Staro 02.01.2008., 18:25   #1
Rev
Rev's Avatar
Lokacija: Plaški
Postovi: 231
odbija učitat prozore.
u igri je stariji komp...
kad ga upalim odbija učitati windowse, već samo učita onu bijelu traku prije neg bi trebo učitat windowse i tak stoji...
a kad pokušam safe mode, onda učitava redom one win-fileove sve dok ne dođe do nekog pod nazivom "mup.sys" (il neki sličan nastavak)...i tu disk prestane učitavat, tj. stane...
u čemu bi mogao bit problem?
(format diska ne dolazi u obzir)
Rev je offline   Reply With Quote
Staro 02.01.2008., 18:31   #2
zippo
herr Flick
zippo's Avatar
Postovi: 2,085
.:S:T:A:L:K:E:R:.. :2 u ocekivanju
nema vise zippacha ......
zippo je offline   Reply With Quote
Staro 02.01.2008., 18:36   #3
Rev
Rev's Avatar
Lokacija: Plaški
Postovi: 231
hm, ok...samo kaj mi ovo niš previše ne pomaže...
Mup.sys is located in the folder C:\Windows\System32\drivers. Known file sizes on Windows XP are 107904 bytes (87% of all occurrence), 104064 bytes, 101632 bytes.
The driver can be started or stopped from Services in the Control Panel or by other programs. The file is a Windows system file. The program is not visible. The service has no detailed description. The file is a trustworthy file from Microsoft. Mup.sys seems to be a compressed file. Therefore the technical security rating is 2% dangerous, however also read the users reviews.
i kaj mi je sad za činiti?
EDIT: aha, našo u user commentsima nešto:
Used to connect to 'novell' servers. 99% of people dont need this. Many people experience problems when windows stops loading at mup.sys during bootup. Can be fixed by booting with CD and repairing, or by the 'disable mup' command.
sad imam opet pitanje: ak idem s Windows CDom popravljat trenutnu instalaciju windowsa, hoće li mi svi programi i fajlovi ostati netaknuti?
odnosno, kaj će točno taj repair napravit kad ga pokrenem?
Zadnje izmijenjeno od: domy_os. 02.01.2008. u 23:31.
Staro 02.01.2008., 19:27   #4
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
prepisati vecinu windows fajlova tako da 99% da ces imati sve na njemu jel ...
.i.
Razer Blade 15
