#92 |
Postovi: 11,642
Pa ne moraš znati poljski da znaš što znači ''Program'' ![]() Ovo ostalo su ''doseri''... I da, samo da napomenem nadam se da koristite doser ''Reset'' između uzastopnog isprobavanja više dosera... |
#94 | |
Ev1LMa5ter
Lokacija: Koprivnica
Postovi: 675
Evo ja jucer probao 5HTP Citiraj:
androidhrvatska.com |
#95 |
Premium moderator
Postovi: 4,600
LOL, doza je da budeš hepi a ti dobio noćne more ![]()
__________________ |
#97 |
Hurr durr
Lokacija: Stančić
Postovi: 1,449
Dali je itko probo "Hand Of God" Hand of God Premium (Unexplainable) 30 Minutes A dose that has been a lifetime achievement for I-Doser.com, and only held internal to I-Doser Labs for a very good reason: It isn’t meant for public consumption because it is considered just too powerful. It’s like the Holy One reaches from the sky, as you lay with closed eyes, and shows you the world. Only 5 people have ever witnessed the power of this dose, and it was put away in the I-Doser vault for fear of release. Fluttering eyelids, great and almost supernatural clairvoyance, rings of light and great insight, but all this comes with a price. It could also force great fear, an unknowing realization of self, and a breakdown of all senses. Weeping, fear, anger: you need to realize with such insight could come with bad consequences.
#100 |
Postovi: 11,642
Nemoraš resetirati ako uzimaš samo jedan doser, to samo ako ideš više komada probati, pa iza svakog... |
#101 | ||
Spermich Termich
Lokacija: Zaprešić
Postovi: 885
![]() ![]() Citiraj:
![]() ![]() al ak neš bude... onda ***iga ![]()
#102 | |
Pijem samo KAJ
Lokacija: Vž
Postovi: 2,688
![]() Koja je najbolja stvar da postaneš lud, tj. najbliže stanje blagoj pijanosti kad ti je sve ravno???? |
#104 |
mogu mislit kako ste vi kaj kazete da ne djeluje slusali, ziher ko ovaj gore pustili onda malo prosurfali po forumu pa porazgovarali sa nekim ukucanom nekim pa pauzirali malo pa osli do vca... btw da, normalno je da sumi. |
#107 |
OMG, thats the funky shit
Lokacija: in The Republic of Peščenica
Postovi: 1,221
Ja probao kokain, no nisam cuo do kraja al negdje iza polovice jer sam zaspao. I kad sam otvorio oci vrtilo mi se i na trenutak ko da sam osjetio kako mi krv tece zilama ![]()
#112 |
Lokacija: Igrane - Split
Postovi: 75
bija san skeptican da je sve to placebo efekt jer se uživiš.. al proba san popodne french roast i bome je djelovalo. e 10.7. iman prijemni za fax jel ima neka doza da mi pomogne malo ![]()
------------------------------------ TCP / IP - tri crne pive, i pelinkovac ![]() ------------------------------------ |
#113 |
Postovi: 11,642
Također 10. ![]() Ja se ujutro mislim nakrkat s ovim: Inspire: Experimental (Moderate) 30 Minutes This dose was created for users who require inspiration, for whatever reason! If you work in a creative job: be it writing, art, or just needing the ability to creatively think, then you know that being in the mood to be creative is not always an easy thing. The Theta 3-7 Hz level is normally associated with recall, fantasy, imagery, creativity, inspiration, future planning, dreaming, and switching thoughts. Writers block chips away with this dose, ideas flow, and you will have creative thoughts more freely flow with this dose. Mislim da je to najbliže onom što trebamo ![]() |
#115 |
Postovi: 11,642
#117 |
Postovi: 11,642
Kako je buljo to dobro rekao, možda je čovjeka RL očvrsnio ![]() ![]() |
