Postovi: 763
Ballistix Tracer RED 4GB KIT XS Review
![]() Are you ready to blow the hinges off your modules? Outfit your system with the new clipless, candy-apple red Ballistix™ Tracer™ modules from Crucial. Our highest density Ballistix module yet, the Ballistix Tracer Red modules feature 2GB of 800MHz DDR2 goodness. Add to it the bright red heat spreaders, red PCB, red LED lights, plus a raised and diamond-cut logo and clipless design—our Crucial Ballistix Red 2GB DDR2-800 module or 4FG kit delivers outstanding results for PC performance enthusiasts everywhere. For systems with dual-channel DDR2-based motherboards, Ballistix Tracer Red is ideal for users craving faster response time and improved reliability. It's a high-performance, low-latency memory option that's the perfect blend of sugar and spice—sweet looks on the outside, red-hot performance on the inside BL2KIT25664AR804 • Module Size: 4GB kit (2GBx2) • Package: Ballistix Tracer 240-pin DIMM (with LEDs) • Feature: DDR2 PC2-6400 • Specs: • DDR2 PC2-6400 4-4-4-12 • Unbuffered • NON-ECC • DDR2-800 • 2.2V • 256Meg x 64 http://www.xtremesystems.org/forums/...d.php?t=178953 Zadnje izmijenjeno od: stopalo9. 03.03.2008. u 20:16. |
Postovi: 7,504
mod:Mislim da slike više od 50kb idu u thumbnails ako se ne varam. |
Postovi: 763
kolko znam to se odnosi na fotke preko 100 kb no da te ne smeta to stavit cu thumb |
Adrenaline junkie
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Eh da, vidio sam ovaj review na XS-u prije neki dan. Kazem vidio sam jer ga nisam citao kompletnog, nego samo onako na preskog procitao sta me zanimalo. Nekako mi je cudno da onaj ko je testirao tu memoriju nije uzvukao vise od 575 (1150). Napon je bio 2,35 ako se ne varam i CL5. Da li ta memorija ne moze vise, ili onaj ko je testirao memoriju nije htio da da vise od 2,35V?
Lenovo ThinkPad W530 - Core i7 3840QM, 32 GB RAM, SSD Samsung 512 GB, nVidia Quadro K1000M 2 GB, 15.6" 1920x1080 IPS, baterija 9 ćelija |
Zanimljiva mema,u svakome slučaju.Dobro,dobro,to je samo jedan od prvih testova,trebati će pričekati još koje vrijeme & još koju kombinaciju sa MBO iz oba tabora...pa i pokoji primjerak još.Ma,biti će tu još štošta za reći glede ove meme...no,meni se već jako sviđa,dočim je gore crveni HS & LED,mene je već osvojila ... ![]() |
Lokacija: x
Postovi: 1,447
Bez obzira na manje clockove od 2x1GB, ovo izgleda mocno. Stvar odabira ce biti cijena kod nas. ![]() |
Adrenaline junkie
Postovi: 3,593
Lokacija: On HDD, Sector 12
Postovi: 357
Mogu se nekako pretrpiti te crvene ledice ali da li je bolja kupovina ovog rama od 4x1GB ballistixa PC6400? Koliko vidim XS je objavi dosta lijepe rezultate... |
#11 | |
3.14zda ®
Lokacija: Orahovica
Postovi: 8,320
teta Mraz
Lokacija: hr
Postovi: 1,596
covik otvorio temu a vi raspravljate o tome koje su boje HS-ovi i ledice na na ramima, ma sigurno ces kad ustekas memu cili dan drzad glavu u caseu i gledat ballistixe ![]() ![]() nego evo ja sam proteklih dana citao dosta testova 2*2Gb kitova boljih performansi, buduci da sam planirao kupnju jednog, i cini mi se da nekih velikih razlika nema, osim u cijeni, sve je manje vise slicno po pitanju OČ mogucnosti btw obicni 2*2GB kitovi bi tribali imat iste performanse ko i ovaj ne? eh da, sta se toce izgleda meni su ove crvene okay, nek se malo razbije monotonost, i tak se sad skoro svaki klinac u selu hvali sa bljestavim metalic zlatnim ballistixima koje je gonio na ijadutrista me`aherci
Postovi: 357
#16 |
Postovi: 357
Došli su mi 2x2GB ballistix tacer ali u crnoj varijanti. Najbolje što sam uspio a da je stabilno 100% je 1090Mhz 5-5-5-15 na 2.1V. Jedina mana ovih "novih" ballistixa ... i 2x2 i 2x1 kitovi imaju problema sa cl4. Jednostavno postanu totalno loši OC-eri. Dok ova starija varijanta sa chipovima na obadvije strane mogu komotno ici nekih 1000MHz na 4-4-4-12 ali su tražili i dosta vise napona i grijali su se ko ludi. Kako god ovi novi ballistixi su odlična kupnja za vožnju na vecoj frekvenciji ali CL5. A uz to malo se zagrijavaju. |
#17 | |
Lokacija: 'di me 'oće...
Postovi: 407
#18 |
Postovi: 357
700kn za 2x2gb kit |
