Staro 14.02.2007., 22:45   #1
acca2211
acca2211's Avatar
Postovi: 10
Question Graficka, molim pomoc.
Dakle imam laptop sa grafikom x1100 i ima 128 MB memorije
medjutim u windowsu mi pise 64, kad promijenim to u Biosu
na 128, cim pokrenem win vrati se na 64, u cemu se radi?
acca2211 je offline   Reply With Quote
Staro 15.02.2007., 00:29   #2
Milentije
Adrenaline junkie
Milentije's Avatar
Lokacija: Doboj - Banja Luka
Postovi: 3,593
A jesi li siguran da dobro snimis te nove postavke u BIOS-u prije nego sto izadjes?
Staro 15.02.2007., 00:48   #3
Mortal
Rambus 3xtr1m
Mortal's Avatar
Postovi: 2,694
A koliko rama ti ima laptop?
Koji je model?
Ryzen 7 2700X
Sonic Tower rev.1 (polirani) + 12cm Chieftec
2x 8gb Crucial
B450 Aurus Elite
Segate 500GB Server edition
Silwerstone Strider 560W +12@11.97-11.94V
GTX 1060
Samsung p2770, Hanns G 22' landscape
Samsung pleomax& Microsoft Sidewinder
Kensington Duo Wawe Pad
1. 2xP3 933, Intel OR840 Server, PCI MX440, 4x128Mb Rambus, 80gb segate, SmartBox 400W
2. P4 2.0 wille, Intel i850, 4x128 Rambus, GF2 GTS PRO, 80gb segate, MS 480w
3. P4 1.6 willie@2.0 - Abit th7 II, 4x128Mb Rambus@ 1078mhz, 9000pro, 80gb segate, silwerstone 400w
3 x Prestigio 710, 3 x Microsoft Optical desktop v2.0
i5 530
640gb
1x4gb, 1x2gb ddr3
GT330M
16' wide - white body
Harman Kardon
MX revolution
Online with nokia E70
Battery grip
Beercan: 35-70, 28-85, 35-105, 70-210
Minolta: 28-80, 35-70, 28-100, 35-80, 28-105xi, 75-300
Sigma: 35-70, 28-135, 18-200, 70-300
Sony: 18-70, 55-200
m42: Zenit 135mm, Crestar 135mm, Helios 44m
Mortal je offline   Reply With Quote
Staro 15.02.2007., 18:26   #4
acca2211
acca2211's Avatar
Postovi: 10
model je acer 5101 i zasad imam 512rama
snimim postavke naravno : evil :
Staro 15.02.2007., 18:49   #5
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
1. Udji u BIOS
2. Stavi grafici 128MB memorije
3. Snimi postavke i izadji iz BIOS-a (restartuj lap)
4. Ponovo udji u BIOS (nemoj pustati da se digne Win nakon prethodnog izlaska iz BIOS-a)
5. Pogledaj sta pise za graficku memoriju.
Ako se opet vrati na 64 probaj flashovat BIOS.
Ako ostane na 128MB onda je nesto do Windowsa (ali mi je nekako tesko vjerovati da se takav problem desava zbog win-a). Ako je do Win-a reinstaliraj ga pa onda vidi hoce li se ponoviti.
Staro 15.02.2007., 21:17   #6
acca2211
acca2211's Avatar
Postovi: 10
Napravio sam kako si rekao, kad sam drugi put usao u BIOS
opet je bilo 64 tako da cu ga probat flashirat ili tako nesto
Staro 15.02.2007., 23:16   #7
acca2211
acca2211's Avatar
Postovi: 10
bios je flashiran, no opet ista stvar
Staro 16.02.2007., 07:50   #8
Postovi: 33,925
Pretpostavljam da je stavio automatski na 64 jer imaš samo 512Mb rama. Da ubodeš još 512 vjerojatno bi mogao staviti grafu na 128Mb. Iskreno, mislim da baš i nećeš vidjeti neku razliku između 64 i 128Mb.
Staro 16.02.2007., 11:32   #9
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
Autor coconut Pregled postova
Hmm cini mi se da bas i nije do kolicinie RAM-a. Imam ja Acer TravelMtae 2003LM i na njemu 256MB RAM-a. Od toga ide 64 za graficku (192MB ostaje). Kada stavim za graficku 128MB fino sve odradi i onih preostalih 128MB radi kao operativna memorija bez ikakvih problema. Ali za svaki slucaj posudi od nekog frenda jos 512MB ako ima cisto da budes siguran na cemu si.
I slazem se da se nece osjetiti neka bitna razlika u performansama.
Staro 16.02.2007., 20:33   #10
acca2211
acca2211's Avatar
Postovi: 10
Svakako planiram ubosti jos 512 rama na laptopu tako da cu javiti sta je bilo, pozz
Staro 20.02.2007., 19:29   #11
Templar
Postovi: 8
Pozdrav!
Imam sličan problem.
Umjesto grafičke imam ovaj čip:
Intel (R) 82845G/GL/GE/PE/GV Graphics Controller
512 rama, a maksimalno mi koristi 64 mb za grafičku.
problem je što bios na mom laptopu nema (ili je zaključana od proizvođača) opciju gdje bi mogao podesiti da koristi barem 128 Mb.
Mislim da je jedina opcija instalirati novi BIOS, gdje bi to mogao naći?
laptop je GERICOM HUMMER 2130 e XL combo (valjda je to! nisam siguran jer mi se obrisala oznaka na poleđini )
Ako tko ima koji koristan savjet bio bi zahvalan.
Templar je offline   Reply With Quote
Staro 20.02.2007., 19:49   #12
Templar
Postovi: 8
e da jos jedna stvar imao sam 256 rama (grafička je 64 mb koristila) i nadogradio na 512 i dalje koristi 64. :confused:
Staro 20.02.2007., 20:51   #13
Fera_os
Ne znam šta da napišem
Fera_os's Avatar
Postovi: 984
Što se tiče uzimanja grafičke meme od sistemske trebaš u BIOS-u namjestit da ti uzima 128, kolko vidim ti to želiš. A nabava novog BIOS-a nije baš nabava nego Flashiranje koje je gore navedeno.. To je mal više kompliciran postupak a mogao bi ti neko ovdje na forumu objasnit to al ak ti nešt krivo napraviš moš si s***at matičnu. Pozovi nekog stručnjaka za PC-ove ili ga reklamiraj ako još vrijedi reklamacija. Ne kužim kak ne moš ući u BIOS??
Nemam ništa pametno za reć!
Fera_os je offline   Reply With Quote
Staro 20.02.2007., 22:24   #14
Templar
Postovi: 8
Autor Fera_os Pregled postova
Ma mogu ući u BIOS samo što u BIOSu nemam opciju gdje bi mogao memoryu podesit. : stoopid
Vec sam razgovarao sa dva servisera, ali nisu ni oni mogli to rijesiti preko biosa jer tamo nije bilo te opcije - savjet je bio da flasham bios - ali oni se u to ne bi upuštali
reklamacija na zalost istekla.
Staro 21.02.2007., 16:25   #15
Templar
Postovi: 8
Danas sam pricao s jednim tipom koji se navodno time bavi i kaže da kada bi i flash-ao BIOS ne bi puno napravio jer navodno takva graficka ne moze vise ni dat od 64.
Staro 21.02.2007., 17:15   #16
Milentije
Adrenaline junkie
Milentije's Avatar
Postovi: 3,593
Eh sada nisam 100% siguran u ovo sto cu napisati ali...
meni se cini da tek Intel Graphic Accelerator 900 ima mogucnos stavljanja vise od 64MB memrije u sluzbu grafike.
Nisam 100% sigauran. Sacekaj da se javi neko ko ima nesto kao sto i ti.
Staro 21.02.2007., 20:26   #17
Postovi: 33,925
Potraži svoj model ovdje i skini potrebne drivere/BIOS http://download.gericom.com/NOTEBOOK/Win98-Win2k-WinXP/
