Staro 31.05.2007., 12:51   #1
ernest1985
Postovi: 35
seasonic 430 w
jel netko zna di ga ima za kupit jer ga nemrem nac ni u jednom ducanu
jedino ga je bilo u linksu al sad ga ni tam vise nema
ernest1985 je offline   Reply With Quote
Staro 31.05.2007., 14:34   #2
Wolverine
Wolverine's Avatar
Postovi: 12,425
Samo u Linksu koliko ja znam. Uzmi onda nešto drugo
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 31.05.2007., 14:41   #3
ernest1985
Postovi: 35
morat cu samo kaj neznam kaj dajte neko dobro napajanje do 600 kn
Staro 31.05.2007., 15:04   #4
Wolverine
Wolverine's Avatar
Postovi: 12,425
CoolerMaster 430W
Silverstone Element 500W
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 31.05.2007., 15:06   #5
mehekek
mehekek's Avatar
Lokacija: At yo' mamaz!
Postovi: 194
seasonic u links dolazi za 15-20 dana pa si pricekaj
mehekek je offline   Reply With Quote
Staro 31.05.2007., 20:44   #6
zlikovski
Mutant Year Zero
zlikovski's Avatar
Postovi: 509
CoolerMaster 430W
CoolerMaster ima shitty svjetleći vent koji prozvrnda nakon pola godine i nema modularne kablove.
Bolje pričekaj Seasonic...
zlikovski je offline   Reply With Quote
Staro 31.05.2007., 22:34   #7
Wolverine
Wolverine's Avatar
Postovi: 12,425
nebi reko....imam 120mm blueLED vent od CM-a već dvije godine i radi ko prvog dana.
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 01.06.2007., 21:05   #8
zlikovski
Mutant Year Zero
zlikovski's Avatar
Postovi: 509
Eto baš takav zvrnda kod frenda i on baš nešto nije zadovoljan s tim napajanjem.
Fora je jedino kaj ima onaj pokazatelj potrošnje u vatima kaj plavo svijetli
Super ak ti radi dobro, ali ja ipak preferiram Tagan, Seasonic, Corsair...
Staro 01.06.2007., 21:10   #9
Wolverine
Wolverine's Avatar
Postovi: 12,425
sorry ali to nije Extreme power serija koju ja preporučujem nego RealPower serija
Ja govorim o Extreme power seriji koja nema taj wattmetar i snažnija je od RP serije iako je jeftinija također nema LED vent nego običan 120mm vent
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 01.06.2007., 21:19   #10
zlikovski
Mutant Year Zero
zlikovski's Avatar
Postovi: 509
Točno zboriš. Frend ima 450W CM real power..
Ak veliš da je extreme CM power serija ok, vjerujem ti jer vidim da pratiš napajanja. Nego kakva je količina buke i ima li cvrčanja kad se optereti?
Staro 01.06.2007., 21:22   #11
Wolverine
Wolverine's Avatar
Postovi: 12,425
čuj ono koje sam ja čuo nije cvrčalo, a buka je na razini Freezera na 7V
no nije bio baš jako opterećen
mislim da je imalo još par ljudi tu na forumu to napajanje
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 02.06.2007., 08:43   #12
JC Denton
dr. sc. tech. dipl. ing.
JC Denton's Avatar
Lokacija: Rijeka-Opatija
Postovi: 3,164
Wolw, kao sto smo nas dvojica pred malo racunali, moj Cheif 360W nije dovoljno jak za malo jacu grafu..pa sam sad u potrazi za novim napajanjem
Čini mi se da ću ići danas po tog CoolerMastera... vidim da nema 20-pin konektor, nego samo 24-pin... jel to kakav problem za spajanje na 20-pin konektor na ploči? Jel dolazi adapter s njim ili trebam kupiti posebno? Ili pak mogu samo upiknuti taj 24pin u ploču pa nek ona 4 pina vise?
Info please
Staro 02.06.2007., 10:29   #13
Wolverine
Wolverine's Avatar
Postovi: 12,425
u principu nemaš problema samo ti ostanu da zadnja četiri pina visit tj ostanu pored ATX utora
no problem ti može biti kasnije ako ćeš kupit matičnu sa 8pin eps konektorom kojeg ovaj CM nema već ima samo +12V 4pin konektor
pa ako ideš na novo napajanje koje ćeš kasnije koristiti uz novije ploče pogledaj npr Chieftec 550W koji je dosta povoljan a ima sve moguće konektore
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 02.06.2007., 10:50   #14
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,962
Je, ali zna biti problema na pločama koje imaju neke elemente blizu 20 pin štekera. Na par ploča nisam mogao uštekati tako 24 pin kabel na 20 pin utor. A i ovo za 8pin eps stoji, iako jedan dio ploča uredno radi kada se u njega ušteka 4pin priključak, a neke neće ni zasvjetliti ako nemaju priključen 8pin eps.
Staro 02.06.2007., 11:49   #15
Wolverine
Wolverine's Avatar
Postovi: 12,425
upravo sam zato napomenuo da ''u principu'' neće imat problema sa 24pin ATX konektorom
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 02.06.2007., 22:47   #16
tor
Administrator
tor's Avatar
Lokacija: Sesvete
Postovi: 15,962
Je, princip je princip
