Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Radeon HD 2950PRO (RV670) Launch on Nov 19
Kakti ![]() Nadam se. I tako to... Earlier we told you that RV670 will launch in mid Nov and now DigiTimes has the exact date, which is November 19th. According to them, AMD has recently notified graphics card makers that DVT samples will be sent out at the beginning of this month and AMD will start producing a batch of 1.5 million chips in the first week of November. The Radeon HD 2950PRO will continue to adopt the R600 chip structure. It will support DirectX 10.1, Shader Model 4.0, PCI Express 2.0, UVD and CrossFire technology. The chip also features built-in HDMI, HDCP and 320 stream processors per GPU. http://www.vr-zone.com/articles/Rade...v_19/5307.html AMD is preparing to launch its new Radeon HD 2950PRO (RV670) chip on November 19, according to sources at graphics card makers. The company recently notified graphics card makers that design verification test (DVT) samples will be sent out at the beginning of this month and AMD will start producing a batch of 1.5 million chips in the first week of November. The Radeon HD 2950PRO will continue to adopt the R600 chip structure. It will support DirectX 10.1, Shader Model 4.0, PCI Express 2.0, UVD and CrossFire technology. The chip also features built-in HDMI, HDCP and 320 stream processors per GPU. The Radeon HD 2950PRO will come in two versions, Gladiator and Revival, with Gladiator adopting 512MB GDDR4 graphics memory, a GPU frequency of 825MHz and a memory frequency of 2.4GHz. Revival will adopt 256/512MB GDDR3 graphics memory, a GPU frequency of 750MHz and a memory frequency of 1.8GHz. AMD declined the opportunity to comment on this report saying it cannot comment on unannounced products. http://www.digitimes.com/mobos/a20071001PD211.html
Lokacija: n/a
Postovi: 6,128
Vec polako razmisljam da ubrzo prodam ovu X1950GT i pocnem skupljat lovu ovu 2950 ![]() |
Super Moderators
Postovi: 17,485
Nadam se samo da ih i budu izbacili po ovoj najavi ![]()
Postovi: 7,568
Super Moderators
Postovi: 17,485
Postovi: 1,011
Super Moderators
Postovi: 17,485
Nemam blage za cijenu ali mislim da je to klasa grafi koja će se takmičiti sa 8800GT (G92) Bar sam ja stekao takav dojam...
#9 | |
Lokacija: n/a
Postovi: 6,128
HD2950Pro ce biti takmac protiv 8800GT, a obje ce sasvim sigurno biti jeftinije od 2000kn. Prije oko 1600kn. Ne znam tocno gdje ce tu biti HD2950GT. |
Postovi: 11,642
Hmmm, bit će interesantno vidjeti kako će na kraju sve to ispasti. Ako izlasci budu kako su najavljeni, mogu svoju polako spremati za prodaju ![]() |
Postovi: 7,568
2900Pro i GT u zemljama u kojima su trenutačno dobavljivi, pa 2950Pro i GT i svi su negdje cijenom i očekivanim performansama oko GTS 320/640 modela. Još ako nVidia odluči dati EOL za 320 nakon kaj stigne 8800GT (i još se pokaže malo boljom?), eto gužve u 1.400 do 2.000 kn. Jedino ova GTS 640 sa 112 stream procesorčeta malo odskače od veselog društva. ![]() |
Wannabe Pilot
Lokacija: High In The Sky
Postovi: 493
Prvi puta u životu mislim ozbiljno preći na ATi. Ova 2950Pro/GT mi se čini odličnom, pogotovo ova Gladiator verzija s 512MB GDDR4 memorijom. Da li će mi se isplatiti ići s 8800GTS 320 na 2950Pro/GT 512MB GDDR4?
#14 | |
Avocado
Postovi: 7,850
ja cekam da dode kod nas 2950 onda prodajem dionice ![]()
Spoiler alert! |
Lokacija: Sinj
Postovi: 1,080
Novosti i slike vezane za HD2950GT i HD2950Pro Baš lijepi nasljednici x1950GT/Pro kartica... ![]() edit:nisam vidio jelcovu temu, prebacite tamo post!
#17 |
Lost soul still wondering
Lokacija: Aiur
Postovi: 474
Ja se samo nadam da će smanjiti potrošnju energije jer ove 2900 pro i xt kartice piju struju ko vodu.
Da nije nas bile za grabu bi spal ![]() |
#19 | |
Postovi: 7,568
Da ne sfali kojem clockeru u naletu. ![]() |
#20 | |
Lokacija: n/a
Postovi: 6,128
![]() Ove 2950 ce se vrtit ispod 100W, vjerojatno oko 70W. Kao X1950Pro. ![]() |
#21 |
Postovi: 7,568
Pa se razme. Potrošnja 2900XT je samo za plašiti potencijalne kupce. Najčešće ih plaše G80 vlasnici. ![]() ![]() |
#23 |
Lokacija: n/a
Postovi: 6,128
Taj dio me najvise brine. Koliko sam vidio na fotkama, ima zaseban dio sa mosfetima koji treba hladit. Dakle nece biti dovoljno samo stavit VF900 ili nesto u tom stilu. Sjecam se da je bilo dosta problema sa zagrijavanjem digitalnih naponskih regulatora na X1950Pro karticama sa referentnim PCB-om. |
#26 | ||
Postovi: 7,568
#28 |
Super Moderators
Postovi: 17,485
Koliko se ja sjećam-clocknuta XT mi je vukla kakvih 35W više od clocknute GTS 320. Kad već pričamo o potrošnji ![]()
#29 | |
Postovi: 7,568
#30 |
Propali Amigaš
Lokacija: Nin
Postovi: 6,994
Or even better, buy two, crossfire them, and beat 8800GTX Ultra in tests, using famous "Two bad, Milosh dead" strategy |
