Staro 04.02.2008., 01:38   #181
von Schultz
Postovi: 494
Ja ga mislim rezervirati sutra, pa kud puklo puklo...
von Schultz je offline   Reply With Quote
Staro 04.02.2008., 01:47   #182
estugarda
"Samo vodu ne!"
estugarda's Avatar
Lokacija: ZG istok > Legrad
Postovi: 1,744
A može se rezervirati?
Meni su rekli u Mikronisu da se ne može.
It just works. Except when it doesn't.
CPU: AMD Ryzen9 7950X3D @ stock + AC Liquid Freezer II 360
MBO: Asus ProArt X670E-Creator WiFi
RAM: 4x32GB DDR5 G.Skill Trident Z5 Neo 6000
GPU1: NVIDIA GeForce RTX 4090 MSI Suprim Liquid X
GPU2: NVIDIA RTX A4000 custom cooled
SSD1: Samsung 990 PRO 2TB m.2 NVMe
SSD2: Samsung 970 EVO 4TB
PSU: Seasonic Prime GX-1300
CASE: Fractal Design Meshify 2 XL
Display: Asus Proart PA329CRV + 2x Dell 2715h
Audio: Asus Xonar U7 MK2 + Logitech X-530 5.1
Input: Ducky One 3 Classic RGB + Logitech MX Master 3
OS: Windows 11 Pro x64
HP Zbook 17 G6
CPU: i7-9850H @ 2.60GHz
RAM: 4x16GB DDR4 2400
GPU: NVIDIA Quadro RTX 4000
SSD: 512GB NVME SSD
Audio: Fiio Q1 DAC + AudioTechnica M50x
OS: Windows 10 Pro x64
CPU: AMD Ryzen Threadripper 2950X @ stock + Noctua NH-U12S
MBO: Gigabyte X399 Aorus Pro
RAM: 4x16GB DDR4 Corsair Vengance LPX 3200
GPU: NVIDIA GeForce RTX 1080 Ti 11GB
SSD: Samsung Evo Plus 500 m.2 NVMe
HDD: Toshiba 3TB
PSU: Corsair CX650M
CASE: Fractal Design Meshify C
Display: LG IPS231P
Audio: OnBoard + display speakers
Input: Microsoft Natural Keyboard + Logitech G602
CPU: AMD Ryzen 4350G @2.8GHz + AMD stock cooler
MBO: ASrock B550m Phantom Gaming
RAM: GSkill 2x8GB DDR4 3600MHz
GPU: AMD Vega 6
SSD: Samsung Evo Plus M.2 NVME 250GB
PSU: Seasonic 620W
CASE: Fractal Core 2300
Display: 32" LCD TV + BENQ W1070 DLP projector
Sound: Yamaha RX481 + ELAC Cinema 5.1
Input: Logitech vulgaris
CPU: AMD Athlon X2 5050e @0.8-2.6GHz + AC Freezer 64 Pro PWM
MBO: Gigabyte GA-M720-US3
RAM: Kingmax 2x2GB DDR2 800MHz
GPU: Gigabyte GeForce 8600 GTS SP
HDD: Seagate 7200.10 250GB single platter (Speedy Gonzales)
PSU: Chieftec 400W
CASE: Frontier generic
Display: 22" LCD AOC 2230Hf + ACER X1160 DLP projector
Sound: Logitech S-220 2.1
OS: Windows 8.1 PRO x64
2017: FX-8370E, ASRock 990FX Extreme3, nVidia GTX970, Windows 10 x64
2016: FX-8320E, Asus M5A97 PRO, nVidia GTX970, Windows 10 x64
2015: i7 6700k, Asus Z170-A, nVidia 750Ti 4GB, Windows 7 x64
2014: FX-8350, ASRock 990FX Extreme3, nVidia GTX660, Windows 8.1 x64
2012: i7 3610QM, Asus N76VZ, nVidia GT650M, Windows 7 x64
2011: AMD Athlon II X4 640, Gigabyte MA770-UD3, nVidia 9600GS, Windows 7 x64
2010: AMD Phenom II X6 1090T, Thuban, ASrock 880G Extreme3, nVidia GTX260, Windows 7 x64
2010: AMD Phenom II X4 Deneb 945, Gigabyte 790X-DS4, nVidia 8800GTS Ultra 320bit, Windows 7 x64
2009: Intel C2Q Q6600, GIGABYTE EP31, nVidia 8600GS, Windows 7 x64
2008: AMD Athlon X2 Winsdor 5600+ AM2, MSI K9N Neo V3, Gigabyte 790x, nVidia 8600GS, Windows Vista x64
2008: Intel Core2Duo T7200, Toshiba A100-847, nVidia 7600 Go, Windows Vista x64
2007: AMD Athlon X2 4600+ Manchester S939, ASUS A8n32-SLI Deluxe, nVidia 7600GT, Windows Vista x64
2005: AMD Athlon 64 3200+ Venice S939, Asus A8V Deluxe, ATI Radeon X700 PRO, Windows XP x64
2003: AMD Athlon XP 2400+ Thoroughbred, Matsonic MS8137C, Matrox G450, Windows XP
2003: Intel Pentium III Mobile 1000 Tualatin, Compaq Evo N110, ATI RAGE LT Pro, Windows 2000
2002: AMD Duron 1200, Matsonic MS8127C, Matrox G450, Windows XP
2001: AMD Duron 750, Matsonic MS8127C, Matrox G400 DH, SB PCI 128, Windows98,
1998: Intel Pentium II 300 Klamath, Matrox G200, SB AWE64, Windows98
1996: Intel Pentium 120, Matrox Millenium, SB AWE32, Windows95
1993: Intel i386SXSA 40MHz(turbo)
1991: Intel 286 @20Mhz
estugarda je offline   Reply With Quote
Staro 04.02.2008., 03:53   #183
von Schultz
Postovi: 494
Hm budem nazvao pa vidio
ili nas čeka kampiranje u četvrtak 14tog preko noći da dočekamo petak ujutro hehe
Staro 04.02.2008., 09:19   #184
Alex21
Postovi: 13
Kao što se moglo očekivati,
Lenovo je bio prvi s 22'' ne-TN panelom, no i drugi su se izgleda malo trgnuli...
Samsung ima novi 22'' panel koji nije TN:
http://www.tftcentral.co.uk/news_arc...samsung_panels
Kad će netko i monitor s tim panelom napravit, treba vidjet... no u svakom slučaju, dobra vijest.
Edit: tek sad vidjeh vjest niže na istom linku... još jedan ne-TN: Eizo CG222W.
Doduše, taj će vjerojatno biti papreniji po pitanju cijene, al eto... nek se zna.
ASUS P5Q-E p45
Intel Core2Duo E8500
ATI Radeon 4870
2 x 2GB DDR2-1600
Seagate 500GB/32MB SATA
Audigy 2ZS
Terratec Cinergy 400TV
Chieftec 550W
Alex21 je offline   Reply With Quote
Staro 04.02.2008., 09:19   #185
The AC
The AC's Avatar
Postovi: 1,156
Autor Catalyst Group Pregled postova
ko star wars fanovi kad je novi film u kinima!
ponesite šator, ja ću uzet ćevape i roštilj.
Staro 04.02.2008., 10:29   #186
gnomisa
gnomisa's Avatar
Datum registracije: Feb 2003
Postovi: 1,556
Autor Alex21 Pregled postova
e moj Aco
http://forum.pcekspert.com/showthread.php?t=96964
gnomisa je offline   Reply With Quote
Staro 04.02.2008., 17:16   #187
The AC
The AC's Avatar
Postovi: 1,156
Autor gnomisa Pregled postova
the point?
Staro 04.02.2008., 17:31   #188
p3tar
Mozilla Slave
p3tar's Avatar
Lokacija: Daruvar
Postovi: 494
Autor The AC Pregled postova
the point?
Već je vijest koju je Alex postao, gnomisa postao nedavno pod nazivom threda "Konačno - Samsung 22" S-PVA 1680x1050p". Samo malo prelistati forum...
p3tar je offline   Reply With Quote
Staro 04.02.2008., 18:33   #189
The AC
The AC's Avatar
Postovi: 1,156
Autor p3tar Pregled postova
pa znam, ali trebao je qoutati alexa onda!
enivej,necemo offtopic!
Staro 04.02.2008., 19:07   #190
Terminator02
Terminator02's Avatar
Postovi: 602
he he, vjerovao ili ne panel koji se ugrađuje u Lenovo proizvodi Samsung!
Terminator02 je offline   Reply With Quote
Staro 04.02.2008., 20:12   #191
p3tar
Mozilla Slave
p3tar's Avatar
Lokacija: Daruvar
Postovi: 494
vidim da si novi...no koga je to onda gnomisa quotao ako ne Alexa21? Neda mi se sad Screenshot raditi ali pogledaj malo bolje, možda te je zbunilo što ga je preimenovao u aco.
I ja se slažem dosta .
Zadnje izmijenjeno od: p3tar. 04.02.2008. u 20:24.
Staro 04.02.2008., 21:07   #192
The AC
The AC's Avatar
Postovi: 1,156
ma sad sam i ja uvidio vlastitu gresku, forum uzasno steka pa sam se sje...! my bad!
Staro 05.02.2008., 12:45   #193
Alex21
Postovi: 13
A šta se može...
Aco reciklira vjesti... moj bed.
ASUS P5Q-E p45
ATI Radeon 4870
2 x 2GB DDR2-1600
Audigy 2ZS
Chieftec 550W
Staro 06.02.2008., 04:17   #194
von Schultz
Postovi: 494
E sad sam čitao sve ovo o 1:1 pixel mappingu itd...
no moram priznati da nisam posve shvaito o čemu se radi...
npr ja gledam običan, non HD, DVD... hoće li mi film izgledati lošije ako manju rezu snimke rastegnem preko cijelog ekrana u nativnoj rezi monitora?
Što je sa igrama...?
Staro 06.02.2008., 09:09   #195
...Tihomir...
...Tihomir...'s Avatar
Postovi: 350
Evo da se i ja uključim. Pratim ovu temu od početka te usput pretražujem net za novim podacima o ovom monitoru.
Na Lenovo forumu je izašlo zanimljivo pitanje pa pogledajte:
"Hi!
From the partnumbers I understand that there exists localised versions of the L220X, e.g. T33HBUK, T33HBIT and T33HBDK for the United Kingdom, Italy and Denmark. Then I discovered there's also a T33HN-variant (e.g. T33HNDK) which is cheaper than the T33HB-variant. On the surface it seems that the B and N variants are exactly the same, except the N-variant is a "TFT Hybrid". Does anyone have a clue as to what that's about?
Just to illustrate the above, have a look at this site (scroll to the bottom of the list):
http://www.cheritononline.co.uk/sect...Sec=51&xPage=2
L220X T33HNUK - £270 (ex. VAT)
L220X T33HBUK - £394 (ex. VAT)
Can anyone tell me where the difference between the N- and B-variant lies?"
E sad zašto takva razlika u cijeni a u opisu nema razlike?
Pozdrav!
...Tihomir... je offline   Reply With Quote
Staro 06.02.2008., 15:28   #196
marq20
marq20's Avatar
Postovi: 620
čudi me da još nitko nije ništa napisao o testu koji je napravio PCEks.
http://www.pcekspert.com/articles/549.html
marq20 je offline   Reply With Quote
Staro 06.02.2008., 15:32   #197
gunther
Postovi: 1,369
Paaaa....
Cini mi se definitivno kupnja bez konkurencije u klasi od 22 incha
AMD Ryzen 5900X; Gigabyte Aorus X570 Elite; Corsair Vengeance RGB Pro SL DDR4 2X16 Gb 3600 Mhz; AMD Radeon Gigabyte 7900 XTX; SSD Patriot Viper VP4300 PCIe m.2 GEN4 2 Tb;Lian Li 011 Dynamic EVO; LG C2
gunther je offline   Reply With Quote
Staro 06.02.2008., 15:32   #198
krešo
Administrator
krešo's Avatar
Datum registracije: Sep 2002
Lokacija: PCE Lab
Postovi: 3,982
Autor ...Tihomir... Pregled postova
Ovo je jako zanimljiva informacija. Inače nama je na testu bio 4433-HB2 monitor. Dakle ovaj skuplji.
krešo je offline   Reply With Quote
Staro 06.02.2008., 15:47   #199
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
4433-HB2!?
Sto je sad to!?
Ovo postaje sumnjivo.
Mikronis navodi T33H-N-EU, sto je valjda ekvivalent T33H-N-UK, tj. ova jeftinija varijanta. A sto sad znaci 4433-HB2!?
Pa nije valjda da ce i sa tim biti lutrija za Hrvate!?
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
Staro 06.02.2008., 15:47   #200
Munjara
Beerman
Munjara's Avatar
Postovi: 1,527
Autor gunther Pregled postova
Paaaa....
kao grand prix za ljude kojima trebaju njegove karakteristike definitivno
No za većinu je neopravdano i nepotrebno dati 50% novaca više od jednog ok 22'' tn monitora.
Munjara je offline   Reply With Quote
Staro 06.02.2008., 15:52   #201
Postovi: 34,075
Kakva je ono utičnica između D-Suba i 2 usb-a s doljnje strane monitora? Mene podsjeća na usb za printere.
Staro 06.02.2008., 15:59   #202
Munjara
Beerman
Munjara's Avatar
Postovi: 1,527
Autor coconut Pregled postova
reče čovjek usb pa da se ispravim
Zadnje izmijenjeno od: Munjara. 06.02.2008. u 16:24.
Staro 06.02.2008., 16:17   #203
Gabre
Lika u mom srcu
Gabre's Avatar
Lokacija: Canada, Toronto
Postovi: 9,887
isto USB utikač, pošto monitor morate spojit preko USB kabla na komp... jel..
da bi dobili funkcionalnost USB-ova koji su na monitoru.. jedino što su koristili drukčiji konektor, da, kao na printerima...
Staro 06.02.2008., 16:21   #204
jurbAs
jurbAs's Avatar
Postovi: 2,583
Autor Munjara Pregled postova
cekaj samo malo jedan TN samsung kosta oko 2400kn tj 2500kn ako se ne varam a ovo je 700kn skuplji monitor sa duplo boljom slikom i kvalitetom... mislim da tu nemam sto komentirat jedini koji je 2000kn je LG i to je to gledano u ve-mil-u i neki phillips eto... i sad vi meni recite jel bolje dat 500kn vise za duplo bolje performanse?! mislim da ce se taj lenovo prodavat ko lud! PC-ekspert strani web bug preporuka pa nemogu svi biti toliko potplaceni!!!! eto ako ih vise kaze da valja onda sigurno valja!
Staro 06.02.2008., 16:27   #205
Munjara
Beerman
Munjara's Avatar
Postovi: 1,527
Autor jurbAs Pregled postova
2200kn philips kojeg imam
3200 lenovo
zadovoljava li me philips? zadovoljava
je li za meni lenovova naprednost toliko bolja i potrebna da platim 1000kn više?
Apsolutno nije.
Da će se prodavati jako dobro to vjerujem.
Ali isto tako mnogi će dati nepotrebno više novaca za ono što im ne treba.
Ne osporavam ja kvalitetu lenova, već komentiram kako ga smatraju svetim gralom uglavnom ljudi kojima nista vise od tna nije potrebno.
Tamo gdje je razlika parsto kuna, kupovina Lenova je opravdana, ali već 1000 kao u mom slučaju...
Staro 06.02.2008., 16:59   #206
krešo
Administrator
krešo's Avatar
Lokacija: PCE Lab
Postovi: 3,982
Autor estugarda Pregled postova
to je Lenovov machine type...
Staro 06.02.2008., 17:03   #207
gnomisa
gnomisa's Avatar
Postovi: 1,556
reci to gamerima (1920 reza)...doduše ovisi od slučaja do slučaja...ja npr. još dugo ne mislim igrati DX10 igre (ili pak iste u dx10 modu) a testovi su pokazali da su u dx9 i opengl-u razlike svega 3-6 FPS-a između 1680 i 1920 reze (na max. detaljima sa isključenim AA i AF koji ionak ne igraju neku ulogu na 1920).....dakle jedna 8800GT bu sasvim dobro gurala na toj rezi a btw, ja još nisam niti jednu igru odigrao bez redukcije detalja (nisam nikad kupovao najjače kartice)...mlađi gameri su možda malo više "razmaženi" glede detalja...
btw, evo kratki prilog o monitoru iz emisije Novi Milenij:
http://www.youtube.com/watch?v=q-_9Ke2wBqg
ja nestrpljivo čekam recenziju prvih vlasnika....koliko će biti igrivo na toj rezi sa jednom od jačih kartica...
Staro 06.02.2008., 17:16   #208
Micko
Peachwize=mudra breskva
Micko's Avatar
Lokacija: Ri
Postovi: 210
ee meni bi sad sjeo ovakav monitor kao budali šamar..u biti bilo koji 22",24"...ajde nadam se da će bit puuno mini testova na forumu.Bit će se lakše za odlučit.
Micko je offline   Reply With Quote
Staro 06.02.2008., 17:20   #209
jurbAs
jurbAs's Avatar
Postovi: 2,583
ja se igram na toj rezi izmedu 1680 i 1920 je stvarno mala razlika u FPS-ovima i u dx 10 igrama ..... po pitanju detalja malo smanjis i cist okey je.... mislim da novije grafe mogu to poterat bez problema pogotvo ove novije koje izlaze.... imas uvijek par igrica koje ne rade kako treba..... kao npr crysis... itd... ono sto mi je stekalo na 19'' monitoru steka mi i sada...... na toj rezi... COD4 radi kako treba itd... eto..
@munjara pitanje je nesto drugo zasto da se netko zadovolji losijom kvalitetom ako si moze priustiti bolju? sveti gral nije ali da nije korak naprjed i dovodenja reda na trzistu 22'' sigurno da je! jer 2500kn za jednog samia koji je los i koji ne vrjedi te pare mislim da obojca se slazemo da im treba cijena past sto se ocekuje da ce lenovo napravit!
Staro 06.02.2008., 18:33   #210
estugarda
"Samo vodu ne!"
estugarda's Avatar
Postovi: 1,744
Autor krešo Pregled postova
A machine type je...?
Otkud vama taj 4433-HB2 L220X, ako se smije znati?
HP Zbook 17 G6
SSD: 512GB NVME SSD
HDD: Toshiba 3TB
PSU: Corsair CX650M
Display: LG IPS231P
GPU: AMD Vega 6
PSU: Seasonic 620W
PSU: Chieftec 400W
