Staro 20.02.2004., 15:00   #1
cyclone
life is a rollercoaster..
cyclone's Avatar
Datum registracije: Dec 2003
Lokacija: Sl Brod
Postovi: 554
Recite sta ne valja
Evo kupujem komp pa recite sta mislite o ovim komponentama=>
-LG 17" T710BH, 70KHz, 1280x1024/60Hz, 0.25mm, Smart Flat CDT, BrightView, -TCO99
-DDR 256 MB 184 pin, 433MHz, SuperRAM, KINGMAX x2
-CPU AMD Athlon XP 2500+ Barton, Socket A MHz
-Thermaltake VOLCANO 11+
-MB EPoX 8RDA3+, Socket A, NVIDIA nForce 2 SPP+MCP, FSB 266/333/400, -UDMA133, Serial ATA, 5PCI, AGP(8x), 3DDR, 6 channel sound, Dual LAN, 2xIEEE 1394, USB 2.0, ATX
-EPoX IR Adapter (5.25")
-HDD Maxtor 6Y120L0, ATA133, 120 GB/2MB/7200rpm
-DVD+RW/-RW NEC ND-1300A, DVD+R (4x), DVD+RW (2.4x), DVD-R (4x), DVD--RW(2x), CD-R (16x), CD-RW (10x), 2MB buffer
-GIGABYTE Radeon 9600XT 128MB DDR, TV-out, DVI-out, AGP 8x, retail
-TEAC Power Max PM-100
-Logitech Value Keyboard, HR raspored tipki, OEM
-LOGITECH mouse optical, 3-button s kotačićem PS/2 S69
-CODEGEN midi tower 6083L-1, 400W, P4, USB+FAN, PC bijela; 495x182x425; 5.25"x4, 3.5"x2, 3.5" (hidden)x1
-Titan TTC-HD82 hladnjak za HDD, Aluminum Heat Sink, 2 Fans, ball bearing
7225,00
Eto sta bi valjalo promijeniti???
cyclone je offline   Reply With Quote
Staro 20.02.2004., 15:12   #2
Isus
Headbangig Grunf!
Isus's Avatar
Datum registracije: Aug 2003
Lokacija: headbanger's ball
Postovi: 4,373
Maticnu u ABIT nF7-sl ili Epox 8RDA+
Cooler u Thermalright SK7 ili Spire Falcon rock II ili Zalman 7000ACu-OBavezno kao ti je sluh mio!!
Napajanje u Neko brand npr. Chieftzec 360W ili ENermax, AOpen/Fortron, Tagan 350W-TO oBavezno!
Grunf je moj idol!
Moji Grunf type modovi
Alfisti site, Alfisti forum
Staro 20.02.2004., 15:35   #3
Sky
Datum registracije: Apr 2003
Postovi: 4,085
Eventualno hard da ima 8 Mb cachea, uz dobar airflow ti neće trebati hladnjak za HDD, na mišonji nemoj štedit (MX500, anyone), i ovo što je Isus napisao.
Staro 20.02.2004., 19:00   #4
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Možda Samsung, još kad bi bio NF.
Vrlo dobro, sjedi 4+.
Nšto od predloženih (moj favorit nf7).
Sasvim u redu. Možda 8MB cahea.
Čua da ima dosta škarta. Možda pionirac kakav.
OK.
Ak baš moraš. Inaće logitech je zakon za mišonje.
Ajd, prođe ali promjeni napajanje. Barem chifa 300 W (oko 300kn).
Nemoj, prijedloge si čuo.
Staro 20.02.2004., 20:57   #5
Chozen
Chozen's Avatar
Lokacija: Okolica Čakovca, točnije Pretetinec
Postovi: 313
OK.
Slažem se.
Chozen je offline   Reply With Quote
Staro 20.02.2004., 23:46   #6
vga killer
Treba kaj skurit??
vga killer's Avatar
Lokacija: Zgb
Postovi: 4,025
Monitor: Samsung 765MB, nikako 757NF (slika očajna, sva žučkasta)
Matična: Abit NF7
HDD: WD 1200JB, 120GB, 8MB cachea
Hladnjak: Zalman 7000ACu, ali ćeš ga za NF7 morat malo modat
Staro 21.02.2004., 09:33   #7
cyclone
cyclone's Avatar
Lokacija: Sl Brod
Postovi: 554
THX na prijedlozima...
BTW VGA killer kako mislis modat cooler??
Znam da nije kompatibilan sa Abitovom plocom jer je malo poveci i nestandardan, pa je to i razlog zasto sam ubacio ovaj.
Jel ima koja standardna verzija Zalmana ili da ubacim neku kombinaciju themalright+ jos neki enermax ili slicno??
Razmisljao sam onaj Thermalright slk-900a i papst 80x80 jel to valja??
Muci me samo taj hladnjak jer nije kompatibilan sa NF-7, ima sta da je u tom rangu a da nije vodeno hladjenje i da sluzi a da se ne cuje kao motorna pila?
Staro 21.02.2004., 09:53   #8
vga killer
Treba kaj skurit??
vga killer's Avatar
Lokacija: Zgb
Postovi: 4,025
Kak imaš sa svake strane ona dva utora za šarafit. Unutarnji je za Intel i za socket A, a vanjski za socket 740. On je otpilio samo s jedne strane ovaj za socket 740 i sve stane.
Staro 21.02.2004., 12:44   #9
rendula
Lokacija: Zagreb, Trešnjevka
Postovi: 5,771
Od Thermalrighta uzmi SLK900A sa Papstom 92mm.
Staro 21.02.2004., 15:17   #10
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
NF? Misliš možda na DFX? NF ima super sliku i jedan je od boljih monitora u klasi.
Staro 21.02.2004., 17:17   #11
vga killer
Treba kaj skurit??
vga killer's Avatar
Lokacija: Zgb
Postovi: 4,025
Imao sam na svoj komp spojen 959NF i 757NF. Slika na 959 je odlična dok mi je slika na 757 bila stvarno očajna. Možda loša verzija, ne znam.
Staro 21.02.2004., 17:57   #12
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,963
Možda loša verzija
Vjerojatno, nisam još vidio žučkastoga na NF serijama...
Staro 21.02.2004., 18:01   #13
vga killer
Treba kaj skurit??
vga killer's Avatar
Lokacija: Zgb
Postovi: 4,025
Ni ja, al ovaj doma je užasan.
Staro 22.02.2004., 00:25   #14
Isus
Headbangig Grunf!
Isus's Avatar
Postovi: 4,373
Sigurno loša verzija!
Grunf je moj idol!
Staro 22.02.2004., 01:21   #15
vga killer
Treba kaj skurit??
vga killer's Avatar
Lokacija: Zgb
Postovi: 4,025
To ti je moja sreća.
A kaj je još bolje, postavke slike su bile identične postavkaama na 959NF-u i nikak nisam uspio popravit sliku.
Staro 22.02.2004., 09:23   #16
LordNitro
LordNitro's Avatar
Postovi: 1,610
Ja samo čitam i smijem se.Neki na forumu baš nemaju sreće!
Kirk: "Spock, you want to know something? Everybody's Human."
Spock: "I find that remark... insulting."
LordNitro je offline   Reply With Quote
Staro 22.02.2004., 10:19   #17
vga killer
Treba kaj skurit??
vga killer's Avatar
Lokacija: Zgb
Postovi: 4,025
Baš ti hvala.
