Staro 17.04.2007., 20:40   #1
toni101
Postovi: 153
QuickTime alternative, ima zvuka nema slike
Skinuo sam QuickTime alternative kojeg koristim sa mpc-om ali QuickTime filmovi nemaju sliku, samo zvuk. Ima li tko ideju zašto.
Hvala
toni101 je offline   Reply With Quote
Staro 17.04.2007., 20:49   #2
bego2
bego2's Avatar
Postovi: 2,724
Codeci? Koje imas instalirane? Makni sve ostale i stavi klite mega pack...
bego2 je offline   Reply With Quote
Staro 17.04.2007., 20:49   #3
TomRi
Can You Hear Me? 142.8 dB
TomRi's Avatar
Lokacija: Zagreb, Kvatrić
Postovi: 2,073
probaj skinuti ovo: k lite
pa vidi jel ti radi,
meni i drugima koji to koriste radi bez greske(i za quick time i 3gp)
EDIT: lol, same time
Danas je teško biti budala, prevelika je konkurencija...
Water cooled PC
Moj najveci MOD
Novi hobby: RC model + HD kamera
TomRi je offline   Reply With Quote
Staro 17.04.2007., 21:20   #4
toni101
Postovi: 153
Evo što piše za QuickTime alternative:
QuickTime Alternative will allow you to play QuickTime files (.mov, .qt, .3gp and other extensions) without having to install the official QuickTime Player. It also supports QuickTime content that is embedded in webpages.
Features of QuickTime Alternative 1.80:
- Media Player Classic [version 6.4.9.0 rev 611]: this is a full-featured player which has internal decoding support for DVD, MPEG-2, MP3, MP2, AAC, AC3 and DTS. It also has internal support for opening Matroska and Ogg containers. Media Player Classic is also capable of playing QuickTime and RealMedia content if those codecs are installed.
- QuickTime Codecs [version 7.1.5.120]: required for playing QuickTime content.
- QuickTime DirectShow filter: allows you to play QuickTime content in all DirectShow enabled players.
Without this filter QuickTime content can only be played in Media Player Classic.
- QuickTime plugin for Internet Explorer: allows you to view QuickTime content that is embedded in a webpage. It is installed together with the QuickTime codecs.
- QuickTime plugin for Opera/Firefox/Mozilla/Netscape: allows you to view QuickTime content that is embedded in a webpage.
- Extra plugins for QuickTime: plugins for viewing some special formats that are sometimes used on webpages.
- CoreAVC: is an external filter for Media Player classic
- CoreAAC: is an AAC DirectShow filter decoder based on FAAD2.
Iz toga slijedi da nikakav dodatan softver ili codec nije potreban za gledanje QuickTime filmova.
Staro 18.04.2007., 13:58   #5
TomRi
TomRi's Avatar
Postovi: 2,073
pa sad kad si ovako fino stavio text tu.... ajmo na razmatranje...
Autor toni101 Pregled postova
ja ne vidim di si ti vidio da dolazi sa codec-ima...
piše samo da MOŽE prikazati,
bez instalacije pravog QuickTimea
i to SAMO AKO su instalirani codeci...
samo napravi ono sto smo ti savjetovali pa vidi, radit ce .
Water cooled PC
Moj najveci MOD
Zadnje izmijenjeno od: TomRi. 18.04.2007. u 14:09.
Staro 18.04.2007., 20:41   #6
toni101
Postovi: 153
Hvala Tom, vjerovatno si u pravu. Ali instalirao sam quicktime a quicktime filmove pokrećem sa mpc-om. Znaš li možda za neki nedostatak te kombinacije.
Većina toga u k-liteu mi ne treba a i ne radi se o sasvim legalnom softveru.
Staro 18.04.2007., 20:55   #7
Ivan_1
Lokacija: Duga Resa
Postovi: 823
Autor TomRi Pregled postova
piše samo da MOŽE prikazati, bez instalacije pravog QuickTimea i to SAMO AKO su instalirani codeci...
ti ne kuzis, tu pise da Media player classic, dakle taj program, moze reproducirati quicktime datoteke ako je instaliran potreban codec. npr. FFDSHOW. za reprodukciju QT video formata Quicktime alternative nije uopce potreban, dovoljan je ffdshow.
Ivan_1 je offline   Reply With Quote
Staro 18.04.2007., 22:45   #8
TomRi
TomRi's Avatar
Postovi: 2,073
Autor Ivan_1 Pregled postova
2 Ivan: Pa Media Player Classic je QT Alternative kuzis?
a bez codeca se moze slikati, htio on to pokretati sa Mediaplayerom Classic, ili drugim nekim playerom...
to je rečeno u mom postu, da mu fale codeci, i dao sam mu link di da ih skine, i gleda filmove u miru, 9 minuta nakon njegovog posta...
a ti se javljaš nakon preko 24 sata i ne vidim na koji način mu ti pokušavaš pomoći... a ako si samo htio flame-at, to je druga priča.
Water cooled PC
Moj najveci MOD
Staro 19.04.2007., 19:31   #9
Ivan_1
Lokacija: Duga Resa
Postovi: 823
MPC je MPC, program kojeg mozes skinuti sa neta kao samostalna aplikacija.
Quick Time alternative je skup filtera i pluginova za reprodukciju QT videa. medu njima je i MPC kao player, on se tu nasao iz razloga suradnje razvojnog tima tih programa, dakle svojevrstan bonus. primjerice lite verzija ga nema.
MPC sam po sebi ne moze reproducirati QT video, moze neke stare verzije, (jer postoji opcija u njemu "MP4/MOV") ipak MPC je vec malo outdated. imam priliku isprobati sto radi a sto ne jer imam puno raznih QT videa na kompu.
no, najgore od svega je to sto si mu savjetovao da skine K-Lite codec pack.
ffdshow je mnogo bolji izbor a i legalan je
