Staro 08.02.2008., 23:41   #1
hiroshi
Lokacija: Virovitica
Postovi: 5
napajanja, dvoumica
ovako neznam koje da napajanje odaberem kazu da je za moju konfiguraciju dovoljno 350w ali neka se nađe
pa mi pomozite
Chieftec power supply 450W, ATX 2.0, 2×12V, Active PFC, AFC, 12cm fan, 2×SATA connectors
Power Supply FORTRON 400W, HQ, PFC, 2 x 12V, 12cm fan
Power Supply FORTRON BlueStorm 400W, HQ, PFC, 2x12V, 12cm fan
racunajte sa time da cu stavit 2 ili 3 chase fan sa diodom
i cpu cooler thermaltake blue orb
edit: konfa
+CPU AMD Athlon64 X2 5200+ BOX, dual core, SckAM2
+MB Gigabyte M57SLI-S4, sAM2, nForce 570-SLI, SATA, FW, GLAN
-**HDD HITACHI HDT722516DLA380 160GB SATA300 7200rpm 8MB
+DDR2 1GB PC6400 (800MHz), Kingmax x 2
+DVD+RW/-RW Pioneer DVR-115DBK, Dual Layer, 20x, black, bulk
PEAK Radeon HD3870, 512MB DDR4, TV-out, Dual DVI
Thermaltake VD6000BNS mid tower Soprano VX, bez PS, crno, USB, Fire wire, 1×120mm fan
hiroshi je offline   Reply With Quote
Staro 08.02.2008., 23:45   #2
elvis again
In the ghetto
elvis again's Avatar
Postovi: 1,943
Jos kad bi i napisal koju kofu imas, to bi bilo jako lepo od tebe?
Fortron 350W PNF pretpostavljam da ce bit dosta.
AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor
elvis again je offline   Reply With Quote
Staro 08.02.2008., 23:46   #3
2 die 4
2 die 4's Avatar
Postovi: 2,241
corsair vx 450w,
pogledaj MOJ KOMP i uzmi u obzir da imam u njemu 4x120mm case fan-s sa diodama, svi na def naponu, tako da nema dvoumljenja!
RedGreenBlue
2 die 4 je online   Reply With Quote
Staro 08.02.2008., 23:55   #4
luki123
_HZTK_
luki123's Avatar
Lokacija: Zagreb/Dubrovnik
Postovi: 616
350 PNF ti je dovoljno
luki123 je offline   Reply With Quote
Staro 09.02.2008., 00:39   #5
hiroshi
Postovi: 5
dali ta napajanja imaju 2x PC expres
jednom cu valjd stavit jos jednu graficku
Staro 09.02.2008., 08:12   #6
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Ne neka od tih napajanje nemaju niti jedan PCI-e a kamoli dva, dva PCI-e ti imaju samo SLI certified pauovi ti su ti u pravilu preko 600kn a Corsair VX od 450 ima 1 ali može voziti SLI preko molex to PCI-e adaptera, mogli bi naravno i ovi gore napbrojani - vjerojatno...
Have a nice day...
Staro 09.02.2008., 08:28   #7
Postovi: 33,927
Autor hiroshi Pregled postova
Tvoja je ploča SLI što znači da na nju NE mogu 2 ATI grafe. 350W PNF ti je dovoljan, ali možeš uzeti i 400W. Blue Storm ti je slabiji i od 350W PNF-a tako da bi ga ja izbacio iz kombinacije.
Staro 09.02.2008., 11:24   #8
Razer
Razer's Avatar
Postovi: 11,642
Ovakve teme treba početi lockati.
