Staro 05.01.2008., 16:51   #1
domy1
Yugokiller
domy1's Avatar
Postovi: 649
Antec ili CoolerMaster
Imam dilemu između ova 2 navedena napajanja: Antec NSK6000 ili Coolermaster Centurion 5?! Mislim i jedno i drugo su mi dobri(izgledom). CM-a sam vidio jel mi ga brat ima al antec nisam. Najviše me zanima gdje je kod anteca naprijed ventilator, ili ga uopće nema, hvala!
Staro 05.01.2008., 16:57   #2
Ozy
Spužva Bob Skockani.. :XD
Ozy's Avatar
Postovi: 1,685
Mislim na dilemu između kućišta..?...
Inače oba su ok ovako na oko,ali ja bih uzeo Centurion jer mi je ljepši od navedenog Anteca.
Athlon64 X2 5400BE Brisbane @3000Mhz + KATANA 2 + AirTunel@2x Xilence 120mm
Gigabyte GA-MA78G-DS3H @F4
Mushkin Redline @1000Mhz 5-5-5
XFX 9600GSO @680/1700 || 2000Mhz
Seagate Gonzales 250GB & 320GB && Spinpoint F1 500GB
Coolermaster Elite Power RS460; Sharkoon Silvation; LG GH22NP20/LG GH20NS10/Pioneer DVR107D/Pioneer 216DBK/ Samsung SH-S223F; Logitech MX518; Philips 190P7ES 19" LCD
Ozy je offline   Reply With Quote
Staro 05.01.2008., 17:16   #3
dzeneral
Valar morghulis
dzeneral's Avatar
Postovi: 280
I jedno i drugo su ok, ja sam osobno Antecov fan..on ti ima naprijed 2x92mm
"The objective of war is not to die for your country, but to make the other bastard die for his."
dzeneral je offline   Reply With Quote
Staro 05.01.2008., 17:27   #4
elvis again
In the ghetto
elvis again's Avatar
Postovi: 1,943
Uzel bi antec jer je nesto veci (visi) iako mi je CM ljepsi pa je to razlog zbog kojega ga imam.
AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor
elvis again je offline   Reply With Quote
Staro 05.01.2008., 17:42   #5
domy1
Yugokiller
domy1's Avatar
Postovi: 649
Autor elvis again Pregled postova
Zbog tebe sam upao u dilemu . Ma meni je i antec lijep
@ozy a kaj se čudiš , neću dati bez veze 400kn na "loše" kućište...
