Staro 08.10.2007., 15:55   #1
Jaymz
Fallen
Jaymz's Avatar
Postovi: 237
Misljenje i mala pomoc
Pozdrav ljudi .
Evo napokon sam skupio nekakve novce pa se bacam u kupnju nove konfe .
Vec 2 dana proucavam forum i vase preporuke pa sam uspio sastavit ovako nesto (sve iz linksa),te bih vas zamolio za misljenje/prijedloge:
MBO ASROCK ConRoeXFire-eSATA2, i945P, DDR2, zvuk, S-ATA, G-LAN, PCI-E, s. 775
ili
MBO GIGABYTE 965P-DS3, i965, DDR2, zvuk, G-LAN, S-ATA, PCI-E, s. 775
ili
MBO ASUS P5B-MX/WIFI-AP, Intel 946GZ, DDR2, zvuk, G-LAN, S-ATA, PCI-E, s. 775
CPU INTEL DualCore E2180 2000MHz BOX, socket 775, 1Mb c., FSB 800MHz, 64 bit
RAM PC-5300, 1024MB, DDR2, CRUCIAL, 667 MHz
HDD 250.0 GB SEAGATE, Serial ATA II, 16MB cache, NCQ, 7200 okr/min
VGA PCI-E GAINWARD Bliss 7600GT, GeForce 7600GT SILENT FX, 256MB DDR3, 2xDVI, TV
Napajanje COOLERMASTER 430W, RS-430-PCAP, Super Silent, eXtreme power, ATX2 v2
Kućište APLUS CS-188A PC Case, with 250 mm fan, w/o PSU, RoHS
Monitor 20'' LCD SAMSUNG SM 2032BW, wide, 2ms, 300cd/m2, 1000:1, crni
Kao sto vidite imam dilemu oko 3 ploce pa ako bi mi mogli pomoc u odabiru
ps. Citao sam da dosta ekipe hvali gainward 7600gs , ali je nisam mogao pronac nigdje u ducanu.
Zasad cu uzet samo gigu rama, planiram sljedeci mjesec uzet jos jedan keks
I da , granica mi je nekih 5600-5700kn .
Jaymz je offline   Reply With Quote
Staro 08.10.2007., 16:33   #2
elvis again
In the ghetto
elvis again's Avatar
Postovi: 1,943
AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor
elvis again je offline   Reply With Quote
Staro 08.10.2007., 18:33   #3
Jaymz
Fallen
Jaymz's Avatar
Postovi: 237
Thnx na prijedlozima ali favoriziram nvidiju i nisam neki ultimate gamer (radim u cubaseu) .Uzet cu u obzir fortrona i samsunga
btw. Ako mi mozes samo objasnit zasto gigabyte i e4400 "osim" sto ima 2mb c. ali je i skuplji i prelazi granicu od 5700kn koliko imam za utrosit
Staro 08.10.2007., 19:20   #4
ECHO
Lokacija: CROATIA-Vukovar
Postovi: 2,354
pozdrav
Ja osobno nebi mjenjao napajanje koje si odabrao CoolerMaster 430W je odlično napajanje a glede MBO pa trenutno je P35 čipset noviji od gore odabranih i bolji a Gigabyte trenutno nudi odlične i povoljne(cijene)ploča sa gore navedenim P35 chipsetom.Nemora biti Gigabyte ploča može i Asusova ali ako se uklapa u cijenu neka P5k i sl.I procesor je dobar 2180=1MB cache i jeftiniji je od E4400 a razlika je u 2MB cache oba dva proca su odlična za clockanje
Staro 08.10.2007., 20:29   #5
Jaymz
Fallen
Jaymz's Avatar
Postovi: 237
onda mozda : MBO GIGABYTE P35-S3, iP35, DDR2, zvuk, G-LAN, S-ATA, PCI-E, s. 775 ?
ucio sam da su ovi rami brzi i jeftiniji :
RAM PC-6400, 1024MB, DDR2, CRUCIAL, Rendition, 800 MHz
ili mozda da uzmem malo skuplje a jos brze :
RAM PC-8500, 1024MB, DDR2, KINGMAX (KLED4), DDR 1066
Staro 08.10.2007., 20:56   #6
elvis again
In the ghetto
Postovi: 1,943
RAM PC-6400, 1024MB, DDR2, CRUCIAL, Rendition, 800 MHz je dobar ram slobodno uzmi
Staro 08.10.2007., 23:32   #7
Jaymz
Fallen
Jaymz's Avatar
Postovi: 237
ovako konacno izgleda sad , imam jos nesto siche pa sam dodao samsunga :
MBO
788kn
655kn
275kn
HDD 320.0 GB SAMSUNG, Serial ATA II, 16MB cache, 7200 okr/min
566kn
787 kn
403kn
337kn
2.099kn
_________________________________________________________________________
= 5.911 kn
kaj velite
bode me u oci kaj onaj 4400 ima 2mb c.(mislim da bi mi to dobro doslo za audio editing) i kaj nemogu nac nigdje tu gainward 7600gs
komp je za home recording (cubase , nuendo , FL,wavelab i slicno ) i malo za zaigrat tu i tamo
ps . optiku imam , dvd przu
Staro 09.10.2007., 00:15   #8
ECHO
Postovi: 2,354
pozdrav
Da sve dobro posloženo i ja mislim da se isplati dodati tih 120-ak kuniča za E4400 a dobro češ ih iskoristiti u aplikacijama kojima radiš sve je tvoja volja(financ. mogučnosti)
Staro 09.10.2007., 00:25   #9
Jaymz
Fallen
Jaymz's Avatar
Postovi: 237
a mozda nesto skubiciram pa uzmem i 4400
Mislil da cu ipak komp uzet u adm-u ,kaj kazete na ovo :
Gigabyte P35-S3, s775, intel P35+ICH9, FSB 1333/1066/800MHz
761kn
Procesor Intel Core 2 Duo E4400 , 2.0GHz, socket 775, 2Mb cache,
768kn
DDR2 1024Mb PC6400 SuperTalent, T800UB1GC5 , pasivni hladnjak, C
289kn
HDD SAMSUNG SpinPoint T166 320GB 7200rpm 16MB cache Serial ATAII
549kn
Gainward Bliss 7600GT 256Mb 128bit, DDR3, TV out, 2xDVI
769kn
403kn ----LINKS
Aplus CS-188A PC Case, with 250 mm fan, w/o PSU, RoHS
350kn
SM 2032BW, Dijagonala 20", Veličina piksela [mm] 0,258
2.095
~5950kn
jedino cu po napajanje morat u links, a mozda uzmem i ram kod njih
Zadnje izmijenjeno od: Jaymz. 09.10.2007. u 13:35.
Staro 09.10.2007., 01:00   #10
Jaymz
Fallen
Jaymz's Avatar
Postovi: 237
misljenje hitno jel kupujem komp sutra-prekosutra
Staro 09.10.2007., 02:00   #11
Zaramoth
Killing monsters
Zaramoth's Avatar
Postovi: 435
Konfa je fino slozhena, slobodno kupuj.
Ali...samo jedna sitnica: varaju li me ochi ili je to stvarno samo jedna giga rama ubachena u tu mashinu?
Ako jest, shteta bi bilo ne navuchi josh kakvih 250 kn pa uzeti 2 gige.
Zaramoth je offline   Reply With Quote
Staro 09.10.2007., 02:20   #12
Jaymz
Fallen
Jaymz's Avatar
Postovi: 237
Je , jedna giga je , ali samo za pocetak
Sljedeci mjesec uzimam jos jedan keks i zvucnu
Staro 10.10.2007., 23:47   #13
Jaymz
Fallen
Jaymz's Avatar
Postovi: 237
U petak cu do ADMa, nadam se da ce imat sve komponente koje sam si izabral
Staro 12.10.2007., 00:32   #14
Jaymz
Fallen
Jaymz's Avatar
Postovi: 237
Staro 12.10.2007., 01:14   #15
ECHO
Postovi: 2,354
pozdrav
VGA Ati Radeon X1950GT, 256Mb GDDR3, 256bit, Dual DVI, PCI X=855KN
uzmi tu grafu bolja je od te dve koju si naveo.Odgovorio sam ti na poruku.
