Staro 02.09.2007., 13:49   #91
MASVA
MIUI HR Translator
MASVA's Avatar
Lokacija: Krapina
Postovi: 632
NEMA VIŠE BRUTEFORCINGA!!!!!
ako želite napraviti full flash i custom ovo je prava stvar
trebate SEToolLite2 v1.07
http://www.savefile.com/files/992768
instarlirati usb flash generic driver koji vam je unutra
otvorite setoollite
izaberite model moba(w810 u ovom slučaju)
kliknuti add i dodati MAIN pa FS
sad kliknite na MISC files i dodajte custom(tpa mapu iz koje napraviti zip file)
sad kliknite flash i pratite upute
Phone detached
Elapsed:xxx secs.
gotovo
tako možete modati acoustic,kameru,flash teme,meni i ikone,itd
ako želite npr promijeniti driver za kameru napravite path
ifs/settings/camera/tu driver
od toga napravite zip file i isto napraviti kao i za custom
welcome to setool2 lite edition v 1.07
supported DB2010/DB2012 CID49/50/51, DB2020 CID49/51/52
Loaded 51 flash descriptors
ChipID:8040,EMP protocol:0301
PHONE IS RED RETAIL PRODUCT
FLASH CID detected:49
Speed:921600
OTP LOCKED:1 CID:49 PAF:1 IMEI:35906100546405 CERT:RED
PATCH:061204 1529 HAN_DB2010_MEM_PATCHER_R2A007_CXC9876543210 0
LDR:060718 0842 LIE_DB2010_FLASHLOADER_R2A003_CXC1326738
Flash ID check:2019
Flash props sent ok
DETACH CABLE FROM PHONE.
REMOVE BATTERY FROM PHONE, THEN INSERT IT BACK
THEN PRESS "READY"
Speed:921600
Trying to launch embedded bootloader...
Embedded flashloader:
COMPACT_ID_LOADER_CRIPPLED_SETOOL2_R2
Flash ID check:2019
Flash props sent ok
FOUND: R4EA031_CXC1250316_GENERIC_HN
Restore from:R4EA031_CXC1250316_GENERIC_HN
CSloader version:
SETOOL2 LITE COMPACT_SEMC_FS_LOADER (FAT V26)
loader startup: executed
loader filesystem startup: executed
loader GDFS startup: executed
Writing package...
Directory: ifs/settings/camera/
camdriver0.dat (20456)
Phone detached
Elapsed:69 secs.
MIUI HR Translator
MASVA je offline   Reply With Quote
Staro 15.09.2007., 13:27   #92
tutix
tutix's Avatar
Postovi: 4,068
Kako se ovo može napravit sa W200i? Mob je brandan kod TMobile-a, jel isti postupak kao i sa W810i?
Može i neki koristan link, jer mi Google ne izbacuje ništa.
W200i Flash theme video
Staro 15.09.2007., 13:47   #93
MASVA
MIUI HR Translator
MASVA's Avatar
Lokacija: Krapina
Postovi: 632
Autor tutix Pregled postova
možeš i w200 flešati na taj način samo očitaj mob da vidiš koji je CID da znaš koji firmware skinuti(50,51 ili 52)
MIUI HR Translator
Staro 15.09.2007., 13:54   #94
tutix
tutix's Avatar
Postovi: 4,068
Autor MASVA Pregled postova
A gdje skinut firmware? Jel mogu kako spremit firmware koji imam trenutno, zbog garancije?
Teme za W200i imam. Znači sve isto, napunit mob, XS++ ubacit teme, editirat XML i to je to.
Staro 15.09.2007., 15:11   #95
MASVA
MIUI HR Translator
MASVA's Avatar
Lokacija: Krapina
Postovi: 632
sa setoolom napraviš sve za 15 minuta
imaš na top sony-u orig.firmware i custom
MIUI HR Translator
Staro 15.09.2007., 15:36   #96
tutix
tutix's Avatar
Postovi: 4,068
Da, ali od tamo ne mogu ništa skinut. Kaže Restricted i uputi me na PayPal. Uglavnom mi se sad mob puni pa ću vidjet. Dodao sam te na ICQ, pa kad ćeš imat koju minutu da mi pomogneš s ovim.
Naišao sam i na ovo. Ali nisam siguran mogu li ovako (s tim file-ovima) to napravit, ipak su ovdje Rumunji u igri.
Staro 15.09.2007., 17:54   #97
MASVA
MIUI HR Translator
MASVA's Avatar
Lokacija: Krapina
Postovi: 632
skinem ti ja nema beda samo vidi koji cid imaš da znam koji firmware skinuti
sad trebaš MAIN_GENERIC i FS_S_E_EUROPE i custom kojeg sam naveo da napraviš debrand samo javi taj CID
MIUI HR Translator
Staro 15.09.2007., 20:23   #98
tutix
tutix's Avatar
Postovi: 4,068
E ovak CID je 52. Evo slikica:
Staro 15.09.2007., 21:44   #99
MASVA
MIUI HR Translator
MASVA's Avatar
Lokacija: Krapina
Postovi: 632
imaš ovdje što možeš sve modati na w200
http://www.centrumse.pl/forum/index.php?showtopic=22490
MIUI HR Translator
Staro 15.09.2007., 21:47   #100
tutix
tutix's Avatar
Postovi: 4,068
Uf sad bi dao svoj Engleski za Poljski, al snaći ću se. Puno hvala na pomoći.
Staro 15.09.2007., 22:22   #101
Hrconja
Hrconja's Avatar
Postovi: 1,615
koristi google translate, ako ima poljski :/
Hrconja je online   Reply With Quote
Staro 15.09.2007., 23:04   #102
tutix
tutix's Avatar
Postovi: 4,068
Uspio sam flashnut mob, ali sad mi ne ocitava SIM karticu . Zeznuo sam, nisam skinuo onaj custom sa TopSony-a - ako mi netko moze skinut i uploadat na rapidshare bio bih zahvalan jer meni uporno prebacuje na Paypal.
Staro 15.09.2007., 23:13   #103
MASVA
MIUI HR Translator
MASVA's Avatar
Lokacija: Krapina
Postovi: 632
ovdje imaš najnoviji firmware za w200 i custom(zip napravljen)
http://rapidshare.com/files/55987102/W200_RAH4014.rar
MIUI HR Translator
Staro 15.09.2007., 23:21   #104
tutix
tutix's Avatar
Postovi: 4,068
U međuvremenu sam uspio preflešat neki MISC Melinda Generic i radio mi je bez beda jedino što nisam imao Hrvatski.
Sad sam ga preflashao sa tvojim fileovima i radi odlicno, imam Hrvatske izbornike, Flash Menu-e. Vidio sam da ima puno drivera za mob na ovoj Poljskoj stranici pa ću još i to ubacit.
Care, veliko hvala na pomoći .
P.S. Daj mi reci, ti si platio svoj Acc na TopSony-u ili treba proć vremena da bi mogao skidat Firmwarese?
Zadnje izmijenjeno od: tutix. 15.09.2007. u 23:42.
Staro 16.09.2007., 00:25   #105
MASVA
MIUI HR Translator
MASVA's Avatar
Lokacija: Krapina
Postovi: 632
frend mi posudio pass a meni fali još par postova da mogu skidat
MIUI HR Translator
Staro 20.09.2007., 07:44   #106
MASVA
MIUI HR Translator
MASVA's Avatar
Lokacija: Krapina
Postovi: 632
;W810 SW-R4EA031
;Remove SIM-Lock
;© IronMaster
+44140000
d12918: 70B5041CF1F2C4F900230022011C1C20 F0B505213A22D1F71FFD0020F0BDC046
riječi nisu potrebne...
MIUI HR Translator
Staro 30.09.2007., 13:07   #107
Daci
Postovi: 141
Gotove teme sa editiranim XML-ovima možete skinuti ovdje
http://www.sendspace.com/file/p2cqsp
može reupload ovih tema u xlm-u
AMD athlon64 3200+
FOXCONN WinFast NF4UK8AA
Super Talent PC3200 DDR400 512MB
PH DDR400 256MB
GALAXY 6600GT PCI-E 128MB (GPU 590, MEM. 1200)
Daci je offline   Reply With Quote
Staro 30.09.2007., 14:13   #108
Wolverine
Wolverine's Avatar
Postovi: 12,425
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 08.11.2007., 11:33   #109
MASVA
MIUI HR Translator
MASVA's Avatar
Lokacija: Krapina
Postovi: 632
izašao je xs++ 3.0 još je beta ali na mom w810i radi bez problema
s ovime možete zaboraviti na far
evo primjera kako modati mob s xs-om 3.0
http://cafe.mobil.hr/showpost.php?p=...&postcount=312
MIUI HR Translator
Staro 12.12.2007., 18:42   #110
De5tr0yer
Avocado
De5tr0yer's Avatar
Postovi: 7,852
evo meni zgleda umro d750 vec modan u w800 radio i sve fino, isao stavljat custom ikone gore i komp se zmrzno... gecrk
nije mi zao jer sam mob tak i tak dobio kao nije valjao, pa sam ga popravio, ali ipak
Spoiler alert!
Staro 17.12.2007., 12:19   #111
MASVA
MIUI HR Translator
MASVA's Avatar
Lokacija: Krapina
Postovi: 632
možete napraviti backup main-s svim patchevima koje imate u mobu s setoolom
start setool,izaberite w810
Start Address: 44140000
Length: 15B56A0
"Read SSW" field označeno
kliknite "read flash" i pratite upute od setoola i vaš main s ekstenzijom ssw spremljen je u setool_u datoteci
ko želi ovdje imate moj main s većinom patcheva,gfx i sys uključeni
obavezno gfx i sys mape staviti u memoriju telefona/drugo(other) i onda flešati mob s navedenim main-om pomoću setoola
start setool,mob w810
add:tu dodati backup-maina.ssw i kliknuti "flash"
kome se ne sviđa samo flešati mob s čistim MAIN-om
u paketu imate moj main,gfx s ikonama,sys->tu se nalaze mape s driverima(ams=save jar igrica,cus=custom,lay=layout,cam=kamera,audio=acou stic driveri,menu=menu.ml i ikone,flash=swf,mp=skinovi za player,splash=starup&shutdown za jednostavnu promjenu drivera s myphoneexplorerom ili s prijenosom datoteka)i ikone za mob i stick kod samopokretanja
main
http://rapidshare.com/files/77157437...chani_main.rar
sys:rakista final megabass,kriomag 21.91,nove ikone izbornika,modani layout s manjim fontom i bez loga operatera,novi startup&shutdown,swf meniji,inverted clock...
gfx:ikone signala i baterije,plave ikone walkman-a i bluetootha
MIUI HR Translator
Zadnje izmijenjeno od: MASVA. 23.12.2007. u 10:30.
Staro 04.01.2008., 13:33   #112
Snowrider
Snowrider's Avatar
Lokacija: Lika
Postovi: 864
Trebam pomoć!!
Ovako imam w200i,i napravio sam neke flash teme ali sad neznam kako da napravim druge ako mi tko može nekako pomoći!!!
E i našao sam na netu neke flash icone i ja neznam kako se stavljaju može tko pomoć???
Snowrider je offline   Reply With Quote
Staro 01.03.2008., 00:32   #113
kiwwy
kiwwy's Avatar
Lokacija: ZgB
Postovi: 158
evo gledo sam malo ovu temu i sad neznam ja instaliram one drivere iz usb_flash_driver ali tamo su mi neki gg(u setool2lite) i nece mi taj program prepoznat mob dal zna ko u cem je problem
kiwwy je offline   Reply With Quote
Staro 03.03.2008., 13:44   #114
JosephBullet
Postovi: 36
Hej MASVA,
Fleshirao sam svoj mobiitel (w810i) i maknuo Vodafone server koristeci tvoja uputstva i SEToolLite2 v1.07 . Sve je proslo dobro. Moje pitanje je kako mogu dodati samo nove drivere za kameru (bez da flashiram cjeli telefon). Probao sam to ugurati pod MISC files i kliknuo Flash ali nije proslo. Moze i neki link na stranice sa vise drivera za kameru, cisto da vidim sto se sve nudi.
Takoder me zanima kako dodati ove patcheve, konkretno me zanima ovaj koji remova restrikcije za shareanje java igara i aplikacije.
Hvala
JosephBullet je offline   Reply With Quote
Staro 03.03.2008., 19:34   #115
MASVA
MIUI HR Translator
MASVA's Avatar
Lokacija: Krapina
Postovi: 632
Autor JosephBullet Pregled postova
Hej MASVA,
Hvala
ovako ubaciš bilo koji patch
http://cafe.mobil.hr/showpost.php?p=632873&postcount=98
a ako želiš modati bilo što najbrže je s xs-om 3.1
http://rapidshare.com/files/73526795/XS3.1__.rar
a ovako to radiš s xs-om
MIUI HR Translator
Staro 03.03.2008., 20:47   #116
MesS
Buy now, cry later
MesS's Avatar
Lokacija: rijeka
Postovi: 193
može pomoc oko w300
šta je scve potrebno za otključavanje
MesS je offline   Reply With Quote
Staro 03.03.2008., 21:33   #117
MASVA
MIUI HR Translator
MASVA's Avatar
Lokacija: Krapina
Postovi: 632
Autor MesS Pregled postova
može pomoc oko w300
provjeri koji firmware imaš na mobu
trebaš setoollite
http://rapidshare.com/files/82010875/setoollite.rar
kako ubaciti patch
patch priložen ako je firmware r4ea031
File Type: rar Remove_SIM_lock_W300_R4EA031.rar‎ (267 byte, 267 views)
MIUI HR Translator
Staro 04.03.2008., 00:10   #118
JosephBullet
Postovi: 36
Hvala, probati cu se poigrati sa patchevima. Ima di kakvo objasnjenje koji radi sto i neki popis?
Drugo sto em zanima je sto je gdfs za kojeg stalno napominjes da napravimo backup? u kojem se slucaju on vraca naazad i sto onda dobijem sa tim? Mislim sto ce mi se vratiti (imenik, savagaemovi od java igri i java igre, Vodafone softver i raspored ikona) ako vratim gdfs? Kako to utjece na patchave i drivere koje dodam? Pobrise ih i vrati one stare?
Staro 05.03.2008., 10:37   #119
JosephBullet
Postovi: 36
Evo da odgovorim na pitanje koje je postavio naociti kolega iznad ovog posta
Nasao sam na Top Sony forumu
GDFS is Global Distributed File System.
GDFS are unique to each and every phones.
GDFS contains the phone settings including EMEI numbers.
Jos mi nije jasno, u kojem se slucaju GDFS vraca nazad u telefon? Sto mi se sve vrati sa tim? I kako to da je IMEI u nekom softverskom djelu? Kaj to ne bi trebalo biti hardkodirano u nekom cipu bez mogucnosti promjene.
Staro 05.03.2008., 20:38   #120
MASVA
MIUI HR Translator
MASVA's Avatar
Lokacija: Krapina
Postovi: 632
naočiti kolega
ako napraviš backup gdfs-a s setoolom onda ćeš ga i vratiti s setoolom
dobiješ file u obliku gdfs_xxxxxxxxxxxxx.bin a vraćaš ga u slučaju
modanja ili flešanja iznenadni nestanak struje,kabel se iskopča slučajno itd
MIUI HR Translator
