Staro 29.08.2007., 11:49   #121
Oklop
Postovi: 3
ista stvar se desila i mene a rjesenje je bilo sljedece
1. NVIDIA Control Panel > Display > Manage custom timings.
2. Click both "Treat as HDTV" and "Allow modes not exposed by the display"
3. Click [Create...]
4. Under Custom display mode values:
Horizontal desktop pixels: (Example: 1440)
Vertical desktop lines: (Example: 900
GDI Refresh rate: (max supported by your monitor at desired resolution)
Bits per pixel: 32
(don't have "Interlaced" checked)
5. Click [Advanced >>]
6. Under "Back-end parameters":
Timing standard: DMT
Desired refresh rate: (max supported by your monitor at desired resolution)
(the rest of the fields are grayed out)
7. Under "Front-end paramers"
Scaling type: Display (none)
8. Click [Test]
9. Click [OK]
opd br2 je ono sto je falilo da bi uspjelo...
Oklop je offline   Reply With Quote
Staro 01.09.2007., 23:16   #122
hipi
Lokacija: nin
Postovi: 133
Driver za NIVIDIA geforce 6600
Posto vec dugo vremena iman ovu NIVIDIA geforce 6600 graficku karticu i jos nikad joj nisan mjenja drivere zanima me koji su naj novi za nju,I gdje ga mogu skinit ako netko zna link za skidanje neka mi ga napise.
Unaprijed hvala.
hipi je offline   Reply With Quote
Staro 01.09.2007., 23:25   #123
Tekla
Tekla's Avatar
Lokacija: livno
Postovi: 1,065
skini sebi drivere 94,24.ja te imam na 6600GT.skino sam ih s nvidia.
Tekla je offline   Reply With Quote
Staro 01.09.2007., 23:25   #124
hash
Postovi: 1,431
...del me..
Staro 02.09.2007., 11:21   #125
hipi
Lokacija: nin
Postovi: 133
znas li - sto od navedenog tamo da izaberen,pod sto ona spada.
Staro 02.09.2007., 11:53   #126
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
GeForce 6 Series --> Windows XP / 2000 i time dobijas link na 162.18WHQL drivere.
Ako hoces bas 94.24 evo ti LINK za njih.
Graphic Driver --> GeForce 6 Series --> Windows XP / 2000 i time dobijas link na 162.18WHQL drivere.
Milentije je online   Reply With Quote
Staro 05.09.2007., 09:46   #127
lol
Postovi: 1
Driver za NVidia GeForce Go 7300
Di mogu skinut nove drivere za GO 7300?
hvala
lol je offline   Reply With Quote
Staro 05.09.2007., 09:58   #128
tomek@vz
White Rabbit
tomek@vz's Avatar
Postovi: 4,993
Staro 01.10.2007., 10:29   #129
pogi
aka Mali Mirko
pogi's Avatar
Postovi: 3,108
Koje forceware drivere danas koristiti za 6800LE (AGP) ?
Dakle sve je u naslovu? Svoju 6800LE još uvijek vozim sa nekim starim driverom v81.95. Da li bi imalo kakve koristi instalirati neki driver serije 160?
PS ne prodajem "grafulju"
Verifikacija poštenog trgovca #1, #2, #3, #4, #5, #6, #7, #8, #9
Staro 01.10.2007., 10:51   #130
daytripper
Ultrabitchinfast
daytripper's Avatar
Postovi: 880
Nemoj popravljati ako nije pokvareno...
mozes probati.., zadnji su 168. serije... za sve kartice..
prijasnji su ti 94.24 prije serije 168. forcewara
Zadnje izmijenjeno od: daytripper. 01.10.2007. u 12:29.
daytripper je offline   Reply With Quote
Staro 01.10.2007., 11:07   #131
Postovi: 33,998
Instalirao sam frendu jednu takvu prije par dana i koristio sam driver za starije modele (6xxx,...) koji se nalazi na DVD-u od PC Chipa. Mislim da je neki 92.44 ili sličan. Kartica radi bez problema s njima.
Staro 09.10.2007., 12:56   #132
hrvojehrc
hrvojehrc's Avatar
Lokacija: zagreb-dubrava
Postovi: 70
7300gt driver pitanje
trebao bih drivere da maknem ono sli u trayu sa svakim paljenjem kompa pa ako bi mi netko mogao dati točan link stavio sam najnovije drivere ali nisam riješio problem,ma imao sam taj driver ali sam izbeisao sa memory usb sricka
hrvojehrc je offline   Reply With Quote
Staro 15.10.2007., 18:51   #133
MeanBoss
|CTS|MeanBoss|
MeanBoss's Avatar
Lokacija: Sinj
Postovi: 1,005
7900gs driveri...
evo nedavno stavio nove NGOHQ drivere...i nisam baš nešto oduševljen,pa me zanima vaše mišljenje i prijedlozi...original NVidija ili neki drugi?
Staro 15.10.2007., 19:06   #134
EvilM@ster
Ev1LMa5ter
EvilM@ster's Avatar
Lokacija: Koprivnica
Postovi: 675
Ja koristim XTreme-G 163.71 i mogu reci da su ok, igram na njima World in Conflict, Company of Heroes, Hitman Blood Money, MOHA, STALKER, Oblivion, FEAR, COD4 i sve igre rade ok.... samo nekad mi se zblesira kod videa u igri, ali sa CTRL+ALT+DEl izadem u wind. i ponovo se vratim i opet je ok...
androidhrvatska.com
EvilM@ster je offline   Reply With Quote
Staro 15.10.2007., 21:03   #135
Codiac
bycod
Codiac's Avatar
Lokacija: Zagreb / Dubrava
Postovi: 6,699
xtreme g dere nvidine..
.i.
Razer Blade 15
Staro 16.10.2007., 19:44   #136
IGoR_2803
IGoR_2803's Avatar
Lokacija: N/A
Postovi: 768
da li ako sad imam nvidia drivere, pa ocu staviti xtreme g, moram ove čistiti sa driver cleanerom ili mogu sam ovak instalirati?
Staro 16.10.2007., 21:13   #137
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
Preporucljivo je da ih pobrises DC-om iz safe moda.
Staro 22.10.2007., 17:11   #138
Crypt0
Crypt0's Avatar
Postovi: 174
nf590sli problem-vista driver
Molim za pomoc. Ovako stvar ide:
Instalirao sam vistu ultimate i sve je proslo ok ali kada sam instalirao driver za plocu koja je abit an9-32x fatal1ty koji sam skinuo sam nvidia starnice 15.01 verzije i stariji sa abitove starnice v1500 sistem mi se rusi i javlja ovu gresku royal.sys addres 80442389 base at 8043e000 date stamp 45e7c315 to se dogadja samo sa driverom za plocu za moj chip.HVALA
Crypt0 je offline   Reply With Quote
Staro 25.10.2007., 21:21   #139
elvis again
In the ghetto
elvis again's Avatar
Postovi: 1,943
Koji driver za Gainward Bliss 7950GT 256MB?
Koji driver bi mi preporucili? Do sad nism koristil nijeden drugi nego onaj koji dolazi s njom na CD-u. Jel bolje stavit origigi nvidiin ili neki modani? Inace OS je XP.
AMD Ryzen™ 5 3600X,Arctic Freezer A35,Kingston FURY DIMM 32 GB DDR4-3200 Kit,Gigabyte B550M AORUS PRO-P,Gigabyte 1TB, M.2 2280, NVMe 1.3 PCI-Express 3.0 x4,INNO3D GeForce RTX 3080 X3 OC LHR, 10240 MB GDDR6X,Fractal Design Meshify 2 Compact Lite White TG Clear,Corsair RM650x (2021) 650W, HPX27i 27" monitor
elvis again je offline   Reply With Quote
Staro 25.10.2007., 21:28   #140
Razer
Razer's Avatar
Postovi: 11,642
Probaj najnoviju verziju Xtreme-G drivera.
Staro 25.10.2007., 21:35   #141
elvis again
In the ghetto
Postovi: 1,943
Jel mi mozes rec koju verziju? Jer tu ih ima dosta a ja nebi htel nekaj zaj*****!
Staro 25.10.2007., 21:40   #142
Razer
Razer's Avatar
Postovi: 11,642
Za XP: XTreme-G 163.75 XP 32bit.
Staro 25.10.2007., 21:44   #143
elvis again
In the ghetto
Postovi: 1,943
Hvala.
Staro 02.11.2007., 12:24   #144
VoodooRain
VoodooRain's Avatar
Lokacija: Požega
Postovi: 706
smetnje sa novim driverima 169.01 i 169.04
evo ovako nikada vidio i nikada cuo takvo sta kada stavim ove drivere kada udjem u igre graficka mi pocme cudno fuckati zvizditi i slika mi na tv-u poludi nesto strasno pocme skakati cim izadjem iz 3D-a vrati se u normalu
VoodooRain je offline   Reply With Quote
Staro 02.11.2007., 12:39   #145
svebee
Lokacija: /
Postovi: 2,053
Autor VoodooRain Pregled postova
meni je fućkala oduvijek i još uvijek svaki put "fućka" kad ulazim u crysis..jedino u crysis - na ostalima (igrama) to nije slučaj, neznam zašto ali eto...ko da tiho "cvili" il kaj već... ali temp. normalne, grafika odlična..ne bunim se
btw. događalo se i prije ^^ drivera
svebee je offline   Reply With Quote
Staro 02.11.2007., 12:57   #146
VoodooRain
VoodooRain's Avatar
Lokacija: Požega
Postovi: 706
meni je nekad prije zafuckala ali mi je presmjesno sto poludi slika na tv-u koji je udaljen nedno 4 metra da dtugom kraju sobe i na posebnoj je utisnici i osigzracu tako da nije do struje mislim presmjesno
Staro 02.11.2007., 13:05   #147
CPU
Varanje na tržnici
Lokacija: Zabok
Postovi: 214
Start/run/dxdiag/morehelp/override/overridevalue/85 i nema zujanja
CPU je offline   Reply With Quote
Staro 02.11.2007., 13:14   #148
VoodooRain
VoodooRain's Avatar
Lokacija: Požega
Postovi: 706
e hvala zujanje nestalo ali slika jos luda na tv-u javlja se ona snijeg po sijeloj slici u vodoravnim linijama skoro preko cijeloga ekrana
Staro 16.11.2007., 18:38   #149
Majo
Lokacija: Zagreb,Dubrava
Postovi: 2,281
Angry novi driveri usporavaju igre...
ej ljudi
jeste mozda skinuli crysis demo s nvidine stranice i odmah skinuli nove drajvere???
ak jeste nemojte ih instalirat!!!!
vratite se starijim drajverima
ja imam gf 66oo i kad sam instaliro nove drajvere svako malo bi mi bilo kakva igra zastekala na tren(vise je stucalo i svakih 30ak sekundi bi mi zastekalo na 5 sekundi)igre tipa:nfsu2 crysis...
e sad jel to je zbog moje grafe a mislim da nije
kad sam se vratil na starije drajvere sve po plinu(igro crysis na 1024x768 i sve low a shadere na medium i ne trza!!!)
pa ak ima netko neka slicna iskustva neka to podijeli a ak se samo to meni desava onda...
P.S.-posto se radi o nvidinijim drajverima stavil sam ih tu
Majo je offline   Reply With Quote
Staro 17.11.2007., 07:50   #150
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Ja sam skinuo Crysis i imao sam prilično nove drivere još od prije instalirane (sad dal je ona kad sam se s njim zabavljao bila baš aktualna verzija neznam više ali sad je) i meni nije trzalo ništa...
Sad nemam crysis demoa vipe na kompu ali ništa od ostalih mi ne trza...
Have a nice day...
