Postovi: 18,907
CyberLink PowerCinema 5 Patch 3807
Updated Patch: This patch file updates PowerCinema 5 to version 3807 and enables PowerCinema 5 to fully support Windows Vista 32/64 bits. Information: The patch is relevant for users who have experienced the following problems. Note:
System Requirements: CPU: Intel Pentium 4 2.6 GHz or higher (higher CPU speed will yield higher video quality) Memory: 256 MB of RAM (512 MB or more recommended) Operation System: Microsoft Windows XP (Home edition or Professional edition) Microsoft Windows Vista DirectX 9 or above Windows Media Player 9 or above Remote Control (Optional): Windows XP Service Pack I is required in order to operate the remote control. Hard Disk: 200 MB of available hard disk space required for installation (500 MB required for running the program, 1 GB of free hard disk space is required for running the TV time-shifting function). Video Display Card: DirectX-compatible display adapter for 16-bit colors display (32-bit color displays recommended). When using 3D UI mode, a graphic card with 64 MB or more of video memory is recommended. A 3D display card is required for PowerCinema's transparent menu index. Audio Card: DirectX-compatible PCI sound card, USB audio box, or built-in audio device required for audio playback and recording. Optical Device: DVD-ROM, DVD-R/RW, DVD-RAM, DVD+R/RW, DVD-Dual, DVD-ROM/CD-RW, or DVD Multi-drive with 1394, USB 2.0, ATAPI, SCSI, or Card Bus interface. TV Tuner Card: CyberLink's bundled TV tuner card has been tested and is recommended for use with PowerCinema 5. Windows-compatible analog tuner cards with a WDM driver or a digital/hybrid tuner card with a BDA driver may also be compatible. For a list of compatible tuner cards please click here. Display: Windows-compatible display with at least 1024x768 resolution. Mouse: Windows-compatible mouse or pointing device. Download: http://download.cyberlink.com/ftpdlo...Link.v3508.exe
