Staro 08.12.2007., 19:26   #1
P1xel
P1xel's Avatar
Lokacija: Kutina
Postovi: 25
Lightbulb AMD - Vaš blagoslov
Konfiguracija s AMD procesorom, za igre, bez monitora, grafička je HD3870 (i ona ne ulazi u ovih 5k kn)
Sve iz Vemila, do 5000 kuna; moja ideja je:
CPU AMD Athlon64 X2 6400+ "Black Box Edition", dual core, SckAM2 -- 1.290,21
Zalman 9500 AM2 Cooler, sck 478/754/939/AM2 -- 410,59
4x DDR2 1GB PC6400 (800MHz), Kingmax -- 556,32
HDD Seagate ST3320620AS, 320 GB 16MB, S-ATA300, NCQ3, 7200 -- 636,35
MB Gigabyte MA69G-S3H, sAM2, AMD 690G, VGA, SATA II, GLAN, FW, ATX -- 474,03
Thermaltake VB6000BWS mid tower Swing, bez PS, crno, USB, Fire wire, 1×120mm fan, prozor -- 509,00
Chieftec power supply 550W, EPS, ATX 2.0, 3×12V, Active PFC, AFC, 12cm fan, 2×SATA connectors -- 500,00
DVD+RW/-RW/RAM NEC AD-7170BKSA, SATA, bulk, black -- 218,00
4594,5
P1xel je offline   Reply With Quote
Staro 08.12.2007., 20:09   #2
elvis again
In the ghetto
elvis again's Avatar
Postovi: 1,943
Znaci ak ides na amd i hoces nasto ajci proc uzmi Athlon 64 X2 5000 black edition koji ide ko i 6400. Taj cooler nemoj uzimat, uzmi u vemilu TT Sonic Tower + 120mm vent.
Inace citati forum ima sigurno 10-ak AMD konfi slozenih.
AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor
elvis again je offline   Reply With Quote
Staro 08.12.2007., 20:39   #3
Postovi: 33,930
Zamijeni tog NEC sa LG ili Pioneerom. Isto tako možeš uzeti Kingmax 667 obzirom da su na njemu isti čipovi kao i na 800MHz. Chief ti je debeli overkill - razmisli o Fortron 350W ili 400W PNF.
Staro 08.12.2007., 20:58   #4
bruno_x
bruno_x's Avatar
Lokacija: split
Postovi: 240
huah
zasto ne zalmana? nego TT Sonic Tower + 120mm vent
molim odgovor.
bruno_x je offline   Reply With Quote
Staro 08.12.2007., 21:01   #5
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Ajmeeee.
Citaj forum.
Zalman je sranje, katastrofalan omjer ulozeno/dobiveno, po meni dobar za Celere i to jedva. :P
Ne isplati se.
Staro 08.12.2007., 21:07   #6
bruno_x
bruno_x's Avatar
Lokacija: split
Postovi: 240
meni nije nesto jasno....kupis slabi procesor ustedis love...nabrijes ga i kupis hladnjak za 50 dolara
Staro 08.12.2007., 21:28   #7
greg SE
greg SE's Avatar
Datum registracije: Oct 2001
Lokacija: Vinkovci
Postovi: 5,231
a jeste navalili na zalmana. nije on toliko los koliko je skup. kako je netko nedavno ovdje na forumu napisao - svi pljuju po njemu ali da ga dobiju na poklon zadrzali bi ga u stroju.
a vidite da uzima kuciste s prozorom, zalman ce kroz njega ljepse izgledati nego tamo neki sonic tower s nakardno uguranim 120mm ventom
no cinjenica je da taj proc bas i nece ici daleko s OCom bez obzira na to sto je black edition. previse je vec napumpan. mislim da bi mogao slobodno na njemu i s stock coolerom naci maksimum procesora.
s druge strane, uzimati 5000+ i dici na clockove ovoga pa se boriti da to ohladis i nema previse smisla. mogu i ja svoga drzati na 6000+, to sto temperatura ode preko 65 sa stock coolerom nakon 5 minuta oprerecenja je druga stvar. al nema sanse da sad idem davati neku lovu za ***en cooler kad sam vec mogao ici na duplo jaci procesor da sam stavio na hrpu lovu koju sam dao za ovaj i koju bi dao za neki dobar cooler
Staro 08.12.2007., 21:41   #8
mislav_os
freak
Postovi: 2,688
Autor elvis again Pregled postova
6400+ ima 2x1MB cachea,dok 5000+ ima 2x512kb,tako da,iako ide na isti takt,opet ne daje iste performanse,6400+ pomaze cache
Al sto je je,ne mora uzimat 6400+ ako misli OC-at...jer ce ga moc OC-at MAX 200-250Mhz,i to ak bude imao srece
Staro 08.12.2007., 21:52   #9
P1xel
P1xel's Avatar
Lokacija: Kutina
Postovi: 25
Autor greg SE Pregled postova
Baš sam zbog toga i mislim uzet taj procesor, inače, nebi' ga OC-ao. Pržilica će onda biti LG jer mi ih je dosta ljudi preporučilo a o cooleru još razmišljam
Zadnje izmijenjeno od: P1xel. 08.12.2007. u 22:02.
Staro 08.12.2007., 21:56   #10
IcyTexx
IcyTexx's Avatar
Postovi: 4,707
Autor bruno_x Pregled postova
Stvar je u tome sta taj skuplji Zalman hladi losije od ovih jeftinijih.
A ovo da ljepse izgleda - no comments.
Staro 08.12.2007., 22:02   #11
Roberto
Roberto's Avatar
Postovi: 2,636
pa ne bih se baš složio, moj 5000+ BE na 3,4 ghz ide s 1.45v i grijanje je sasvim prihvatljivo, hladim ga sa scythe infinity i ne ide to preko 45 stupnjeva. Držim ga na 3.3ghz 24/7 pri istoj voltaži.
A da ga i ne clocka taj proc je na defaultu sasvim ok. a s druge strane ne vidim zašto ga ne bi bar malo dignuo, može samo povisiti množitelj i to je to.
A to što 6400+ ima duplo više cache možete objesiti mačku na rep, to se osjeti samo u superpi i sličnim testovima... U radu se to ne osjeti, kod AMD-a cache igra vrlo malu ulogu pri porastu performansi, nije to Intel
Staro 12.12.2007., 19:23   #12
P1xel
P1xel's Avatar
Lokacija: Kutina
Postovi: 25
Što kažete? Nemaju Swing i pola Zalmana =(
I još nešto, ova grafa je privremeno riješenje :/
Btw, inače uploadam na imageshack ali mi je account umro, vjerojatno zbog inactivity-a ili neki k -.-
Staro 12.12.2007., 20:11   #13
flajpan
flajpan's Avatar
Lokacija: Zagreb, Centar
Postovi: 1,796
Autor P1xel Pregled postova
Ak ti je ova grafa privremeno rješenje, zašto ne uštedjeti 1000kn pa koristiti integriranu (i ona je dobro privremeno rješenje).
Staro 12.12.2007., 20:24   #14
P1xel
P1xel's Avatar
Lokacija: Kutina
Postovi: 25
Vidiš, vidiš, o tome nisam razmišljao... Hoće li mi na integriranoj grafi raditi igre iz recimo 2003.?
Staro 12.12.2007., 21:49   #15
flajpan
flajpan's Avatar
Postovi: 1,796
Hoće, zašto ne bi?
Jel mora sve biti iz Ve-mila? Ja bih radije uzeo:
  • 5000+ Black ed. u Nitelu (876kn),
  • tu matičnu ma-69g-s3h u Ve-milu (474kn),
  • HDD WD 320 AAKS (545kn u Nitelu ako su dobili),
  • Sonic Tower u Ve-milu (269kn),
  • Crucial Ballistix 2x1Gb 667 (460kn u Linksu),
  • 120mm Xilence red wing u Formelu (36kn).
  • DVD przu koju sad imam - Samsung sata SH-S203N u Linksu (215kn).
  • Napajanje - Corsair VX 450w u ADM-u (515kn)
a kućište odaberi sam. Meni se Chieftec osobno ne svidja (dizajn) iako su vrlo kvalitetna kućišta, pa sam uzeo Antec Solo.
P.S. A grafičku uzmeš club 3d kad i ako dođe, u HGSpotu 1370kn.
Sve zajedno: 4760kn (grafička uračunata, kućište nije) - bolje od onoga "sve iz Ve-mila", a za manje love.
Staro 12.12.2007., 22:25   #16
P1xel
P1xel's Avatar
Lokacija: Kutina
Postovi: 25
Autor flajpan Pregled postova
kad i ako dođe
Vidiš, čekanje me više ne interesira budući da od početka jedanaestog mjeseca čekam ovu komponentu pa onu pa ovo pa ono... 1950pro ću imati godinu-godinu i pol i to je to, ako imate neku bolju (iako je skuplja) a LAKO nabavljivu grafičku karticu recite svoje prijedloge...
Isto vrijedi i za ostale komponente; što se tiče tvojih prijedloga, procesor ne planiram clockati tako da 5000+ nije za mene, što se tiče kućišta uzeo bi' Swing da je dostupan u Vemilu, 1x2, pogotovo Ballistix, koji se bolje clocka ali je to sve isti koš, me ne interesira. Ostale komponente su više manje jeftinije verzije ovih koje sam ja naveo, ali hvala na prijedlogu.
Staro 20.12.2007., 22:35   #17
P1xel
P1xel's Avatar
Lokacija: Kutina
Postovi: 25
Koji cooler da uzmem u slučaju da im Sonic Tower stigne za 150 godina? (Kutinski Vemil )
