Staro 12.05.2007., 00:33   #1
X4K
X4K's Avatar
Lokacija: -------
Postovi: 22
Comp za cca 5000-5500
Trazim savijet oko slijedecih komponenti. Comp mi treba za CAD, photoshop, Corel, obradu videa (nista profi) i tak... Uglavnom, NE za igranje. Dakle, moja ideja je (HGSPOT):
MBO GIGABYTE, s. 775, 8I945P-S3, i945P, BUS 1066 MHz, serial ATA II, 7.1 zvuk, DDR 2, 1Gbps, ATX 2 566,00
Intel® Core(TM) 2 Duo E6320 1.86 GHz, 4MB LGA775, BUS 1066MHz, Allendale, BOX 1.328,0
RAM, 1 Gb, DDR 2, PC-6400, 800 MHz, KINGMAX 403,00
Midi Tower, NEON CX-5059, 400 W, ATX 2, crno 254,00
VGA PCI-E CLUB 3D ATI Radeon X1550, 256 MB, tv-out, DVI 450,00
HDD SEAGATE Barracuda 320 GB, serial ATA II 7200.10, 7.200 o/min., 16 MB cache 624,00
DVD pisač, DVD±RW & DVD±R & DVD-Ram SAMSUNG SH-S182D, 18x, 8x dual layer 8.5 GB, bulk, crni 242,00
Mon. LCD 19" LG FLATRON L194WT 1.699,00
5556kn
Oko maticne nisam na cisto jel to ok. Ne mislim ja nista clockati i sl. Bitno da sve radi i da proc dise punim plucima na njoj. Monitor ok ili bolje philips Mon. LCD 19.1" PHILIPS 190CW7CS, 5 ms, wide, silver 1.749,00.
Tnx
POZDRAV!!!
X4K je offline   Reply With Quote
Staro 12.05.2007., 10:59   #2
Postovi: 34,005
Malo jača grafa ne bi bila na odmet. Npr. neka X1600.
Staro 12.05.2007., 12:06   #3
Matesonik
prcknedl
Matesonik's Avatar
Postovi: 3,131
Sve iz vemila:
Intel Core 2 Duo E4300 BOX, 2×1.80GHz, 800MHz, 775-pin, 2MB 894,73
MB Gigabyte 965G-DS3, s775, iG965, VGA, DDR II, SATA II, GLAN 868,09
HDD Seagate ST3320620AS, 320 GB 16MB, S-ATA300, NCQ3, 7200 609,74
DVD+RW/-RW/RAM LG GSA-H30N Dual Layer, SATA, 18x, black 249,19
Power Supply FORTRON 350W, ATX 2.0, HQ, PFC, 12cm fan 212,00
Chieftec midi tower SG-01B, bez PS, crno, USB, audio 310,00
Monitor Philips 190C7FS Silver, 800:1, 300 cd/m2, 1280 x 1024, DVI-D 1.499,00
2x DDR2 1GB PC5300 (667MHz) Kingmax 614,28
---5207.03kn
Komp se nece koristiti za igre pa sam stavio integriranu grafu. Ako bas hoces, mozes pristedjeti na kucistu (Mode com step 207 bez PSU umjesto ovog) i uzeti neki jeftinu ATI-cu i neku drugu plocu bez integ. grafike (mislio sam gigabyte 965P, no to ce intelovci bolje znati od mene). Ako hoces wide ekran-uzmi si onda tog Philipsa. Ja imam nekako vise povjerenja u Philips nego u LG.
Staro 12.05.2007., 12:53   #4
X4K
X4K's Avatar
Lokacija: -------
Postovi: 22
Tnx on oba replaya. Na zalost moram uzeti u jednoj firmi u vz koja nije vemil, jer imaju najbolje uvijete kreditiranja, no drzat cu se ovih komponenti. Imam ustvari 5600kn za potrositi, pa budem uzel neku solo grafu. Cak mi je podsvjeno doslo da sklepan i neku game (to kaj sam familiy man ne znaci da sam se zaboravio igrati opciju sa 4000+ i 8600GTS i 1GB rama, 17inch mon i tak to..., no kaj se moze ispada na NE game. Tnx jos jednom!
Staro 12.05.2007., 14:13   #5
Postovi: 34,005
19" lcd će ti bolje doći od 17", a za igranje ti je dosta i X1900pro koja je duplo jeftinija od 8600GTS. Razliku radije uloži u veći monitor i eventualno još 1Gb rama.
Staro 17.05.2007., 12:04   #6
X4K
X4K's Avatar
Lokacija: -------
Postovi: 22
Na kraju ispalo:
E4300 @ 3Ghz
Gigabyte 965P-DS3P
2x1GB PC 6400 Patriot
ATI X1550
Seagate 320GB 16MB
HIPER Power 430W
DVDRW LG 18x
Codegen 604AL-CA
Acer 1916Wsd 19inch
Logitech EX110
Pozdrav i hvala jos jednom na pomoci.
