Staro 04.06.2007., 23:06   #1
HAL 9001
Poboljsana verzija
HAL 9001's Avatar
Postovi: 484
Cooler za chipset
Pozdrav , imam maticnu plocu DFI LP i chipset se jako zagrijava(temp ne pada nikad ispod 50 stupnjeva).Molim vasu preporuku za aktivni ili pasivni cooler samo da je bolji od trenutne brusilice.
HAL 9001 je offline   Reply With Quote
Staro 04.06.2007., 23:14   #2
Simba-OS
Simba-OS's Avatar
Postovi: 359
Ovo je moja preporuka.
Simba-OS je offline   Reply With Quote
Staro 04.06.2007., 23:59   #3
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
E mislim da je plavi zalmanek malo preslab hladnjak za lanparticu pogotovo ako klokamo...
Ali 50C ti je ok temperatura
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 05.06.2007., 00:15   #4
HAL 9001
Poboljsana verzija
HAL 9001's Avatar
Postovi: 484
Autor Simba-OS Pregled postova
Cini mi se da bi taj mogao smetati grafickoj kartici.
Staro 05.06.2007., 00:26   #5
stuc
stuc's Avatar
Datum registracije: May 2005
Lokacija: Online
Postovi: 2,404
stuc je offline   Reply With Quote
Staro 05.06.2007., 01:39   #6
ninja666xx
ninja666xx's Avatar
Lokacija: Zdenčina
Postovi: 314
čuj i ja sam imao sličan problem...mislim da te nebi trebalo zabrinjavat što je chipset prevruć mislim da je 50c ok temp i dok ti se sustav ne sruši nemaš brige...a ono bolje spriječiti nego liječiti zaboravi u ovome slučaju...
ninja666xx je offline   Reply With Quote
Staro 05.06.2007., 03:38   #7
mislav_os
freak
Postovi: 2,688
Pa ja mislim da je ta temperatura jos uvijek u granicama normale za tu plocu.
Staro 05.06.2007., 09:26   #8
Simba-OS
Simba-OS's Avatar
Postovi: 359
Autor HAL 9001 Pregled postova
Hm, da. Nisam gledao prije. Vrlo nespretan raspored elemenata na ploči.
Staro 05.06.2007., 12:37   #9
Optik
________
Lokacija: .
Postovi: 774
HR-05 Sli
http://www.links.hr/index.php?naziv=...kl=050.909.099
mislim da dalje ne trebas trazit
Optik je offline   Reply With Quote
Staro 05.06.2007., 12:38   #10
Jelc
Super Moderators
Datum registracije: May 2002
Postovi: 17,485
50c nije puno.
Za tu ploču je dobitna kombinacija (ali nije jeftina) Zalman na grafi i THERMALRIGHT HR-05 SLI na chipsetu.
Zalman puše po pasivcu i hladi izvrsno.
Skuplje je, ali se može premjestiti kad se kupi druga ploča ili grafa...
Staro 05.06.2007., 12:46   #11
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,507
HR-05 SLI ako se ima para!
Ja imam plavog zalmana, po njemu piri 120mm na 5V, ali onako malo jer piri i po VGA, a k tome otpuhuje i vrući zrak sa HDD-a. Naravno računalo radi 24/7 i to na 31X FSB-a...
Staro 05.06.2007., 13:53   #12
Gen1us
Gen1us's Avatar
Postovi: 300
Autor Anarki Pregled postova
HR-05 Sli
Ako se bolje razmisli u cemu je poanta dat za cooler za chipset 50% vrijednosti ploce mozda i vise...
Na kraju bi mu hladenje trebalo sve ukuno ispast vise od vrijednosti kompa
Idi na zalmana i vent koji ce puhat po njemu
Gen1us je offline   Reply With Quote
Staro 05.06.2007., 13:55   #13
-POP-
Eddie
-POP-'s Avatar
Postovi: 5,507
Da, ali HR 05 SLI će komotno ohladiti bilo koju ploču, pa i one koje dolaze, a može se montirati na svaku. Proda ploču sa zujalicom, TR ostavi sebi.
Staro 05.06.2007., 14:11   #14
domy_os
domy_os's Avatar
Postovi: 18,906
Autor -POP- Pregled postova
Ne može na svaku, je li, Lihto?
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 05.06.2007., 14:45   #15
John Creasy
Vocna iglica u mudante
John Creasy's Avatar
Lokacija: Beograd
Postovi: 2,837
Posto je HR 05 sli pasivni hladnjak, da li treba kakav ventic da ga hladi il je on sam dovoljan?
Staro 05.06.2007., 16:18   #16
Lihto
The Dark Side of Moon
Lihto's Avatar
Postovi: 3,945
Autor domy_os Pregled postova
ma šta ne može jesmo ga stavili na moju abiticu,makar piše da ne ide
Macbook M1+ LG32UQ85R
iPad 5 White 32gb Wifi
iPhone XR 128gb
Lihto je offline   Reply With Quote
Staro 05.06.2007., 23:47   #17
Optik
________
Lokacija: .
Postovi: 774
Moze se stavit na bilo koju koja ima rupe samo malo maste ,materija i skila
(u mene je neko vrijeme bio na 9600pro)
@john-To ti opet ovisi od ploce do ploce tj od chipseta do chipseta. Nf4 moze pasivno bez problema dok za novije bi trebao kakav vent na 5-7
Staro 06.06.2007., 00:43   #18
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
heh... imo sam DFI LP i DFI Infinity i mogu rec da uzasno zivcirala zujalica pa smo je dali smaknut po kratkom postupku. TR HR05 SLI rijesava probleme i ako netko misli hladit NF4 sa Zalmanom... mislim da nece ic (pasivno) jer se cak HR05 bez ikakvog venta zagrijava za poludit.
ugl. HR05 SLI ti je jedino rjesenje kako Bog zapovijda za nf4 chipset.
Staro 08.06.2007., 11:05   #19
yedwy
Beskorisna bitanga...
yedwy's Avatar
Lokacija: Sesvete (Zg)
Postovi: 6,956
Zlaman CNPS7700AlCu + ZM-NB47J - 42-45C u loadu (i to nekidan po vrućinama) i to PRAVIH 42-45 ne naštimanih i samo sa jednim 80mm koji ispuhuje (imao sam prije 80mm na boku ali kad sam prošli tjedan ubo zalmana za proc maknuo sam ga)...
I čak i bez toga se možda radit (čisti pasivni zalman) makar se svinjski grije jer nf4 može i 70C izdržati na duge pruge a da mu se nebude ništa desilo...
Have a nice day...
Staro 08.06.2007., 12:48   #20
e-one
Civic (ab)user
e-one's Avatar
Lokacija: Zagreb-Dubrava
Postovi: 471
ma ne treba nista.hladi pasivno bez problema.kod mene zalman na grafi pushe po njemu,al i dok nije tog zalmana bilo temp nb-a nije isla preko 55C.sad je 40-45C.inace ploca iz sig-a na 300mhz.
e-one je offline   Reply With Quote
Staro 08.06.2007., 12:53   #21
Gen1us
Gen1us's Avatar
Postovi: 300
Dobar je i pasivno ali nij eti neki problem izdvojit 20 kn i kupit si tc il tak nes ak vec nemas doma vent od 80mm jer onda jos dosta bolje hladi....
Staro 08.06.2007., 13:35   #22
Jelc
Super Moderators
Postovi: 17,485
Autor e-one Pregled postova
Ako je na grafi Zalman ne treba ništa drugo, ako uzmeš neko veliko đubre od grafe koja ima vent taman do pasivnjaka a zrak izbacuje van-treba.
Ili ako se radi o nekoj X1xx ATI-ci pa ti njeni pasivci mosfeta dođu taman iznad chipseta a preko njih grafa ispuhuje topli zrak.
U takvim slučajevima treba ostvariti barem minimalan protok zraka preko pasivca...
Staro 08.06.2007., 13:43   #23
Bullet1
Bullet1's Avatar
Lokacija: Dubrovnik
Postovi: 2,583
u cemu je problem?
pitanje hladnjaka smo rijesili (valjda), pitanje dal treba vent na njemu? ukoliko ce OC-at svakako ukoliko ne, moze a ne mora. ako ima dobar protok u kucistu onda mu ne treba u oba slucaja.
npr ja na svojoj Infinity ploci drzim pasivno HR05 i dok mi ventovi rade na 5V dosta se zagrije (45-50°C) a dok su ventovi na 12V HR05 je onak... topao (niti 35°C)
prije sam drzao vent na njemu i vidio da je nepotrebno kad imam protok zraka u kucistu. 1 vent koji upuhuje 1 vent koji ispuhuje i ostalo je grafa,proc,napajanje.
zakljucak: ako imas dobar protok zraka ne treba ti vent u suprotnom ga mozes stavit a nemoras.
Staro 08.06.2007., 21:24   #24
PSIHO
Bloodshed Protected
PSIHO's Avatar
Lokacija: BiH
Postovi: 53
Definitivno najtisi aktivni potpuno bakarni cooler
http://www.thermaltake.com/product/C...4/cl-c0034.asp
PSIHO je offline   Reply With Quote
Staro 09.06.2007., 00:08   #25
Lord_Calidor
Extreme Air Cooler
Lord_Calidor's Avatar
Datum registracije: Sep 2004
Lokacija: Kastav & Rijeka
Postovi: 491
Autor PSIHO Pregled postova
"Definitivno"? O_o
Moze kakav test, review ili sl.?
---= The eternal mistake of mankind is to set up an attainable ideal =---
Lord_Calidor je offline   Reply With Quote
Staro 09.06.2007., 00:53   #26
Optik
________
Lokacija: .
Postovi: 774
Ma cemu izmisljat toplu vodu?
Onaj thermaltake najtisi aktivni nb cooler? to cu ti rec
hr05 (sli) pasivno ili ne vidjet ces sam kad stavis
Staro 11.06.2007., 00:08   #27
Daedalus
Sir Paški
Daedalus's Avatar
Postovi: 356
Za DFI LP Thermalright HR-05 SLI. Malo šta drugo stane zato jer se nb nalazi baš tamo di ne triba. Meni su prije temperature u loadu iznosile do 54C a nakon ugradnje HR-05 oko 44C. Cijena je oko 180 kn, dobiva se s pastom a dodatni problem predstavlja ugradnja jer one priložene plastične 'vide' ne drže. Ja sam to jednostavno rješia kupnjom i ugradnjom normalnih vida, matica i plastičnih podloški koje staviš na donju stranu matične da ne dođe do kratkog spoja. Dosta košta ali bolje ladi i nema više pilane na 6500 rpm.
Daedalus je offline   Reply With Quote
Staro 11.06.2007., 12:24   #28
Ništa
Lokacija: Josipovac
Postovi: 4
Tako je
Ništa je offline   Reply With Quote
Staro 12.06.2007., 00:25   #29
yedwy
yedwy's Avatar
Postovi: 6,956
Samo što Zalman košta 30kn i nudi isto ako imaš prozračan case a ako imaš neku puhalicu na CPU (a mniogi klokeri/moderi to imaju) nemora čak ni to zadovoljavati...
A meni se čini da je to oveća razlika u cjeni, naravno ako postoji neki drugi razlog zašto se to nemože napraviti to je nešto drugo, mada npr one ploče koje imaju nb oko grafe često može rješiti puhalica na grafi...
Naravno puhalice imaju svoju razinu buke ali mislim da ćemo se složit da VF700 ili cnps7700 na 5V ne ulazi u kategoriju neke velike buke...
Have a nice day...
Staro 12.06.2007., 00:27   #30
rendula
Lokacija: Zagreb, Trešnjevka
Postovi: 5,777
4500rpm i 19dB, yeah right
