#91 |
Lokacija: Zagreb, Trešnjevka
Postovi: 5,777
imaš upute za to na http://www.hydrogenaudio.org/forums/...howtopic=49783 , odmah drugi post |
#92 | |
...carpe diem...
Lokacija: Zagreb - okolica
Postovi: 1,363
da,vidio sam,ali problem je taj kaj sam napravio sve kak piše(valjda) pa mi se pojavilo nekaj sasvim drugo. nisam baš ekspert još ko ti pa sam možda nekam krivo stavio.ah ne znam.čitam već cijelu noć i dan te stranice i nekaj kemijam. ![]() |
#93 | |
Postovi: 5,777
help anybody ![]() |
#94 | |
Postovi: 1,530
![]() A jde ako ti nije problem nabaci screenshot svog foobara, pa da probamo utvrditi gdje zapinje |
#95 |
Postovi: 1,530
Ajde nabaci tu kod, koji stavljas u trackinfo da ja isprobam kod sebe. I ako slucajno imas sliku tog setupa isto stavi. |
#96 |
...carpe diem...
Postovi: 1,363
mene najviše ovo zehabava(iako je to većina): ne znam kam da to sve stavim tak da radi ko urica.to je sa onog site-a kojeg mi je rendula stavio.(napomena:ak je prevelik post budem ga lako zbrisao) REQUIRED FREE TO USE FONTS: Arial LCD Fonts Family Rsegment Webdings Deja Vu Sans Condensed Note: Instructions on how to install a font can be found here. REQUIRED COPYRIGHTED FONTS: Segoe UI, Dungeon (included in the download of this Windowblinds skin), Century Gothic, Franklyn Gothic, Wingdings and Windings 3. These fonts may likely already be on your system, but they cannot be re-distributed. Note: These fonts, other than Dungeon, are included in Microsoft Office full and trial versions. REQUIRED LIBRARY (to be copied to the foobar root directory): libpng Library REQUIRED MICROSOFT COMPONENT: Net 2.0 must be installed, but it may already be on your system. The best way to install it is to use Windows Update. However, here are the download links for x86 Machines (most computers) and for x64 Machines. REQUIRED THIRD PARTY COMPONENTS (.dll files to be copied to the components folder in the foobar root directory): Note: All of the below were authored by others who can be contacted on the component's corresponding thread on this forum. You must also use the most recent versions of these components so as to avoid certain settings not transfering. Columns UI Utilities Package Album Art Panel UIE_Tabs Foo_Browser Foo_Playlist_Tree Foo_UIE_Lyrics Foo_UIE_Trackinfo Foo_UIE_Quicksearch Foo_Trackinfo_Mod Foo_CWB_Hooks Foo_Continuator Foo_DSP_Delta Foo_Title Foo_Menu_Addons Foo_Playcount (Unofficial) Foo_Prettypop Foo_Run Mini Lyrics BLACK SKIN: This configuration is designed to be used with a black explorer skin. The download contains a file called My Black.3dc which can applied with the shareware program 3 D Color Changer. You can also, obviously, use any black explorer skin you like or other visual style. |
#97 | |
Postovi: 5,777
kod trackinfa http://www.box.net/public/agc7c0r7c9 |
#98 | ||||||
Postovi: 1,530
@rendula tek sam sad vidio ovaj tvoj gornji post sa slikom, neki postovi su se izgubili od jucer, pa ne pratim bas kako bih trebao (a database errori isto bas ne pomazu) To je setup od rusella777, koliko sam skuzio iz ovog topica osjetljiv je na verziju trackinfomoda koju imas. Probaj za pocetak na vrh trackinfomod koda staviti ovo Citiraj:
Gledam taj configuration distribution thread - zadnji put je post sa tim setupom bio modificiran prije mjesec dana (6.12.). Nisam bas u toku, ali moguce da se ne slaze bas tekuca verzija trackinfomoda sa tim kodom. @kalixus Citiraj:
Trebaju ti gorenavedeni fontovi za taj setup koji te zanima. Na tebi je da ih nabavis i instaliras. Ili da upotri***is druge fontove. Citiraj:
neki detalji visual stylea (koliko ja znam). Nisam bas radio sa njim tako da ne znam kako i sta treba raditi. Nije neophodan za foobar. |
#99 |
Postovi: 5,777
morph ljudim te u čelo, ovo persecond je sredilo stvar rep up! |
#100 | |
...carpe diem...
Postovi: 1,363
najviše si želim popraviti dizaj.a sviđa mi se i opcija da onak iznad u sredini slovima piše koja pjesma svira,odbrojavanje sa onim % koliko je pjesme prošlo i tak. @rendula,morph - imate MSN ili ICQ? ![]() |
#101 | |
Postovi: 1,530
ako radis po crnovom vodicu i mojoj dopuni vodica (samo prvo sve procitaj pa onda tek kreni raditi jer sam ja neke bitne stvari nadodao) ne bi smio imati problema. sve ti se na kraju svede na copy/paste sa jednog mjesta na drugo (osim ako zelis uciti kodiranje) ako zapnes gdje pitaj (samo sto preciznije i ako ti nije problem screenshot staviti) ne koristim vise niti jedan instant messenger |
#102 |
Postovi: 380
#103 |
Postovi: 7,568
.... Zadnje izmijenjeno od: McG. 13.01.2012. u 02:07. |
#104 |
Postovi: 4,069
#105 |
Postovi: 1,530
#106 |
daysleeper
Datum registracije: Apr 2004
Lokacija: zaprešić
Postovi: 405
#107 |
Postovi: 1,530
http://fofr.trivialbeing.net/2007/02...version-02.php Evo linka, vec si ga dobila (ili trebala dobiti) kad sam ti odgovorio na pm... |
#108 | |
daysleeper
Lokacija: zaprešić
Postovi: 405
kud stavit onaj folder 'images'? : stoopid |
#109 |
Postovi: 1,530
#110 |
daysleeper
Lokacija: zaprešić
Postovi: 405
#111 | |
Postovi: 1,530
nadjes dio koda sa C:\Documents and Settings\FofR\Application Data\foobar2000 i Fofr promijenis sa svojim usernameom, i tako svugdje gdje naidjes na taj path |
#112 | |
daysleeper
Lokacija: zaprešić
Postovi: 405
![]() sad je sve ok puno ti hvala : cheers2 |
#113 |
Postovi: 86
evo napravio sam i ja ovaj setup, ali trosi mi previse memorije (oko 25Mb), jeli to normalno ili...jer prije mi je trosio 3-6Mb ??? |
#114 | |
Postovi: 1,530
Meni osobno to ne smeta, jer je setup fenomenalan. A i tako kada pokrecem neku memorijski zahtjevniju aplikaciju, nema potrebe da foobar bude na desku, moze svirati i iz traya. |
#115 |
Postovi: 86
a je**ga kad imam 128Mb ram ![]() |
#116 |
Postovi: 1,530
Dobro to onda moze bit poprilican problem, ja imam 1 gb pa u radu niti ne primijetim. Ne znam kako se ponasaju inace ove nove panels UI konfiguracije, pa ne mogu preporuciti bas neku konkretnu. Mozda da se vratis na neki stari columns UI setup - meni su ostali u sjecanju kao poprilicno mali potrosaci memorije, a opet sa druge strane jako funkcionalni. Jedino sto vecinom nisu bas eyecandy. Inace izgleda da je ovaj novi Panels UI sustav smjer u kojem ce se foobar razvijati. Moram priznati da mi se sviđa poprilicno laka "instalacija" setupa koji je fenomenalan. Potrebne su samo minimalne prilagodbe u kodu i to je to. |
#117 |
Postovi: 86
#118 | ||
Postovi: 1,530
Meni se nije dalo zahebavat sa tim stvarima na prvom linku. Koliko sam skuzio to funkcionira tako da ti automatski skida slike artista i prikazuje kao malu slicicu ispred ove velike (te slike di je zenska - to inace treba biti album cover). Nije mi bas to interesantno tako da ces ti morati sam malo pogledati po hydrogenaudio forumu ako ti je to bitno. E sad, ja sam shvatio da tebi ne prikazuje niti covere albuma - tj. umjesto njih ti pokazuje nocover image (zenu). To ovisi gdje su ti smjesteni coveri i na koji nacin su prikazani, te da li imas tagove na albumima. Ovako je to kod mene. Coveri su smjesteni u folderu (naravno username ovisi od korisnika do korisnika) C:\Documents and Settings\Username\Application Data\foobar2000\Covers i to u formatu artist - album.jpg (znaci ime izvođača/razmak/povlaka/razmak/ime albuma.jpg) Inace samurize je podesen (crnov plugin) da automatski skida albume sa interneta u taj folder u tom formatu (one koje ne nađe ručno ubacujem ako mi se da). Prepostavka je da su albumi uredno istagirani (znaci selektiras sve pjesme nekog albuma>>desni klik>>properties Artist name i Album Title moraju odgovarati nazivu covera tj. obratno). Ne znam sad koliko si upoznat sa tim tagiranjem, postoji automatski nacin, da selektiras sve pjesme sa jednog albuma>>desni klik>>tagging>>get tags from freedb (treba imati odgovarajuci plugin, duzina trajanja pjesama mora biti tocna i pjesme obavezno moraju biti poredane po redu tj. track numberu da bi uspjelo) I kad je to sve obavljeno moras reci foobaru gdje ti se nalaze coveri i u kojem formatu. Desni klik na crnu traku dolje pored now playing/playlist/browse pa kliknes na settings. Pokazat ce ti se kod. Dio koji moras promijeniti je ovaj: Citiraj:
Naravno tu umjesto tog patha koji sam napisao mozes staviti i neki drugi, ovisi gdje su ti smjesteni coveri i u kojem formatu. Sacuvaj originalni dio koda tako da znas vratiti kasnije ako podje po zlu ili napravi backup foobar.cfg i panels ui filea (smjesten u C:\Documents and Settings\Username\Application Data\foobar2000\PanelsUI) Eto to je to, nadam seda si uspio pohvatat, jer malo je komplicirano, a ja nisam najbolji u objasnjavanju. Koliko je lakse kad netko da sliku i link onoga sto ga muci ![]() |
#119 |
Postovi: 86
a pohvata sam nesto... hehe hvala puno na objasnjenju, ni meni se ne da zaj**avat sa FofR-ovim nacinom skidanja album arta, pa sam napravio kako si reka i sad sve radi hvala jos jednom |
#120 |
Postovi: 1,530
Evo za one koje zanima, 2 setupa Brumal (5. post) ![]() I FofR je izbacio 0.5 verziju svojeg setupa, radi sa 0.7 verzijom panels ui Nisam jos probao niti jedan niti drugi, vjerojatno hocu ovaj FofRov, ali tek kad vidim reakcije sto se tice stabilnosti, potrosnje itd. - ovaj 0.3 mi radi odlicno |
