Staro 24.11.2007., 13:37   #1
thmh
Postovi: 44
komp od 7-8 soma za igranje
Procesor Intel Core 2 Duo E6750 , 2.66GHz, socket 775, 4Mb cache 1.188,28Kn amd
DDR2 1GB PC6400 (800MHz), Kingmax 625,88 ve-mil
HDD Seagate 320GB, Serial ATA II, 7200 rpm, Barracuda 7200.10 599,00Kn amd
Gigabyte P35-S3, s775, intel P35+ICH9, FSB 1333/1066/800MHz 740,07Kn amd
Power Supply FORTRON 550W, EPS, HQ, PFC, 2 x 12V 659,00 ve-mil
DVD upisivač NEC AD 7170A, DVD±RW 18x8x18x crn 197,27Kn amd
Powercolor Radeon HD3870 PCIE, 512MB, TVout, dual DVI 1.621,4 ve-mil
prijedlozi di kolko zašto , kupujem danas zg
thmh je offline   Reply With Quote
Staro 24.11.2007., 17:58   #2
elvis again
In the ghetto
elvis again's Avatar
Postovi: 1,943
Ovdje je sve ok samo uzmi napajanje Fortron 400W PNF u adm-u za 300kn. Mozda ti se cini ko losiji izbor ali nije.
AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor
elvis again je offline   Reply With Quote
Staro 24.11.2007., 18:17   #3
Postovi: 34,081
Zamijeni Seagate hdd sa Samsung T166 ili WD AAKS. Isto tako, NEC baš i nije neka prža te savjetujem Samsung 202/203, LG ili Pioneer.
Staro 24.11.2007., 19:35   #4
mislav_os
freak
Postovi: 2,688
Vidim da si napisao da komp sluzi za igre,a posto si uzeo C2D koji se jako dobro kloka na stoc voltazi,zasto ne bih?? Ako si gamer,vazan ti je svaki FPS
Pa bih ti preporucio neki cooler,naravno,ako zelis:
~200kn:AC Freezer 7 PRO
CM HyperTX
iznad 200kn: TT Big Typhoon,Sonic Tower,CM Gemini itd
Staro 25.11.2007., 01:29   #5
razor i2c
razor i2c's Avatar
Lokacija: Hercegovina
Postovi: 363
Talking
Procesor Intel Core 2 Duo E6750 , 2.66GHz, socket 775, 4Mb cache Gigabyte P35-DS4, s775, intel P35+ICH9R, FSB 1333/1066/800MHz ili Gigabyte P35-DS3R, s775, intel P35+ICH9R, FSB 1333/1066/800MHz HDD 320.0 GB SAMSUNG, SATA, 16MB c., 7200 okr/min 8800GT, GeForce 8800 GT, 512 MB, tv-out, Dual DVI Napajanje CORSAIR 450W, VX Series CMPSU-450VXEU, 12cm vent.,ATX2 DDR2 1024Mb PC5300 Kingmax MARS , 667MHz 2 ili 4 gige-koliko ti treba,ako imaš više para kupi kvalitetniju memoriju DVD upisivač Pioneer DVR-212BK, DVD±RW, black kućište po želji oko 6500 kuna sa ds4 i 4 gige rama -bez kućišta
ako ćeš clockat svakako uzmi neki kvalitetniji hladnjak od stocka
Zadnje izmijenjeno od: McG. 25.11.2007. u 02:23.
razor i2c je offline   Reply With Quote
Staro 25.11.2007., 01:48   #6
Ive_ri
Ive_ri's Avatar
Postovi: 36
Autor thmh Pregled postova
Mislim da ti je ovo svakako premalo memorije u današnje vrijeme. Pa ja sam kupovao komp pred dvije godine i onda se stavljalo 1 gb memorije (doduše ddr 1 je onda više bio u điru )
Znači memorije svakako uzmi najmanje 2 gb.
A grafičku možda bolje da uzmeš gf 8800 gt ako imaš para.
Ive_ri je offline   Reply With Quote
Staro 25.11.2007., 03:13   #7
mislav_os
freak
Postovi: 2,688
Autor Ive_ri Pregled postova
Vidis da pise 625kn da je,a doticni Kingmax(1GB) kosta 156kn,znaci 625/156=4,uzeo je 4GB
