Staro 04.02.2008., 22:21   #1
exstacy
Lokacija: KUCA
Postovi: 30
Windows Vista corupted file
Poz
Ovako imam na kompjuteru instaliran windows XP i windows vistu ultimate...I sad palim comp i kad idem pokrenit vistu javlja mi error ovaj:
Windows failed to start. A recent hardware or software change might be the cause.
To fix problem:
1. Insert your windows instalation disk and restart your computer.
2. Choose yourlanguage settings and click next
3. Click "reapir your computer"
File: \Windows\system32\config\system
Info: Windows faild to load because the system registry file is missing or corrupt!
E sad...ja sam stavio CD od viste ultimate i stavim u biosu da se prvo loda CD rom...Restartam comp i ponovo mi dode ovaj eror...znaci ne loda mi cd:S?
Mogu li ja pokreniti Windows XP i preko njega sa cdom od viste popraviti nekako taj corupted file?Ili sto da uradim kako bi to popravio!
Hvala puno!
exstacy je offline   Reply With Quote
Staro 05.02.2008., 07:15   #2
sipe
sipe's Avatar
Postovi: 993
Samo digneš vistu nekako s dvd-a i imaš startup repair sve sredi za minutu
sipe je offline   Reply With Quote
