Staro 10.10.2007., 17:18   #1
mdrla
mdrla's Avatar
Lokacija: ZG Dubrava
Postovi: 471
savjet za starudiju!
imam ovu MBO:
Motherboard ID 01/10/2001-8363-686B-6A6LMB09C-00
Motherboard Name Biostar M7VKB
Front Side Bus Properties
Bus Type DEC Alpha EV6
Bus Width 64-bit
Real Clock 100 MHz (DDR)
Effective Clock 200 MHz
Bandwidth 1600 MB/s
Memory Bus Properties
Bus Type SDR SDRAM
Bus Width 64-bit
DRAM:FSB Ratio 1:1
Real Clock 100 MHz
Effective Clock 100 MHz
Bandwidth 800 MB/s
Chipset Bus Properties
Bus Type PCI
Bus Width 32-bit
Real Clock 33 MHz
Effective Clock 33 MHz
Bandwidth 133 MB/s
Motherboard Size 220 mm x 300 mm
Motherboard Chipset KT133
Biostar Group
pa me zanima koji nabrzi amd ide u ovu starudiju, jel moze koji od xp+?
unaprijed zahvaljujem!
mdrla je offline   Reply With Quote
Staro 10.10.2007., 23:53   #2
SetH
SetH's Avatar
Lokacija: DS
Postovi: 3,327
vjerovatno može...
SetH je offline   Reply With Quote
Staro 16.10.2007., 18:17   #3
maX
maX's Avatar
Postovi: 7,326
mozda ce ic, a mozda i nece, treba probat...
Staro 16.10.2007., 19:28   #4
fanATIk
NITKOV
fanATIk's Avatar
Lokacija: Maksimir / Dugave
Postovi: 4,016
Autor mad max Pregled postova
baš si mu pomogao...
Asrock FM2A78M-DG3+
G.SKILL RipjawsX series 8 GB
Palit GTX 460
Corsair VS550
Thermaltake Core V21
22"LCD LG W2242T
MX Revolution
Logitech X-230
Logitech K740
Canon CanoScan 4400F
Win 10
Unique case by fanATIk
Avatar BIG SIZE
Staro 16.10.2007., 19:33   #5
maX
maX's Avatar
Postovi: 7,326
a ***ga, ja sam imao par KT133 ploca, na nekima je radilo, a neke nisu htjele bootat... jedino da mu netko veli tko ima tocno takvu plocu onda moze biti ziher ili da malo progugla...
