Lokacija: Đakovo
Postovi: 24
Šta kažete na ove konfe?
Konfa 1. monitor : Monitor Samsung SM 206BW, 20" LCD, 2 ms, DVI, Premium stand procesor: CPU AMD Athlon64 X2 6000+ BOX, dual core, SckAM2 matična: MB Gigabyte M59SLI-S4, sAM2, nForce 590-SLI, SATA, FW, GLAN memorija: 2x DDR2 1GB PC6400 (800MHz), Kingmax HDD: HDD Seagate ST3320620AS, 320 GB 16MB, S-ATA300, NCQ3, 7200 pržilica: DVD+RW/-RW/RAM LG GSA-H62N Dual Layer, SATA, 18x, bulk, black FDD: FDD 1.44 MB BLACK grafička: Gigabyte GF 8800GTS, 320MB DDR3, TV-out, Dual DVI kućište: Thermaltake VD2000BNS, mid tower Matrix, bez PS, crno, met-alu maska, USB, Fire wire, 1×120mm fan napajanje: OCZ power supply GameXStream 600W, SLI-ready, crno, EPS, ATX 2.2, 4×12V (72A), 12cm blue led FAN OS : OEM. Windows Vista Home Premium Croatian konfa 2. monitor: Monitor LG LCD L194WT, 1440 x 900 widescreen, 2000:1, 5ms, DVI procesor: Intel Core 2 Duo E6750 BOX, 2×2.66GHz, 1333MHz, 775-pin, 4MB matična: MB Gigabyte 965P-DS3, s775, i965P, DDR II, SATA II, GLAN memorija: 2x DDR2 1GB PC6400 (800MHz), Kingmax HDD: HDD Seagate ST3250620AS/ST3250410AS, 250 GB 16MB, S-ATA300, NCQ3, 7200 pržilica : DVD+RW/-RW/RAM LG GSA-H50L Dual Layer, LightScribe, 18x, bulk FDD: FDD 1.44 MB BLACK grafička: Gigabyte Radeon HD 2600 XT 256MB DDR4, PCIE, TVout, dual DVI napajanje: Chieftec power supply 550W, EPS, ATX 2.0, 3×12V, Active PFC, AFC, 12cm fan, 2×SATA connectors OS : OEM. Windows Vista Home Premium Croatian hvala!
MOJ KOMP: CPU AMD Athlon64 X2 6000, Matična : MB Gigabyte M59SLI-S4, sAM2, Mema: 1GB PC6400 (800MHz), Kingmax x2, HDD Seagate ST3320620AS, 320 GB 16MB, 8800 GTS 320 MB, napajanje: OCZ 600W. AMD i Nvidia su najbolji!!!!!!!!!!! |
Agent 0
Lokacija: Kutina - ZG
Postovi: 4,311
Što mislim...hmmm...Prva je tvoja konfa, druga vjerovatno frendova...pa se ti pitaš koja je bolja? Moja je najbolja, normalno! ![]() Sutra će škola pa nećeš imati vremena otvarati glupe teme ![]() |
Postovi: 1,431
radit ce oba ![]() ako kupujes novo reci kolko love je u igri i da li si ogranicen na odredjene ducane? sto se tice monitora mislim da je 19'' wide premalo ali to je subjektivno pa pogledaj diskove bi radje uzeo samsung t166 ako postoji takva mogucnost u intel konfi bi uzeo plocu baziranu na p35 chipsetu mislim da ti netreba ovaj OCZ od 600W, mislim da bi bio ok neki chieftec sa 500W ali sve ovisi o kolicini love i razlici u cijeni windowsi?? to ti je za firmu komp ili za igre? 8800gts je puno bolja kartica od 2600XT, opet, sve ovisi o kolicini love i kolko se igras na kompu koja je rezolucija na onom 20'' monitoru, mozda ce ti trebati graficka sa 512ili vise MB ako je reza 1680xnesto (to pricekaj jos nekog ko bolje zna) edit: sad vidim o cem se radi ![]() prva je bolja za igre, druga ima bolji procesor ***ote na sta sam ja sad potrosio svoje vrijeme ![]() |
Lokacija: Đakovo
Postovi: 24
prcknedl
Postovi: 3,131
Prva je bolja za igranje zbog osjetno jace grafe, no druga ima nesto jaci proc. Prva ima i bolji i veci ekran. Po ostalome su konfe tu negdje, ok prva ima veci disk no i druga ima sasvim dovljno velik. |
Lokacija: nowhere
Postovi: 16
Bok drustvo ![]() ![]() ![]() ![]() ![]() Ko da sam doima na f***m.hr, toliko mi je prijatelja tu ![]() |
teta Mraz
Lokacija: hr
Postovi: 1,596
prva je bolja a druga je jos bolja, zato sto mozes vrtit super PI <20s kad je naklokas, stavi Zalman kuler od 450kn i brzim ventilatorom, opcenito preslaba su napajanja, ja bi barem 700 Vati u svaku piknuo, za svaki slucaj, 2600xt vuce bar 300 Vati znas, memorija je trebala bit na 1066Mhz jer je ta prespora i usporavat ce ti komp, umisto crnog stavi bijeli Floppy, to je jako vazno jer ces ga cesto koristit, a crna nije bas ugodna boja kada gledas floppy dok stavljas danas izuzetno popularne crne diskete, Vista Ajtimejt je bolja od home premijum pa i to treba prominit, i naravno, u obe konfe je jedna velika greska, a to je da maticna ploca treba bit Fokskon Zvijer ![]()
Postovi: 4,707
bobe je pod utjecajem nepoznatih preparata... dobra dobra... |
Lokacija: Đakovo
Postovi: 24
[quote=hash;803944]radit ce oba ![]() ako kupujes novo reci kolko love je u igri i da li si ogranicen na odredjene ducane? sto se tice monitora mislim da je 19'' wide premalo ali to je subjektivno pa pogledaj diskove bi radje uzeo samsung t166 ako postoji takva mogucnost u intel konfi bi uzeo plocu baziranu na p35 chipsetu mislim da ti netreba ovaj OCZ od 600W, mislim da bi bio ok neki chieftec sa 500W ali sve ovisi o kolicini love i razlici u cijeni windowsi?? to ti je za firmu komp ili za igre? 8800gts je puno bolja kartica od 2600XT, opet, sve ovisi o kolicini love i kolko se igras na kompu koja je rezolucija na onom 20'' monitoru, mozda ce ti trebati graficka sa 512ili vise MB ako je reza 1680xnesto (to pricekaj jos nekog ko bolje zna) edit: sad vidim o cem se radi ![]() prva je bolja za igre, druga ima bolji procesor Kako druga može imati bolji procesor kad je u prvu konfu ugrađen najjači procesor koji postoji od AMD-a na tržištu??
Agent 0
Postovi: 4,311
#14 | |
teta Mraz
Lokacija: hr
Postovi: 1,596
prvo naući quotat, jer se u tvom zadnjem postu ne zna ko pije a ko placa, evo vako: Citiraj:
#16 |
Lokacija: Đakovo
Postovi: 24
Ja sam mislio na nominalnim postavkama a ne na OC-anim postavkama!!!!!! (pola ljudi svejedno ne OC-a svoje procesore -Intelove , jer ne znaju!!)
#17 |
teta Mraz
Lokacija: hr
Postovi: 1,596
hmmm, tih pola ljudi mene ne zanima, jer vecina na ovom forumu nabaci OC proca, a i oni koji neznaju kad dodju tu saznaju, i nakon tjedan-dva tucu reze u top 10 SPI@PCE ![]() btw mislim da si mogel zakljucit na kojoj je razini moja ozbiljnost u ovoj temi, jer i sama tema je totalni "OT" ![]()
#18 | |
Lokacija: Đakovo
Postovi: 24
#20 |
Postovi: 1,450
obje konfe su super.. x2 6000+ je sitno sporiji od E6750(na defaultu). zamjenio bih grafe, 8800gts stavio u intel konfu i onda bi to bilo over kill i gaming do jaja ![]() |
