#241 |
Baja!
Lokacija: Sisak
Postovi: 761
Oprosti sto sizim,ali stvarno sam lud..ako mi skuzi tko to..ufff...jos jednom se ispricavam! I da..probao sam to i stalno mi pise PORT STATUS:ACTIVE i dolje u statusnoj liniji pise DEVICE OPENED..ali on njega uopce ne prepoznaje niti ista ![]() Daj molim te pomagaj! |
#242 |
Soul Eater
Lokacija: Isolated
Postovi: 538
Za početak, deinstaliraj drivere od moba, pa ih stavi ponovo. Nakon toga, spoji mob na xs, drži c, i trebao bi dobiti nešto ovako : 13:33:37| XS++ v1.2 Ready ! 13:33:46| Attempting to open the interface... 13:33:46| ++++++++++++++++++++++++++++++++++ 13:33:46| Turn off phone 13:33:46| Hold C Button on phone and connect phone. 13:33:46| You have 30 seconds. 13:33:46| ++++++++++++++++++++++++++++++++++ 13:33:53| PORT STATUS: ACTIVE 13:33:54| Baseband ID: 8040 13:33:54| Hardware Platform: db2010 Marita compact 13:33:54| Protocol Version: 3.1 13:33:54| Sending loaders\db2010_cid00_prodid_p3k.bin... 13:33:54| This is a PRODUCTION_ID loader 13:33:54| Activating GDFS... 13:33:54| Warning: IMEI name does not match GDFS name (IMEI:K750 GDFS:W800) 13:33:54| ...using IMEI name 13:33:54| Sending loaders\db2010_cid36red_flash_r2ab.bin... 13:33:55| This is a FLASH loader 13:33:55| ++++++++++++++++++++++++++++++++++ 13:33:55| PHONE INFO 13:33:55| ++++++++++++++++++++++++++++++++++ 13:33:55| DBID: db2010 13:33:55| OTP CID: 36 13:33:55| EROM CID: 36 13:33:55| EROM color: Red 13:33:55| IMEI: 35785000xxxxxx 13:33:55| Phone: K750 13:33:55| Operator: EMEA_6 13:33:55| CDA: CDA102430/6 R2A 13:33:55| Firmware: R1BC002 13:33:55| EROM: n/a 13:33:55| ++++++++++++++++++++++++++++++++++ 13:33:55| Ready for operation! Što god dobiješ kopiraj ovdje, ali samo ono dok upališ mob, nemoj ništa flashat ili tako nešto. |
#243 |
Baja!
Lokacija: Sisak
Postovi: 761
Nazalost nije ![]() Obrisao sam drivere,restartao komp,i ponovno instalirao drajvere,ali nece bas nista...mob se nece ni upaliti a u XS++.u mi pise opet ono...PORT STATUS:ACTIVE! Daj mi molim te reci da ima nekog lijeka ![]() |
#244 |
Soul Eater
Lokacija: Isolated
Postovi: 538
Jel imaš msn? Ako ne, idi na http://get.live.com/messenger/overview pa skini msn, napravi si account, pa ćemo step-by-step preko neta. |
#245 |
Postovi: 11,642
Probaj sa XS-om v1.2... |
#246 |
Baja!
Lokacija: Sisak
Postovi: 761
#248 |
Postovi: 11,642
Što te košta da probaš...ova nova verzija je malo drukčija od stare, možda se ova neš zblesirala ![]() |
#250 |
The Geek Wants Out
Lokacija: xxx
Postovi: 1,193
#252 |
Lokacija: Vukovar
Postovi: 91
Upute: Skinite Fast forward & rewind patch.zip i sa GSlideom ga slajdamo u main, zatim isti flashamo sa XS++ i to je to i kad main ocu prebacit na mobitel -treba ga stavit u files_to_upload??? i dali treba napravit neku mapu prije toga ili direkt u files_to_upload??? |
#253 |
Postovi: 11,642
#254 |
Lokacija: livno
Postovi: 1,065
#255 |
Postovi: 3
![]() jel može netko objasnit jel se može to staviti na k800i....ili ima neki drugi program za to? ![]() |
#256 |
Postovi: 11,642
Ne ide ti to na k800... |
#257 |
Postovi: 3
aha...ok...jel znaš možda jel ima negdje objašnjeno kako se te ikone mijenjaju na k800? ![]() |
#258 |
Postovi: 11,642
Koliko je meni poznato, to (još?) nije moguće na k800... |
#259 |
Baja!
Lokacija: Sisak
Postovi: 761
@Tekla pise ti pod lokacija:Sisak ![]() A sad jos jedno pitanje;ovi drajveri za kameru,jel se to isplati instalirati..i da mi netko pokusa sto je krace moguce to objasniti..gledao sam post od Crnog,ali opet nekak se gubim tamo :| I da..jel ima kakva modifikacija/drajver ili slicno kako bi mi pojacao zvuk..znaci kad odvrnem muziku u busu da cuje cijeli bus ![]() |
#260 |
Postovi: 3
ok...Razer ipak hvala =)...ak neko drugi zna jel se to može na k800 nek napiše...hvala ![]() |
#261 |
Postovi: 11,642
U crn-ovim postovima imaš modane drivere za zvuk pa tako i za kameru...probaj jedan od njih... |
#262 |
Strichek Moderator
Postovi: 9,343
@Apacer Ogameru ![]() Dakle u XS++ folderu imaš folder koji se zove Files to upload I unutra napraviš redom foldere \ifs\settings\camera I onda u zadnji staviš driver od kamere, odeš u XS++ i napraviš kak je na slici u 2 postu objašnjeno. Isto i za zvuk samo napravi sljedeće foldere \ifs\settings\acoustic I to je to. P.S. Jel još igraš uni9 ? ![]()
žmnpp |
#263 | |
Lokacija: livno
Postovi: 1,065
@pa joj apacer a kog si ti zezo ODAKLE SI na lol serveru ![]() |
#264 |
Baja!
Lokacija: Sisak
Postovi: 761
Uspjesno sam sve instalirao...i drajvere za zvuk (njih nemogu trenutno isprobati jer neki u kuci jos spavaju ![]() Evo sada kako sam ja rijesio problem sa instalacijom drajvera:kad god sam neki drajver instalirao,ili meni novi..obrisao sam taj folder iz files_to_upload jer mi se cini da mi je zbog toga malo sralo..pa sam morao 7-8 puta sve ispocetka flashati! I da..svaki puta kada instalirate neki drajver ili slicno...resetirajte mobitel,jer se u suprotnom nece upaliti (bar meni nije htjeo) i nemojte se zabrinjavati ako vam bude trebalo da nakon toga trebate duze cekati kako bi se sam mobitel upalio da ne bi dosli u napast da razbijete mobitel ko ja ![]() ![]() @Buljo-UNI 9 neigram od onda kad me je Widowmaker (ako se dobro sjecam) skrsio,jer mi je taman tada pocela 4 godina,pa nisam htjeo jos jednu godinu za***ati (iako skoro jesam ![]() @Tekla,oprosti ali ja te neznam..vjerojatno si sa mojim bratom nesto razgovarao..jer i on igra (vise od mene) Call of Duty,pa...a koristi moj nik ![]() |
#265 |
Hurr durr
Lokacija: Stančić
Postovi: 1,449
E sada ovako meni se neda citati 7 stranica pa cu vas pitati ,dali je ikako moguce drugacije srediti mob bez kabla jer ga nemam a nemam volje ga kupovati i da nabavio sam si firmware za mobitele pa bi ga htio nadograditi
#266 |
Baja!
Lokacija: Sisak
Postovi: 761
Mislim da nije moguce..jer sam program XS++ trazi od tebe svako malo da ukopcavas/iskopcavas mobitel... A i ne kuzim na koji drugi nacin bi mogao to raditi ako ti je mob cijelo vrijeme ugasen. BTW. procitaj sta pise,sve stranice..evo ja sam to sve procitao,malo se prebacio na strane forume i mogu ti reci da je stvarno zanimljivo i da od moba mozes napraviti stvarno cuda ![]() |
#267 |
The Geek Wants Out
Lokacija: xxx
Postovi: 1,193
još da si prvo sve pročitao pa tek onda išao flashati gdje bi ti bio kraj ![]()
#268 |
Lokacija: ----
Postovi: 107
sve sam uspio i to davno.... al me zezaju drajveri kad ih hocu ubacit stane mi na ovom dijelu i nista 02:30:25| ++++++++++++++++++++++++++++++++++ 02:30:25| Ready for operation! 02:30:33| +++ Flashing breakin... 02:30:33| Sending loaders\db2010_cid49red_flash_r2a003.bin... 02:30:33| This is a FLASH loader 02:30:33| Sending flashfile loaders\jhf02.bin 02:30:33| 1 flashblocks 02:30:35| Done flashing 02:30:35| ++++++++++++++++++++++++++++++++++ 02:30:35| Disconnect phone from USB-port and wait for 02:30:35| further instructions. 02:30:35| You have 8 seconds. 02:30:35| ++++++++++++++++++++++++++++++++++ 02:30:43| Open the battery-cover and reinsert the battery. 02:30:43| Hold C Button on phone and connect phone again. 02:30:43| You have 30 seconds. 02:30:43| ++++++++++++++++++++++++++++++++++ poslje ovog mi nece se upalit mob. al sreca prepozna ga XS++ i mogu ga ponove flash imal veze sto mi je XS++ 1.2 |
#269 |
Lokacija: ----
Postovi: 107
probo sam XS++ 1.5 ne benda,na istom stane! |
#270 | |
Kernel panic
Postovi: 522
Keyboard error or no keyboard present Press F1 to continue, DEL to enter SETUP |
