Pečurka
Lokacija: U blizini Osijeka
Postovi: 1,294
R9250 i driveri za Vistu?
Jel postoje driveri za R9250 za Vistu? Probao sam sve koje sam uspio naći i niti u jednima nema podrške za tu karticu. Jel moguće da su totalno odbacili karticu koja je još uvijek u prodaji???
ECS Z77H2-A2X Deluxe I5 3350P G-Skill 16 GB DDR3 2133MHz Gainward Phantom GTX760 250 GB Samsung Evo Basic SSD XFX XTR 650W Silencio 650 |
Propali Amigaš
Lokacija: Nin
Postovi: 7,006
U prodaji je zato što su trgovci pohlepni i ne spuštaju cijenu pa nitko ne kupuje |
Pečurka
Postovi: 1,294
Baš sad malo bolje gledam, niti NVidia nema ništa bolju podršku. Definitivno smatram jadno i s jedne i druge strane da nisu podržali starije kartice. OK, ne mogu koristiti Aero, ali dosta ih ima TV-out, dosta ih još može vrtiti OGL igre.
Postovi: 18,908
Pa kako će raditi Aero kad to nije DirectX 9 kartica? EDIT: Kasnim...
Pečurka
Postovi: 1,294
Pa da, ok, ne radi aero, ali to ne znači da ne bi trebao raditi ni TV-out, ni OGL igre i slično
#7 | |
Lokacija: Zagreb,Sesvete
Postovi: 139
EDIT: fakat, u krivu sam, a cijelo vrijeme do sad sam mislio da je DX9 grafička, a zapravo je samo dx9 'compliant' ![]() Zadnje izmijenjeno od: Purica/Tamara55. 10.09.2007. u 13:49. |
#8 | |
Propali Amigaš
Lokacija: Nin
Postovi: 7,006
![]() "The Radeon 9000 (RV250) was launched alongside the 9700 (the new flagship part for ATI). This chip dropped one of the two texture units, the "TruForm" unit, Hierarchical-Z, and one of the two vertex units, bringing the configuration down to a 4x1 pixel/texture pipeline layout. It was not just cut down, however, but was actually refined as well. The texture cache was doubled in size to 4 KiB, improving a serious inefficiency in R200. Because of this, performance was still quite competitive, considering that the "R200" chips were more expensive and much larger and power consuming. In games, it performed around the same as the highly-refined "NV17" used on GeForce 4MX440. Its main advantage over the GeForce4 MX440 was that it had a full DirectX 8.1 vertex and pixel shader implementation. The Radeon 9000 replaced the uncompetitive Radeon 7500 (RV200) in the mainstream market segment. A later version of the 9000 was the 9200 (RV280), which, aside from supporting AGP-8X, was identical. However, there was a cheaper version, the 9200SE, which only had a 64-bit memory bus. Another board, called the Radeon 9250, launched in summer 2004. It was simply a lower-clocked variant of Radeon 9200. It, in fact, used the same "RV280" GPU. It was usually equipped with more RAM than the Radeon 9200 cards though (128 MiB or even 256 MiB), taking advantage of the low-cost of slow-clock high-density DDR SDRAM, a popular trend at the time." http://en.wikipedia.org/wiki/Radeon_R200 |
