Staro 19.12.2007., 08:58   #1
pogi
aka Mali Mirko
pogi's Avatar
Postovi: 3,138
Prelazak sa X1 na X2, opaske i pitanja
Dakle nakon nemoguće misije nabavke polovnog s939 X2 procesora kupio sam novog u Linksu, A64 Toledo s939 3800+ X2. To je zadnje davanje snage dobroj staroj AGP platformi....
Jednostavno sam izvadio 3000+ Venicea i uboo ovo novog prvo na defaultnim postavkama BIOSa ,a onda i OC postavke.
Zapažanja:
1. X2 radi bez problema na nForce 3 Ultra chipsetu
2. Moj Toledo je dobar potencijal za oc. Na defaultnih 1.3V Vcore radi na 260x10. Veniceu je za 290x9 trebalo 1.475V (po mojoj ploči). Vjerujem da ću ga probati podignuti još.
3. Windowsi XP SP2 su prepoznali novi CPU, nešto doinstalirali i to je bilo to.
4. Hladim ga istim hladnjakom kao i Venicea Freezer 64 Pro
Pitanja:
1. Da li se što dobije instaliranjem drivera i utilitija sa AMDove stranice
AMD Dual-Core Optimizer - The AMD Dual-Core Optimizer can help improve some PC gaming video performance by compensating for those applications that bypass the Windows API for timing by directly using the RDTSC (Read Time Stamp Counter) instruction. Applications that rely on RDTSC do not benefit from the logic in the operating system to properly account for the affect of power management mechanisms on the rate at which a processor core's Time Stamp Counter (TSC) is incremented. The AMD Dual-Core Optimizer helps to correct the resulting video performance effects or other incorrect timing effects that these applications may experience on dual-core processor systems, by periodically adjusting the core time-stamp-counters, so that they are synchronized.
i još ovaj
AMD Athlon™ 64 X2 Dual Core Processor Driver Version 1.3.2.0053 for Windows XP and Windows Server 2003 (x86 and x64) - Allows the system to automatically adjust the CPU speed, voltage and power combination to match the instantaneous user performance need. This package is a user friendly localized software installation of the driver designed for end-users. This driver supports AMD Athlon™ 64 X2 Dual Core processors and supports future quad-core upgrades on Windows XP SP2 and Windows Server 2003 SP2 x86 and x64 Editions.
2. mjerenje temperaturi jezgri je po meni čudno. Pri opterećenju temperature trenutno skoče za 10stC i kada se rastereti trenutno i padnu za 10stC. Pri opterećenju idu do 59-60stC. Za mjerenje koristim "Core Temp" i neki Everest Ultimate 2.8. U idleu su oko 45stC
Verifikacija poštenog trgovca #1, #2, #3, #4, #5, #6, #7, #8, #9
pogi je online   Reply With Quote
Staro 19.12.2007., 09:17   #2
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,964
AMD Dual-Core Optimizer - pričaju svi da se dobije svašta, tak da stavi
A driver ti treba jedino ako ćeš koristiti automatsko mijenjanje brzine procesora u zavisnosti od opterećenja.
Staro 19.12.2007., 10:39   #3
ZMAJ
Postovi: 2,937
Ja sam imao jedan problem u warcraftu3 sve dok nisam stavio ovaj AMD dual core optimizer...
sto se tice drugih aplikacija nisam imao problema...
nista te ne kosta da stavis taj optimizer, a ionako nije nikakva "aktivna" aplikacija u taskbaru il tak nekaj...
ZMAJ je offline   Reply With Quote
Staro 19.12.2007., 19:43   #4
pogi
aka Mali Mirko
pogi's Avatar
Postovi: 3,138
Procesor je izvrstan. Evo pri istoj defaultnoj voltaži od 1.3 V sada vozi na 2800MHz. Instalirao sam Dual Core Optimizer ali nemam još nekih dojmova o njemu...
Staro 19.12.2007., 20:26   #5
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Niti buš imal nekakvih dojmova o njemu. Imao ga ili ne - ja baš i ne primjećujem.
Inače, dobar stepp, fino on ide na 2.8 i defolt
Staro 19.12.2007., 23:56   #6
ZMAJ
Postovi: 2,937
optimizer ti nece nista ubzati vec npr. mozda se dogodi da on sprijeci neki error/bug/ili nesto trece, no to onda neces ni skuzit
Staro 20.12.2007., 10:23   #7
pogi
aka Mali Mirko
pogi's Avatar
Postovi: 3,138
Autor ZMAJ Pregled postova
Čak mi se čini da sam na CoD4 dobio 7-8 fps više. Obzirom da sam imao cca 25fps prije novog CPUa to mi dosta znači.
Ono što me posebno razveselilo je ubrzanje u kodiranju videa od cca 30%
Konačne postavke 270x10 na 1.275V (po mojoj ploči).
Definitivno vrlo dobar proc, To je maximum za moju AGP/nForce 3 platformu.
Staro 20.12.2007., 13:27   #8
Tekla
Tekla's Avatar
Lokacija: livno
Postovi: 1,065
o ljepo si ga clocko. je li to def napon ili??? jos si ubodes polovnu 7900gs ili 7800gs agp grafu.
Tekla je offline   Reply With Quote
Staro 20.12.2007., 14:39   #9
pogi
aka Mali Mirko
pogi's Avatar
Postovi: 3,138
Autor Tekla Pregled postova
Po MBO malo ispod def vcore (1.3 - 1.35V) a cpuz i everest kaže cca 1.31V
Vidiš o zamjeni grafulje još nisam razmišljao... moram malo proguglati 6800 vs 7800/7900
Staro 22.12.2007., 19:05   #10
alien_2
alien_2's Avatar
Lokacija: Ogulin
Postovi: 158
Evo i ja razmišljam o prelasku sa x1 na x2 proca. Trenutni je sckt 939 3000+ sa Winchester jezgrom (da onaj sada starac), pa sam isto u Linksu vidio gore navedenog x2 3800+ i u ADM-u x2 4200+ . E sada, razlika je cca 100 kn. Dali uzeti 3800+ prodat starog i + onih 100kn kupit bolji cooler (svaki prijedlog dobrodosal) ili dati 100kn vise za 4200+. Inace kratak sam s parama pa ono. Svaka kuna vrijedi zlata. Nista ne OC-am tako da je sve vanilla lol. Savjeti molim.
MB je Gigabyte K8NF-9 (treba samo update biosa).
alien_2 je offline   Reply With Quote
Staro 23.12.2007., 18:23   #11
SniperWolf
SniperWolf's Avatar
Postovi: 4,193
amd dualcore optimiser ti praktički "optimizira" ove starije igrice što nisu napravljene da rade na novim procevima
npr kod frenda stari serious sam 1 je jako trzao, nakon sto sam stavio amd dual core optimizer vise nije (4600 x2)
warcraft3 je bio duplo brzi (prebrza je igra bila, ko da se na 1000fpseva vrti) itd
Pošteni Trgovci: 1,2
Staro 24.12.2007., 00:09   #12
Tekla
Tekla's Avatar
Lokacija: livno
Postovi: 1,065
Autor alien_2 Pregled postova
uzmi x2 3800+ jer 200mhz se neosjeti. a za tih 100kn dodaj jos 60kn i kupi freezera.
