Staro 05.09.2007., 23:13   #1
Vuco
Vuco's Avatar
Lokacija: Zagreb, Tresnjevka
Postovi: 9,505
Test nekih od najboljih napajanja
# Antec Neo HE 550 (550W): Error Correction
# Cooler Master Real Power Pro RS-850-EMBA (850W)
# Etasis ET850 (850W)
# Floston Energetix ENFP-750W (750W)
# FSP Epsilon 700W, 800W, and 900W
# Rosewill Turbo Series RT550-135-BK (550W)
# Seasonic M12 SS-700HM (700W)
# Thermaltake Purepower RX 550 AP (W0150, 550W)
# Thermaltake Toughpower 600 AP (W0103, 600W)
# Thermaltake Toughpower 850 AP (W0131, 850W)
# Ultra Products X-Pro ULT-XF800S (800W)
# Zalman ZM500-HP (500W) and ZM600-HP (600W)
I think the leaders of this review are the Antec Neo HE 550, Cooler Master Real Power Pro RS-850-EMBA, Seasonic M12 SS-700HM, and the three models from Thermaltake.
The first three of them are high-quality and exceptionally quiet power supplies. If you want not only top-performance but also a quiet PC, you should consider them. These models are each nearly silent under low loads and do not become irritating at high loads.
Thermaltake’s PSUs feature superb electrical characteristics but are not quiet. They are rather average in terms of noise. Oddly enough, the 850W Toughpower is generally louder than the 550W and 600W models from the same brand, which refutes the widespread opinion that a PSU with a higher wattage rating is going to be quieter than a lower-wattage model under the same load.
Izvor: X-bit labs
Dobar review po meni, ali i skupa napajanja
Enjoy
EDIT:
Isprike svima, od copy/paste-anja sam zaboravio dati link. Razer ga je ostavio dolje, ja ću ga staviti samo da bude u prvom postu.
Hvala Bulletu koji je vijest donio, a ja prenio sa jednog drugog foruma.
Zadnje izmijenjeno od: Vuco. 06.09.2007. u 00:30.
Staro 05.09.2007., 23:17   #2
Pomo
Laughing Man
Pomo's Avatar
Postovi: 3,040
Znam ja da je kasno i to, ali kad si već postao neki link bi bio poželjan
Staro 05.09.2007., 23:20   #3
Razer
Razer's Avatar
Postovi: 11,642
Staro 05.09.2007., 23:47   #4
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
I opet bez i jednog jedinog Chiefteca. Mogli su staviti bar jednog, cisto da se vidi kakav je sada u odnosu na ostala napajanja.
