11.02.2008., 23:21 | #1 |
Datum registracije: Jun 2004
Lokacija: split i zagreb
Postovi: 490
HDD otvara search
Kad iden otvorit "dvoklik mišom" C: ili D: particiju mi se otvara search opcija toga diska. kako da to vratin na default da mi prikaze sta ima na disku.
CPU: E6400 & termaltake ST RAM: 2x1Gb DDR2 super talent 800-CL4 MB: D975XBX2 GRAF: ASUS 8800GT; Dell 2407 wfp-hc HDD:WD raptor 74Gb (10000rpm) & HITACHI Sata II 250Gb(7200 rpm) CASE: chieftec dragon big black;Corsair HX 520W AUDIO: X-Fi Xstreme Music; Logitech 5.1 Z-5500 THX |
12.02.2008., 00:34 | #2 |
N00B
Postovi: 3,886
Jesi provao ovako Start>Run>Regedit>OK i nadi ovaj registry key:HKEY_CLASSES_ROOT\Directory\shell>default>modify>value data:"none" ovako treba biti postavljeno na "none"..Ili ako ne ide to mozes ovo dolje pogledat "If you are also experiencing this problem when you try to click on a drive, you can run this command from the run box or command prompt:"regsvr32 /i shell32.dll" (bez navodnika) |
12.02.2008., 00:53 | #3 |
Postovi: 490
Thx. Napravija san System Restore. Iman jos par ljudi koji imaju isti prob pa cu to probat kod njih.
