x Gotovina/Kartice: 132,13 Gigabyte GF 8600GTS PCIE , 256MB, TV out, dual DVI Gotovina/Kartice: 949,22 Chieftec power supply 550W, EPS, ATX 2.0, 3×12V, Active PFC, AFC, 12cm fan, 2×SATA connectors Gotovina/Kartice: 505,00 Thermaltake VC2000BNS, mid tower Mambo, bez PS, crno, USB, audio, 1×120mm fan Gotovina/Kartice: 335,00 PS: opticke uredaje ima |
In the ghetto
Postovi: 1,943
mbo - Gigabyte P35-DS3, s775, intel P35+ICH9, FSB 1333/1066/800MHz cpu - Procesor Intel Core 2 Duo E4500 , 2.2GHz, socket 775, 2Mb cache ram - DDR2 1024Mb ( 1Gb ) PC5300 Kingmax MARS , 667MHz, CL5 x2 vga - Gigabyte GF9600GT 512Mb DDR3 256bit, DVI-I / D-sub / HDTV, DX10 hdd - HDD Seagate 250GB, SATA II , Barracuda 7200.10, 16Mb,ST3250410AS psu - Napajanje FORTRON 400W, PNF serija, PFC, Super Silent, 12cm vent cas - Coolermaster Centurion 534 lite , black , bez napajanja 3.880,01Kn sve iz www.adm.hr
te je a...
Lokacija: Duga Resa
Postovi: 598
CPU AMD Athlon64 X2 5000+ "Black Edition", dual core, SckAM2, imaš ga negdje i jeftinije pogledaj nabava.net, za grafiku bi ti preporučio Gigabyte Radeon HD 3870 512MB DDR3,256bit, DVI-I / D-sub, napajanje Napajanje 380W, SEASONIC 80 PLUS Series, S12II-380(380HB), bez problema goni tu konfiguraciju, kvalitetnije je i jeftinije! Zadnje izmijenjeno od: McG. 09.03.2008. u 16:29. |
Postovi: 108
evo napravio novu pa da vas cujem ![]() ![]() MB Gigabyte M56S-S3, sAM2, nVidia NF560, FW, GLAN, ATX Gotovina/Kartice: 462,44 CPU AMD Athlon64 X2 5000+ "Black Edition", dual core, SckAM2 Gotovina/Kartice: 762,03 HDD Seagate ST3160815AS, 160 GB 8MB, S-ATA300, 7200 Gotovina/Kartice: 338,11 2x DDR2 1GB PC6400 (800MHz), Kingmax 2x Gotovina/Kartice: 132,13 Gigabyte GF 9600GT, 512MB DDR3, TV-out, Dual DVI Gotovina/Kartice: 1.227,38 Chieftec power supply 550W, EPS, ATX 2.0, 3×12V, Active PFC, AFC, 12cm fan, 2×SATA connectors Gotovina/Kartice: 505,00 Thermaltake VC2000BNS, mid tower Mambo, bez PS, crno, USB, audio, 1×120mm fan Gotovina/Kartice: 335,00 |
Postovi: 7,568
