Staro 06.12.2007., 22:11   #121
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Mislim da to nije takav problem, da bi se riješio smanjivanjem takta.
http://techreport.com/articles.x/13741/1
Staro 06.12.2007., 22:14   #122
LAcy
Pink Floyd fan
LAcy's Avatar
Lokacija: Santa Clara, CA
Postovi: 5,539
Autor Vuco Pregled postova
A što sam ja napisao u postu prije tvoga?
Veći je problem što AMD-u treba viši takt, jer su ovaj put zeznuli stvar i nisu (ili možda jesu ali ne puno) brži od Intela na istom taktu.
Core i7-6700K LGA1151 Skylake
RTX 2080 TI 11GB GDDR6
Samsung 850 EVO M.2 1TB SSD
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 06.12.2007., 22:27   #123
Vuco
Vuco's Avatar
Postovi: 9,505
Ne znam ja što si ti htio reći. No, koliko sam ja skužio, ovaj error ili errata kako ga ovi zovu (odmilja TLB) je bug koji se pojavljuje neovisno o taktu.
Velim, koliko sam ja skužio iz teksta.
Staro 06.12.2007., 22:29   #124
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,539
Uh, sad sam ja napravio errata Pogrešno sam pročitao tvoju rečenicu i shvatio da si htio reći da se taj problem mogao riješiti smanjivanjem takta.
Sorry.
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 07.12.2007., 01:35   #125
borgy
kenova
borgy's Avatar
Lokacija: München / Dubrovnik
Postovi: 921
Autor Dailytech
How does the TLB erratum occur? All AMD quad-core processors utilize a shared L3 cache. In instances where the software uses nested memory pages, this processor will experience a race condition.
AMD's desktop product marketing manager Michael Saucier describes a race condition as a series of events "where the other guy wins who isn't supposed to win."
In the software world, a typical memory race condition occurs when the memory arbiter is instructed to overwrite an older block of memory, but write the old block of memory to somewhere else in cache. In the instance where two arbiters follow this same rule set, its easy to see how a race condition can occur: both arbiters attempt to overwrite the same blocks of information, resulting in a deadlock.
From what AMD engineers would tell DailyTech, this example is very similar to what occurs with nested memory pages in virtualized machines on these K10 processors.
Bug ce se rijesiti tek revizijom B3 koja se ocekuje u 3. mjesecu, do tada ide BIOS fix
borgy je online   Reply With Quote
Staro 07.12.2007., 09:47   #126
Jerry
Jerry's Avatar
Postovi: 1,816
nebi htio palit vatru ali ni Phenom nije bez bugova, koliko mi je poznato CPU voli smrznut stroj pri većem opterećenju
Više možda saznam kada/ako mi uleti koji primjerak na testiranje
više o bug-u
http://www.extremetech.com/article2/...2228878,00.asp
A izgleda da ni Intel nije htio ostat duzan po pitanju bugova
http://www.behardware.com/news/9264/...confirmed.html
Izgeda da su svi Yorkfield odgodjeni
Vise o bugu
ftp://download.intel.com/design/proc...t/31872701.pdf
Mozda za onu trakavicu oko nVidia 680i i Yorkfielda nije samo jedna strana kriva.
Stupid is as stupid does
Jerry je offline   Reply With Quote
Staro 07.12.2007., 09:56   #127
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
Kad smo već krenuli u tom smjeru, dosad pronađene 82 greške kod Core Solo i Core Duo procesora:
http://download.intel.com/design/mob...T/30922213.pdf
Čovjek se zapita kako današnji procesori uopće rade
Da ne pomislite da sam pristran, evo i AMD liste (malo je teže pobrojiti zbog drugačijeg načina označavanja grešaka):
http://www.amd.com/us-en/assets/cont...docs/25759.pdf
Staro 07.12.2007., 10:07   #128
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,539
Ja se ponekad također pitam kako uopće rade, to su toliko složeni sklopovi da ih skoro nemoguće u potpunosti iz testirati.
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 07.12.2007., 10:53   #129
Jerry
Jerry's Avatar
Postovi: 1,816
Mislim da bi ovo bio kraj trakavice o errata u Phenom procevima
http://www.fudzilla.com/index.php?op...=4599&Itemid=1
BTW
'' The most interesting parts is that Core 2 technology has about 120 listed bugs and no one, including me, complains or cares about it.''
Staro 07.12.2007., 12:14   #130
Bimbix, Drago klon
Lokacija: VT
Postovi: 81
Autor Jerry Pregled postova
BTW
Imate tu i prijevod tog teksta:
http://www.itx.ba/index.php?option=c...=3782&Itemid=1
Bimbix, Drago klon je offline   Reply With Quote
Staro 07.12.2007., 12:17   #131
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,005
Ovo me podsjeća na moje programerske dane, iako sam imao manje grešaka od nekih kolega, ja bi svoje priznao i riješio, a oni svoje odšutjeli. Pogodite kome se više dugoročno isplatilo
Staro 07.12.2007., 16:07   #132
borgy
kenova
borgy's Avatar
Postovi: 921
ma fora s ovim "bugom" je sto fixevi inace nemaju tako izrazen udar na performanse, inace bi se mozda i zaboravio
Autor Hardcoreware
The reason they were able to proceed with the launch is that this particular erratum is fixable via a microcode update (done using a motherboard BIOS update). Basically, the part of the L3 logic that causes the problem is disabled. However, running the fix instills a performance penalty, because of how the L3 cache’s throughput and latency is affected. There was no way to know exactly how performance would be affected, except for the “around 10%” estimate that has been floating around. Fortunately, our friends at Tech Report have obtained a retail Phenom 9500, and tested its performance before and after applying the patch on an MSI motherboard.
The results were even worse than expected. When looking directly at cache memory performance, bandwidth dropped by as much as 38.7%, and latency slowed down by over 50%!
Of course, what really matters is how the actual programs we use every day are affected. Tech Report ran a full suite of Worldbench tests, to find that the performance drop ranged from around 5% to as high as 50% in programs like Firefox. The average drop in performance in their tests ended up being 13.9%.
dobra strana je dobitak na performansama kad rijese problem u 3. mjesecu
Staro 07.12.2007., 21:49   #133
nino
nino's Avatar
Postovi: 12,613
Dali mi netko moze potvrdit da ima nekih problemcica oko neke revizije Phenom proca. Zippo mi bacio bubu u uho da ovi prvi nes "nisu dobri"?? Imam priliku kupiti Phenoma 9500 pa da se ne razocaram sa 2+2=5..
I usput da najavim moju slijedecu plocu. To je definitivno ova... http://www.hardwaresecrets.com/article/502/1
Do sada nisam vidio tako dobar layout, ma samo nek stigne u moj omiljeni shop i kupujem, a vidim da je diskont24 vec ima, cak ni cijena nije prevelika.
A na kraju kazu: "We couldn’t simply find any negative point on this motherboard. If you are looking for the most high-end motherboard for your AMD system supporting CrossFireX – i.e. up to four video cards – for your “Spider” gaming system this is definitely the motherboard you should buy."
Eto da i ja pomognem Amd/Ati-ju i moj Q i ploca za koji dan lete na trznicu.
Staro 07.12.2007., 21:57   #134
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,539
Autor nino Pregled postova
Super, uspjeli smo te navuć sad mogu od tebe kupiti to Intel quad smeće
Sad pročitaj u postu iznad svog o tom problemu, neće biti 2+2=5. Skrpali su ga sa biosom, malo/dosta izgubili na performansama... Valjda će im već više krenuti, grafe su im donekle krenule, barem u srednjem i najvažnijem segmentu, našli su i navodno ispravili taj bug....
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 07.12.2007., 22:03   #135
nino
nino's Avatar
Postovi: 12,613
A sram me je da to gore nisam vidio, sorry ekipa, postao sam kao lipi014
Ma stalno mislim na tu plocu...jbga
@Lacy ne tjeraj me da popijem na detaljima
Staro 07.12.2007., 22:05   #136
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,539
Uvijek? I u intimnim trenucima?
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 08.12.2007., 12:35   #137
borgy
kenova
borgy's Avatar
Postovi: 921
Benchmark spider-a sa Phenomom 9900:
http://www.hexus.net/content/item.php?item=10648&page=1
(ukratko: crossfire je izveden puno bolje nego na intelovim maticnim, sve ostalo je losije)
Staro 08.12.2007., 14:04   #138
Jerry
Jerry's Avatar
Postovi: 1,816
@nino
Pricekaj prvi mjesec (ako zelis/mozes) i kupi 9600 Black Edition (10€ skuplji od obicnog) stepp B3 i mislim da neces pozaliti. Koliko sam citao na XSforumu vecina opcija u BIOSima 790FX ploca jos nije ni otkljucana!
Staro 08.12.2007., 14:20   #139
nino
nino's Avatar
Postovi: 12,613
@nino
To te ja pitam, znaci B3 da cekam, ova je B2 ravizija. Ufff, jos mjesec dana moram vozit ovu hrgu od Intela . Fala Jerry
Staro 12.12.2007., 09:40   #140
Jerry
Jerry's Avatar
Postovi: 1,816
Jedno upozorenje buducim vlasnicima/testerima Phenoma:
Izgleda da Vdimm veci od 2.35V zauvijek ugasi CPU!
Staro 12.12.2007., 13:04   #141
Razer
Razer's Avatar
Postovi: 11,642
Odakle ti ta informacija?
2.35v za DDR2 memoriju je ništa, ili ti pričaš o DDR3 memorijama?
Staro 12.12.2007., 13:09   #142
Jerry
Jerry's Avatar
Postovi: 1,816
Autor Razer Pregled postova
Da, pricam o DDR2 jer ne postoji Phenom+DDR3 kombinacija (osim u nekima labovima).
Informacija:
http://my.ocworkbench.com/bbs/showth...threadid=69350
http://www.xtremesystems.org/forums/...1&postcount=40
Staro 12.12.2007., 13:14   #143
Razer
Razer's Avatar
Postovi: 11,642
Ovo nikako nije dobra vijest...
Na stranu OC, no AMD ima i gro ostalih problema koje se vežu uz novog Phenoma, kad moraju srljati kao guske u maglu
P.S. moja greška u vezi DDR3 memorije...
Staro 12.12.2007., 13:17   #144
Jerry
Jerry's Avatar
Postovi: 1,816
Pa ista stvar je bila i na s.939 tako da ne znam u cemu je velika stvar.
Kombinacija BH5/UTT na 3.5V i nekog SD/Venicea s niskim Vcore je jako cesto znala zavrsiti mrtvim mem. kontrolerom (procom).
Staro 12.12.2007., 13:21   #145
Razer
Razer's Avatar
Postovi: 11,642
U čemu je velika stvar? Jedno je kad rikne jedan procesor na njih par stotina (karikiram), a drugo je kad rikne četiri procesora za redom zbog iste stvari...očito je da su Phenomi puno puno osjetljiviji na te stvari. Ako uspiju to riješiti super, ako ne, neće biti dobro...
Staro 12.12.2007., 13:22   #146
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Na Gigabytici se ne moraš toga bojati-ta ni ne daje više od 2.35v za memu
Staro 12.12.2007., 13:27   #147
Jerry
Jerry's Avatar
Postovi: 1,816
A zasto ne bi bilo dobro?
Po JEDEC standardu Vdimm DDR2 je jos 1.8V ako se ne varam?
Bez uvrede ali tvoja usporedba je kao da kazes da si imao za redom 4 Q6600 i da su sva cetiri umrla nakon sto si im dao 1.85V.
Buduci da je mem. kontroler u procu ne mozes gledati stvari na FSBovki nacin.
Staro 12.12.2007., 19:28   #148
Razer
Razer's Avatar
Postovi: 11,642
U pravu si. Samo mi nije jasno kako su to stariji procesori (kako na socketu 939 i AM2), mogli to ponositi bolje.
Staro 13.12.2007., 06:38   #149
greg SE
greg SE's Avatar
Datum registracije: Oct 2001
Lokacija: Vinkovci
Postovi: 5,231
nisu podnosili bolje nego su oscilacije bile manje. uzmi u obzir da su DDRu voltaze bile vece i pomak od 0.5 nije bio isti kao sto je to memoriji kojoj je default 1.8. ako znamo da je kontroler i na s939 znao krepat s +0.6-0.7 dodjemo do jednostavne racunice da rikne kada je povratni signal od memorije oko 30% jaci nego sto bi trebao biti. tako je bilo na s939, tako je ocito i sa phenomom. ne znam cemu tu sad neki sokovi. wow, necemo moci memoriju za 133kn clockati do 1000mhz tako da joj opalimo volt vise nego sto je predvidjeno? katastrofa. cisto sam zaprepasten
Staro 14.12.2007., 01:40   #150
Scorpius
Scorpius's Avatar
Postovi: 393
Evo ga, cijena Phenoma 9500 se izjednačila sa q6600 u jednu jedinu kunu (izvor: nabava)
Q6600
AMD 9500
Scorpius je offline   Reply With Quote
