Povratak   PC Ekspert Forum > Računala > Periferija > Ostalo
Staro 05.02.2008., 17:43   #1
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
Projektor=grafoskop+LCD matrica; iskustva!?
Zanima me ima li tko iskustva sa izradom projektora od grafoskopa i LCD matrice 15" monitora?
Ovdje je opisan postupak.
Relativno je jednostavno za izvesti. Osim toga u startu je mnogo jeftinije od kupovanja projektora (800-1000kn po mojoj prosudbi). Narocito zarulje za grafoskop koje su 100ak kuna, a one projektora par k kuna.
Osim toga, ovisno o rezoluciji monitora moze se dobit i do 1280*1024. Takvi projektori su jos uvijek skupi.
Jel itko probao slozit to?
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline   Reply With Quote
Staro 06.02.2008., 13:20   #2
johnsmith
Lokacija: vž
Postovi: 1,337
imal sam negde link, tip neki iz hr slozil. Enivej, ja sam hitil to sve na papir i dosel do zakljucka da se ne isplati. Napomena da nisam imal NIS, znaci grafoskop cca 1250kn, lcd neki 800, 400w lampa s balastom (morti bi islo s ovom kaj ima u grafoskopu al lik je hitil tu 400w) jos nekih 1000kn i em je velko em je tesko, i plus, htel sam widescreen a ne znam dal bi 15 ili 17" stal na grafoskop. Tak da sam radije hitil 4,5k za benq w100 projektor i uzivam. Lampa je 1250kn, a dura 3k odn 4k sati. Obavezno provjeri kolko lampe traju, jer negde pokupil informaciju da grafoskop obicne lampe traju cca 50sati, a komad je po 60kn pa onda ova moja lampa od 1,25k ispada bagatela. Nej me krivo shvatit, al velim, meni je ispalo neisplativo.
Staro 06.02.2008., 13:33   #3
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Autor dajdroge Pregled postova
Da, ako kupujes novi lcd i grafoskop.
Vidim rabljeni grafoskop u oglasniku za 400kn. 15" lcd isto za 400kn.
WS 15" ne stane sigurno jer je obicni 15" na knap. Ali to ionak nije vazno. Udaljis grafoskop 1m vise od zida i imas 1m vecu dijagonalu koja ti nadoknadi tu razliku u WS.
Ne vjerujem da zarulja grafoskopa traje samo 50h, a ovi sa linka kazu da je i 350W dovoljno. Ja bih osobno radije to sam slozio, no samo kad bi znao da bi bilo gledljivo. Da ne utrosim vrijeme bez veze. Zato sam i pitao ovdje.
BTW, kak si zadovoljan sa w100? Npr. sa filmovima?
Nisam nikad gledao film na tome. Samo prezentacije.
Jel glasan? Mora li biti maksimalno zamracena prostorija?
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 06.02.2008., 13:43   #4
johnsmith
Lokacija: vž
Postovi: 1,337
Autor estugarda Pregled postova
LOL nije +1m udaljenosti +1m slika Ja picim s nekih 4.5-5m i imam negde 3metra, morti 3.5 dijagonalu, samo za usporedbu. A 16:9 na 4:3 je greh jer imas te proklete crne trake kojih sam se dosta nagledal na 4:3 monitoru. 16:10 na projektoru i laptopu je godsend.
Gledam uglavnom xvid i to zgleda ok, teram ga na 848x480, to mu toboze native. Glasan? Paa neki bi rekli da je, al dok gledas film, zvuk to pokrije bez problema. Prostorija ne mora biti full mracna, al buduci da je 1300 ANSI na papiru, direktna sunceva svjetlost je malo bed. Oblacno ili rolete spustene da sunce ne upada je ok. Kolko vidim, ti WS projektori su toboze slabi kaj se ANSI tice jer je slika sira (zvuci malo lol al mislim da se tak pricalo)
evo ak se os divit :P http://youtube.com/watch?v=kc4_9FnAusI
Staro 07.02.2008., 01:08   #5
Imagine
undercover
Imagine's Avatar
Lokacija: u raljama ovisnosti
Postovi: 1,407
estugarda ,
nisam baš razmišljao puno o takvim kemijama ali kad sad idem pogledat neke stvari....
s tom kemijom bi kao i s svim LCD projektorima imao prednost oslobođenosti 'efekta duge' što ti može npr zagorčat gledanje pokretnnih slika do krajnih granica.
Meni osobno nema šanse da bilo kakva vidljivo bolja crna od DLPa nadoknadi patnju s tim efektom ...no pošto je to uvelike subjektivni dozivljaj svakako bi bilo dobro da se uvališ na kakvu prezentaciju.
Stvar nije strašna no moj mozak lakše trpi i lakše se navikao na STALNO gledanje u 'mrežastu sliku' i lošije boje LCDa nego POVREMENO raspadanje slike boljih mekših boja kod DLPa a koliko sam imao prilike primjetit tu nije toliko važan pokret na ekranu koliko je važan pokret tvog oka jer bilo koju veču sliku nemoš odjednom obuhvatit pogledom te bar ja letim očima "all over the place"
druga prednost koja mi pada na pamet od te kemije je veličina samog LCD ekrana i strmina propadanja matrice pošto je fizički veča i sigurno nije toliko zahebana za ohladit poput nekog kupljenog LCDa a s tim/zbog tog ide sigurno i veča tišina...
treča prednost je onaj filing da si sam nešto sklopio
a negativna strana je što je to ipak kemija
if you build it they will come
Imagine je offline   Reply With Quote
Staro 07.02.2008., 09:40   #6
Perki
Lokacija: VG
Postovi: 775
Mene ovo puca već neko vrijeme, al' nikako da se primim posla. Spremam se 'ko gladni srat. Uvijek nešto..
Anyway, u odnosu na kupljene LCD projektore, izgleda i više nego isplativo. Nije to neka teška kemija, tehnologija je krajnje jednostavna, jedina mana je veličina. Fora je u tome da se ne kupuje grafoskop kao takav, nego se od njega posudi ideja. Dakle, samo izvor svjetla, fresnel i projekcijska leća. Evo, kod ovih se to da nabaviti za nevelike novce, a namijenjeno je upravo u tu svrhu :
https://secure.lumenlab.com/estore/home.php?cat=253
Lampa i pribor se može i kod nas nabavit.
Evo još par linkića:
http://www.diyprojectorcompany.com/
http://www.corax.hr/projektor/index2.htm
Najnezgodnija stvar u svemu tome je odabir LCD-a pogodnog za raskapanje. Naime, neki se uopće nedaju lijepo rasklopit, dok kod nekih bi pojedini dijelovi elektronike mogli smetat pri konstrukciji. Evo jedna baza monitora koja bi trebala olakšat izbor :
http://www.baseportal.com/cgi-bin/ba...&localparams=1
Trust me - I know what I'm doing!
Perki je offline   Reply With Quote
Staro 07.02.2008., 13:17   #7
johnsmith
Lokacija: vž
Postovi: 1,337
Bilo bi doro pogledat kolki je kontrast na lcdu prije kupovine, jer ovi stariji, mislim da jedva 1000:1 imaju, a to je tak. Moj projektor recimo ima 2500:1 a to je entry level.
@imagine: ak sam doro shvatil velis da je grafoskop verzija bolja jer se ne grije lcd? moguce, al kod projektora se hladi lampa a ne matrica A kaj se rainbow-a tice, ja imam 4x brzinu 7 segmenti colorwheel (moj benq je DLP jel), i usudil bi se reci da nisam ni jednu dugu videl.
Staro 14.02.2008., 13:14   #8
Imagine
undercover
Imagine's Avatar
Postovi: 1,407
i zbog čega onda propadanje matrice s vremenom ? hladne svjetlosti ?
a za duge....blago tebi
koliko mi se god sviđala ta razina crne npr. inFocusa IN 72 moja draga ni ja nismo mogli to gledat. Znam mozak bi se trebao naviknut ali...
inače zanimljiva stvar je da sam manje primječivao taj efekt s npr. InFokusom IN72 nego s skupljim Optoma HD70 koji je ako se dobro sječam imao isto 4x7 segmentni 'kotačič' za razliku od inFocusa sa 6 segmentnim gdje je mislim nedostajao bijeli dio.
a opčenito - prvotno sam bacio oko na Benq PE 7700 ali tu mi je bilo previše ona zbrka sa firmireom i preranim krepavanjem lampi ....a u toj nekoj klasi jeftinijih DLPa meni je W100 bio zanimljiv čisto iz cjene lampi i 1000h sati dužeg rada iste no nekakvi problemi s DVI/HDCP i prejake ,zasičene boje , ton koji baca na plavo / hladno te nemogučnost zasebnog namještanja tih boja su mi okrenuli pogled na IN72 koji je nosio opčenito bolju sliku (zbog DC2) i neusporedivo bolji dizajn no tu mi je opet išao na živce onaj njihov M1 konektor....
btw, ne shvati me krivo kao JA protiv DLPa....Ja sam prije chichen wire / SDE ,te propadanje matrice smatrao največim zlom i oduševljavao se crnom DLPa no na kraju sam napravio preokret i završio s LCDom.
