Postovi: 1,212
Qtek 9100, BlueSoleil i ActiveSync
Nikako ga sinkronizirati. Imam neki Sempre BT iz Linksa (BU100-01S) koji koristi taj BlueSoleil. Na kompu od brata ili starog ju bez problema napravim (oni imaju neki Widcommov), a na mom nikako. Evo iskopao i ovo na netu: ------------------------------------------------------ How to use an active sync Bluetooth Connection Through the Bluesoleil software. 1. Set ActiveSync on the PC to listen to connections from the Bluetooth serial port. 2. Start ActiveSync on PDA 3. Select Connect via Bluetooth 4. A dialogue Cannot find an existing bluetooth partnership with a PC that supports ActiveSync. Do you want to create a new partnership now appears. Select yes. 5. Ensure PC is discoverable. 6. Search for devices. 7. The PC will show up. 8. Pair with device, enter PIN on both devices. 9. Select the serial port service to use. 10. From the Bluetooth screen, select the COM Ports tab. 11. Create a new Incoming Port. 12. Go back to ActiveSync on the PDA. 13. Select Connect via Bluetooth 14. The dialogue Cannot find an existing bluetooth partnership with a PC that supports ActiveSync. Do you want to create a new partnership now appears again. Select yes. 15. Now select the PC the paired with. 16. Serial port is shown. 17. Select refresh. 18. Watch in astonishment as serial port changes to ActiveSync ------------------------------------------- Sve lijepo ide, samo se meni na 18. koraku serial port nece promjeniti u ActiveSync |
Postovi: 18,928
Probaj Widcommove drivere instalirati i kod sebe. Moj BT stick radi na oba + driverima od SP2. Ako ne ide, u BS-u pokreni taj Active Sync ili kako se kod njega već zove...
Postovi: 1,212
Probao sam s njihovim driverima i kaze da ustekam stick, a u BS-u mi nije dostupan taj servis - samo Bluetooth Dial-Up Networking Service i Serial Port Service Edit: gore sam zaboravio napomenuti ako ce nekome nesto znaciti - sinkronizacija preko kabla ide bez problema |
Postovi: 18,928
Što se dogodi kad pokreneš serial port service? Pukne veza ili ostane aktivna? Ako pukne, klikni još par puta...
Postovi: 1,212
Evo tek sam sada ovo vidio (tražio sam neš u google-u ovaj BT). I kakav je? Još sve u redu? Jesi stavio WM6? |
