Staro 26.11.2007., 04:45   #1
Crazy Shale
Crazy Shale's Avatar
Postovi: 397
Konfa do 6000kn s lcd-om
Dakle trebo bih konfu za frenda sa 2gige rama i lcdom za gaming bez periferije samo monitor da je ukljucen znaci kuciste, ram ,mbo ,psu ,cpu ,rom ,hdd ,gpu. max 6k kn. hvala unaprijed.
Prodajem BEŽIČNI KABEL na metre!!!
Crazy Shale je offline   Reply With Quote
Staro 26.11.2007., 04:58   #2
elvis again
In the ghetto
elvis again's Avatar
Postovi: 1,943
cpu - Procesor Intel Core 2 Duo E4500 , 2.2GHz, socket 775, 2Mb cache
mbo - Gigabyte P35-DS3L, s775, intel P35+ICH9, FSB 1333 4xsata gblan
ram - DDR2 1024Mb ( 1Gb ) PC5300 Kingmax MARS , 667MHz x2
hdd - HDD Samsung 160Gb SpinPoint, Serial ATA II, 8 MB cache, 7200 okr
vga - Ati Radeon X1950GT, 256Mb GDDR3, 256bit, Dual DVI, PCI X
(za grafu mozes pricekat i uzet 3850 kad vec bude dostupna)
dvd - DVD upisivač Liteon DH-20A4P-06C, 20x , DVD-Dual, black, ATAPI,
psu - Napajanje FORTRON 350W, PNF, Super Silent, 12cm ventilator, ATX2
cas - Aplus CS-185A PC Case, w/o PSU, RoHS
mon - PHILIPS 220WS8FB, 22" LCD, widescreen, 1000:1, 5ms, VGA, DVI-D
5.704,05Kn sve iz www.adm.hr
AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor
elvis again je offline   Reply With Quote
Staro 26.11.2007., 07:40   #3
edge
edge's Avatar
Lokacija: Šibenik / Zagreb
Postovi: 78
ja sa sebo ovo sastavio u admu-u, za 5500kn
-core 2 duo e6550 2,33ghz
mb gigabyte p35-ds3l
-2gb ram kingmax cl5 800mhz
-kućište frontier shinobi 400w
-sapphire 1950gt 256mb ddr3 256bit
-hd wd aaks 320gb ili samsung spin point 320gb
-mon lg 19" 2000:1, 2ms, 2.6mm
napajanje po kupi po zelji....
napajanje nisam posebno kupovao jer smatram da je to bacanje novaca, dosad sam uvijek u zivotu imao ova jeftina i nikad nije bilo problema, a uostalom ako ti sto i rikne zbog napajanja imas garanciju a opet mislim da frontier nece savit neko najjadnije napajanje.
ovu konfiguraciju sam sastavljao tjedan dana pomno proučavajući komponente po web-u, i bit će odlična za igranje novih naslova na rezolucijama 1280*1024
isto tako mislim da ti je bolje kupiti e6550 ili e6750 pa ga pustiti na miru, nego e4400 ili 4500 pa ga oveklokati, jer za mene to stvarno nema smisla da se kupi novi procesor pa se kloka.
toliko od mene...
edge je offline   Reply With Quote
Staro 26.11.2007., 14:07   #4
Postovi: 7,568
Autor edge Pregled postova
Bacanje novaca je kad uplatiš 500 jura na račun zamamne brinete i kad se nađete u istoj sobi, gledaš u pod, jer si sramežljiv.
Koga briga dal si ti imal problema ili ne. Totalno nebitno. Čovek kupuje novo računalo, a ti mu preporučuješ šrot od napajanja, jer ti nisi nikad imal problema. Vrla stvar. Ovo argumentiranje s garancijom podjedanko nema smisla. Komponente on lako reklamira (samo je pitanje dal budu sve prešle kak spada), a kaj je s podacima na disku, koji je skupa s ostatkom društva potonul u mračne vode. Može se slikat i nikakava garancija i reklamacija mu tu ne pomaže.
Bilo bi prokleto ljubazno od tebe (i drugih) da se okaniš preporučivanja napajanja za koja se zna da ne vrijede više od pakiranja 505 bombona, jer s tim nikome ne pomažeš. Kvalitetna napajanja danas nisu skupa i jednostavno nema razloga da neko ko ima za Core, itd., kupuje loša i nekvalitena napajanja, zato jer tebe ili nekog desetog služe kak spada.
Staro 26.11.2007., 17:12   #5
blackened
blackened's Avatar
Lokacija: Beli Manastir
Postovi: 1,281
Autor McG Pregled postova
evo i ja sam taj neki deseti
Staro 27.11.2007., 00:33   #6
razor i2c
razor i2c's Avatar
Lokacija: Hercegovina
Postovi: 363
slažem se sa elvisom samo bi ja stavio disk od 250-320gb,3850-kad bude dostupna i eventualno 6750 ako se mogne ugurat budžet
razor i2c je offline   Reply With Quote
