Staro 01.03.2007., 23:41   #451
LAcy
Pink Floyd fan
LAcy's Avatar
Lokacija: Santa Clara, CA
Postovi: 5,538
Autor kuzma_killa Pregled postova
. mislio sam mozda je firewall ..... ali .....
Core i7-6700K LGA1151 Skylake
RTX 2080 TI 11GB GDDR6
Samsung 850 EVO M.2 1TB SSD
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 02.03.2007., 19:54   #452
Nebelwerfer
Nebelwerfer
Nebelwerfer's Avatar
Datum registracije: Apr 2004
Postovi: 270
Evo, isti problem i kod mene. Otvara recimo Index ali ne zeli otvoriti jutarnji.hr, a problem se javlja i u FF i u IE....čudno skroz...
A modem je ono Elconovo đubre....
Tiruliru!!
Nebelwerfer je offline   Reply With Quote
Staro 02.03.2007., 20:55   #453
Nebelwerfer
Nebelwerfer
Postovi: 270
Kako je ovaj problem iritantan, prestrašno....ne otvara 90% sajtova, i taman nađem neki sajt di se raspravlja o tom problemu a ne mogu ga otvorit. Za poludit...
Jel može neko pršvrljat kroz temu na sljedećem linku i vidit dal je netko ponudio rješenje pošto ja taj sajt ne mogu otvorit:
http://tinyurl.com/2b7cmz
Tiruliru!!
Staro 02.03.2007., 21:08   #454
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,538
Kako ideš na net? Pod WinXP sve ide OK? Ako koristiš router da li je spojeni preko Marwell ili nVidia mrežne? Probajte preko Marwell (to je za Animal Mother, a kuzma_killa vjerojatno pretpostavlja da smo vidoviti i znamo kakav komp posjeduje). nVidia mrežna ima onaj shield pa možda on blokira promet.
P.S.
Zadnji post od tri na onoj stranici, prva dva kukaju:
Strangely enough, I am seeing the exact same thing, running Firefox 2.0.0.1, IE 6.0.2800.1106 on Win2k. I'm using Avast Home edition 4.7. What I have found is that Avast's Web Shield plays a roll in this anomaly as disabling it resolves the issue. I found it very worrisome at first as primarily only financial web sites were able to render. This just recently started as I have been using these products for some time. Have another system with the same that shows none of these presentations. Still researching.
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 02.03.2007., 21:29   #455
Nebelwerfer
Nebelwerfer
Postovi: 270
Autor LAcy Pregled postova
Elcon je spojen na mrežnu. A u XP-ima sve ko podmazano. Ide preko nVidia mrežne, probat ću vidjet sa driverima... Marwell?
Tiruliru!!
Staro 02.03.2007., 21:40   #456
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,538
Autor Animal Mother Pregled postova
Zar nemaš drugu mrežnu? Marwell Yukon? Jesi li instalirao nForce za Vistu (ako nisi ni nemoj jer će ti hardovi početi škljocati ko ludi).
NEMOJTE instalirati nForce drivere 15.00 za Vistu! Jer postoji bug koji prilikom restarta ili gašenja računala isključi hardove (valjda ih želi odspojiti jer je SATA hot swappable) i onda pričeka malo pa ih opet uključi i tek onda ode u restart ili gašenje. Osim što produljuje vrijeme restarta/gašenja ne zvuči baš zdravo. Performanse su lošije nego sa generičkim, a koliko sam vidio na nvidia forumu ljudi se žale i na korupciju podataka.
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 02.03.2007., 21:47   #457
Nebelwerfer
Nebelwerfer
Postovi: 270
Nemam, samo jednu, integriranu nVidijinu mrežnu....
A nForce sam odmah nakon instalacije Viste instalirao...baš ću probat sa generičkim driverima...
Tiruliru!!
Staro 02.03.2007., 21:54   #458
Nebelwerfer
Nebelwerfer
Postovi: 270
Problem riješen, a problem su nVidijini nForce driveri... Strašno, izbace drivere koji koji su totalno zaqrac. Napravio potpuni uninstall drivera i sad se mogu spojit na Jutarnji i ostale stranice...
Takva firma sa milijunskim prihodima a ne mogu drivere kako spada složit. Letile bi meni glave da sam direktor tamo...
Tiruliru!!
Staro 02.03.2007., 21:57   #459
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,538
A zašto? Zar nisi pročitao moj post malo iznad? Ti driveri ne valjaju, istina i ja sam ih bio instalirao ali uči na tuđim greškama. Pokušaj napraviti system restore, ako ne ide onda moraš ručno u device manageru izabrati generičke.
Edit: Eto riješili smo problem I znamo za još jedan bug u nForce driverima.
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 02.03.2007., 22:04   #460
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,691
Ja sam zakljucio nakon mukotrpnog tjeda na visti, da se još ne isplati ici na nju i od sljedeceg tjedna sam na blaženom XP-u. Isprva mi je bila ok, no sad vidim da ima jos puno nedostataka tak da na nju idem tek nakon nekog ozbiljnijeg SP-a...
Staro 02.03.2007., 22:15   #461
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,538
Autor Problem Pregled postova
Ja nisam baš bio zadovoljan sa x86 verzijom ali x64 sam već pisao da lete. Takvu brzinu sučelja, podizanja i gašenja programa, multitaskinga... još nisam vidio.
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 02.03.2007., 22:18   #462
Buger
Postovi: 4,391
koliko vam traje boot u Visti?
Buger je online   Reply With Quote
Staro 02.03.2007., 22:30   #463
goc_mails
low_rider
goc_mails's Avatar
Postovi: 486
Vista hebeno izgleda no imam dosta problema s driverima. Leadtek tv kartica radi ko pokvareni semafor (znaš ono radi-ne radi, radi-ne radi). Kopiranje fajlova kao da je usporilo a koje su to fore kad nesto skines s neta vista nekaj grunta 30sek (preparing to open, copying i sl.). Usb mp3 playeri- koma treba ga svaki put nanovo instalirat. Na xp-u ga jednostavno prepozna kao removable drive i udri.
goc_mails je offline   Reply With Quote
Staro 02.03.2007., 22:37   #464
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,538
Za TV karticu pročitaj moj DVB Tutorijal, i dajte ljudi napišite taj sig, koju Vistu koristite...
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 02.03.2007., 22:51   #465
Problem
Pijem samo KAJ
Problem's Avatar
Lokacija: Vž
Postovi: 2,691
da, ali di cu ja sad nabaviti x64???? A ima kakve razlike u kompatibilnosti šta se tice programa -gore/bolje/isto??? Ma ionako za sad mi je i XP prek preveč. Imao sam Vistu, pohvalio sam se u školi, a sad mogu opet lagano na XP. Ako Bog da da sad na ljeto kupim novi komp ili ako neda ovo ljeto nego sljedece kad budem imal 4gb rama i quad core onda bum ju stavil-pa nek onda i ždere gigu rama ako oce
Staro 03.03.2007., 14:11   #466
Mr.Ex.President
Torrent freek
Mr.Ex.President's Avatar
Postovi: 3,947
Autor blablu Pregled postova
Malo....jako malo
15-ak sek
Doduše friška je instalacija i sve to, al ipak je prebrzo
MBO: MSI B450 Gaming Plus
PSU: Corsair RM550X 550W
Periferija
LCD: HP ZR24w
Mouse: Logitech G400
Sound: Genius SP-HF1201A
Printer: HP LaserJet 1020
Scanner: HP ScanJet 4300
Headphones: Philips SHC 2000
MBO: Gigabyte GA-F2A85XM-HD3
HDD: WD Green 2TB [WD20EZRX]
PSU: Antec SU380
TV: Samsung 43E450 @HDMI
LINK
Staro 03.03.2007., 14:41   #467
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,538
Ako nekog zanima: Vista codecs package
Ima i x64 extenzija: x64 components
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 03.03.2007., 16:17   #468
snermin
snermin's Avatar
Postovi: 273
sve radi u 64 bitnoj visti...
meni
ladatek dvb kartica
sky star2 kartica2 sa prog dvb bez beda
naravno sav operativni sustav sa svim softwerima kao i card reader koji čita 51 karticu.
U biti 64 ili 32 bit sve radi malo truda i loghitec kamera ,kuglica bez beda radi .
postoji dosta drivera npr za kameru je nema na ofic stranici ali postoji kompatibilna i radi ko ura.
snermin je offline   Reply With Quote
Staro 03.03.2007., 18:53   #469
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,538
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 03.03.2007., 19:38   #470
Don
je gladan!
Don's Avatar
Postovi: 1,698
Molim pomoć.
Formatirao sam xp i sad nemam više izbor da li izabrat xp ili vistu, kako vratiti boot menu kao prije?
fala
Don je offline   Reply With Quote
Staro 03.03.2007., 20:13   #471
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,538
Digni Vistu sa DVD-a, mislim da ima opcija repair boot sector ili tako nešto.
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 03.03.2007., 20:40   #472
Buger
Postovi: 4,391
Malo....jako malo
15-ak sek
opla već se vidim na VISTI za mjesec dana, meni boot na XPu traje 55s otkad imam SP2
ej aj mi reci jel tv kartica radi normalno
Staro 03.03.2007., 21:26   #473
domy_os
domy_os's Avatar
Postovi: 18,866
Evo i ja instalirao 64-bitnu Vistu, zasad sve fino radi, ali još uvijek nema drivera za AIW, grrr...
RAM: 2 x 16 GB DDR4-3200
WLAN: Intel Wi-Fi 6 AX201
LCD monitor: AOC AG493UCX
SB: Mackie Onyx Producer 2x2
Speakers: 2 x JBL LSR305
MFP: Canon Pixma MP240
Staro 03.03.2007., 21:34   #474
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,538
Radi bolje/lošije od 32bitne?
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 03.03.2007., 21:59   #475
domy_os
domy_os's Avatar
Postovi: 18,866
Zasad malu prednost ima 64-bitna, ali ipak imam 1 GB RAM-a pa ne radi baš punim plućima.
Staro 03.03.2007., 22:55   #476
Mr.Ex.President
Torrent freek
Postovi: 3,947
Davno san gleda i nije radila. E sad jer se šta u međuvremenu promjenilo - neznan
Periferija
LCD: HP ZR24w
PSU: Antec SU380
LINK
Staro 03.03.2007., 23:52   #477
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,538
Evo još malo spama, ono lijevo crno gore je zbog niže rezolucije TV-a
Novi grafički engine nisu samo aero efekti.
MacBook M1 Pro
MacBook Air M2
Moto Edge
Staro 04.03.2007., 21:23   #478
Tichma
Tichma's Avatar
Postovi: 164
evo instalira vistu sve radi super nisam imao nikakvih problema sa driverima jedino sam morao instalirati drivere od zvucne, prezadovoljan sam vistom sto se tice brzine i svega neznam zasto ali vista mi radi duplo brze od xp-a
Tichma je offline   Reply With Quote
Staro 04.03.2007., 21:31   #479
val
Postovi: 66
vista radi bez greške i brzo. svi uređaji su prepoznati i driveri su sami postavljeni.
3dviz
val je offline   Reply With Quote
Staro 04.03.2007., 21:35   #480
LAcy
Pink Floyd fan
LAcy's Avatar
Postovi: 5,538
Autor Tichma Pregled postova
Dobro sad ne radi baš duplo brže, možda su ti winxp bili stari i natrpani svačime, ali da radi dobro radi još da nvidia napravi upotrebljive drivere za chipset i grafičku...
MacBook M1 Pro
MacBook Air M2
Moto Edge
