Staro 13.08.2007., 23:27   #1
Mailman
Mailman's Avatar
Postovi: 1,606
ATI Catalyst 7.8
New Features
This release of Catalyst™ introduces an enhanced version of ATI Overdrive for the ATI Radeon™ HD 2600 Series and ATI Radeon™ HD 2400 Series. Users can now Over-clock both GPU engine and graphics memory clock speeds in Crossfire™ mode (and over-clock single ATI Radeon™ graphics accelerators as well). This version of ATI Overdrive also includes a new stress test application to verify any over-clocking speeds users may have configured (either manually or through the auto-tuning tool) on their ATI Radeon™ graphics accelerators.
Performance Improvements
The following performance improvements are noticed with Catalyst™ 7.8:
* Lost Planet DX10 with anti-aliasing improves 11% or greater on Radeon™ HD2900XT products
* Radeon™ HD2600 and Radeon™ HD2400 (single and CrossFire™) show improvements of as much as 6% in 3DMark 2006 and 3DMark 2005
* Serious Sam 2 with HDR enabled improves as much as 14.5% on Radeon™ HD2900, Radeon™ HD2600 and Radeon™ HD2400 products
Resolved Issues for the Windows XP Operating System
CounterStrike Source, Day of Defeat Source, and Half-Life 2 Episode 1, Excessive fog is no longer noticed when playing these games. Further details can be found in topic number 737-28795
http://ati.amd.com/support/driver.html
Mailman je offline   Reply With Quote
Staro 14.08.2007., 04:23   #2
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
Resolved Issues for the Windows Vista Operating System
This section provides information on resolved issues in this release of the ATI Catalyst™ Software Suite for Windows Vista. These include:
Call of Duty->United Offensive: Having all of the in-game settings at their maximum levels along with the Catalyst™ Control Center->3D aspect set to Optimal Quality no longer results in the Windows Vista (64 bit) operating system failing to respond after a short period of game play. Further details can be found in topic number 737-28793
The default audio device is no longer set to ATI HD Audio after installation of the display driver for the ATI Radeon™ HD2900, HD2600, and HD2400. Further details can be found in topic number 737-28483
Hot-plugging a CRT to a system running Windows Vista and containing an ATI Radeon™ X1100/1150 series of product no longer results in extended desktop mode failing to be applied. Further details can be found in topic number 737-25801
Enabling CrossFire™ followed by disconnecting and then reconnecting the CRT display device no longer results in duplicate video options being seen within the Catalyst™ Control Center. Further details can be found in topic number 737-27457
Enabling CrossFire™ followed by setting AA to 14x and AF to 16x no longer results in the AA showing a setting of 0x level when disabling CrossFire™ and unchecking the AA option in the 3D aspect. Further details can be found in topic number 737-27458
Making changes to the Color aspect found in the Catalyst™ Control Center without applying the changes no longer results in the Reactivate ATI color controls button remaining active after the Catalyst™ Control Center is closed and then re-launched. Further details can be found in topic number 737-27459
Enabling CrossFire™ followed by setting the OverDrive™ clocks to their maximum settings no longer results in the Catalyst™ Control Center failing to accurately report the requested OverDrive™ values. Further details can be found in topic number 737-27621
Performing an un-install of the display drivers on a CrossFire™ configured system no longer results in extended desktop mode becoming active resulting in all of the desktop icons failing to appear. Further details can be found in topic number 737-28478
Catalyst™ Control Center->3D->Anti-Aliasing: Unchecking the option to Use Application Setting found in the 3D aspect page when CrossFire™ is enabled no longer results in the maximum AA setting being 6x. This issue may also be experienced under the Windows XP operating system. Further details can be found in topic number 737-28479
Performing either a custom or express install of the display driver no longer results in the system possibly failing to respond and the installation of the driver failing. This issue was known to occur when using an ATI Radeon™ X1950 CrossFire™ Edition product installed on in a system containing an Intel975. Further details can be found in topic number 737-28481
HDMI audio stutter is no longer heard when playing MPEG clip at certain resolutions on some HDMI device. Further details can be found in topic number 737-28484
The Scaling options found in the Catalyst™ Control Center no longer disappears when relaunching the Catalyst™ Control Center after applying optimized and custom formats for Component Video. Further details can be found in topic number 737-28855
Connecting a secondary display device (CRT) and enabling extended desktop mode no longer results in invalid refresh rates being available in the Display Manager. Further details can be found in topic number 737-28787
Making adjustments to the Gamma, Brightness, and Contrast and not applying the changes no longer results in the desktop image failing to return to its default color values when performing a hot-reboot of the system. Further details can be found in topic number 737-28787
All supported display resolutions are now available in the Display Manager when connecting a secondary display device and enabling extended desktop mode. Further details can be found in topic number 737-28789
Performing an un-install of the display driver no longer results in the display entering an extended desktop mode and the desktop icons failing to be displayed. Further details can be found in topic number 737-28478
Setting the Avivo Video Brightness to less than 0 within the Catalyst™ Control Center no longer results in a white frame being created in the Windows Media Player when fullscreen mode is enabled. Further details can be found in topic number 737-28790
The Enable ATI Overdrive clocks for 3d applications is no longer available on non supported products such as the ATI Radeon™ HD 2600 series of product. Further information may be found in topic number 737-28477
Setting the Avivo Video De-interlacing setting to auto, motion adaptive or vector adaptive no longer results in certain DVDs, menu videos and some special features failing to benefit from the options. Further information on this issue may be found in topic number 737-27196
The color depth no longer changes to 8bpp when enabling or disabling CrossFire™ for the first time. Further information may be found in topic number 737-28485
Connecting a TV followed by removing the display resolution of 640x480 from the mode table no longer results in the both the TV and LCD failing to display an image. Further details can be found in topic number 737-28490
An unhandled exception no longer occurs when running an OGL application and resuming from S3 under Vista on various ATI Radeon™ Xpress 1200/1250/1300 series products. Further details can be found in topic number 737-27960
Windows Media Player: Playing a DVD in full screen mode no longer results in vertical bar corruption being noticed during playback. Further details can be found in topic number 737-28497
DVD display no longer blinks in red when Overdrive is enabled. Further details can be found in topic number 737-28794
This section provides information on resolved issues in this release of the ATI Catalyst™ Software Suite for Windows XP. These include:
Star Wars knights of the Old Republic 2: Corruption is no longer seen when running the game on some members of the ATI Radeon™ Xpress 1200/1250/1300 series of products. Further details can be found in topic number 737-27098
The Overscan/Underscan slider bar is no longer enabled when setting display resolutions of 1280x1024 or higher on systems containing an ATI Radeon™ HD 2900 XT series of product. Further details can be found in topic number 737-28843
Adobe After Effects 8: The application no longer fails to load on systems containing an ATI Radeon™ X700 series of product. Further details can be found in topic number 737-28796
PowerDVD6: Momentary desktop corruption is no longer noticed when minimizing the DVD playback window after stretching the playback window approximately 80%. Further details can be found in topic number 737-28797
The system no longer becomes unresponsive and no longer requires a reboot while randomly moving Video Player window from primary to extended desktop under certain hardware configurations where the second adapter is an ATI Radeon™ X1200/1250/1270 series of product. Further details can be found in topic number 737-27092
A warning message indicating CrossFire™ cannot be enabled because some 3D applications are running or the interconnect cable is not connected, or the motherboard has no communication channels between PCI-Express slots is no longer displayed when using a motherboard with an Intel I965 chipset. Further details can be found in topic number 737-28798
The CrossFire™ page is no longer greyed out and cannot be enabled when attempting to use a software CrossFire™ configuration on a system using a motherboard with an Intel I975 chipset. Further details can be found in topic number 737-28799
The Avivo components are now listed in the ADD/Remove Programs after installation of the display driver. Further details can be found in topic number 737-28800
Switching HD-DVD titles during playback with hardware acceleration enabled no longer results in the playback to be blocked. Further details can be found in topic number 737-28802
WinDVD8: Playing a DVD and changing the video setting to Hardware Acceleration mode no longer results in corruption being noticed. Further details can be found in topic number 737-28803
Staro 14.08.2007., 08:44   #3
Roberto
Roberto's Avatar
Postovi: 2,655
Jel netko isprobao?
Ja sam na poslu pa ne mogu... A imam doma jednu 2600xt, budem kad dođem doma nabacio, mada ne vjerujem u neka značajna poboljšanja - pogotovo kaj se tiče AA i AF...
Staro 14.08.2007., 10:04   #4
Momir
Momir's Avatar
Postovi: 1,012
Ja probao. Sve radi osim markova. 01 mi dao 1000 bodova manje sa time da se za vrijeme izvodjenja 2 puta upalio vpu recover. A 03 isto izbaci vpu recover i nezeli nastaviti izvodjenje. Ostale nisam imo zivaca isprobati. Eto toliko od mene. Ja sam osim tih drajvera instalirao i HDMI audio 7.8.
Momir je offline   Reply With Quote
Staro 17.08.2007., 11:41   #5
stopalo9
stopalo9's Avatar
Postovi: 763
najvise se isplati ako imate 2600xt ili 2400 jer na njima se dobivaju puno vece reze sa 7.8 al na ostalima nema nekih velikih razlika
stopalo9 je offline   Reply With Quote
Staro 17.08.2007., 19:29   #6
Tuna
Unregistered User
Tuna's Avatar
Lokacija: Našice
Postovi: 426
pa ti driveri postaju sve veći i veći.
još malo pa ču morati na flate samo da mogu skidati nove drivere
Tuna je offline   Reply With Quote
Staro 17.08.2007., 19:41   #7
Angelus
A mighty pirate!
Angelus's Avatar
Postovi: 429
tek sam danas dobio 7,8 i 2600 xt.pričekajte malo
Angelus je offline   Reply With Quote
Staro 19.08.2007., 15:06   #8
Momir
Momir's Avatar
Postovi: 1,012
Imajuci u vidu da svi hvale doticne drajvere odlucio sam ih ponovno skinuti sa neta i instalirati. Ovaj puta sam imao vise srece. Sada sve radi kako bi i trebalo. Dakle evo usporedbe drajvera.
7.7 VS 7.8
3dmark01
24692 VS 25136
3dmark03
12219 VS 12355
3dmark05
8758 VS 8976
3dmark06
4413 VS 4496
Proc je amd x2 3600+ koji radi na 2850MHz (300*9,5), windowsi su vec dosta stari i prezivjeli su vec dosta hardvera i softvera, u pozadini su bili upaljeni 2*CPU-Z, everest, msn, icq, itd. Unatoc svemu poboljsanja ima.
Staro 21.08.2007., 20:22   #9
marko.maky
marko.maky's Avatar
Lokacija: Vukovar
Postovi: 160
Ati i Nvidia su izdali nove beta drivere.Njveći je razlog taj što nam je došao bioshock pa i jedni i drugi žele da se što bolje vrti na njihovim karticama.
http://www.itx.ba/index.php?option=c...=2283&Itemid=1
marko.maky je offline   Reply With Quote
