Staro 06.09.2007., 17:13   #1
Keo
Keo's Avatar
Postovi: 53
konf do ≈4000kn amd/game
links.hr :
-MBO ABIT KN9 Ultra,nForce 570 Ultra 712,37
-CPU AMD Athlon64 X2 3600+ BOX 465,97
-2x RAM PC-5300, 1024MB, DDR2, KINGMAX, 667 563,99
-HDD 320.0 GB SAMSUNG, Serial ATA II 583,77
-VGA PCI-E SAPPHIRE ATI RADEON X1950PRO, 256MB DDR3 1.089,09
-DVD±RW PIONEER DVR-212D, 18x, Serial ATA, Dual layer, bulk 277,79
-Kućište SHARKOON Rebel9 Economy-Edition, MIDI, crno 330,96
-Napajanje CHIEFTEC 400W 321,51
UKUPNO: 4.345,45kn
vemil.hr:
-MB Gigabyte M59SLI-S4, sAM2, nForce 590-SLI 803,98
-CPU AMD Athlon64 X2 3600+ BOX 442,62
-Powercolor Radeon X1950Pro AGP, 256MB, TVout, DVI 1.157,84
-2xDDR2 1GB PC5300 (667MHz) Kingmax 530,82
-HDD HITACHI HDT725032VLA380 320GB SATA-300 7200rpm 8MB 546,47
-DVD+RW/-RW/RAM LG GSA-H42N Dual Layer, 18x, bulk, black 219,05
-Thermaltake VC2000BNSD, mid tower Mambo 333,46
-Chieftec power supply 400W 320,00
UKUPNO: 4.354,24
što kazete na ovim konf... iz jednog ducana mi trebaju komponente...
try to stay relaxed
Zadnje izmijenjeno od: Keo. 07.09.2007. u 23:50.
Keo je offline   Reply With Quote
Staro 06.09.2007., 17:28   #2
Razer
Razer's Avatar
Postovi: 11,642
OK su konfe, samo ubaci drugu ploču - Gigabyte MA69G-S3H.
U drugoj konfi si stavio AGP karticu, vjerujem, zabunom
Staro 06.09.2007., 18:56   #3
Keo
Keo's Avatar
Postovi: 53
-HDD 250.0 GB SEAGATE, Serial ATA II, NCQ, 16MB 583,77
-VGA PCI-E SAPPHIRE ATI RADEON X1950GT, 256MB DDR3 977,66
evo ovaj sam odlucia uzeti
try to stay relaxed
Staro 06.09.2007., 18:57   #4
Keo
Keo's Avatar
Postovi: 53
Autor Razer Pregled postova
zabunom sam kopira tu grafu ali ista cijena ^^
try to stay relaxed
Staro 06.09.2007., 18:58   #5
Razer
Razer's Avatar
Postovi: 11,642
Samo uzmi drugi disk - WD ili Sami ako uzimaš u ADM-u ili Linksu, a Hitachi ako uzimaš iz Ve-Mila...
Staro 06.09.2007., 21:24   #6
Keo
Keo's Avatar
Postovi: 53
HDD 250.0 GB WESTERN DIGITAL Caviar, Serial ATA II, 16MB cache, 7200 okr/min
evo uzea sam ovaj!
try to stay relaxed
Staro 06.09.2007., 21:49   #7
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
Samo ako mozes da napises iz koje je serije.
Milentije je online   Reply With Quote
Staro 06.09.2007., 22:04   #8
Bravo
Bravo's Avatar
Postovi: 1,450
sve ok.abi kn9 u je odlićna ploća.
ako ideš na konfu br. 2 onda ubaci 7900 kad ploća već podržava SLI.
Staro 06.09.2007., 22:54   #9
Keo
Keo's Avatar
Postovi: 53
naručia sam u links-a, a sto se tiče disk-a ne pise koja je serija
try to stay relaxed
Staro 07.09.2007., 01:11   #10
ROMO
Postovi: 153
Samo da te upozorim da je Mambo po meni NO GOOD,dalje od toga,plastika,jeftino,nekvalitetno,bar u usporedbi sa rebelom.Rebel znam samo iz ducana,ali mambo sam kupio braticu,u manje od 2 tjedna mu kupio novo uz isprike.
ROMO je offline   Reply With Quote
Staro 07.09.2007., 13:32   #11
Keo
Keo's Avatar
Postovi: 53
Autor Keo Pregled postova
HITNO!!!!!
sad me zva ovaj iz linksa da nemaju matičnu, grafičku, kućište i napajanje pa bi mi trebala adekvatna zamjena ili ako se ikome da napisati neku inetl konf iz links
try to stay relaxed
Staro 07.09.2007., 23:52   #12
Keo
Keo's Avatar
Postovi: 53
evo uzea sam ovu matičnu: MBO MSI K9N SLI Platinum, nForce 570 SLI, DDR2, zvuk, FW,
2xG-LAN, PCI-E, s. AM2
i napajanje: Napajanje FORTRON 350W, FSP-60THNP, Super Silent, 12cm vent.,
ATX2 ver 2.0
jesam li napravia veliku pogrešku?
try to stay relaxed
Staro 07.09.2007., 23:55   #13
Razer
Razer's Avatar
Postovi: 11,642
Po pitanju napajanja, jesi.
Staro 11.09.2007., 15:09   #14
bozzomfeeder
bozzomfeeder's Avatar
Lokacija: Sinj
Postovi: 1,080
a i ploče....
bozzomfeeder je offline   Reply With Quote
Staro 11.09.2007., 16:37   #15
ECHO
Lokacija: CROATIA-Vukovar
Postovi: 2,354
pozdrav
Napravio si pogrešku ali ukoliko ti se bude rušio sistem odma imaš krivca(napajanje preslabo)prvo pomisli nanjega još pogotovo ako clockneš proc
probaj zamjeniti uz neku nadoplatu i uzmi jače i bolje napajanje(ako može).
Staro 12.09.2007., 15:42   #16
Keo
Keo's Avatar
Postovi: 53
evo sastavia sam comp ... i za sad sve ide bez problema .... clockat jos necu, jer mi nije potrebno.
a kad odlucim clockati kupit cu novo napajanje i cooler ^^
ps. nije ploca valjda tolika katastrofa???
try to stay relaxed
Staro 13.09.2007., 01:20   #17
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
Nije ti ploca tolika katastrofa kolika bi mogla biti napjanje.
Ako jos nije proslo 7 dana od kupovine (a nije) pokusaj zamjeniti za PNF. Ti si dobio THN sto nije najbolje.
