Staro 24.05.2007., 02:29   #1
Solmyr
Postovi: 92
bogovi konfiguracija Čujte moj poziv....
Recite mi mišljenje o ovoj budućoj konfiguraciji...
PROCESOR: Intel Core 2 Duo E6600 BOX, 2×2.4GHz, 1066MHz, 775-pin, 4MB 1.691,02
MATICNA: Gigabyte N680SLI-DQ6, s775, nF 680i SLI, DDR II, SATA II, FW, GLAN 2.096,63
DDR2 2GB (2x1GB kit) PC8500 (1066MHz) OCZ, nVidia XTC, SLI ready 1.331,69
DDR2 1GB PC8500 (1066MHz) OCZ, nVidia XTC, SLI ready 671,06
*HDD Seagate ST3400633AS/ST3400620AS, 400 GB 16MB, S-ATA300, NCQII, 7200 817,47
DVD+RW/-RW/RAM LG GSA-H12L Dual Layer, LightScribe, 18x, bulk 243,39
Leadtek GF 8800GTS, 640MB, PCI-E, TV-out, 2 x DVI novo 2.780,44
Chieftec mediumtower LBX-02B-B-SL, bez PS, crno-srebrno, USB, Fire wire, audio
495,00
Thermaltake power supply Toughpower 600W, crno, EPS, ATX 2.2, 4×12V, PFC, AFC, 14cm fan,6×SATA
777,63
Monitor Samsung SM 225BW, 22" LCD, 5 ms, DVI, srebrno-crni
2.799,00
Logitech G5 Laser Mouse USB /931376-0914
519,00
Logitech G15 Gaming keyboard USB /967599-0100
559,00
I dali bi koje kuciste mogli preporucit?
Solmyr je offline   Reply With Quote
Staro 24.05.2007., 02:57   #2
BladeRunner
Type R
BladeRunner's Avatar
Postovi: 1,485
Preskupa matična i proc,wtf je ovo s ramom?i on je skup...
bolje neki 6320 i DS4 i Patriot 800mhz 4GB...
David linčujem Davida Finčera
BladeRunner je offline   Reply With Quote
Staro 24.05.2007., 03:11   #3
Razer
Razer's Avatar
Postovi: 11,642
Procesor: Intel Core 2 Duo E6600 - 1486kn, Diskont24
Matična: Intel Bad Axe 2 - 1499kn, Links
Memorija:
2x 1gb Crucial Ballistix 667 - 2*646kn - Links
Grafička: Gigabyte GF8800GTS 640MB DDR3 - 2564kn, Android
Hard: Samsung Spinpoint 320GB, SATA2, 16MB - 607kn, Links
Optika: LG GSA-H30N, SATA - 249kn, Ve-Mil
Kućište: Antec Solo - 662, ADM
Napajanje: Seasonic 430W - 646kn, Links
Monitor: Samsung SM225BW - 2383kn, Diskont24
Miš: Logitech G5 - 484kn, ADM
Tipkovnica: Logitech G15 - 559kn, Ve-Mil
UKUPNO: 11821kn, sve iz različitih dućana...
Staro 25.05.2007., 16:05   #4
eluminer
eluminer's Avatar
Lokacija: Zlatar, Zagorje
Postovi: 683
Ovo što si napisao ti je skoro 15k kuna......!!!!
Ak je to cifra s kojom raspolažeš, onda bih ja ovome Razer-ovome dodao još možda 2gb rama (jer ovi OCZ XTC su totalni promašaj, hello 2k kuna za rame, za 1k kn kusur kupiš 4gb kingmaxa), 226bw umjesto 225 (razlika 200kn), možeš staviti GTX-icu (upitna isplativost, ali..), možeš uzeti neko opakije kučište, tipa TT Kandalf ili sl...
Samo da napomenem, to ja govorim u odnosu na onu cijenu koja je za ovo šta si ti gore napisao, a da je 15k kuna (a nemaš niti kučište u tome) full previše za komp, to je istina....
Da ja imam 15k kuna za komp, 10 bi otišlo u periferiju...
Možeš uzeti neke opake zvučnike, dva monitora i slična ekstremna rješenja...
Ipak, sa Z-5500 i dva monitora si veći frajer nek s 8800GTX/GTS i E6600 koji će za kojih 6mj. pojeftinit bogu za plakati, a ti nećeš imati ništa....
eluminer je offline   Reply With Quote
Staro 27.05.2007., 15:54   #5
Solmyr
Postovi: 92
Imat cu tako cca 14000kn za novi komp.
Staro 29.05.2007., 09:50   #6
mat
Postovi: 2,105
derni si kandalfa i gtx-icu za te novce obavezno. pa bemu misa decko kupuje kantu za 12000kn, najbolje da ima neke 6x20 ili 4xxx modele proceva, za te novce uzmi komponente kak bog zapovjeda
mat je offline   Reply With Quote
