Staro 22.11.2007., 23:07   #361
lajchi
Postovi: 506
Fraps
Evo i crysis bench. 1680x1050, FULL, 4xAA
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s
!TimeDemo Run 0 Finished.
Play Time: 115.58s, Average FPS: 17.30
Min FPS: 9.47 at frame 276, Max FPS: 20.69 at frame 1761
Average Tri/Sec: -15794874, Tri/Frame: -912816
Recorded/Played Tris ratio: -1.00
!TimeDemo Run 1 Finished.
Play Time: 108.80s, Average FPS: 18.38
Min FPS: 9.47 at frame 276, Max FPS: 20.72 at frame 1763
Average Tri/Sec: -16579325, Tri/Frame: -901918
Recorded/Played Tris ratio: -1.02
!TimeDemo Run 2 Finished.
Play Time: 108.62s, Average FPS: 18.41
Average Tri/Sec: -16593732, Tri/Frame: -901237
!TimeDemo Run 3 Finished.
Play Time: 108.44s, Average FPS: 18.44
Average Tri/Sec: -16619749, Tri/Frame: -901099
TimeDemo Play Ended, (4 Runs Performed)
Zadnje izmijenjeno od: lajchi. 22.11.2007. u 23:32.
lajchi je offline   Reply With Quote
Staro 23.11.2007., 00:27   #362
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Ma, kaj se gnjaviš sa 4xAA u Crysisu...trebao si samo izvrtit bez...
Ta reza me baš i zanima koliko daje na srednjim a koliko na high postavkama.
Da mogu usporedit sa mojom krampinom
Staro 23.11.2007., 08:27   #363
lajchi
Postovi: 506
Autor Jelc Pregled postova
Izvolte gospodine
1680x1050 sve HIGH bez AA
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
Play Time: 76.23s, Average FPS: 26.24
Min FPS: 15.44 at frame 152, Max FPS: 30.85 at frame 1782
Average Tri/Sec: -24762692, Tri/Frame: -943784
Recorded/Played Tris ratio: -0.97
Play Time: 72.15s, Average FPS: 27.72
Min FPS: 15.44 at frame 152, Max FPS: 32.34 at frame 991
Average Tri/Sec: -25877656, Tri/Frame: -933586
Recorded/Played Tris ratio: -0.98
Play Time: 72.07s, Average FPS: 27.75
Average Tri/Sec: -25905582, Tri/Frame: -933522
Play Time: 72.08s, Average FPS: 27.75
Average Tri/Sec: -25933684, Tri/Frame: -934655
1680x1050 sve MEDIUM bez AA
Play Time: 37.46s, Average FPS: 53.38
Min FPS: 40.81 at frame 145, Max FPS: 61.87 at frame 907
Average Tri/Sec: 46854300, Tri/Frame: 877672
Recorded/Played Tris ratio: 1.04
Play Time: 33.41s, Average FPS: 59.86
Min FPS: 40.81 at frame 145, Max FPS: 71.36 at frame 83
Average Tri/Sec: 52965616, Tri/Frame: 884833
Play Time: 33.39s, Average FPS: 59.89
Average Tri/Sec: 53019396, Tri/Frame: 885219
Play Time: 33.40s, Average FPS: 59.88
Average Tri/Sec: 53033272, Tri/Frame: 885669
Recorded/Played Tris ratio: 1.03
Zadnje izmijenjeno od: lajchi. 23.11.2007. u 08:40.
Staro 23.11.2007., 10:04   #364
gog
gog's Avatar
Postovi: 582
Može neki benchmark na 1920x1200?
gog je offline   Reply With Quote
Staro 23.11.2007., 10:42   #365
zippo
herr Flick
zippo's Avatar
Postovi: 2,085
Kaj tebi nije rikno taj Iper dok je komp bio ugašen?
KGB super moderator, sve znas Da mi je samo znati kako ? Neciji prstici su jos tu umijesani, imas neku vezu u Umagu ?
Krepala je mrcina ne radeci nis, mozda je to i sreca, ko zna. Da je to bilo u radu mozda bi mi bilo skurilo i komp brrrrrrrrr, ne smijem ni pomisliti
Ali bio je pod garancijom, i zahvaljujuci pomoci debelog kempera Mitzeka dosao sam do
http://www.chieftec.eu/index.php?opt...id=268&Itemid=
sada 2900 Pro ima svoje odvojene 6 i 8 pinske konektore za napajanje i radi ko pupica. Sa HR-03 R600 najvise temperature poslije 2 sata Crysisa su joj :
CPU 53, VRM 65 Ko zna bi li isao na 3870 i na koliko bi je ohladio ? Mozda zaledio ?
.:S:T:A:L:K:E:R:.. :2 u ocekivanju
nema vise zippacha ......
zippo je offline   Reply With Quote
Staro 23.11.2007., 10:49   #366
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,345
Ko zna dal bi pasalo na nju, a s obzirom da ova tvoja ide bez greške na taktove XTa nema potrebe za novom nekom bzvz 3 serijom
žmnpp
Staro 23.11.2007., 11:35   #367
Jelc
Super Moderators
Postovi: 17,485
Autor lajchi Pregled postova
Izvolte gospodine
Fala
Bemti, ja na medium imam 26 FPS-a a ova grafa više nego duplo...
Dakle pametnom kombinacijom high-medium detalja bi se mogao dobiti fini frame-rate a da igra dobro zgleda
Staro 23.11.2007., 12:21   #368
Roberto
Roberto's Avatar
Postovi: 2,651
Ma da dobro izgleda.... Izvrsno izgleda!
A najavljuje se i pad cijena 38xx serije kroz tjedan dva, kud ćeš bolje (Eto zašto ne treba odmah kupiti nove stvarčice)
Staro 23.11.2007., 12:27   #369
lajchi
Postovi: 506
Autor Roberto Pregled postova
Ja sretan jer me jeftino ispala, a drugi mjesec 100% kupujem još jednu
Staro 23.11.2007., 12:30   #370
Razer
Razer's Avatar
Postovi: 11,642
Pad cijena jest najavljen, samo nekako sumnjam da će se to kod nas ''osjetiti'', ali nada umire posljednja
Staro 23.11.2007., 12:31   #371
LAcy
Pink Floyd fan
LAcy's Avatar
Lokacija: Santa Clara, CA
Postovi: 5,545
A neki kažu i da je nada ku*va
Core i7-6700K LGA1151 Skylake
RTX 2080 TI 11GB GDDR6
Samsung 850 EVO M.2 1TB SSD
MacBook M1 Pro
MacBook Air M2
Moto Edge
LAcy je online   Reply With Quote
Staro 23.11.2007., 12:45   #372
Jelc
Super Moderators
Postovi: 17,485
Nekaj se LAcy u zadnje vrijeme često zatekne na ATI podforumu-nije vrag da bude prešao na ATI???
Staro 23.11.2007., 12:49   #373
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,545
Misliš da pređem u crveni tabor? Odnosno zeleni? nVidia je zelena i AMD je zelen, baš su ga zapetljali
Ja imam namjeru mijenjati grafičku. Sad pratim i gledam što bih, čekam do 03.12. kada bi trebal izaći nova GTS. Nakon toga datuma odvagnem i uz konzultaciju kolega sa foruma odlučim što.
Imao sam kratko vrijeme ATI u kompu i ugodno me iznenadio. Pamtim ga kao proizvod sa iznimno mušićavim driverima ali sad mi se čini da je situacija obrnuta.
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 23.11.2007., 13:04   #374
Momir
Momir's Avatar
Postovi: 1,011
Taman pad cijena za tjedan ili dva, ma mozda i dobro sto nisam oma imao novce
Doduse, kako ce se to odraziti na nase trziste, e to je vec problem.
Momir je offline   Reply With Quote
Staro 23.11.2007., 13:06   #375
Roberto
Roberto's Avatar
Postovi: 2,651
Nekako se i meni čini da jenjava ''8800gt opsesija''
Što se cijena tiče, mislim da bi one išle dolje i bez ove najave. Trgovci kod nas uvijek po dolasku ovakve robe stave malo višu cijenu za prvi ulov, a za relativno kratko vrijeme to padne na neku razumniju cijenu. Naravno, ne treba očekivati 3850 ispo 1000kn za dva tjedna
Staro 23.11.2007., 13:40   #376
Swarm dude
Premium moderator
Swarm dude's Avatar
Postovi: 4,600
Pad cijena, na koliko bi pale?
MBO: MSI 760GM-E51 FX
VGA: Nvidia Quadro K600
SSD: Crucial BX500 1TB
Staro 23.11.2007., 14:01   #377
Roberto
Roberto's Avatar
Postovi: 2,651
Autor Swarm dude Pregled postova
Ne spominju se brojke, ali za očekivati je nekih 10%,možda još malo niže i za Božić
Staro 23.11.2007., 14:13   #378
antrax
antrax's Avatar
Lokacija: Vz - Zg
Postovi: 2,930
hmm.. ako envidija i a(md)ti uspiju proizvesti do bozica neku enormnu kolicini 38x0 i 8800 g92 kartica koje ce se sve razgrabit ma kako bilo moglo bi se desit da napokon proizvodaci igara pocnu optimizirat te igre pa da se malo duze mozemo igrat posto ce to prakticki bit jedini cipovi u opticaju
Msi x79a GD65
Intel i7 3930k @ 4.7 1.4V
4x 4GB Kingston 1866 9-11-9
Gigabyte gtx 460 1gb
Samsung 830 128GB
640GB WD AAKS
WD green 1.5TB
LG drzac za kavu
Seasonic S12 500W
Coolermaster Stacker 831
HP LP2065 / LG IPS231P
Windows 7 Enterprise
Trenutno nepostojeci
Staro 23.11.2007., 14:21   #379
Postovi: 7,568
Autor antrax Pregled postova
TSMC i UMC su za AMD već sad proizveli (u usporedbi s 8800GT zalihom) enormnu količinu kartica. nVidia šuti o daljnoj raspoloživosti G92 čipova, a priča se da bude 8800GTS G92 128SPa stigel u manjim količinama nego kaj je to bil slučaj s 8800GT.
Staro 23.11.2007., 14:23   #380
antrax
antrax's Avatar
Lokacija: Vz - Zg
Postovi: 2,930
ma znam znam, al nadam se da ce svaki isporucit jos 5x tolko (mislim, nemoguce, al ajd) pa da preplave trziste i da ih svi imamo... ah pusti snovi
Msi x79a GD65
Samsung 830 128GB
640GB WD AAKS
WD green 1.5TB
LG drzac za kavu
Seasonic S12 500W
Staro 23.11.2007., 14:29   #381
Postovi: 7,568
AMD more preplavit tržište (ne baš s 5x većom količinom, ali more). S tim da daljnim rezanjem cijena HD 3800 serije i nVidia mora stavit kakav popust, ako hoće prodat svoje kartice. Jeftinija izrada čipova za HD 3800 seriju, brutalni zahtjevi (od strane Della i HPa) za G80 modelima, rokovi za nove kartice i mjesec dana uranjen izlazak 8800GT su glavni razlozi za slabu dobavljivost i (pre)visoke cijene 8800GT kartica.
Staro 23.11.2007., 14:34   #382
SRV
SRV's Avatar
Lokacija: n/a
Postovi: 6,128
I to je steta, jer nece doc do nekog pada cijena 38x0 kartica. Jer nece bit potrebe pored fantomske 8800GT. A 3850 zapravo ionako nema konkurenciju.
Staro 23.11.2007., 14:40   #383
Postovi: 7,568
IMHO ~1.300 kn za HD 3850 i ~1.700 kn za HD 3870 su i više nego pristojne cijene za ono kaj kartice nude. Naravno da je bolje da budu još jeftinije, ali ako su ljudi (kad je još bila nova) pokupovali 8800GTS 320 koja je bila debelo iznad 2.000 kn, nema sumnje da bude i HD 3800 serija našla sretne vlasnike. Još ako u međuvremenu (spominje se 29.11 pa nadalje) cijene padnu za koju kunu - di ćeš bolje.
Staro 23.11.2007., 14:58   #384
celzus
Lokacija: sisak
Postovi: 19
Gdje kupiti hd3850 bez čekanja
Dakle, jel zna tko gdje bi se to sutra moglo kupiti? Većina ovih sa nabave, nemaju i moraju naručivati, pa me zanima dali ima neka trgovina u kojoj je ta kartica raspoloživa odmah.
celzus je offline   Reply With Quote
Staro 23.11.2007., 15:09   #385
tech
Postovi: 1,687
Vjerojatno u ni jednoj, kartica je tek u ponedjeljak izasla...
Staro 23.11.2007., 17:03   #386
Jelc
Super Moderators
Postovi: 17,485
Autor zippo Pregled postova
Ma, javili mi sa više strana
Autor LAcy
Pa, od revizije do revizije drivera...ali da, generalno gledajući je
Staro 23.11.2007., 18:52   #387
elvis again
In the ghetto
elvis again's Avatar
Postovi: 1,943
U vemilu je 3870 po cjeni od 1621kn - jako dobra kupnja
AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor
elvis again je offline   Reply With Quote
Staro 23.11.2007., 19:05   #388
buljo
Strichek Moderator
buljo's Avatar
Postovi: 9,345
Znači ipak nisam pogriješio što sam ubrzao sa kupnjom ove moje, ispala je ipak best buy (naravno ne po cijeni koja je u dučanu)
žmnpp
Staro 23.11.2007., 19:22   #389
zippo
herr Flick
zippo's Avatar
Postovi: 2,085
Autor buljo Pregled postova
Ma kakvi, imamo kartice koje "jedu malu decu" i mirni smo koji mjesec
Staro 23.11.2007., 19:29   #390
Kobe
Kobe's Avatar
Lokacija: Ispod zvijezda
Postovi: 95
Talking
Veoma ugodno iznenađenje, očekivao sam cijenu od 1900 kn, kad ono 1621 kn. Sreća da sam pričekao sa kupnjom.
Kobe je offline   Reply With Quote
