Staro 20.01.2006., 00:10   #1
Postovi: 7,568
Arrow Nadolazeći AMD socketi, ploče i procesori
Nadolazeći socketi, ploče i procesori
Zadnje izmijenjeno od: McG. 28.02.2011. u 02:08.
Staro 14.05.2007., 16:30   #2
Postovi: 7,568
Službeno predstavljeni Phenom modeli
AMD has finally named its next-generation desktop processors; and the new name is Phenom. At the top of the product lineup we have the Phenom FX processors. These processors will be quad-core only and run at the highest clock speeds in AMD's lineup. Phenom FX processors will be available in both Socket-1207 and Socket-AM2 flavors. The X4 and X2 will be Socket-AM2/AM2+ only and are 100% backwards compatible with current AM2 motherboards.
Phenom will work in current Socket-AM2/Socket-1207 motherboards with a BIOS update, but it loses the ability to run its Northbridge and CPU cores at separate voltages/clock frequencies. If you buy a new Socket-AM2+/Socket-1207+ motherboard, then the CPU cores and Northbridge can run at separate voltages/frequencies. The benefit of doing this is not only power savings, but AMD has indicated that it can actually run the Northbridge faster than the CPU cores (by 200 - 400MHz) which will improve performance. The L3 cache happens to run on the same voltage plane and at the same frequency as the Northbridge, compounding the performance benefits of using a new "plus-socket" motherboard (Socket-AM2+/Socket-1207+).
Given that Phenom will be DDR2 from the start, it looks like AMD's transition to DDR3 will be much like its transition to DDR2: it will complete well after Intel has made the move. AMD's current roadmap shows the second generation Phenom core (Shanghai) due out in 2008 but still on Socket-AM2+/1207+. It's quite possible that AMD will introduce another socket in late 2008 (AM3?) that will offer DDR3 support to begin its transition to the new memory technology.
Izvor: AnandTech
Staro 15.05.2007., 21:26   #3
Postovi: 7,568
Gigabyte "Churchill": mini DTX AM2 ploča
Gigabyte today announced the first mini DTX motherboard catering towards home servers. The new Churchill motherboard supports AMD’s Socket AM2 Athlon 64 and Sempron single and dual-core processors. Gigabyte equips Churchill with a SiS761GX north and SiS966 south bridges. The SiS761GX features an integrated Mirage 1 graphics core with DirectX 7 support. Other notable features of the Churchill motherboard include one PCIe x1, one PCI, six SATA 1.5 Gbps/sec ports with support for native command queuing, eight USB 2.0 ports and high definition audio support. Expect Gigabyte to release the motherboard in July.
DTX:
It is for small form factor PCs (especially for HTPCs) with dimensions of 200 mm by 244 mm. AMD stated that the DTX form factor is an open standard, and is backward compatible with ATX form factor cases. They also present a variant named Mini-DTX which is smaller in PCB size of 200 mm by 170 mm.
Upcoming DTX boards will likely contain one PCI-Express slot and one PCI slot. The spec also provides for optional ExpressCard expansion slots on DTX motherboards.
  • DTX will allow up to four motherboards – for low cost – per standard printed circuit board manufacturing panel sizes
  • Mini-DTX will allow up to six motherboards – for low cost – per standard printed circuit board manufacturing panel sizes
  • DTX motherboards can be manufactured in as few as four layers of printed circuit board wiring for motherboard cost savings
Izvor: DailyTech
Zadnje izmijenjeno od: McG. 30.09.2010. u 18:20. Razlog: Reupload slika.:)
Staro 18.05.2007., 19:09   #4
Postovi: 7,568
AM2 ploče bazirane na AMD 570X chipsetu i detalji mobilne platforme
Jetway has announced 5 new products based on AMD 570X chipset. AMD 570X chipset supports CrossFire just like AMD 580X and AMD 480X. The difference is that it supports one 16X/8X + 8X. The models are variants of M2A581 series and HA02 series.
Jetway M2A581
  • M2A581 uses AMD 570X+S600 chipsets. AMD 570X supports 1X PCIe x16 + 1 X PCIe x8 connectors, it supports CrossFire using HD2000 graphics cards. AMD 570X supports AMD AM2 processors, DDR II, PCI,, PCI-E SATA2, USB2.0. The board also comes with GB LAN (RTL8111B) and HD AUDIO (ALC888).
Jetway HA02
  • HA02 also uses the AMD 570X +SB600 chipset and promises more overclocking features. The HA02 has one less PCIe X1 and it is replaced by a PCI slot. HA02 has all the functions of M2A581-SGE e.g ESATA, DEBUG etc. It also has optical out (M2A581 does not have). HA02 has two models: HA02-GT and HA02-GTE. GTE is similar to GT with the addition of IEEE1394A.
Griffin + Puma mobilna arhitektura
Griffin will be a 65nm dual-core chip with 1MB of L2 cache per core and it won't have a shared L3 cache. But it will nonetheless have split power planes between both cores and the north bridge/memory controller. The chip will also be able to scale to 1/8th of its rated clock speed in order to conserve power. Further power savings will be brought by HyperTransport 3.0, which will dynamically scale link widths to save energy. On the memory front Griffin will support DDR2-667 and DDR2-800 memory, and perhaps even DDR2-1066 like Barcelona. Puma platform will include a new chipset dubbed 780G. AMD's slides say the 780G will monitor I/O and the processor's power state to establish the "optimal power management profile for a given set of system conditions.
Griffin + Puma: 1, 2, 3, 4
Izvor: OCWorkbench, DailyTech, Hot Hardware, Bit-Tech i AnandTech
Staro 26.05.2007., 23:48   #5
Postovi: 7,568
Athlon 64 X2 BE-2350 i detalji oko 570X chipseta
AMD BE-2350 still based on 65nm design, this CPU has a lower TDP of only 45W. From the CPU-Z screen using v1.39 and v1.40. This CPU is recognised as Athlon 64 X2 Dual Core Processor BE-2350. It runs at a multiplier of 10.5x and bus speed is at 200MHz. HT is at 1GHz. From what we gathered, AMD is also changing its branding of this new processors, the BE-2XXX series. They won't be called Athlon 64 X2. Instead it will be known as Athlon X2 Dual Core. The "64" is dropped. No reasons were given for dropping the "64".
  • A few days ago, we reported that Jetway will have 5 new models of mainboard based on this AMD 570X chipset. Officially, this chipset officially supports a 16x + 8x slot. It can run CrossFire in a Dual 8x mode. We received information that this chipset is similar to the 580X and it can actually turn on the remaining 8x PCIe to make the chipset support full DUAL 16x just like the 580X.
EDIT:
AMD began sampling its upcoming Athlon 64 X2 BE-2000-series processors. The new Athlon 64 X2 BE-2000-series remains based on AMD’s 65nm Brisbane-core, but with lower thermal ratings. AMD Athlon BE-2000-series processors will arrive with 45-watt TDP ratings, equaling that of the energy efficient single-core processors. As with other Brisbane-based processors, the AMD Athlon 64 X2 BE-2000-series feature 2x512KB of L2 cache, 2000 MHz HyperTransport speed and AMD Virtualization technology.
Expect AMD to debut its Athlon 64 X2 BE-2300 and BE-2350 next month. The Athlon 64 X2 BE-2400 will arrive later, in August.
Izvor: OCWorkbench i DailyTech
Zadnje izmijenjeno od: McG. 05.12.2008. u 03:40. Razlog: Nadopuna posta
Staro 02.06.2007., 15:43   #6
Postovi: 7,568
Gigabyte GA-M790-DQ6 AM2+ ploča
Gigabyte United is again excited to participate in Computex 2007, highlighting some of their latest Ultra Durable 2 motherboards which continue to lead the industry for top quality design. Gigabyte presents the GA-M790-DQ6, featuring the AMD RD790 chipset and support for the new AMD Phenom quad-core processors, with the latest socket AM2+ support, integrated DDR2 1066 memory controller, HyperTransport 3.0 technology links and 128-bit Floating Point Units. The GA-M790-DQ6 also features support for PCI Express 2.0 as well as ATi CrossFire with dual x16, or four x8 connectivity for the ultimate High-Def entertainment experience.
Izvor: IT-review i Hexus
Zadnje izmijenjeno od: McG. 30.09.2010. u 18:20. Razlog: Dodana slika
Staro 04.06.2007., 17:03   #7
Postovi: 7,568
Nova "imena" za procesore iz Stars obitelji
On June 5th, AMD will launch its Athlon X2 BE-2350 and 2300 processors. The new Athlon X2 BE-series marks the debut of AMD’s new naming scheme. In addition to the Athlon X2 BE-series, AMD is to revamping its complete product lineup using the alphanumeric scheme. The new naming scheme designates the first letter as the processor class.
AMD currently has three processor classes for the new scheme – G, B and L.
  • All G-class processors are designated as premium processors under the Phenom X4 and X2 names.
  • The B-class processors slot below the G-class processors as an intermediate model.
  • At the bottom of the AMD ladder is the L-class processors. L-class processors carry the AMD Athlon or Sempron names.
The second letter in the model designates thermal design power class. AMD P-class processors have TDPs greater than 65-watts; S-class processors have TDPs of approximately 65-watt while E-class processors have less than 65-watt TDPs. Under the new naming scheme, upcoming Stars-family dual and quad-core processors will carry the AMD Phenom X2 GS-6xxx and Phenom X4 GP-7xxx names. Value-priced AMD Athlon and Sempron processors will carry the Athlon X2 LS-2xxx and Sempron LE-1xxx names.
Izvor: DailyTech
Zadnje izmijenjeno od: McG. 30.09.2010. u 18:21.
Staro 06.06.2007., 00:50   #8
Postovi: 7,568
Athlon X2 BE-2350 review i novi pad cijena
Power consumption is definitely down over the standard 65nm 65W Athlon 64 X2s, but not as low as the old 35W EE SFF parts were. Power consumption and thermal testing, however, did show a significant decrease compared to both 65w processors. Athlon X2 BE-2350 performed exactly as we expected today. Unlike other low power consuming chips where clock speed is severely compromised, the BE-2350 performs as a similarly clocked previous generation X2. Intel currently has no direct answer to this kind of performance at these power levels giving AMD a chance to fall into some unique system designs like home theater PCs and even some small form-factor boxes. The performance of this chip really needs to be taken into consideration when looking at its price as well as its power consumption levels.
Review: 1, 2, 3, 4
On July 9th AMD desktop processor family will have a reduction in suggested prices. Savings for the AMD Athlon 64 X2 (dual-core) processor family will be about 20% and the AMD Athlon 64 (single-core) processor family will be adjusted by approximately 15%. If you are looking for a great value, look to the AMD Sempron processor, which will also offer savings of about 15%.
Izvor: AnandTech, HotHardware, PC Perspective, ViperLair i AMDZone
Zadnje izmijenjeno od: McG. 15.06.2009. u 17:27. Razlog: Reupload slika:)
Staro 07.06.2007., 16:45   #9
Postovi: 7,568
RD780/790 i RX780 AM2+ ploče na Computexu
  • Gigabyte is the only partner to have a live demonstration of RD790, from what we have seen. The Gigabyte GA-M790-DQ6 features four PCIe 2.0 x16 slots capable of dual x16 or quad x8 configurations. The Gigabyte GA-M790-DQ6 does not have any PCIe x1 slots. However, the GA-M790-DQ6 features two standard PCI slots.
  • Asus have a rather stylish looking RD790 motherboard at their booth which will support upcoming 45nm AM2+ processors from AMD. The upcoming Asus M3A32-MVP Deluxe supports Socket AM2+ processors with HyperTransport 3.0, or HT3. The board features dual PCIe 2.0 x16, three PCI and one PCIe x1 slots. The Asus M3A32-MVP Deluxe will also support DDR2-1066 memory.
  • The Asus M3A-MVP features the mainstream RD780 chipset with a cut-down PCIe lane configuration. Asus equips the M3A-MVP with two physical PCIe 2.0 x16 slots. The PCIe 2.0 x16 slots default to dual eight-lane configurations when both slots are occupied.
Expect AMD RD790, RD780 and RX780 motherboards later this year.
Izvor: DailyTech
Zadnje izmijenjeno od: McG. 15.06.2009. u 17:28. Razlog: Reupload slika.:)
Staro 14.06.2007., 00:14   #10
Postovi: 7,568
Chipseti serije 7 u drugoj polovici '07.
The upcoming series 7 will introduce support for HyperTransport 3.0 for AMD's processors - and reportedly AMD has decided not to release series 7 chipsets for Intel CPU's, thus putting an end to the RD700, RS700, and RC710.
Here is a breakdown of the expected chipsets:
  • RD790 will adopt PCIe 2.0 - this will be the high end chipset, scheduled for Q4
  • RX780 will be the mainstream chipset, scheduled for Q3
  • RS740 will feature an integrated DX9 capable GPU, scheduled for Q3
  • RS780 will have a DX10 capable GPU with AMD's "UVD" (universal video decoder) scheduled for Q4
The chipsets will initially use the existing SB600 southbridge, but apparently AMD plans to release a SB700 in Q4.
Izvor: Neoseeker, DigiTimes i DailyTech
Staro 14.06.2007., 08:42   #11
Postovi: 34,093
Izgleda neka nova poslovna politika - umjesto 'čim bržeg' rade se 'čim štedljiviji' procevi. Ali zato na ploči bakra ima sve više. Još malo pa će chipset cooleri biti veći od cpu coolera.
btw, koji će ...ac MSI ploči 4 PCI-E 16x slota?
Staro 14.06.2007., 11:05   #12
segregator
Propali Amigaš
segregator's Avatar
Lokacija: Nin
Postovi: 7,007
Evo i steppinga pa da znate kad kupujete nove AMD-e.
Zadnje izmijenjeno od: McG. 30.09.2010. u 16:04.
segregator je online   Reply With Quote
Staro 15.06.2007., 13:58   #13
Postovi: 7,568
Phenom GP, GS, GE i FX modeli
The newest information showed that AMD will launch GS-6550, GP-7000 and 7100 products in Q4; GP-6800, GS-6650, GE-6600, 6500 and 6400 in 2008 Q1.
The clock range of:
  • 7100 is 2.2-2.4GHz
  • 7000 is 2.0-2.2GHz
  • 6800 is 2.4-2.8GHz
  • 6650 is 2.2-2.6GHz
  • 6550 is 2.0-2.4GHz
The high-end desktop FX series will remain its name methods including FX-80 and FX-9x. Only FX-9x is 1207+ interface. FX-80 clock is 2.2-2.4GHz the same with FX-90. FX-91 is 2.4-2.6GHz.
Izvor: Hardspell
Staro 20.06.2007., 00:15   #14
Postovi: 7,568
65nm Athlon64 5200+ X2 u dva okusa
This June the company is going to launch 65nm version of their Athlon 64 X2 5200+ processors on Brisbane core that will hit 2.7GHz frequency. Note that a lot of Brisbane processors are now capable of overclocking to 2.8GHz with the nominal Vcore that is why it may strike you as a bit surprising that AMD has been holding off the launch of faster 65nm 64 X2 CPUs for a while.
AMD’s documents mentioned two modifications of 65nm Athlon 64 X2 5200+ (2.7GHz) processors. It is 65W for ADO5200IAA5DD and 76W for ADI5200IAA5DD. As a result the supported voltage ranges are also different: 1.3-1.35V and 1.325-1.375V respectively. Both processors are built on the same G1 core stepping. This CPU is available in Chinese retail at $158 for an OEM unit and the official wholesale price is $178.
Izvor: X-Bit Labs
Zadnje izmijenjeno od: McG. 30.09.2010. u 18:21. Razlog: Reupload slika.:)
Staro 21.06.2007., 13:45   #15
Postovi: 7,568
Roadmap i vrijeme lansiranja Phenom procesora
  • AMD targets Barcelona to launch in Summer 2007 and expects ramp in frequency and volume subsequently. We can expect low clocked Barcelona in August timeframe
  • Phenom series to be launched in Nov-Dec with DVT samples in Sep/Oct timeframe
  • Phenom FX AM2+ part called FX-80 in Q4 timeframe and TDP for the FX series are yet to be determined
  • 45nm Deneb, Propus, Regor and Sargas STARS cores in H2 2008
  • Single-core Lima has been removed from the roadmap so single-core Orleans will be replaced by dual-core Rana in Q1 next year. The mainstream segment will shift from single core to dual core by early next year
  • AMD expects to provide next schedule update in July
Izvor: VR-Zone
Staro 22.06.2007., 17:40   #16
Postovi: 7,568
Biostar TF560 A2+ AM2+ ploča
Biostar has released a new T-Series model TF560 A2+ in expectation of the launch of new AMD socket AM2+ CPUs. AMD is going to announce AM2+ socket CPUs, the so-called real Quad Core architecture, later this year. Socket AM2+ CPUs will be backwards compatibile. TF560 A2+ is designed for both CPU series, AM2 and AM2+. Packed with the same technology used by the most demanding PC Enthusiasts, nVidia nForce 560 media and communications processor (MCPs) delivers outstanding quality and performance for every PC user.
Izvor: Madshripms, Biostar i VR-Zone
Staro 02.07.2007., 17:49   #17
Postovi: 7,568
45W TDP Phenom X2 modeli
AMD will offer at least three models of dual-core AMD Phenom X2 processors with 45W thermal design power. The new AMD Phenom X2 chips based on the new micro-architecture from the chipmaker will not have high TDP, though, they are projected to offer performance levels inline or higher with today’s dual-core AMD Athlon 64 X2 products with decreased power consumption.
The new dual-core AMD Phenom X2 processors with 45W power consumption are:
  • Phenom X2 GE-6600 (2.3GHz, 512KB L2 per core, 2MB shared L3)
  • Phenom X2 GE-6500 (2.1GHz, 512KB L2 per core, 2MB shared L3)
  • Phenom X2 GE-6400 (1.9GHz, 512KB L2 per core, 2MB shared L3)
Advanced Micro Devices has been consistent in its attempts to lower power consumption of its chips from 89W to 65W and from 65W to 45W. Already in the third quarter of the year AMD will have five dual-core chips with 45W TDP and a number of single-core offerings with similar thermal specs, which is an indicator that the chipmaker is pretty serious about offering low-power desktop solutions.
Izvor: X-Bit Labs
Zadnje izmijenjeno od: McG. 30.09.2010. u 18:22.
Staro 08.07.2007., 16:59   #18
Postovi: 7,568
High-end RD790 chipset - 15W TDP
AMD RD790 is the next chipset from AMD that is suppose to rock our worlds. The RD790 is next high-end chipset that brings a lot of interesting features besides its support for the coming Phenom processors. RD790 will have dual socket and Quad CrossFire support along with HyperTransport 3.0 and PCI Express 2.0. Being such a feature-rich chipset we have to say that we were fearing that the chipset would be immensely hot. That doesn't seem to be the case though as Chilehardware now reports that the RD790 chipset will have a TDP of a mere 15W. This is actually a lot lower than today's high-end chipset where the C55 of the 680i is the perhaps worst with its 23.9W. The TDP isn't a guarantee for the chipset being cool though as the 975X (17W) has a lower TDP than the 965 (23W), but still runs hotter.
Izvor: NordicHardware i ChileHardware
Staro 11.07.2007., 14:29   #19
Postovi: 7,568
nForce 570LT SLi chipset - odgovor na AMD 570X
Right after AMD announced a new chipset 570X that supports CrossFire in a 8X + 16X configuration, nVidia comes out with another chipset known as nForce570 LT SLi. nForce570 LT SLi should be similar to the nForce570 SLi with reduced functions, but it turns out that 570 LT SLi is way apart from the 570 SLI. For example, for SATAII: 4 VS 6, 570 LT SLi also removed TCP/IP Acceleration and Dual net etc. nForce570 LT SLi seems to look like the nForce560, compared to nForce560, nForce570 LT SLi has an additional Dual 8X SLi functionality. The rest are just like the nForce 560.
Izvor: OCWorkbench
Zadnje izmijenjeno od: McG. 30.09.2010. u 18:22. Razlog: Reupload slika.:)
Staro 18.07.2007., 17:07   #20
Hrvoje S
Lokacija: Garešnica
Postovi: 43
to kada se pojavi na trzistu to ce biti masine a vjerojatno ce i cjene biti paprene (visoke) a do tada ce nam valjati i nasi (sada zivuci)
Hrvoje S je offline   Reply With Quote
Staro 20.07.2007., 17:12   #21
Postovi: 7,568
nVidia MCP78 chipset u studenome
nVidia is targeting to launch their first GeForce 8 DX10 UMA chipset called MCP78 for AMD processors in November. MCP78 support the new Hybrid SLI technology, HyperTransport 3.0 and PCI Express 2.0. nVidia hopes to create a new category of motherboard graphics that offers entry level discrete GPU performance but cheaper. nVidia touts a Hybrid performance boost up to 40% by pairing up with a mainstream discrete graphics card, ~20% with a performance card and ~5% with enthusiast card.
There will be 3 variants; MCP78 U, MCP78 S and MCP78 D and all supports 1x16 PCIe 2.0.
  • MCP78 U is priced at US$70-80 where its 3DMark performance on par with entry level graphics card and PureVideoHD support.
  • MCP78 S is priced at US$55-65 with decent graphics performance and PureVideo support.
  • MCP78 D priced at US$55-65 has no int. graphics capability and thus no Hybrid SLi and PureVideo support.
nVidia plans to deliver A01 samples to customers in August and A02 samples in October where mass production and launch slated for November.
Izvor: VR-Zone
Staro 24.07.2007., 22:03   #22
Clifton
humanoid carbon unit
Clifton's Avatar
Lokacija: tamo
Postovi: 347
Autor McG Pregled postova
Dual-core Brisbane CPUs clocked in the 1.9 GHz to 2.3 GHz range, will feature a 45W thermal envelope[/B][/I]. AMD guidance claims these chips will get a simpler designation.
Each of these new processors will be named as follows:
  • AMD BE-2400: 45W Brisbane, 2.3 GHz
  • AMD BE-2350: 45W Brisbane, 2.1 GHz
  • AMD BE-2300: 45W Brisbane, 1.9 GHz
đizs, trebalo im je da stignu... svejedno, ful je čudno više ne čitat PR nazive u gornjem desnom kutu pakiranja... nekak "intelovski"
Zadnje izmijenjeno od: McG. 30.09.2010. u 16:02.
Clifton je offline   Reply With Quote
Staro 24.07.2007., 22:07   #23
Postovi: 7,568
Autor Clifton Pregled postova
Kasnili su kojih mjesec dana. U inozemstvu su u prodaji od prije tjedan i pol, tak da nismo preveč iza njih.
Nego, ako nije tajna ta dva modela si u našim dućanima našel? Ako jesi, po kojoj cijeni i koji dućani? Unaprijed zahvaljujem.
Staro 24.07.2007., 23:10   #24
Clifton
Clifton's Avatar
Lokacija: tamo
Postovi: 347
Kasnili su kojih mjesec dana. U inozemstvu su u prodaji od prije tjedan i pol, tak da nismo preveč iza njih. Nego, ako nije tajna ta dva modela si u našim dućanima našel? Ako jesi, po kojoj cijeni i koji dućani? Unaprijed zahvaljujem.
je, u mojem di delam. links. cijenu ne znam, bit će formirana sutra poslijepodne vjerojatno kad se puste u prodaju...
Staro 26.07.2007., 03:36   #25
Ozy
Spužva Bob Skockani.. :XD
Ozy's Avatar
Postovi: 1,685
Ima li kakav info o novoj cijeni navedenog Brisbane-a..?
Ja danas bio u Linksu i uzeo (još jedan , prvi iz Vemila);i vidim da piše X2 3600+ , dakle kutija po 'starom PR rejtingu,a i cijena je i dalje 481kn...
Te još bitnije - dali bi se ovi sa 45W TDP-a trebali bolje clockat;dosta bolje,ili...ili je to sve podjednako..? Da znam i imam info negdje ako su ovi BE-2300 zvijeri za clock,pa da svog i ne otvaram nego ga utrpam nekome u konfu...
EDIT :
A skupi su ovi BE,ja mislio bit će ista ili skoro ista cijena...kad ono ništa...AMD nas neće privući ovakvom politikom,a taman je imao full egzotične cijene...
I da,ako je i OC podjednak;onda mi 45-watni TDP i nije tolika prednost,samo će biti još malo 'hladniji ; što nije loše;ali ipak mi se ne daje razlika od 250kn za "isti proc" odnosno isti takt..
Athlon64 X2 5400BE Brisbane @3000Mhz + KATANA 2 + AirTunel@2x Xilence 120mm
Gigabyte GA-MA78G-DS3H @F4
Mushkin Redline @1000Mhz 5-5-5
XFX 9600GSO @680/1700 || 2000Mhz
Seagate Gonzales 250GB & 320GB && Spinpoint F1 500GB
Coolermaster Elite Power RS460; Sharkoon Silvation; LG GH22NP20/LG GH20NS10/Pioneer DVR107D/Pioneer 216DBK/ Samsung SH-S223F; Logitech MX518; Philips 190P7ES 19" LCD
Zadnje izmijenjeno od: Ozy. 26.07.2007. u 14:36.
Ozy je offline   Reply With Quote
Staro 26.07.2007., 12:28   #26
Postovi: 7,568
Autor Ozy Pregled postova
Cijena 65W Brisbane procesora, pogotovo 3600+ X2 više ne bude padala. Možda koju kunu kad se udomaće BE modeli, ali i to je upitno.
Vani je BE-2300 oko $90, a BE-2350 oko $100. Evo ima ih sad u Linksu za 749 kn i 803 kn. Kaj se tiče clockanja 45W modela imaš na prijašnjim stranicama ove teme par linkova, pa provrti ako ti se da. Uglavnom idu isto/slično ko i 65W primjerci.
Staro 26.07.2007., 19:34   #27
Postovi: 7,568
Demonstriran Phenom(enalni) X4 na 3.0GHz
Izgleda da je masa samoprozvanih tržišnih analitičara, plaćenih recenzenata, uvijek dežurnih spammera i pokoja gospodična iz marketinga na relaciji Indija-Izrael-Kalifornija blago rečeno podcijenila ljude iz doline Saske.
AMD is showing off something that many people have doubted them about lately, and that is a high speed quad core processor. While not mentioned by name at AMD's analyst day, there are "Quad Core Processors for Desktop" being demonstrated using 3-way CrossFire. Both machines are running a yet-to-released Phenom processor based on the Agena core. One machine is running Call of Juarez and the other is running Stranglehold. I have personally played stranglehold on an Agena system and watched it fully utilize all four Agena cores.
I guess the speed path problems with Barcelona were a bit overblown. At the analyst day this morning, AMD demoed a 3Ghz Phenom running the new 'Tri-Fire multi-GPU' setup. Not much more to say, 3.0 GHz, three 2900XTs and lots of available gaming goodness. You will notice that the two cards connected with a bridge, a third in software.
EDIT:
Octal-core Bulldozer obitelj procesora, 4-Way CrossFire, desktop i server planovi za sljedeće dvije godine: 1, 2, 3, 4, 5, 6
Izvor: [H]ard|OCP, Inquirer, AnandTech, DailyTech i The Tech Report
Zadnje izmijenjeno od: McG. 15.06.2009. u 17:22. Razlog: Dodane informacije o planovima za sljedeće dvije godine
Staro 27.07.2007., 11:12   #28
LAcy
Pink Floyd fan
LAcy's Avatar
Lokacija: Santa Clara, CA
Postovi: 5,564
Nadam se da je ovo točno, držim palčeve AMD-u.
Core i7-6700K LGA1151 Skylake
RTX 2080 TI 11GB GDDR6
Samsung 850 EVO M.2 1TB SSD
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 27.07.2007., 13:50   #29
Postovi: 7,568
Ovo za Phenom na 3.0GHz je točno i u to nema sumnje. Sad budu napokon prestale razno-razne gluposti kružiti po netu kak AMD ima probleme s wafferima, kak nemreju napraviti quad-core s radnim taktom većim od 2.0GHz i tome slične nebuloze. Pošto i AMD i Intel već jedno dulje vrijeme imaju spremne 45-nm procesore (kaj za pokazivanje, kaj za testiranje), ne bi bilo ništ čudno da su ovi planovi za sljedeće dvije godine također točni. Ma, da i pol toga kaj su najavili naprave kak su zamislili opet bu dobro.
Staro 27.07.2007., 14:01   #30
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,564
AMD trenutno ima financijskih problema i to je na žalost točno, također im ne pomaže to što stalno odgađaju nove proizvode kao ni silne glasine. No AMD je žilav i inovativan igrač, zaista mu želim da se izvuče.
MacBook M1 Pro
MacBook Air M2
Moto Edge
