Staro 21.02.2008., 18:32   #1
why mee
Postovi: 6
Konfa 5K
VGA GC HD3870/512 X-TURBO, INFOTEK CORPORATION, Radeon HD3870 , PCIe x16, 512 MB, DDR4, 256-bit, Radni takt GPU 800 MHz, Takt memorije 2500 MHz, 2x DVI-I, 1x D-sub, HDTV da, Video izlaz S-Video, HDMI, 2560x1600, GC-XHD3870XTG4-E3
Intel Core 2 Duo processor E8200 LGA - 2.66GHz, 6MB, FSB 1333MHz, S.775, BOX
Seagate 160 GB, 7200.10 okr, 8MB S-ATAII
DDR2 2GB PC6400 (800MHz), Kingmax
DVD+RW/-RW Pioneer DVR-115D, Dual format drive, DVD+R DL (10x), DVD-R DL (10x), DVD+RW (8x), DVD+R (20x), DVD-RW (6x), DVD-R (20x), Access Time: DVD-ROM 130msec, DVD-RAM 210msec, CD-ROM 120msec, ATAPI, 2MB buffer, srebrni, bulk
MB Gigabyte P35-DS3R, s775, iP35, Core 2 Extreme Quad-Core/Core 2 Duo ready, FSB 1333/1066/800MHz, 8
Thermaltake VC2000BNS, mid tower Mambo, bez PS, crno, USB, audio, 1×120mm fan odozada, 4×5,25", 7×3,5", 430,30×200,20×502,20mm #17070
Corsair VX Series, 450 Watt, ATX, ATX DS+12V, PS/2, Power Supply, EU Version
el dobro ili treba kaj mjenjat?
why mee je offline   Reply With Quote
Staro 21.02.2008., 18:53   #2
elvis again
In the ghetto
elvis again's Avatar
Postovi: 1,943
Ja bi promjenil Hdd za samsunga istog kapaciteta (ako ce ti uopce 160GB bit dosta) ili seagate 250GB ...410AS model.
I kuciste nije bas najbolji izbor, mnogi ga zovu zmija otrovnica sa razlogom -> voli raskrvarit ljude svojim ostrim djelovima.
pogledaj tu:
http://forum.pcekspert.com/showthrea...t=85161&page=2
pa izaberi
AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor
elvis again je offline   Reply With Quote
Staro 21.02.2008., 19:22   #3
why mee
Postovi: 6
Ma komp mi treba za cod4,,,,tak da mislim da če mi HD bit dovoljno,,jer nemislim niti inst nikaj osim glavnih stvari niti skidat filmove,music horen itd.A kučište bum promjenil onda,,,nebi htel izgledat doslovno ko da sam bil u ratu
Staro 21.02.2008., 19:25   #4
elvis again
In the ghetto
Postovi: 1,943
Da samo uzmi samsunga 160GB jer je hladniji i tisi od seagate-a 160GB.
Staro 21.02.2008., 19:37   #5
why mee
Postovi: 6
Evoga Samsung 160 GB, 7200, 8 MB, SATAII i Thermaltake VB1000SWS, mid tower Soprano, bez PS, srebrno, metal i plastika, USB, Fire wire, po 1×120mm fan naprijed i odozada, 1×90mm fan sa strane, prozor, instalacija uređaja bez alata, filter za prašinu, nožice, 4×5,25", 7×3,5", 495×210×478mm (vך×d)
Pitanje:kolko bi vrtilo FPS u CoD4?250 lock?
Staro 21.02.2008., 20:03   #6
elvis again
In the ghetto
Postovi: 1,943
Ovaj uzmi jeftiniji je 50kn:
http://www.adm.hr/product_info.php?c...oducts_id=4659
FPS ovisi kolko velki monitor imas (tj. koju rezoluciju tjeras) i koje postavke u igri stavis a nesto malo i o kloku grafe i proca.
Staro 21.02.2008., 20:21   #7
why mee
Postovi: 6
btw,,el znaš možda kak se zove ovo kućište http://allyoucanupload.webshots.com/...10865030067540
hvala
Staro 21.02.2008., 20:28   #8
mislav_os
freak
Postovi: 2,688
Autor why mee Pregled postova
hvala
Ako mislis na plexi i vent itd.,da ima tako nesto kupiti,ne vjerujem..To mi izgleda kao moddano kuciste,da je zaprvao bilo neko "normalno"(bez plexija i venta)...A ne mogu reci koje je jer mu ne vidim prednji dio...
Staro 21.02.2008., 20:38   #9
elvis again
In the ghetto
Postovi: 1,943
Staro 21.02.2008., 22:06   #10
mislav_os
freak
Postovi: 2,688
Autor elvis again Pregled postova
Vidi fkt ima ga..
De idem si to odmah kupiti,ozbiljno...
Izgledalo mi predobro da bi bilo tvornicki napravljeno,bas izgleda kao da je moddan
Hehe
@why mee
Ispricavam se zbog nestrucnosti,sto nisam znao koji je to case
Staro 21.02.2008., 22:14   #11
why mee
Postovi: 6
@why mee
Ispricavam se zbog nestrucnosti,sto nisam znao koji je to case [/quote]
ma np
Staro 21.02.2008., 22:19   #12
why mee
Postovi: 6
fakat zgleda prejebeno,,,stavim neku ledicu u ovo kučište + ovo kaj bum kupil....nova zvjezda je rođena
Staro 21.02.2008., 22:21   #13
elvis again
In the ghetto
Postovi: 1,943
Ja mislim da vec imaj jedan led 120 vent unutra ali na prednjoj strani.
Staro 21.02.2008., 23:41   #14
mislav_os
freak
Postovi: 2,688
Ako budes imao srece,mozda dobijes i na ispuhu ...Jer po cijeni i marki kucista,rekao bih da se dobiju bar 2
Staro 21.02.2008., 23:47   #15
elvis again
In the ghetto
Postovi: 1,943
Sve skupa dobis 3 120 venta
