Staro 28.03.2007., 13:45   #1
Wolverine
Wolverine's Avatar
Postovi: 12,429
Seasonic X900
Za gladuše za strujom Seasonic nudi novu seriju napajanja
evo malo podataka o novom Seasonic X900
http://www.seasonic.com/pdf/datasheet/01PC/X900.pdf
U kratko 4 +12V raila čija zajednička suradnja nudi 72A dakle 864W na +12V kombinirano
od konektora tu se nalazi
1x 20/24pin ATX
1x 4pin ATX 12V
1x 8pin EPS 12V
9x molex
6x SATA
4x PCI-E 6pin
2x PCI-E 8pin adapter
2x floppy splitter (1molex->2floppy)
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
256GB LiteOn LMH-256V2M mSATA
NEC USB 3.0 ExpressCard
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
CoolerMaster Cavalier
ViewSonic VX922
Win7 x64 SP1
Staro 28.03.2007., 13:58   #2
Bartuc
The All Seeing Eye
Bartuc's Avatar
Postovi: 1,103
Ajme meni kako zakon! Napajanje je zvjer i pol
Ali to ti je ona fora... "Tata tata, kad čemo kupiti Golf 5? Kad izađe Golf 10 sine! "! Tak bum i ja kupio ovo napajanje kad izađe model od soma i pol wata
Bartuc je offline   Reply With Quote
Staro 28.03.2007., 14:03   #3
SilentException
SilentException's Avatar
Lokacija: RI-KR
Postovi: 789
vidio sam ga na cebitu, napajanje je mrak iako neznam zasto bi pobogu netko trebao tolko snage kad je i moj corsairs hx620 sasvim dovoljan i za najmocniju konfu
bit ce paprena cijena!
SilentException je online   Reply With Quote
Staro 28.03.2007., 14:10   #4
Wolverine
Wolverine's Avatar
Postovi: 12,429
Prestiž!
Mark Twain
Intel Core i5 2520
8GB DDR3 Patriot
Intel HD3000
14" 1366x768
Windows 10 Pro x64
Gigabyte GTX 560Ti
DVD-RW LiteOn SATA
Corsair HX520
TT Chaser MK-1
Logitech MX3200
Windows 10 Pro x64
Intel DP67BG
Intel G1610
Hitachi 250GB
VTX3D HD6670
DVD-RW Asus SATA
FSP 350 PNF
ViewSonic VX922
Win7 x64 SP1
Staro 28.03.2007., 14:16   #5
SilentException
Lokacija: RI-KR
Postovi: 789
ja imam vise watti od tebe i te spike?
ma nekako mislim da ce sve skupa stat kod jedno 1500w, onda ce komponente sve manje i manje struje trosit.. tehnologija ide naprijed
Staro 28.03.2007., 14:24   #6
Bartuc
The All Seeing Eye
Bartuc's Avatar
Postovi: 1,103
O, ja mislim da nebu to samo tako stalo! Pogotovo kad se neki lik sjeti napraviti multi CPU (>>> 4 jezgre) i multi SLI/CrossFire (>>> 2 VGA)!
Pa ovdje na forumu je bila jedna tema o kompu sa 60Gb memorije i valjda 50 jezgri CPU (ne znam dali sam dobre brojke rekao jer idem po nekom sjećanju)! Takav komp treba malo više od 1500W da bi radio
Staro 28.03.2007., 14:41   #7
Matesonik
prcknedl
Matesonik's Avatar
Postovi: 3,131
Pa, vec postoje takve ploce...
http://www.pcekspert.com/articles/477.html
Sa 7900gtx sistem u punom pogonu trosi 500w.
Jooj, kad to vidi ekipa koja misli da im za c2d i 7900 treba milion wati...
Staro 28.03.2007., 14:45   #8
Bartuc
The All Seeing Eye
Bartuc's Avatar
Postovi: 1,103
Autor Matesonik Pregled postova
Mislio sam na "puno više" (>>>) od 4 jezgre CPU i "puno više" (>>>) od 2 VGA u SLI modu
Znak >>> je znak za "puno više"
Staro 28.03.2007., 15:27   #9
Matesonik
prcknedl
Matesonik's Avatar
Postovi: 3,131
Da, no to izlazi iz domene obicnih PC-ja i za to se konstruiraju specijalna napajanja...
Staro 28.03.2007., 22:09   #10
SilentException
Lokacija: RI-KR
Postovi: 789
Autor Bartuc Pregled postova
ovo trazis?
http://www.xbitlabs.com/misc/picture...2kw_bg.jpg&1=1
imam i ja svoju sliku ali ova je bolja )
