Staro 05.01.2008., 23:14   #1
axeafrika
Postovi: 43
Angry čodan prob. samo crkne....
kanta... nemože se upalit, crkla...
evo moj post sa techarpa:
Autor EVIL_SoMEoNE Pregled postova
am i cursed or something?
again i have a problem.... i don't know whats wrong so i put it in the mother of all forums
ok so ive had this problem since i cleeaned my cpu cooler.
after i cleaned it, whenever i play some game it would just shut down after a minute or two.
i thought it was some cooling issue so i cleaned every single cooler on my motherboard and today ive replaced thermal paste thing(that gum-like thing) ive turned on my pc
and i realised that i forgot to plug in the ps2/usb power pin. i turned it off, plugged in and when i try to boot windows it just crashes, dies...
i have to unplug my power supply to be able to turn it on again(if i dont i get black screen and it shuts down in few seconds)
then when i get to choose which os to boot(both are the same but one has custom boot-screen)
usually there it crashes, if not then even earlier
i have checked entire system if it has dust or anything but its clean like new
tried to boot. another failure.
then i was looking around my mobo and saw the speaker pin. ive plugged it in snd now while the mobo POSTs i hear one beep
thats it.
i have double checked and triple checked that everything is connected and stable.
gpu isnt the prob thats all i know, i have two cards and with both the boot fails. anyways heres my configuration:
asrock 4coredual-vsta
celeron d 356@3333mhz
512 mb of ram(very old)
sapphire 9600pro atlantis agp(~1 year old)
40gb 512rpm hard drive(ultra mega old)
300w power supply bought few months ago(very cheap, about 15$)(bought becouse last one died after a lightning hit my house lol)
bios ver: 1.60
win xp pro
i think thats all, i have 2network cards plugged in for no reason.
so i think something of this is dying or has died
my dvd drive died few days ago, it was producing weird vibration noises, and bios cant see it anymore so i unplugged it.
wow... thanks 4 reading, now help if ya can!
thanks:faint:
http://forums.techarp.com/motherboar...tml#post320834
Zadnje izmijenjeno od: axeafrika. 06.01.2008. u 01:06.
axeafrika je offline   Reply With Quote
Staro 06.01.2008., 00:45   #2
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Ok sad objasni što ti znači da si očistio "svaki CPU cooler" mislim kolko CPU coolera imaš...
Anyway ako si skidao razne hladnjake sa stvari i mjenjao pastu imaš dvije stvari za provjeriti_
1. Pasta se razmazala po čipsetu/proesoru/ploči i sad stvara spoj di netreba, nedaj se zavarati neke paste iako pišu da ne vode mogu napraviti probleme (osobno provjereno) a dosta ti je da ti se rezlije po rubu silicija ako nije dobro zaliven (npr na čipsetu) i odeeee - eto ti ovakvih simptoma...
Dakle pazi da je tanki sloj paste a ne potop...
2. One žvake na čipset coolerima nekad imaju takav postav da nosači za čipset coolere postanu problem, naime kako je žvaka podebelja masa kad staviš standardni tanki sloj paste na čip (poslje odstranjenje žvake) i onda nakon stavljanja čipset coolera isti uopće ne dotiče čip - jer ostane iznad njega na nosačima... Nesretna oklnost ako ti se to desi - ali bilo je ploča s tom sklonošću, pa ako je tako stavi se tanka bakrena ili alu pločica ili ako nemaš ništa sličnoga kovanica od 1 ili 2 lp gore (aluminijeske su) i s tim se može improvizirati dosta dobro samo moraš paziti da ne zdrobiš čipset...
Have a nice day...
Staro 06.01.2008., 01:08   #3
axeafrika
Postovi: 43
hehe bio je typo. sad je ispravljeno
da malo mi je stare paste otišlo na onaj mali zeleni dio na celeronu
1x1mm, probo sam oćistit ali nije išlo, mislio sam da nije važno.
evo idem sad to očistit pa se javim
edit zeleni dio(zapravo crna udubina):
http://images.tomshardware.com/2007/...t_2/775cpu.jpg
Staro 06.01.2008., 02:58   #4
axeafrika
Postovi: 43
ista stvar, očistio sam ali opet se gasi
Staro 06.01.2008., 10:12   #5
yedwy
yedwy's Avatar
Postovi: 6,956
Hmm jbga... Rastavi sve (izvadi ramove i sve iz ploče pa i CPU) i dobro provjeri da nije negdje u socket ili na ploču pored nekaj kapnulo (traži friški pastu ona je vjerojatnoji uzrok) i prebriši si konektore od rama i kartice kad si već kod toga prije sastavljanja možda ti nebi bilo loše niti čipset cooler provjerit posebno ako si vaddio ploču iz casea nekad se znaju iščašit da ljudi ne primjete jer dižu ploču držeći je za cooler ili stiskaju na stolu kad stavljaju cpu pa se izguraju pinovi...
I dvaput provjeri sve kablove dal je sve spojeno kako treba, posebno naponske provjeri 2x neki put se desi da se EPS i PCI-e zamjene i sl...
Have a nice day...
